Results 1 to 40 of 52
    Veteran Member Three Rings Trev's Avatar
    Nov 25 2007
    b6 a4tq, 95 Eagle Talon (Rip)
    British Columbia, Canada
    W/M Injection: 2 - Throttle Body: 0
    First and original TB lasted 1-1.5 years with the meth injection. Second TB (used unknown mileage) lasted 6months.
    Some how the O-ring that seals the the butterfly shaft in the TB is breaking down thus allowing fluid to enter into the electronics causing complete failure. Only been using distilled water/VP meth and standard blue -40* washer fluid http://www.recochem.com/en/index.php...eld_washer_40c
    Luckily i can just pull her apart, dry up all the moisture and slap her back on. But as soon as i start spraying moisture gets in and screws it up again.
    Any one else running W/M having this problem? How long have you been running W/M with or without any failures?
    ~~~On a side note, please PM me if anyone has a spare TB
    Some Go, No show
    02 Qtip, Apr II+ 93Oct, tt-225 injectors, Ecode fmic, W/M Injection, Magnaflow 16601,TT225 Down Pipe, VMR test pipe, APR TIP, Forge 007, Vag-Com, Podi V2, RS4 LSB, ECS Snub, USP front lower, S4 Front Brakes, Slotted/Dimpled Rotors f/r, SS Lines f/r, 19x8.5 & 19x9.5 RPM 505's, RNS-E
    Wish List
    Custom fab intake heat shield, Custom fab system in trunk, Adjustable Coilovers, S4 blades, DTH side skirts
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    I spray after the TB.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Veteran Member Three Rings cdn20valve's Avatar
    Oct 09 2007
    B6 A4 Avant
    North Toronto
    after spraying about 2.5 years by brothers tb failed on his gti. On my A4, i have had w/m for 2 years, no issue yet.
    Veteran Member Four Rings AudiHere04's Avatar
    Nov 21 2005
    East Coast
    Items for Sale
    are you spraying before or after TB?
    I have a spare OEM TB...will PM you.
    Buy My Parts!
    K03 w/ lines & OEM manifold - $300
    OEM FlyWheel - Best Offer
    Precision 6262 Turbo - $1300
    Nov 25 2007
    Quote Originally Posted by kwimberly View Post
    I might go that route, but i like having the added cooling effect with the nozzle further away.
    Spraying 1 regular sized nozzle about 18" from TB.
    Start psi=8 full=12
    Some Go, No show
    Wish List
    Aug 26 2005
    You don't mention if you replaced the O ring or not, but I assume not. Is there some reason for not replacing the O ring?
    Vorsprung durch Technik
    Nov 25 2007
    Its not easily accessible. I had to literally rip apart my fist one to get to the O-ring. The shaft is pressed in and there are some special (ring clips?) that hold other parts and the bearings in.
    http://www.audizine.com/forum/showth...light=Throttle
    AudiHere04 has a spare one that he's going to see me. Ill try and carefully dissemble this one to see if i can replace the O-ring. But last time i had to do quite a bit of damage to get it all apart....
    Some Go, No show
    Wish List
    Aug 26 2005
    Gotchya.
    Aug 26 2005
    To add a second O ring to seal the throttle shaft reliably, ( provided you can disassemble and reassemble the throttle body without damaging the physical and functional properties,) Is to notch the throttle plate at the operating end of the shaft, with the notch slightly shorter than the thickness of an O ring plus a precision ground washer with the same OD with the ID just enough larger to fit on the throttle shaft without any slop, to fit into the notch of the throttle plate. On the free end of the throttle shaft, a ball bearing and a spring are added under the press in plug to press the shaft toward the operating end to compress the O ring for the seal between the throttle shaft and the TB bore.
    To remove the throttle plate screws, the end of the screws needs to have the punch staking ground away first, so that the screws will back out without any interference in the threads from the staking. For exact realignment of the throttle plate on the shaft, a pair of small taper pins should be fitted through the plate and shaft before removing the screws. A small arbor press and support blocks or a custom support block, will allow pressing apart and back together the pressed parts.
    I will draw up a sketch of the details described above, if you are interested in making a serious effort to add the second O ring seal.
    Clearly, using post TB WM injection, preferably one nozzle at each intake port runner inlet, is an easier and a quicker fix. Since WM is best used as an anti-detonation measure, and not as an increasing charge air density method, (although this still happens regardless.) the effectiveness of moving the nozzle down stream of the TB does not reduce overall performance as a practical matter. because the WM volume injected displaces the same amount of charge air/oxygen the maximum amount of WM on a ratio basis of the fuel flow, should be limited to only enough to prevent knock onset and detonation with the most ignition advance and boost pressure combination practical for operating conditions with your setup and tuning.
    Nov 25 2007
    Absolutely!!! Wow that was good info diagnosticator
    I'm defiantly going to do this once my replacement has arrived. I have a basic understanding on how shes put together now that i ripped apart my first one.
    Some Go, No show
    Wish List
    Aug 26 2005
    PM me when you have the replacement TB in hand.
    Veteran Member Four Rings IVRINGS's Avatar
    Mar 27 2009
    05 Audi A4 1.8T K04 6-Speed, 03 Audi A4 STB 2.7TT 5-Speed
    Audi Columbus Sales
    I also have one if you need one. Let me know since I have no use for it.
    Audi Enthusiast and Audi Columbus Brand Specialist
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Just FYI - OP how much meth are u spraying? What size nozzle are u using?
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Nov 25 2007
    Using one 175ml/min nozzle
    Some Go, No show
    Wish List
    Apr 12 2009
    Methanol is a drying agent and its corrosive as well. You may be spraying too much meth in your mixture if your body is failing that soon.
    Veteran Member Four Rings BNZ TOY's Avatar
    Oct 29 2006
    1G FX35, 03 R6, B6 A4 MT6
    Vancouver
    scary.... I spray before the IC and just before the part that splits into 4 (going into the engine). I'm a bit worried now, my mixture is like 55meth/45water (maybe I'll back that up to 50/50)
    Another silver B6
    Go/Stop: K04-015 ~ Intake/TIP ~ Forge Splitter ~ Neuspeed turboback ~ B&M SS ~ H&R Sport w Bilsteins ~ S4 Sways ~ Eurocode FMIC ~ 245 Rotors/18z ~ FX300 240mm LWFW ~ Snow Meth Inj ~ EURODYNE tune
    Flair: USP Front ~ Cupra R ~ S4 Trunklip ~ Euro Roof Lip ~ VMR v710 235/19/35 ~ S4 doorblades ~ B7 rear valance ~ LED fogs ~ B7 DTM skirts ~ Euro RS4 Steering Wheel ~ S4 Recaros
    Veteran Member Four Rings Dolphin18T's Avatar
    May 17 2007
    Quote Originally Posted by BNZ TOY View Post
    You have a nozzle pre-IC? This is not a good idea. Methanol will pool in there and create a possible fire hazard and could also deteriorate your intercooler.
    -Ryan
    Maestro Tuned
    Now with slushbox-delete mod!
    May 03 2008
    Orlando
    I can't seem to stop a leak at the anti-siphon solenoid. It's located in the little space to the left of the steering fluid reservoir. I see meth dye on my coolant tank and nearby areas. Fire hazard?
    Kevin W.
    May 17 2007
    If it's mostly dried up and just the dye is left behind, you're fine. I would try to remedy the leak though.
    -Ryan
    Maestro Tuned
    May 03 2008
    Orlando
    Quote Originally Posted by Dolphin18T View Post
    I've tried re-cutting the lines and inserting them into the solenoid - re-gooped everything, too. I did notice that since I have the nozzle sticking straight up out of the TB spacer, my hood is smashing down on it a little - I can see the indentation of the nozzle in the fire retardant material underneath the hood. I should probably rotate the spacer 90 degrees.
    Kevin W.
    May 17 2007
    Flipping the adapter plate would be a good idea. Does your setup still look like this?
    I would suggest putting a service loop in that line running to the solenoid. It may be getting tugged on, creating the leak?
    -Ryan
    Maestro Tuned
    May 03 2008
    Orlando
    lol. That is my setup. Since that pic was taken I did loop the line from the solenoid to the TB. (and I have a FMIC, so that stock TB hose is gone.)
    Kevin W.
    Oct 29 2006
    Vancouver
    seriously? i was told that the dual nozzle set up would be best....argh.... I have a hole there, not sure if i want to dig in there again....sigh.
    Another silver B6
    May 17 2007
    Dual nozzle is good, but you should have one just post-IC and one post-throttle body.
    -Ryan
    Maestro Tuned
    Oct 29 2006
    Vancouver
    I see, I may have some work this weekend.
    Another silver B6
    Nov 25 2007
    Quote Originally Posted by shoppingcart111 View Post
    Been running the required mixture.
    Quote Originally Posted by Trev View Post
    Some Go, No show
    Wish List
    Mar 27 2005
    Here & There
    2nd this. I have my larger nozzle in the lower intercooler pipe just after the air leaves the fmic, then I have a smaller nozzle post throttle body. Works excellent.
    2014 VW Touareg - 4Motion - Midnight Blue
    May 17 2007
    Quote Originally Posted by EBG 18T View Post
    Eric, what size nozzles are you using?
    -Ryan
    Maestro Tuned
    Mar 27 2005
    Here & There
    175cc post tb and 225cc at the fmic. I need to upgrade to a larger size come spring. I think I will do 225cc post tb and 325cc down at the fmic.
    Nov 21 2005
    East Coast
    Items for Sale
    you got pm
    Buy My Parts!
    Oct 09 2007
    B6 A4 Avant
    North Toronto
    3rd tb on my brothers gti. spraying 6" before tb.
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    Pasadena, CA
    Items for Sale
    Seems like TB failure isn't so much a possibility but an eventuality when using WM on our cars. Or even a fire hazard (fix that ish Ben, scary stuff man).
    Realistically, what can be done to decrease likelihood of TB failure... just run water / non corrosive injection, anything else?
    Thomas
    | Chronicles | Threads | IG
    // A U B A
    Sep 12 2008
    South Central PA
    -20*F washer fluid.
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Veteran Member Four Rings EErie B6's Avatar
    May 30 2008
    Honda HRX
    Fort Worth, TX
    has anyone tried running a reverse of this? The known TB failure issue has me wondering...
    for ease of math, lets say engine "x" needs 400cc.
    has anyone tried spraying say 25% (100cc) of this just after their FMIC to help ensure that it is 100% atomized/vaporized by the time it hits the TB... also allowing you to still have the benefits of chemical cooling
    then spraying the remaining 75% (300cc) post TB where there is no worry of TB compromise?
    Nov 25 2007
    I'm going to try and add a second O-ring to the TB shaft as per diagnosticator's suggestion. Just need to go pick up my new TB, been way to busy to hop across the border to pick it up.
    Some Go, No show
    Wish List
    Mar 27 2005
    Here & There
    Quote Originally Posted by EErie B6 View Post
    That was the recomendation from Scott @ USRT. He was the suggested the staggered setup.
    I am swapping in a 225ml post TB and keeping my 225ml in the lower intercooler pipe. Moving the pump pressure up to 220psi tommarow too. Then more logs and software adjustment.
    May 30 2008
    Honda HRX
    Fort Worth, TX
    very nice Eric.
    not singling anyone out... im just curious in general...
    I wonder if there is a way we could see how well it distributes to all 4 cylinders when sprayed post TB only. I would think atomization would be poor with cyls 2 & 3 getting a bath. I know that nitrous from a single fogger nozzle is difficult to get an even distribution on certain long runner EFI intakes... you can even end up with fuel pooling in the intake on "wet" kits. Im wondering how water/meth travels.
    Sep 12 2008
    South Central PA
    thats why I chose to spray mine before the TB
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    May 30 2008
    Honda HRX
    Fort Worth, TX
    what if we assume wrong? what if it atomizes and distributes well... then killing TBs would not be necessary. I would like to know this.
    Eric,
    when choosing nozzle sizes, how do you determine if you stand to benefit from going larger? what do you look for to tell you "thats enough"? What happens when you spray too much?
    Dec 01 2007
    Pasadena, CA
    Items for Sale
    < listening >
    I've danced around the idea of W/M for some time now and was initially against it due to emissions concerns here in CA. But now that I see how easy it is to swap n and out, that's no longer a concern. But if the TB issues can be overcome... this becomes a no brainer mod ASAP.
    Thomas
    // A U B A
