Results 1 to 2 of 2
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    Cars being worked on
    Fort Collins, CO
    B5S4 Front brake install for A4B6 1.8T
    This is a short write-up on how to install this kit....
    1. Jack up the car in the front and take off the front wheels
    2. Unbolt the 2 big bolts holding on the stock caliper. You might
    need to use some PB lube or wd-40 to loosen the bolts from
    from their frozen position.
    3. Take the caliper off the rotor and place the rotor aside.
    4. Make sure you have something to rest the caliper on so you
    don't put stress on the lines.
    5. unscrew the lines that go to the caliper, and the sensor plug.
    Have a cup or small bucket by you when doing this, so you can
    drain the brake fluid in it.
    6. After the fluid is drained, unscrew the rubber lines, and screw
    in the stainless steel lines if you're using them.
    7. Next, screw the lines back onto the new caliper.
    8. Grab the pads for the caliper and place them inside to fit,
    make sure you put the metal clamps back over the pads to set
    them in place....you might need to use some super glue to hold
    the pads in place or it will be a PITA to get them all on the
    rotor perfectly
    9. Grab the rotors and place them between the pads on the
    caliper...you might need to push the pistons back to get the
    rotor on.
    10. Place the rotor back on, and bolt back on the caliper.
    11. re-connect the sensor wire for the brakes
    12. Bleeding -- take the little black cap off the caliper and place
    a clear air tight hose on it
    ....get a brake bleeder pressure kit,
    for $30-40 or make your own, and fill it with the new brake
    fluid...screw the cap to your brake fluid reservior(next to
    battery
    Feb 12 2004
    Fort Collins, CO
    Seems that my bleeding section got cut short...anyways....
    Start with the passenger side rear first, then drivers rear, then drivers front, then pass front.
    Unscrew the little gold bolt on the brake line 1/2 turn to let the fluid flow easier
    Make sure someone is pressing down on the brakes with full pressure pumped on them when you do each caliper.
    ...pump ~20psi into the system, and let the fluid drain till there are no more air bubbles in the line, then tighten the bolt back up, and place the rubber cap back on the caliper....do that for each brake, and you're done.
