Page 3 of 3 FirstFirst 123
Results 81 to 95 of 95
  1. #81
    Jul 03 2011
    IL
    I have the problem and I'm stock. It seems to be getting worse as it gets colder out.
    x2. RPM fluctuations used to be steady once the car warmed up & while in higher gears, but now the situation as worsened - does it all the time, even after a 30 minute drive. Also have an annoying whine, and there is definitely a significant lack of power.
  2. #82
    Active Member Two Rings redcon1's Avatar
    Oct 22 2009
    '99.5 GTI VR6
    South Central PA
    Hoping that AOA is working up a warranty extension on this problem... seems pretty widespread!!
    Dave
    2008 A4 Avant S-line/TI
    1999.5 GTI VR6
  3. #83
    Jan 24 2012
    Connecticut
    Quote Originally Posted by redcon1 View Post
    I am currently working on fixing the same issue. I purchased my 2006 A4 with 2.0T and tiptronic 30 days ago and I have the same rpm fluctuation issue at low speeds. They have already replaced some turbo valves and hoses thinking it was an internal boost leak but that didnt fix it. Seems like a lot of people have this issue and replacing the torque converter seemed to fix it. My car is at the dealer now so I am waiting to hear back from them. Luckily the car came with a 60 day warranty.
  4. #84
    Active Member Four Rings Charles.waite's Avatar
    Jun 27 2011
    2004 A4 1.8TQ 6MT USP • 2006 A4 Avant 2.0T tip
    Quote Originally Posted by ridin View Post
    Is the whine more of a whistle? Could mean your PCV is blown, which could somewhat explain the lack of power.
    -CP
    2004 A4 1.8TQ 6MT USP APR Stage 1 - Achtuning Snub - FSI Coils - BKR7EIX-11 (.04" gap) - 710N
    Maintenance: 034 Silicon Breather - US Plastics Check Valves - Rev. D SJP - Rev. F PRV - Injector Seats - Coolant Flange
    Issues: All control arms are shot - Shitty, poorly worn YK520s - Sloppy TREs - Godawful stock brakes
    2006 A4 2.0TQ Avant Tiptronic stocker - Failing TC Mod
  5. #85
    New Member One Ring
    Jan 27 2012
    New York
    I would take if back to the dealer
  6. #86
    Active Member Two Rings Infamouz627's Avatar
    Mar 26 2011
    Anyone on AZ have a clue as to how to get some type of a class action/petition going so AOA is aware of this widespread occurance and hopefully can dish out a recall or something??
    I've owned my 06 B7 for about a year and a half now and have noticed this surging a couple of months back. Today for some reason, it became much more noticeable. It's cold in NYC today but we've had colder days and it wasn't as noticeable. I also suspect the TC to be the culprit for the hard kicks when up or down shifting and the "shuddering" before a complete stop that so many have also complained about.
    06 A4 2.0T Q Tip
    APR Stage I, Koni Eibach Pro FSD, 18x7.5 HD MSR, R8 Style Bi-xenon, DDM Tuning 6000K HID Head and Fogs, Apikol Snub, Podi Electronic Boost Gauge, Upgraded Piston DV, RS4 Rear Sway, Dice Electronics iPod Kit
  7. #87
    Jul 03 2011
    IL
    It is definitely a whine. Kind of like a DC motor whine and follows the engine RPM even in neutral. Would a blown PCV be a whine or a whistle (or both)?
  8. #88
    Active Member Two Rings rune's Avatar
    Nov 13 2010
    A4 2.0 TFSI Q,VW Golf
    Norway
    So, you still have your problem. Can you make a video and share it with us ? Maybe we can hear the sound ? could be easier to try to help. Would be interesting to see your tachometer when you have the rpm jumps/variation.
  9. #89
    Jun 27 2011
    To those of you who've been following this issue, I wanted to share a little update:
    Last Saturday I replaced my Thermostat as it was was opening way too early (around 45-50*C rather than 80*C that its supposed to). It was causing really long warmup times and it would drop as low as 1/4 frequently while driving around. Anyway after I replaced my T-Stat, the car warms up great and is pinned at 1/2 temp while driving after initial warmup. Since my temps are finally being regulated correctly I've noticed a funny thing: My Trans has almost completely stopped the TC lockup/slip issue. It was starting to get REALLY bad too. With the new T-Stat I can BARELY notice it, mostly just when the engine is cold, but once it warms up you really can't feel it slipping at all.
    My guess is that the Trans wasn't warming up properly since the coolant cycling through it was too cold and not allowing the trans fluid to get up to temp. Essentially causing the transmission to act like it was underfilled since the ATF was never up to temp. I still get harsh shifting, but even that has smoothed out somewhat.
    I thought I would pass this along as its kind of shocking the difference it makes to have a trans finally operating at the correct temp. I never anticipated looking into the Transmission temps but clearly thats a large factor in the behavior of the transmission.
    -CP
  10. #90
    Nov 13 2010
    Norway
    when i replaced my TC i was using the same thermostat. Thermostat was not changed.
    Interesting to hear your theory.
  11. #91
    New Member One Ring
    Apr 16 2012
    San Antonio/TX
    I just bought my first Audi A4 60K 2 weeks ago I'm in the same boat as you were.
    Quote Originally Posted by wildcat333 View Post
    UPDATE:
    I picked up my car today. The newly installed torque converter did the trick! They installed it, did a 60 mile road test, checked the computer, and everything was good. I drove it 1.5 hours home tonight with all sorts of driving (city driving, highway, and sporty acceleration) and it is driving perfectly. The RPM's no longer fluctuate where it used to (always when shifting from 4th to 5th around 40 mph) in drive.
    It had been in the shop for almost two weeks, which sucked. BUT it made me truly appreciate the car again. It is so much better than the Q5 loaner in my opinion.
    Rune, and any others with similar issues: I hope this thread helped. Feel free to message me or reply to this thread for any questions. I wish you the best of luck with your repairs.
    NEW TORQUE CONVERTER FTW!!! CPO FTW!!!
    Now time for the mods listed in my signature!!! WINNING!!!
    My car is doing exactly what you have described. Ill be telling them about this thread so can go straight to the problem rather than tinker with everything else it 'could' be. I bought the extended warranty but I hope they'll take care of the costs since I've only had the car 2weeks! we'll see what happens
    Thank you for posting your problems!
    Is your car still running like a top?
  12. #92
    Active Member Four Rings wildcat333's Avatar
    Feb 25 2011
    2009 Suzuki GS500F
    Seacoast NH
    Quote Originally Posted by robdalli View Post
    Ya man. Car is running great currently ( knock on wood)!!!
    Good luck. Post up your results here.
    Sent from my iPhone using Tapatalk.
    2008 Audi A4 2.0T | S-Line | Quattro | Automatic-Tiptronic | GIAC 93 | 35% Tint | KW V1 Coilovers | Evolution Thor Skid Plate | 6000K Bi-Xenons (DDM) | Clear-Corner Mod | Clear Sidemarkers | Hoen Endurance Fogs | LED DRL's + 6OHM/50W Resistors (Krauto Parts c/o Emil) | 6000K LED City Lights + 25OHM/25W Resistors (V-LEDS)
    *Pics of my car/ projects/ installs*
  13. #93
    Active Member Three Rings Ed Gein's Avatar
    Sep 21 2011
    is nonexistant
    Location, Location!
    mine does it a tiny bit when its cold and its cold out
    2008 Ocean Blue A4, Turbo, AWD
    REVO stage 2|2.5" test pipe|B8 DV|K&N drop in|NewSouth boost gauge
  14. #94
    Nov 08 2009
    Ottawa, Ontario
    FYI there is a TSB for this service. It should be a recall in my oppinion. my car is out of warranty and I cant spend 4K to fix it.
    Technical Service Bulletin Transaction No.: 0
    32 Shudder or RPM fluctuations while at cruising speed Release date: Feb 3, 2012
    Condition
    Customer may report shudder or RPM fluctuation while at cruising speed in 4th, 5th, or 6th gear.
    Technical Background
    Torque convertor clutches may have excess slippage while cruising.
    Production Solution
    Not applicable.
    Service
    1.
    Check and verify that the software is at the highest level using TSB 2028053, 37 TCM software update for downshift concerns or 2028279, 37 Shift concerns when slowing vehicle. Also, check that the fluid level and condition is clean, full, and matches the required color per the applicable TSB.
    Tip: If needed, update the software of the transmission and change the fluid before proceeding with this TSB.
    2.
    Test drive the vehicle to verify the concern is present.
    If the concern can be duplicated, verify there are no fault codes stored for misfires and watch the Measure Value Blocks in the ECM to verify no misfires are seen when the condition is present.
    3.
    Check MVB 7 from the TCM. Verify Field 3 is reading control and record the slip count from Field 4 while the concern is present. The slippage of the TCC should not exceed 120 RPM in MVB 7 field 4 while the convertor is in control mode. The RPM surge should coincide with TCC slippage. If this reads higher than 120 RPM, the torque convertor should be replaced.
    Tip: The TCC slippage will vary when in open TCC mode and should read 0 when in closed TCC mode, this is normal. Replace the convertor for high slippage when the TCC is in control mode (above 120 RPM) or for any slippage when in closed mode (MVB 7 field 4).
    Tip: It is not necessary to receive a Repair Authorization to perform this TSB.
  15. #95
    Mar 26 2011
    hmmm...very interesting. Where did you find this TSB FuriouS? Maybe now that Audi is aware of the issue (though I'm sure they've received many complaints in the past) it will transition into an extended warranty/recall?? Or not....since it's such an expensive and tedious part to get to and replace respectively...not to mention it's hard to duplicate after the engine is warmed up (that's the case for me at least).
    06 A4 2.0T Q Tip
