Senior Member
Four Rings
S4 gauge cluster now code P1650?????
So I switched my a4 cluster to a S4 cluster and now I have codes for P1650...how would I go about clearing/fixing this???
The CEL doesnt work I noticed and the mpg's are off by quite a bit idk if that helps at all.
Senior Member
Four Rings
Unitronic stage 2, 3 inch turboback, Stasis SS coils...
Senior Member
Four Rings
Thats for an S4 how about an A4?
Four Rings
Did you recode the new cluster? I think you have to match the cluster to your ECU, not to sure though.
Senior Member
Four Rings
you do have to recode it
Senior Member
Four Rings
Tried to at my buddies but he has a hacked version of vagcom and couldnt code it right I dont think.
Senior Member
Three Rings
I did it with a hacked version before, only problem is I can't figure out why it reads 5.0mpg all the time. Is that an adaptation thing I need to run?
2001 A4 1.8T Quattro - 3 Pedals-Short Shifter-GIAC-3" Turbo Back-VMAXX-710N-Neuspeed Sway Bars-Phat Box<3
Badass enough to get pulled over on suspicion of being a Gangster
Senior Member
Four Rings
mine doesnt really go higher then 150mpg i dont think as well.
Four Rings
it works on a hacked version as long as they have the full version.
search around for that code on here, i had it in the 01 car but not the 99.5 car. ewok has some very good replies to threads with that code, a lot of them he talks about changing variables in a few blocks.. i did just as he did and the code went away and everything was back to normal.
Four Rings
no you can change the variables in all of that.. if you search here for Ewok-Fetus i think was his name, Ewok something.. he has a LOT of great replies to ppl from 2-4 years back with variables to use and it got mine working again.
Four Rings
reinstall your old cluster, and go to every channel and check what is missing, write down and reinstall the other one check the same channels
Senior Member
Four Rings
old cluster was sold about 2 months ago. thanks, bobby. i will have to lokk that up.
Senior Member
Four Rings
So this problem is fixed.
Had Jesse at Banchwerks recode it. Took maybe 10min and now CEL and MPG are accurate.
Forum Moderator
Four Rings
Nice! How is this done? My 00' S4 cluster doesn't work right in my 01. Any details? I'd def like to get my MPG numbers back along with the CEL that prevents me from passing inspection (doesn't come on when key is 'ON'
Thanks
BetaAlphaTau Member #12 01' A4 1.8TQMS 5spd swapped GT2871R|CTAPP MAFless|034 EM|Godspeed FMIC|APR 2.5"|EVO MS DV|CM FX400-LWFW
My 5-Speed Swap DIY
- B6 USP
Senior Member
Three Rings
Yeah I'd like to know what I need to change it to, I guess I could plug in my old cluster and write everything down but that is a pain in the ass. I miss my mpg, all my cars have always had digital fuel range and I was accustomed to it. I don't have a cel though.
Senior Member
Four Rings
very interested in how you recode it also
99 A4 1.8TQM: APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
00 B5 S4 Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
Forum Moderator
Four Rings
My 5-Speed Swap DIY
- B6 USP
Senior Member
Four Rings
Not sure exactly how its done as I had someone with legit registered vagcom do it but its along the lines of the first link above. I think the MPG may be a little off still but the all instrument lights come on now.
Forum Moderator
Four Rings
I followed the MPG stuff in there, just waiting tomorrow to see if it will change now.
I also did this: For block 125, you should read 1 0 1 0...
Measuring block 125 - Powertrain data-bus participants (Corresponds to Adaptation Ch 60)
Field 1 - Engine - 1
Field 2 - Transmission - 0
Field 3 - ABS - 1
Field 4 - ADR - 0
Now for measuring block 125, you need to go to adaptation ch 60 to change these... Really, here in America, you should only have Engine and possibly ABS... So the value you need to enter here in Adaptation Ch 60, is 00005. You may need to add 1024 to that value, for an entry of 01029. That is what it is supposed to be but my car didn't take it. Either way, what you are doing is adding that the engine and abs send information to the cluster...
and now I have my CEL back!! It comes on when I turn the key on, and I am currently CEL-free with engine on.
My 5-Speed Swap DIY
- B6 USP
Senior Member
Four Rings
good stuff. thanks Chris.
not real sure if what biketsai posted above would help, but i do know for a fact P1650 is a bogus code for a-box car's coverted to m-box. this has been verified by m-box owners who have installed a-box clusters and received the same code-** anyways, if you just want to code this out, please follow this link:
http://nefariousmotorsports.com/foru...pic,773.0.html
Forum Moderator
Four Rings
I am still getting that code for the powertrain data missing, etc....
Where can I get this program that is shown in that link?
My 5-Speed Swap DIY
- B6 USP
the program is tuner pro and you need the mtx electronics VAGME7 checksum plugin.
personally, if you just want to get it done, download the nefmoto flash tool and rip your rom.
send me the rom i'll code it out for you and send it back. then you should be good to go...
my s4 gas read in 5.0mg.its normal
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
