Results 1 to 8 of 8
    Senior Member Three Rings eurotecknik's Avatar
    Feb 23 2008
    06 A4
    Chicago Бъл
    Items for Sale
    Throttle Body calibration
    First I'd like to point out that I've searched and know how to do the procedure.
    The problem is that I thought I had a bad throttle body and bought a new unit.
    After that the problem was still the same. In fact when the key is turned on "ON" position, there is NO noise coming from the throttle body indicating that it is calibrating itself.
    Could the problem be in any way connected with the engine wiring harness? How do I test it? Can anyone explain the steps for me to test if I have proper voltage going to the throttle body.
    I read about the ECU being the issue and wish it was the issue, but it is not. I have 2 working ECU's and none of them fix the problem. Basically, the car will crank but won't ever start.
    Car: '01 A4 1.8T quattro
    I do have Vag-com and here are the codes:
    VCDS Version: Release 10.6.3 (x64)
    Data version: 20101206
    Thursday,13,January,2011,12:56:56:36755
    Chassis Type: 8D - Audi A4 B5
    Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
    Address 01: Engine Labels: 058-906-018-ATW.lbl
    Part No: 4B0 906 018 M
    Component: 1.8L R4/5VT G 0003
    Coding: 16201
    Shop #: WSC 06435
    VCID: 2B481377F383
    3 Faults Found:
    17987 - Throttle Actuator (J338): Adaptation Not Started
    P1579 - 35-00 - -
    17956 - Boost Pressure Regulation Valve (N75): Open Circuit
    P1548 - 35-10 - - - Intermittent
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-00 - -
    Readiness: 0110 1101
    Obviously, I cannot perform throttle body adaptation. When I try to go into Group 060 vag-cam gives me an error message.
    Please help a brother out! Any insight into the situation?
    01 A4 1.8T Quattro Manual - SOLD
    90 Audi 90 Quattro Manual - SOLD
    03 A4 1.8T Quattro Manual - SOLD
    B5 S4 Daily Driver - SOLD
    Current:
    06 A4 Quattro Auto
    Feb 23 2008
    06 A4
    Chicago Бъл
    Items for Sale
    Also, want to point out that the battery is fully charged
    Current:
    06 A4 Quattro Auto
    Senior Member Two Rings mills's Avatar
    Feb 26 2008
    01' S4 00' S4 00' Blazer
    Pa
    http://www.ross-tech.com/vag-com/cars/throttlebody.html
    Have to fig. out how to clear that n75 before you can do anything with the tb
    01' S4 Stg III
    Feb 23 2008
    06 A4
    Chicago Бъл
    Items for Sale
    I guess my throttle body was asleep! It took a couple of ECU swaps and disconnecting the battery and playing with Vag-com for it to wake up. Now, the are absolutely no codes.
    My car still won't start!
    Current:
    06 A4 Quattro Auto
    Jan 27 2011
    SEPA
    Try 098
    Any time the computer is unplugged or the battery disconnected, the TB needs to be calibrated. Also cleaning the TB helps...
    Feb 23 2008
    06 A4
    Chicago Бъл
    Items for Sale
    Quote Originally Posted by sxwnsx View Post
    Try 098
    What the....^^^? That was a useless post because you obviously didn't read. Thanks anyway :)
    Current:
    06 A4 Quattro Auto
    Established Member Two Rings SR-71's Avatar
    Jul 20 2010
    Burnaby, BC
    Quote Originally Posted by eurotecknik View Post
    What he meant to say is try going to 098 instead of 060...some DBW cars will give an error if you try to go to 060 in basic settings.
    Бъл&Бъл&Бъл&Бъл&Бъл&Бъл&Бъл&Бъл&
    Jan 27 2011
    SEPA
    Your welcome :)
