Results 1 to 15 of 15
    Senior Member Three Rings Audi4.2's Avatar
    Jan 29 2011
    06CLS55AMG
    Edmonton%2C%20AB
    6 CD Changer stuck?????
    just went outside and took all the disk out of my 6 cd chager and put 3 newly burned ones in, the first one was a 800 mb disk and the other 2 700 the usual ones. never used 800s before so i put it in and turn the radio on cdc and it says no disk so im like WTF?? go to the back and press the button and the thing doesn't come out??? Turned the car on tried again, put the radio on fm tried again thing doesn't come out. I tried figuring it out for 10 min holding the button down and so on, when i press the button nothing happens except when i look in the side a little red light inside the changer goes on when button is pressed but no sound nothing??
    how can i get it out??
    Jan 29 2011
    06CLS55AMG
    Edmonton%2C%20AB
    nobody has an idea???
    Veteran Member Three Rings Hambone101's Avatar
    Apr 21 2009
    1967 Mercury Cougar
    Clearwater, FL
    Sorry bud, never had this problem with my four.deuce, hopefully someone can chime in and help you out. TTT
    redneck truck - Everybody quieted down when the guy up in the back of the theater asked his date for a Come flavored slurpee.
    Veteran Member Four Rings EinSchnellAudi's Avatar
    Oct 24 2009
    2011 X3
    CT / RI
    Which radio are you using? Symph I or II? What format did u use on the CDs?
    Jan 29 2011
    06CLS55AMG
    Edmonton%2C%20AB
    Symphony 1, using wma on the disks which works fine but i think the 800 mb cd messed something up? some kind of pin i can press to get the cd holder out??
    Feb 07 2008
    04 silverado V8, 06 Touareg V8, 03 S6 V8, 03 RS6 V8TT
    The boonies, near Seattle
    You'll probably have to buy a new one. Check ecs.
    -dre
    Apr 21 2009
    1967 Mercury Cougar
    Clearwater, FL
    Josh, symph I had the external cd changer option, symph II had an in dash cd changer. I believe he's talking about not being able to get the cartridge our of the changer.
    Oct 24 2009
    2011 X3
    CT / RI
    So your talking about the trunk mounted 6 disk cassette?
    Current '14 Ibis White B8 A4 6MT | Previous '03 B6 3.0 6MT | '00 C5 4.2
    Apr 21 2009
    1967 Mercury Cougar
    Clearwater, FL
    That's what I got out of it, seeing as he said he has a symph I. I personally have never ran into this problem, but maybe the previous owner has, seeing as I have a mercedes cd changer cassette in my car, lol.
    Oct 24 2009
    2011 X3
    CT / RI
    ^ thats what I got from it too, but cant hurt to ask to be sure. Hell if he needs a new CD changer I have the whole housing minus the cassette, but that can be had for ~15 on ebay
    Jan 29 2011
    06CLS55AMG
    Edmonton%2C%20AB
    Quote Originally Posted by Hambone101 View Post
    thats exactly what i mean lol sorry
    so its stuck for some reason idk why it is messed up, 2 min earlier it worked fine switched the discs out put back in and it wont come out anymore.
    Veteran Member Four Rings Silverstreak98's Avatar
    Dec 11 2006
    Minnesota
    I believe I've fixed an issue similar to this before on an A6.
    Are you getting an error on your radio when you try to play the CDs?
    ~Brian
    1998.5 A4 2.8QT
    Jan 29 2011
    06CLS55AMG
    Edmonton%2C%20AB
    well it worked fine before all 6 discs, i took them all out and put 3 new ones in one being an 800 mb cd which i never used before. Put it back in the changer pressed cdc on the radio and it tells me "No CD" but not error or anything like that went back and it doesn't come out anymore
    Dec 11 2006
    Minnesota
    Alright....well you might find this tech article helpful, it tells you have to manually eject the CD changer cartridge. Hopefully it will eject manually, otherwise you have to remove the entire changer from the car which will take you a little bit longer (what I had to do to get the cartridge out). In my case one of the CD's had bent just enough to jam the mechanism.
    CD Changer Manual Eject
    ~Brian
    1998.5 A4 2.8QT
    Jan 29 2011
    06CLS55AMG
    Edmonton%2C%20AB
    fixed it, took the whole thing out and put a pin all the way in there and it flopped out. I still dont know why it got stuck but works fine now. Thanks guys appreciate it
