Page 3 of 24 FirstFirst 1234513 ... LastLast
Results 81 to 120 of 958
  1. #81
    Active Member Two Rings liberty603's Avatar
    Jan 12 2011
    2009 A4 Premium Plus
    Quote Originally Posted by cory_can View Post
    ummm....did I miss something :)
    ummm ... what do you mean? lol
  2. #82
    Veteran Member Four Rings Stubek's Avatar
    Feb 13 2004
    2011 A4 Avant
    Santa Clara, CA
    We have lots of interest in a group buy. I talked to Anth, I am going to call Ross-Tech. I will try to today, but I might not have time at work until after they close in which case I will do it first thing tomorrow morning from home
    2011 A4 Avant Meteor Grey/Black, Titanium Package, Prem+ Nav, B&O. Tint, LED license plate lights, LED interior lights, custom sub, lots of VAG updates, APR Stage 1
    Build thread: http://www.audizine.com/forum/showth...ead?highlight=
  3. #83
    Aug 20 2010
    toronto
    Hi David, indeed a great job.
    one question, do we need a new BCM2 module for this LED mod?
  4. #84
    Senior Member Three Rings jcs's Avatar
    Jul 22 2009
    2009 Audi A4 2.0TQPS, 2002 Infiniti Q45, 2006 Kawi ZZR600
    GTA, ON
    Quote Originally Posted by mage0608 View Post
    I'm going to say no on behalf of David. Correct me if I'm wrong though.
  5. #85
    Senior Member Four Rings rlarsen's Avatar
    Mar 20 2009
    Sweden (south)
    Quote Originally Posted by jcs View Post
    +1
    But you need an extra wire from inner LED to outer LED on both sides - and this applies for A4 Avant and A5.
    A4 Sedan should be fine as it is today.
    Rene Larsen
    A4 Avant 3.0 TDI quattro tiptronic MY2009
    VCDS 11.11.3 (HEX-USB+CAN)
  6. #86
    Senior Member Three Rings zee007's Avatar
    Jan 12 2010
    2010 Audi S5; 2010 VW Golf TDi
    from the UK to Virginia
    Fantastic work again David and crew - looking forward to trying this out on mine...
    - Zee
    His: 2010 S5 | Sprint Blue | Alcantara | Black Optic | B&O | BBS | Eibach | Stasis | B&B | H&R | K&N | PIAA | E-codes | OEM mods | Tint
    Hers: 2010 VW Golf | TDI | Black | OEM mods | Tint
    Departed: 2009 TT | S-Line | Ibis White | Black Leather | 19" RS4's | OEM mods | Tint
  7. #87
    Apr 07 2007
    B6 A4 3.0 (Wife's Ride)
    Mountain View, CA
    Couple quick questions:
    1. Is module 46 accessible in '09 AMI/non-Nav P+ Sedan to make these various changes - Rene, believe you said awhile ago there is some 'hidden menu' access in "MMI basic" (ambient lighting, TPMS menu, battery state).
    2. If so, can '09 P+ Sedan bulb tails be changed to ROW LED tails - bulb amber turns [later change to LED], no side markers.
    Am I 'off the island' here
    Cheers
    2009 3.2L Sedan BB/Beige. VMR V710 Gunmetal 19" Rims. Exterior Chrome Trim painted Quartz Grey. LED ROW tail lights. KW V1. H&R RSB. StopTech PosiQuiet Pads, Painted Calipers. HOEN Xenon Match Fog Lamps. Fog Grilles converted to S-Line look. Stone Guards. Modified Votex Rear Diffuser. LED interior lights, cup holder lights & door pocket lights. RS4 Pedals. Remus Mufflers.
  8. #88
    Senior Member Four Rings Ryan_T's Avatar
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    Quote Originally Posted by rlarsen View Post
    +1
    An extra wire is required for A5? I thought the general structure is identical between A4 Sedan/Avant and A5.
    Ryan - flickr
  9. #89
    Senior Member Four Rings DavidB8's Avatar
    Nov 06 2009
    Oakville, ON, Canada
    Quote Originally Posted by Ryan_T View Post
    No, there is a wire that joins the two lights together. The A4 doesn't have it. Looking at the wiring, it seems a bit strange for the A5. It shows 2 reverse lights per side. Is that how it is on the US versions?
    EDIT: Interesting looking at it more. The wire that joins them is ROW only, not US. The ROW light shows 3 light circuits on the inner light but only 2 on the US.
    Mods:Votex spoiler, tint, Clear Bra, S4 replicas, Audi winter and trunk mat,mud flaps, Dipstick, oil pan heater, KW V2's, AWE Dual Exhaust, Votex valance, AWE FMIC, Eurocode IC pipe, PIAA fog lights,Vag Com, APR Stage 2, E-Codes, trunk mount emergency triangle, LED plate bulbs, Audi compressor and tire repair kit, RS4 Pedal set, Power Folding Mirrors, S4 steering wheel, heated rear seats, ski pass through.......
    www.audienthusiasts.com
  10. #90
    Veteran Member Four Rings DeMOROlized's Avatar
    Sep 18 2006
    2010 A5 2.0T
    GTA Canada
    Quote Originally Posted by DavidB8 View Post
    The entire transparent part of the tail light, both on the outside and on the trunk lid, is the reverse light.
    1st Ring: 2002 Dolphin Grey B6 A4 1.8TqMS
    2nd Ring: 2006
    Moro Blue B7 A4 2.0TqMS
    3rd Ring: 2010 Phantom Black B8 A5 2.0TqM S Line
    4th Ring: TBD
  11. #91
    Dec 01 2009
    Greenville, SC
    Well there is lots going on here people may not realize. By getting into that module it now makes it possible to not only reprogram NA to ROW lights but it also allows the ability to program a module from Bulb to LED.
    You are absolutely right, and THAT (the RoW) coding is no minor change, having spent the better part of several hundred hours and about 4 months myself, working with Kufatec into the J393 (BCM2) to get eCode LEDs to function correctly, (all lights working as they do in RoW without bulb faults) on my NA S5. And I know of only three such cars so equipped as a result. I'm sure you've found the multiple level of coding (NOT so easily reached in VCDS alone) to have been a fun challenge. Great work and looking forward to your continuing documentation...
    - Roger
    __________________________________________________ _________________________________
    Quartz/Tuscan/Carbon/Blk Optik - AWE Exhaust/Pedals - Hartmann HS5-209 20s - STāSIS Challenge Susp. - eCodes F & R
  12. #92
    Dec 01 2009
    Greenville, SC
    Quote Originally Posted by Greg Nelson View Post
    Cheers
    This IS possible - as myself and two others have eCode tails (LED w/amber bulb turns) working correctly (all NA B8 coupes). But, as David notes, this is NO mean feat, and simple VCDS coding is NOT possible - the J393 BCM2 where this coding takes place is multilayered, and NOT all accessible via VCDS...
    - Roger
  13. #93
    Dec 01 2009
    Greenville, SC
    Yup, the B8 coupe for NA uses BOTH clears as reverse lights, unlike the eCode which uses the outboard one as a turn signal. btw, the eCode version has an amber reflector (which the NA DOT version does not) there for the signals, which use a clear bulb - even on the LED versions. The wire you mention, is the cross wire to the inboards for the brake light. These lights use PWM to adjust brightness between the tail and brake. Check this thread for more : http://www.a5oc.com/forums/146741-post366.html
    - Roger
  14. #94
    Mar 20 2009
    Sweden (south)
    Cheers
    I can remember saying that there was a "hidden menu" in MMI basic (red/black screen), but I remember posting the codes to enable the MMI menu items on MMI basic - http://www.audizine.com/forum/showth...=1#post5961276
    Rene Larsen
  15. #95
    Jul 22 2009
    GTA, ON
    Found the channel that controls the license plate lights tonight. You can make them flash with your indicator.. Not sure that is worth while. But what you may like is you can control the brightness. I put in LED lights and can control the brightness of them while still keeping the cleaner colour.
    Sweet!
  16. #96
    Veteran Member Three Rings scottyuk's Avatar
    Sep 20 2006
    Honda CBR1100XX
    Essex, UK
    Now that really is nice !
    I've avoided LED plate lights as I find them too bright !!
    Good effort.
  17. #97
    Feb 13 2004
    2011 A4 Avant
    Santa Clara, CA
    You are my god!
    I will now face north twice per day and only eat snow
  18. #98
    Forum Moderator Four Rings MrPerfect's Avatar
    Dec 21 2006
    '10 A4 Avant 2.0T, '12 Ford Focus
    San Jose, CA
    You mean I can finally install the LED plate lights I got months ago? :) We're all really on the edge of our seat with good-ness.
  19. #99
    Senior Member Two Rings jabicho's Avatar
    Feb 02 2010
    Muchos Bandidos, Spain
    You still haven´t mentioned the possibility of brightening tail lights as position lights , I mean for halogen cars.I think this would be great as there´s a lot of contrast between halogen and tails in position lights, not to mention when they ´re functioning a brake lights!
  20. #100
    Feb 13 2004
    2011 A4 Avant
    Santa Clara, CA
    I may have missed it, but do the rear fogs work yet?
  21. #101
    Senior Member Four Rings cory_can's Avatar
    Mar 05 2009
    (Very) Red B8 Avant, '11 Volvo XC70 T6
    Golden Horseshoe, ON, Canada
    Quote Originally Posted by Stubek View Post
    You are my god!
    You should probably avoid the yellow snow.
  22. #102
    Mar 05 2009
    Still looking for cars to scan, I haven't done any yet. A few have volunteered and should be scanned soon but need some more. Both ROW and NA led and bulb.
    Hi David, I believe 'jcs' and I are going to help you out this coming weekend (Sunday?). We both have NA '09's....his a Sedan and mine an Avant.
  23. #103
    Senior Member Three Rings Scorpio's Avatar
    Apr 15 2009
    The Island
    OMG..cant wait to be able to lower the intensity of my license plate lights
    ~bill
  24. #104
    Jan 12 2010
    Happy to help - 2010 S5 with LEDs. Let me know what you need.
    - Zee
  25. #105
    Nov 06 2009
    Quote Originally Posted by zee007 View Post
    Thanks Zee, would like to get a few A5/S5's. Just curious is your car Euro or NA? Hard to tell from your signature. In order to do a remote scan you need to install Teamview software http://www.teamviewer.com/en/download/index.aspx and just have internet access while you have VCDS running on your car. That and let me know when your ready to go. Should take about 10-15 mins tops.
    Just let me know what time you guys will be ready to go Sunday and we'll get your scans added.
    There has been progress on getting the channels mapped but scans are needed to determine where the differences are between the bulb and LED lights so we know what has to be changed for a conversion.
  26. #106
    Veteran Member Four Rings todd1010's Avatar
    Jun 17 2004
    Jacksonville, Florida
    Just started reading this thread and I must say great work but I'm sure there's a way to go to get this finished.
    I have a 2009 NA Audi S5 with NON-LED tail lamps. If you need me to help out I can when ever you want. Just let me know and I can be ready any time. I'll go ahead an install/setup the remote desktop.
    2009 S5 Ibis White-Magma Red Interior
    Loaded with stuff
  27. #107
    Nov 06 2009
    Quote Originally Posted by todd1010 View Post
    Thanks Todd, a scan would be appreciated. The A5/S5 are different in few regards so it would be nice to get a few scans from some different configurations. I'm free most nights and the weekend. So when ever your ready and around we can do a scan.
  28. #108
    Dec 18 2009
    2009 Subaru Forester 2.5XT Limited
    Atlanta, GA
    David ** I'm happy to donate the scan of my 2010 Sedan LED if you need it.
    2010 Audi A4 2.0TQ 6MT - Meteor Gray Pearl, P+, Sport, B&O
    APR Stage II+, APR DP, EC IC Pipe, H&R OE Sport Springs, Spacers, LEDs
    Previous Cars █
    2008 Audi TT 2.0T S-Line DSG
    2005 VW Jetta GLI 2.0T 6MT
  29. #109
    Jun 17 2004
    I am free at those times also including tonight. If you'd like to email whenever your ready just hit me up.
    todd1010 AT gmail DOT com
    Loaded with stuff
  30. #110
    Nov 06 2009
    Thanks for the help Todd, the software worked great and scan went flawless. Now if we can get a few more people to brave up :)
  31. #111
    Jun 17 2004
    No problem. I'll get another guy on her with a 2010 with LED tails, and we'll do the same thing sometime within the next few days.
    Loaded with stuff
  32. #112
    Sep 20 2006
    Honda CBR1100XX
    Essex, UK
    David - how do you do so much on your car without flattening the battery????
    I spent a few hours on mine with VCDS recently (ignition on) and the car self protected when the level got down to 20%. I'm low mileage so it'll take a few days to get it back up again.
    Does your car live on a trickle charger? ;)
    Keep up the good work.
  33. #113
    Dec 01 2009
    Greenville, SC
    David - man, I'd love to have you scan my 2009 S5 NA car with fully functioning eCode LEDs at the rear - (all coded by Kufatec) but, I just happen to be in the UK on business until about 1st week of April. Plus they want to make one last tweak (by remote to Germany) to fix a hyperblink in the dash and a "data set implausible" message in VCDS ...at least one of the other two successful cars coded this way - and one of them is PERFECT - may be able to volunteer.
    - Roger
  34. #114
    Dec 30 2010
    Audi A4 (B8), Suzuki Jimny 4x4 Convertible
    Germany
    Quote Originally Posted by rnlabas View Post
    @rnlabas
    That would be a great help. Please do a full scan before and after (no need for a security access code). Although I'm sure the only changes are done in the adaption channels, I'd love to get this confirmed.
    @David
    Remember my mail after I coded my module to NA-led? Same eror message in VAGcom, so we already have the same state of knowledge like Kufatec :-))
    Maybe they should arrange a closeout sale for their dongles - who's going to buy them when we release everything? They must hate us ...
    retrofitted (OEM+): tow bar, bluetooth&rSAP kit, pdc+, color dis, light&rain sensor, auto dimming mirror, highbeam assist, auto folding&dimming mirrors, charisma switch, alarm, electrical front seats (memory driver side), light package+ambient lighting+illuminated door pockets, heated rear seats, xenon incl. auto leveling+headlamp wash system, side assist, illuminated exterior door handles front+rear, LED taillights, auxiliary heater, powered rear window blinds ...
    next: we'll see
  35. #115
    Mar 20 2009
    Sweden (south)
    Quote Originally Posted by TR464 View Post
    @rnlabas
    @David
    When Kufatec should find the correct coding, they used many "new" units (46), and they more less destroyed them all - but I think by now they have earned all the money back times at least 50.
    Rene Larsen
  36. #116
    Dec 30 2010
    Germany
    So we're even better since we didn't destroy anything?
    next: we'll see
  37. #117
    Mar 20 2009
    Sweden (south)
    You can say that
    You also have an advantage, because you'll get codings from both LED and non-LED cars - which you can use in the search for the correct coding. Kufatec found the coding before the S4 was available for sale (which was the first B8 with LED tails).
    Rene Larsen
  38. #118
    Sep 16 2006
    B8 S5
    David, my NA 09 S5 is the one with the 100% working ROW lights(no errors and no hyperblink) that rnlabas mentioned above. Kufatec did a remote session and got this working for me. Let me know if you'd like to scan my car, I have a VCDS and don't mind helping out at all.
    This is how they function:
    http://www.audizine.com/forum/showth...=1#post6216722
    ExhaustNote
    __
    13 Audi RS5 Ordered
    09 Audi S5 FOR SALE!!
    Daytona Grey Pearl
    HRE|KW|Alcon|Stasis|AWE |JHM
    Build Thread
    activfilms.tv
  39. #119
    Dec 01 2009
    Greenville, SC
    Quote Originally Posted by ExhaustNote View Post
    Thanks - I was hoping you'd spot this. NOW we can get the security we want/need...
    - Roger
  40. #120
    Feb 01 2009
    Did you get any Avant scans?
