Page 5 of 5 FirstFirst ... 345
Results 161 to 183 of 183
  1. #161
    Sep 21 2008
    Toronto, Canada
    anyone know if these lenses can fit in halogen b5 oem headlights?
    I have a HID kit retrofitted currently, and thinking the clear lense could help with the output.
  2. #162
    Senior Member Four Rings somebody5788's Avatar
    Aug 13 2008
    Indiana
    Quote Originally Posted by kbjy11 View Post
    If you call TRS they can tell you what you need. I did this to find out which ones to order for mine.
    -Nic
    2011 Honda CBR250R - gas sipping toy
    2001.5 Audi S4 - APR 93/100 | 710n's | EvoMS intake | RS4 clutch | RS4 Grill | Plasti-Dip'd center console | Podi gauge pod | VDO boost gauge | TSX-R clear lenses
    1994 Suzuki RF900R - It needs some love but it'll get there!
    1994 Jeep Grand Cherokee - rattle canned OD green Zombie Response Vehicle
  3. #163
    Aug 13 2008
    Indiana
    Quote Originally Posted by AKS4 View Post
    Let me know how it turns out for you guys. Would rather replace the OEM fresnel lens and clean the headlight Assembly than plunk down for new assemblies.
    Yes I would, but I would also want the E-Code corners. I'm really curious if you can bolt in the Valeo projectors with a TSX-R lens into a Depo housing. That would be my ideal setup besides going to a Bi Xenon retrofit.
    -Nic
  4. #164
    Stage 2 Banner Advertiser Two Rings Sales@EPL's Avatar
    Jun 23 2011
    The whole point of swapping for TSX-R lenses is to replace the Fresnel lenses with clear ones, which all Depo housings already come with (both the US-spec and Ecode housings). If anything, I would do the projector swap though for better output and quality bulb options.
    European Performance Labs
    (203-345-6499)
    Sales@eplabs.net
    http://www.facebook.com/EPLabs
    Please feel free to contact us with any questions!!
  5. #165
    Senior Member Three Rings BlkBullitt's Avatar
    Feb 06 2009
    2011 Honda Civic EX Sedan
    Fairview Park, OH
    Quote Originally Posted by Marioh View Post
    Let me know if I can help in any way. There's so much misinformation floating around regarding lighting. It'd be great to have a clear concise document that references OEM headlights, DEPO headlights, Valeo E-Codes, and the fresnal lens, TSX-R lens, etc. After finally owning OEM fresnals, TSX-Rs, and now the DEPO H7 setup, it's easier to understand but there is just no good documentation about them all.
    My write up will cover all of the possible combos with the following items...
    Projectors:
    OEM US B5 A4 (H7)
    DEPO ECode (H7)
    OEM US B5 S4 (D2S)
    OEM Euro B5 (D2S)
    *Plus all of the above with TSX-R lenses from TRS
    Ballasts:
    OEM B5 S4
    DDM 55w Slim
    Bulbs:
    OEM Halogen H7
    OEM Xenon D2S
    eBay Xenon 4300k D2S
    DDM Xenon 4300k H7
    I do very much need another US OEM B5 S4 D2S projector assembly... projector lens, cutoff, and bulb bowl (unburnt/scorched). I had supposedly purchased a pair from a member of another Audi board and be neither of the ones he sent me were correct.
    I suppose if someone wanted to send me a set of aftermarket projectors to test as well (such as a set of Morimoto from TRS) that would be the only option I currently do not have.
    This will be an epic amount of info and hopefully will help people understand the differences and advantages/disadvantages of running different setups. I'll spill a little info I've noticed just looking at each of the projectors quickly...
    All of the projectors I list above have unique cutoff shields, the H7 units both have unique rear reflector bowls while the D2S units seem to share the same rear reflector bowl (I haven't examined both side by side in detail yet), and lastly the only differences in the lenses seem to be whether they are clear or fresnel (again I haven't examined them in detail yet).
    Drew
    1998 Audi A4 2.8QM
    ... almost facelifted
    Laser Red Sport and Cold Weather Packages
    B5 A4 / S4 Headlight and HID Thread | B5 A4 / S4 Center Console Thread
  6. #166
    Feb 06 2009
    Fairview Park, OH
    Quote Originally Posted by somebody5788 View Post
    You can. You need to understand that the DEPOs are essentially knock off OEM (Valeo) Euro headlights. So the projectors are fashioned the same as stock US B5 S4 units except they have H7 rear reflector bowls, different cutoff shields, and clear lenses. All of the components are fairly modular and with little to no work can interchange with one another.
    Drew
    1998 Audi A4 2.8QM
  7. #167
    Feb 06 2009
    Fairview Park, OH
    Yes, TSX-R lenses (2.5") will fit any B5 A4 or S4 projector without modification.
    Drew
    1998 Audi A4 2.8QM
  8. #168
    Aug 13 2008
    Indiana
    Quote Originally Posted by BlkBullitt View Post
    Then that is the correct way to go Depo and getting basically the exact same performance as new Valeo E-Codes!
    -Nic
  9. #169
    Senior Member Three Rings getslideways's Avatar
    May 16 2008
    WA
    I cannot wait for this write-up!
  10. #170
    Senior Member Three Rings Korben007's Avatar
    Nov 08 2007
    00 Celica Supercharged, 93 MR2 BAT, 90CQ/S2
    Lake Tahoe, CA/NV
    why cant depo make a D2S headlight
    Current Rides:
    2000 Toyota Celica GT-S Supercharged
    1993 Toyota MR2 Big Turbo
    2000 Audi S4 Stage 3
    1999 Audi A4 Avant 2.8
    2008 Audi TT 3.2
    1990 Audi Coupe Quattro(SOLD)
    Links:
    Check Out My Celica - Check Out My S4 - Check Out My MR2 - Check Out My Facebook
  11. #171
    Active Member Three Rings vteckiller2000's Avatar
    Jan 22 2011
    2011 Mustang GT, 2008 ZX6R
    Iowa City
    Quote Originally Posted by Korben007 View Post
    You wouldn't want it.
    2011 Mustang GT 5.0 - 419/378
    2003 B6 A4 TQM - 187/232
    --14.168@94.16 mph STOCK K03--
    2008 Kawasaki ZX6R - ?
  12. #172
    Feb 06 2009
    Fairview Park, OH
    If these are legit than DEPO does - http://www.ebay.com/itm/99-01-AUDI-A...item1c22c07830
    However, while the photo shows a lack of the side amber reflector found on Valeo US headlights they don't have the turn signal light cover that DEPO ECodes have...
    vs
    Drew
    1998 Audi A4 2.8QM
  13. #173
    Senior Member Three Rings amd is the best's Avatar
    Oct 05 2007
    '91 200, '01 S4, '10 Jetta TDI
    Schenectady, NY
    Those don't have auto leveling or mention anywhere in the listing that they can support it (that I could find). Not sure if that's a big deal to you or not. I'm curious if these have the Euro projector or the american one and the clear corners are certainly different then the OEM Euro ones. Something fishy about those however they do look nice and are 1/4 the price or OEM Euro.
    I really like what you plan to offer the community! Keep up the good work!
    2010 VW Jetta TDI
    2001 S4 - 11.80 @ 119
    1991 200 20v - 12.31 @ 110 (slipping clutch )
    www.pbase.com/amdisthebest
    www.youtube.com/amdisthebest
  14. #174
    Feb 06 2009
    Fairview Park, OH
    It all depends. Since I haven't done the testing yet and can't base a recommendation on my results I can only say what I would do in your situation. Since you want the ECode corners I'd do the following...
    1. Buy a pair of H7 DEPO ECodes
    2. Pull your projector assemblies out of your OEM US Valeo D2S headlights and inspect the rear reflector bulb bowls for any sort of burns or scorching (might want to clean them up as well... don't use any sort of cleaning product as they can damage the reflective coating)
    IF your rear reflector bulb bowls are in good shape...
    3. Use the the projector lenses from the DEPO ECodes with the following from your OEM US Valeo D2S headlights: D2S bulbs, rear reflector bulb bowls, cutoff shields, ballasts, internal headlight wiring harness, and auto level motors.
    *You might want to upgrade to TSXR lenses, however, I can't say they'll provide any advantage over the ECode lenses (both of them are clear lenses) until I do my tests.
    IF your rear reflector bulb bowls are in bad shape...
    4. I'd buy a new set of projectors such as the Morimoto Mini D2S 2.0 Bi-Xenon from TRS to use with the following from your OEM US Valeo D2S headlights: D2S bulbs, ballasts, internal headlight wiring harness, and auto level motors.
    If you can wait until my write up is done and you'll be able to compare different projector combos to decide for yourself.
    Drew
    1998 Audi A4 2.8QM
  15. #175
    Feb 06 2009
    Fairview Park, OH
    Quote Originally Posted by amd is the best View Post
    I assume you're talking about the lights I linked to above. They ship with a set of "shipping plugs" in the location where the auto leveling motors sit (I'll discuss this in my write up). All you have to do is remove the shipping plugs and swap your auto level motors into the new headlights.
    Drew
    1998 Audi A4 2.8QM
  16. #176
    Oct 05 2007
    Schenectady, NY
    Yeah, I was. I just didn't see it in the ad. Thanks for the info. The harnesses would also have to be swapped by the looks of it, but I'm sure you noticed that as well
    2010 VW Jetta TDI
  17. #177
    Feb 06 2009
    Fairview Park, OH
    I'm assuming that the D2S housings should have the correct harness for use with OEM Valeo ballasts (I can't physically see the 6pin connector in there... only a single H7 connector which is probably for the high beam), but of course I can't be certain. The ECode H7 housings contain a wiring harness with H7 connectors for the low and high beams along with a connector for the city light. So if you buy the H7 housings and want to use your OEM Valeo ballasts you need to swap over your OEM internal wiring harness.
    Drew
    1998 Audi A4 2.8QM
  18. #178
    Aug 13 2008
    Indiana
    I doubt the Mini D2S will fit. I have a set and they are fairly tall. If they do fit, I'm doing it.... lol
    -Nic
  19. #179
    Feb 06 2009
    Fairview Park, OH
    I'll have to attempt to measure when I get home tonight... it might... if not TRS's Bi-Xenon Morimoto Mini H1s should (a little over 1/2" longer, but ~ 1/3" shorter in height and almost a 1/2" less wide).
    Drew
    1998 Audi A4 2.8QM
  20. #180
    Aug 13 2008
    Indiana
    Maybe I should try, I have them after all and they are really fairly nice.
    -Nic
  21. #181
    Feb 06 2009
    Fairview Park, OH
    Go for it. By the way what part of IN are you in? I'm originally from the Evansville area.
    Drew
    1998 Audi A4 2.8QM
  22. #182
    Feb 06 2009
    Fairview Park, OH
    For anyone who is interested I've started my Headlight Writeup Thread.
    I won't have final data up until mid next week (to allow for the addition of a TRS Morimoto Mini H1 projector).
    Drew
    1998 Audi A4 2.8QM
  23. #183
    Jan 22 2011
    Iowa City
    Please take lots of pictures.
    I have sold my b5 since starting this thread, now I have a b6 which needs the same help.
