Page 1 of 10 123 ... LastLast
Results 1 to 40 of 385
    Veteran Member Four Rings slimmj0k3r's Avatar
    Jul 31 2005
    Kia Rio
    Arizona
    (slimmj0ker's) - HTA3582R Big Turbo Build
    Decided to make my own thread, Many people may have followed previous threads:
    DW Garage HTA Build
    Another B7 A4 Pushing the Envelope
    Lets leave the politics out of this thread and get down to the business. 56k grab a kit-kat
    Specs On the Car: (Updated 2/2013)
    HTA 3076R .63 AR
    Tial 38mm v-band wastegate
    Pagparts cast stainless steel v-band manifold
    Mahle 83mm 9:1 pistons with steel pins
    Brute 144mmx20mm H-beam rods
    Coated rod bearings
    Ferrera 1mm oversize intake and exhaust valves
    Fereara titanium retainers
    Ferrera valve springs
    ARP main studs
    ARP head bolts
    ARP crank bolt
    ARP flywheel bolts
    Fluidampr pulley
    ASP Motor Mounts
    INA Engineering intake manifold
    APR High Pressure Fuel Pump
    RS4 injectors
    HPFP 155bar Performance Rail Valve
    Custom 3” Downpipe
    Custom cat-back exhaust
    Clutchmasters FX400 ceramic 6 puck
    Clutchmasters billet steel flywheel
    JHM Short Shifter
    JHM Linkage Upgrade
    Garrett 900HP Core
    Devils Own Water/Meth
    BSH Race Catch Can
    Eye Candy (In No particular order):
    Glad to say that I've actually driven the car these past two days, to break the motor in and clutch, and I can say it feels amazingly stronger. I was not able to get into boost since we're running a base file and we had to just take it easy on the clutch but around town the car is simply great. Currently its back in the shop to re-torque the head bolts and start the tuning. Originally I had no intention to run water/meth but with my upcoming move to Arizona, no 93 in AZ, and scorching summers I decided that running meth would actually be beneficial..... My massive intercooler should help also lol
    Hopefully next week we will have some actual numbers. Aiming to break 400whp but only time will tell. Hope this will be some motivation for some more b7ers to start going BT....we need more BT threads and less "what rims/what mod should I get/do".
    Made a little video of a cold start.... a bit rough but things will be ironed out within the final tune. Enjoy.
    cheers.
    Senior Member Four Rings Staz's Avatar
    Jul 03 2010
    QUEENS, NY
    thats is awesome, holy crap at the size of that front mount
    and lol @ camera falling
    Senior Member Four Rings Gil2.0T's Avatar
    Oct 11 2010
    Tampa, FL
    Very nice. Cant wait for some videos once that thing is tuned. Props
    F.T.W.L.T.B.D.W.I.C.T.W.
    \ Liquid Blue Metallic B7 \
    Non-Sline Club Member: 007
    Senior Member Four Rings viceprp's Avatar
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    You'll easily break that 400whp mark. I know on my little b5 and 1.8 displacement. I've seen 427whp on w/m on only a GT3076. A 2.0 GT35 on meth with conservative tune should easily see 430+whp. Look forward to the numbers! GLWD
    ATW 1.8TQM | SCAT | FX400 | GTcougaR | Meth
    For sale: RAI FMIC & misc '00 parts
    STEVE
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T
    NC
    Hoping to have mine dynoed in a couple weeks....
    05.5 B7 A4 6sp AWD Quartz Gray 179,000mi I like to drive!
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Jul 31 2005
    Kia Rio
    Arizona
    Quote Originally Posted by viziers View Post
    Sweet keep us posted. Eastwick should be getting his car back this weekend or monday with results and I'm expecting mine about wednsday of next week.
    We will have some footage of everything. Going to put together a nice video with results when everything is done, eastwick has a new dslr to test out haha
    Senior Member Two Rings B7Daily's Avatar
    Dec 25 2010
    B7 A4, MK2 GTI, ummm and alot of other things
    Hopkins/mn
    I would like to see the numbers and hear about how the maintenance is
    AWE quad tip Black exhaust W/ Test Pipe | AWE Boost gauge vent | APR HPFP | APR 2+ | Carbonio | PSS10's | Stern adj. conrtol arms | 19x9 19x11 Auto Art wheels | H-Sport Front and Rear | Poly Drive train Mounts | RS4 Engine mounts | BBK Porsche 350MM | Clutch Masters stg. 4 | O34 Studs | Test Pipe | BSH CC | S4 Interior |
    Senior Member Four Rings eastwick897's Avatar
    Jun 26 2008
    New Jersey
    Quote Originally Posted by B7Daily View Post
    What do you mean by maintenance? It's similar to what you do on every other FSI. Minus the intake valves being caked up.
    B7 A4.... 394awhp
    Jul 31 2008
    Minneapolis
    sweeeeeeeeet
    Jun 26 2008
    New Jersey
    YESSSSS finally the cat is out of the hat. Saw this monster in person yesterday as slim drove to my house. It's a beast!
    B7 A4.... 394awhp
    Veteran Member Four Rings viperdsa's Avatar
    Aug 28 2007
    '06 Dolphin Gray A4 2.0T
    west of the equator
    Awesome. It's interesting how different piston manufactures go about getting the desired c/r. I have a set of JE 9.5:1 and they have no visible dish to them like your CP's do.
    2006 Dolphin Gray A4 2.0T Quattro
    Senior Member Four Rings jimrobbington's Avatar
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    Thats sick slim. I didn't even know you were doing a build. How long did your build take? If they are getting 400 whp on that other thread with no internals or meth, with the right tune you should be able to surpass that by quite a bit, I would think. No lpf issues?
    05.5 A4 2.0T 6spd, REVO Stage 2, Vast Stage 3 clutch, VMR test pipe, custom non-res 2.5" Techtonics exhaust, Borla mufflers, wastegate adjustment, Treadstone TR6 FMIC, custom cold air intake, 034 catch can, BKR7E, 145 bar prv, DW300 LPFP, shiny manually cleaned valves, JHM Short Shifter, KW V1's, 19" V710's, drilled/slotted rotors, Akebono pads, Podi boost gauge, 640 Mod, 18% tint, baby seat.
    Dyno proven 221 whp/302 wtq on 91 oct!
    Jul 31 2005
    Kia Rio
    Arizona
    We started doing research back in 2008 before we actually began anything, i'd say we began work around april 2009. I had to learn all about the FSI motor and kept this 200 page book with me at all times lol, I still have it actually. Fast forward almost 2 years later and a lot of unplanned parts/circumstances, we're finally close to what I wanted to achieve. Its an ultimate sleeper.
    LPFP is not the issue at this point, I feel that we're going to hit our limit at the RS4 injectors.
    I feel that we'd be able to break 400whp without the meth, Only reason i'm running the kit is because 93oct is not available in arizona and it gets HOT...heatsoak ftl.
    Senior Member Two Rings trevor51590's Avatar
    Dec 18 2007
    AH-64D
    Stanhope, NJ / Rutgers NB
    pure $3x
    '06 A4 2.0TQM Premium+ | Nav | Debadged | Revo Stage 2 | 034 HFC | K&N Air Filter | OEM Revision D Diverter Valve | Neuspeed Snub | RS4 Rear Sway | A6 3.0T Wheels | OEM Aux Port | VAG Mods | Yellow Calipers | Blacked OEM HID| Clear Corner | Blackout Grille
    '09 Ducati Monster 696 | Termi | ECU | Air Filter
    '99.5 A4 1.8TQM Gone
    Jan 27 2007
    2005.5 A4 2.0T
    NC
    Ut oh I think I jizzed on the screen looking at the pics again!
    Mar 26 2007
    Colorado
    redonkulous
    SRT8 Jeep / Custom exhaust w/ X pipe / Catch can / AFE intake / Diablo Intune/ 275's & 315's
    Veteran Member Four Rings nnnick's Avatar
    Nov 01 2005
    2006 S4 6MT
    Tempe, AZ
    Hope the tune goes well, it seems everyone that goes with a custom big turbo setup can never get it tuned worth a damn. Excited to see this beast out in AZ!
    2006 Audi S4 | Brilliant Red on Platinum Silver | STaSIS Ohlins SL, Swift Metric Springs, Stern UCAs, 19" BBS CH, 370mm Alcon BBK, Aerofunction hood, flat bottom steering wheel, RS4 Grilles, Milltek Catback, Piggie Pipes, oCarbon trim + B&C pillars, JHM tune, etc
    NicksCarBlog.com | FRRG Southern Ring
    Jan 27 2007
    2005.5 A4 2.0T
    NC
    Quote Originally Posted by nnnick View Post
    Thats not true Vast's BT tune is working great as they just dynoed their B7 at 400WHP and mine is going to be dynoed hopefully in the next few weeks, fingers crossed I can near what they put down then get my ass up there for the fine tuning.......
    Nov 01 2005
    2006 S4 6MT
    Tempe, AZ
    Guess I should have said everyone I know out in Arizona that has had a BT + custom tune. No one out here really does VAST tunes, so that might explain it
    Jan 27 2007
    2005.5 A4 2.0T
    NC
    Haha, yes that deffinately would explain a bit...
    Jul 31 2005
    Kia Rio
    Arizona
    I haven't really heard of a solid tuning shop out in AZ. Evoms does rock solid work on the porsche but idk about they're capabilities with the audi platform (not bashing them).
    Senior Member Three Rings crazytex21's Avatar
    Jan 31 2010
    Georgia
    is it weird that my pants are a little tight right now?
    tex lee
    2007 A4 2.0TQ 6MT
    Maestro Tuned, APR HPFP, AWE FMIC, Drakes STG IV Clutch, Clutch Masters Steel LWFW, JHM Short Throw, H&R Street COs, 034 Turbo Inlet, RS4 Sway Bar, 034CC, RAI DP, Fuckin Sick Hair
    Senior Member Four Rings ryanworth's Avatar
    Nov 16 2009
    DTLA, CA
    Looks amazing dude! I love how you shaved the crash bar to fit the IC. And that turbo is a very stealthy install.
    B7 S4 - 6MT Dolphin Gray Avant - Current
    B7 A4 - 2.0T 6MT Quattro Brilliant Black Titanium S-Line - Old
    -Ryan
    Dec 03 2005
    audi, chevy, jeep, lots and lots of bicycles
    connecticut
    Very Clean.
    I can't wait for a ride.
    Oct 17 2009
    alonE, Pa
    The RS4 injectors are 480cc, correct? I would think you would make them out fairly quick. Why not upgrade to a larger injector?
    STEVE
    Jul 31 2005
    Kia Rio
    Arizona
    Quote Originally Posted by viceprp View Post
    There is simply nothing else right now. We've explored MANY options. The only alternative will run about $4000 for a set and from what I've been hearing they're not all that much better, I only know of 1 car running them.
    We've even tried modifying the stock injectors
    Once more people start going bt we hope to see something eventually I hope, right now the market really isn't there IMO
    Oct 17 2009
    alonE, Pa
    Quote Originally Posted by slimmj0k3r View Post
    Didn't realize the market was that small for the B7 plateform. I'm very familiar with the B5/B6 and starting to look into the B7 a bit more (to be well rounded in my thirst for knowledge). I hope you get all things squared away and break that 400whp marker. The inj will be a big factor.
    STEVE
    Senior Member Three Rings bartles's Avatar
    Apr 11 2010
    07 Jeep Commander, 06 A4 2.0
    Denver/ Chicago
    Why not run a 5th injector set up? I believe Dimitris is
    2006 A4 2.0T
    Jun 26 2008
    New Jersey
    Quote Originally Posted by bartles View Post
    It isn't as simple as just adding a 5th injector. I spoke with 034 about it, and they said that for a car that would be daily driven the car just won't run smoothly. People always think that by just adding things it solves problems. Ideally, you want your car to be smooth out of boost and a pleasure to drive. 034 isn't the only tuner who told me the car would run rough, Mark at Autospeed also said the same thing. There are rumors going around on Vortex that there is a company designing some higher flowing injectors along with a fuel rail. I would be happy with just some injectors for now.
    B7 A4.... 394awhp
    Jun 26 2008
    New Jersey
    They are 480cc which totally sucks for a turbo this size. We have looked into other FSI platforms,but the other injector options aren't any better. There are a few companies out there "claiming" they are working on injector solutions, but i'll believe it when I see it. These engines have great potential and it seems like the only thing figured out right now is an injector solution.
    B7 A4.... 394awhp
    Oct 17 2009
    alonE, Pa
    Quote Originally Posted by eastwick897 View Post
    I just don't see why the B7 platform doesn't have larger injectors yet. The car has been out for 5+ years and from day one, tuners should have known the market will BOOMIG for any Turbo Charged Audi. For an HTA35, I wouldn't go any smaller than an 830cc inj for my platform. What kind of numbers have you seen with your setup? Just hard to imagine a turbo setup with improper fueling. Really is a shame.
    STEVE
    Jul 31 2005
    Kia Rio
    Arizona
    Forgot to mention that the FSI is also a pain in the arse.
    Oct 17 2009
    alonE, Pa
    Yeah, I saw the price tag on the HFFP. I couldn't imagine spending that kind of money on JUST a chip, but BAT would make it worth it.
    STEVE
    Jun 26 2008
    New Jersey
    I should have a dyno by the beginning of this week. I am also surprised no company has looked into developing some higher flowing injectors with the number of BT GTI's out there.
    B7 A4.... 394awhp
    Senior Member Three Rings projectb7's Avatar
    Mar 20 2009
    1989 BMW 325i four door waiting for a 3.5 turbo swap. 2007 Chevy Impala
    Albuquerque NM
    Damn... looking good! I want to see some dyno nummers..
    Schnell Weg? RICHTIG!
    Ryan
    Jul 31 2005
    Kia Rio
    Arizona
    just some updates. Car is finally on the dyno!
    Since I will be running 91 octane in AZ we've decided to tune the car on 87 Pump + 87 pump w/meth since the 91 here and the 91 in az are in no way comparable. Mark has tuned cars on 91 octane out west and he knows exactly what its capable of.
    Dyno results by weeks end.
    Jul 31 2005
    Kia Rio
    Arizona
    update, was at the shop today. We've decided to up the octane to 91 as 87 has proven to be pretty shitty. Hopefully the car will be ready on friday.
    Dyno run video, only revving up to 5k
    Jun 26 2008
    New Jersey
    87 FML!
    B7 A4.... 394awhp
    Dec 03 2005
    connecticut
    making progress.. car is right in-line with eastwick's car right now in terms of power and performance. on 93oct.
    -Doug
    2002 A4 2008cc GT-3076R turbocharged Avant
    397awhp/371awtq on straight 93oct and 96*F ambient
    You too can have this kind of power if you click here
    Jul 31 2005
    Kia Rio
    Arizona
    93 ftw!!! I'm going to have to iron out the tune on AZ 91 pump. Car won't be performing at 100% since we're running this shitty 89 but oh well, Not going to post dyno numbers until I get over to AZ and fix the tune.
