Page 1 of 3 123 LastLast
Results 1 to 40 of 92
    Senior Member Three Rings braker15's Avatar
    Nov 14 2008
    2000 S4 Nogaro Blue
    S.Florida
    WHAT'S the best trans/diff fluid to use to better performance and extend life?
    Wanna do my manual trans fluid, and diff as well, because its noisy.
    Is Redline any good? what to use on dff?
    I searched.
    tk
    2000 S4//GIAC Tune//AWE Intake//AWE DTS Bar//Cross,Drilled Rotors//18" RS4's AtItalia//Bridgestone//Pioneer Navi//more to come
    Gone: B6-APR stage II+/K04-015/ER sport fmic/Genesis 380cc/Forge 007/Magnaflow 16601/R8 reps/Prosport gauge/Koni Coilovers/K&N/badged
    Registered Member Four Rings ThirdStrike's Avatar
    Nov 17 2006
    b5S4, mk4GTi
    Norf Las Vegas
    Redline Shockproof
    Fixed many of synchro and gear grinding issues on different vw/audis for me. Its the best by far imo
    K04|Eurodyne ME7|E85|No bitchassness
    Stage 3 Forum Advertiser Four Rings Scotty@Advanced's Avatar
    May 16 2008
    South Texas
    We've gone through a number of gear oils, and redline has the worst shear stregth of just about any fluid out there.
    My recomendation would be the Titan Fuchs SintoFluid 75W90 or Motul Gear 300. We stock the Sintofluid here.... Best thing about the Fuchs is it is a performance oil that meets the OEM fluid specification.
    Jan 03 2010
    Gloucester Ontario
    neat... cant get that motul stuff easily around here. nice to see an alternative.
    Nov 17 2006
    b5S4, mk4GTi
    Norf Las Vegas
    Quote Originally Posted by Scotty@Advanced View Post
    Good to know. I was just about to change the gear oil in my golf too.. Ill buy some motul
    Nov 14 2008
    2000 S4 Nogaro Blue
    S.Florida
    so, 75w90 in the trannny? and what goes into rear diff?
    Veteran Member Three Rings IamEzraM's Avatar
    Jul 21 2005
    2001.5 Audi S4 Santorin
    Bedford/MA
    Redline MT-90 for the tranny, Redline 75W-90 for the diffy
    My car is fast
    Jan 09 2011
    Pleasant Gap PA
    Royal purple 75-90 in both boxes and it meets the GL4 spec of the gear oil which is required and its cheaper then many alternatives. As is the 75-90 for both boxes by amsoil which also meets the GL4 spec which is required. Also cheaper as well and available at many auto parts stores. Both are full synthetic and have great properties (one of which being shear strength) and others like thermal stability and breakdown. Could do more detail but you would have to be a chemist almost to understand it.
    Senior Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Parts
    Your Computer Screen
    Redline mt90
    Active Member Two Rings coreyj's Avatar
    Jul 28 2010
    nashville
    hands down this stuff is the best... my old shop used it in all the race cars mainly Porsche, but works extremely well in the 01E and other quattro transmissions, ( even stop bad syncros from slipping in one customers TT) it is GL5 spec.
    Race-proven gear oil
    Special adhesive/cohesive formulation eliminates "dry starts", dramatically reducing initial start-up wear on pinion and ring gears
    Helps improve "stiff shifting" manual transmissions
    Reduces operating temperatures
    Blended with highly refined pure paraffinic base stock and a high tech additive package, including SWEPCO's proprietary additive, LUBIUM®
    Helps keep gearbox and transmission seals soft and pliable, reducing leakage
    Meets all AGMA specifications, API GL-5, and MT-1
    EP and limited slip differential additives
    Available in SAE 80W-90, 90, 140 and 250; ISO Grade 150, 220, 320, 460, 680, 1000
    I do ME7.1 and ME7.5 ecu tuning (stock-NA-Big turbo), emissions deletes, immo defeat, etc..
    email me at coreyj03@gmail.com for more information.
    Senior Member Four Rings gearhead1186's Avatar
    Mar 17 2009
    02 S4, 06 GTO, 69 Camaro, 73 Cuda, 68 Torino
    Queens, NY
    motul gear 300 here.
    Jan 09 2011
    Pleasant Gap PA
    Quote Originally Posted by coreyj View Post
    It is not a good idea to use that fluid as it is a GL 5 spec luid and is not meant for out gear boxes. It is actually too slippery and will over time cause quite a bit of extra wear at contact surfaces.
    Jan 03 2010
    Gloucester Ontario
    i tried this in my 02J trans years ago.
    car was UNDRIVEABLE when it was cold.
    had it out 2 days later and replaced with stock fluid at the shops expense.
    Jul 28 2010
    nashville
    Quote Originally Posted by sweets4style View Post
    if you put this in your fingers it strings like syrup, it wont cause wear... there are several cases where this stuff has actually gripped better on the syncros and caused gears not to grind anymore. also this oil is MT-1 approved (which means it does not cause harm to yellow metals)
    If porsche 996, gt2/3 owners use this stuff then id say its safe for our transmissions. since some of the Porsche transmissions use a few of the same parts. ( I can prove this with because i came accross the parts when i build my last couple 01E's)
    Jul 28 2010
    nashville
    Quote Originally Posted by J-b5 View Post
    yes i will agree this stuff is not to be used in -30*F lol... if you live in southern half of US or Cali, then you will love it.
    Jan 03 2010
    Gloucester Ontario
    Dude this was on a balmy 60 degree day. Once the trans warmed up it was usable, but until it did the syncros did not work at all.
    Jul 28 2010
    nashville
    Do you even know how syncros work? lol. also i never said to use this in a VW 02j trans. i have this in my car right now and started it at 20*F this morning and had no issues whatsoever...
    Jan 03 2010
    Gloucester Ontario
    scotty how do you stand this forum sometimes?
    Senior Member Two Rings Nadrealista's Avatar
    Jan 09 2009
    2001.5 Audi S4
    Falls Church, VA
    I use motul gear 300 but I am curious how did you come to the conclusion that redline has worst shear strength?
    Redline oils are based on esters (group V fluid) which is very shear resistant...
    MTM Stage 2+ | VAST Meth Kit | Piggie Downpipes | LaBree Dual Catback | IC Misters | Eibach Suspension | Short Shifter | PCV Delete
    Jan 03 2010
    Gloucester Ontario
    im guessing he had some tested after pulling it out of severely worn transmissions. but ill let him field that.
    Nov 14 2008
    2000 S4 Nogaro Blue
    S.Florida
    hey chief, where to get this stuff? at auto parts??
    Jul 28 2010
    nashville
    ^ pelican parts or ebay
    Nov 17 2006
    b5S4, mk4GTi
    Norf Las Vegas
    Im not saying that scott@advanced is wrong but my old jetta (02J) had first to second gear grinding issues even at low rpm, until I put the Redline shockproof in. Shifting felt like new again. (and my clutch wasnt bad)
    Jan 03 2010
    Gloucester Ontario
    your old fluid might have been finished. new redline is still a good product, hes just saying its got a short life.
    May 16 2008
    South Texas
    It is challenging at times.
    Quote Originally Posted by Nadrealista View Post
    There are a couple different studies I've pulled found which showed how poorly the redline fluid sheared (note I do not know specifically which redline fluid it was, but I suspect it was MTL). Redline also scored poorly on the high temp particulate test. One study was done by Amsoil, and the other IIRC I saw it on bob is the oil guy.
    We've also seen shear related gear face damage on some of the 01E's we have rebuilt which the owners stated they ran Redline for most of the trans' life.
    Quote Originally Posted by ThirdStrike View Post
    People always testify a particular fluid worked great when it after flushing old fluid from the gearbox. This is not an objective test but rather and observation.It is highly likely that any fluid (be it redline, motul, or stock) would have likely displayed similar improvements due to the fact the old fluid was spent, or contaminated and likely needed to be changed in the first place. On another note, Audi and VW's lifetime fluid recommendation is a farce only implemented to sell gearboxes or parts (IMHO).
    I've been meaning to send a few samples of some of the common gear lubricants as well as some of the shit drained from gearboxes to a couple of labs for analysis and evaluation, but haven't had much opportunity to do so.
    Someone posted earlier a GL4 versus GL5 fluid. In the past most GL5 gear oils contained sulfur compounds which helped with smooth LSD clutch plate operation, however at elevated temperatures, the sulfur tended to bind with yellow metals (brass) found in syncro rings turning them into sludge. However modern chemistry has mostly eliminated sulfur in lubricants so it is now safe to run a GL5 fluid in a GL4 application. Just because a fluid is specified as being GL5 does not mean it won't function properly in a gearbox requiring
    GL4, as long as the GL5 is sulfur free.
    Jan 03 2010
    Gloucester Ontario
    SCIENCE!
    Nov 17 2006
    b5S4, mk4GTi
    Norf Las Vegas
    good point
    Definitely gonna get Motul after this thread! I've been advised by other people to get Motul before
    May 16 2008
    South Texas
    Quote Originally Posted by braker15 View Post
    I searched.
    tk
    To directly answer your question, the best things to improve transmission life and performance is use a good oil, redline, motul, fuchs, factory whatever, don't shift like a tool, and change the fluid one every 2 years or 50K or if driven hard 1 year or 25K. If you ask me what I prefer, I say again Motul, factory or the Fuchs.
    Jul 28 2010
    nashville
    on manual trans service motul is very good also imo. for track duty i would do the motul 300 or swepco 201
    Active Member Two Rings TozoM8's Avatar
    Sep 17 2010
    Black on black 01 Twin Turbo S8, 6MT, built in SRX 01' allroad 2.7T
    Chicago
    Just to make this thread more interesting I run 10 W40 motor oil in my trans. We had some -4F last week and it shifted like butter.
    01' black on black twin turbo S8 with 6 speed manual (euro TDI 6th gear), RNS-E, Passport SRX
    May 16 2008
    South Texas
    Quote Originally Posted by TozoM8 View Post
    Some of the detergents in motor oil can cause issue after prolong use but frequent oil changes can alleviate those problems.
    ATF is a pretty awesome lubricant, but a bit harsh on syncros. Dog boxes can run the stuff with no issue.
    Nov 14 2008
    2000 S4 Nogaro Blue
    S.Florida
    Scotty, is good to use the same 300 motyl gear oil for rear diff??
    tk
    Nov 06 2006
    Philadelphia
    redline MT90 does not work well in cold weather (at least for me S4 - 2001.5 6mt)(and yes I know that you can mix MT90 and MTL and that that might work better in cold weather). Here in south eastern PA temps have been around 22F in the mornings. Shifting has not been easy. This past Friday night I switched back to the factory fluid (G 052 911 A2). Yes it was $26.00 per liter. Had to by 3. Since then shifting is fine especially the 1 to 2. No issues even this past Monday when it went down to -1F. When MT90 is warmed it works fine but, when it is below 35F I had issues.
    Also found that this Pentosin should work in our trans.
    http://www.pentosin.net/pressrelease...nto_MTF2_2.pdf
    Looks like it costs $23.00?
    Stage 2 Banner Advertiser Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    We've been recommending and using Motul 300 for years. It's a great fluid for both the diff and transmission.
    Available on our website.
    Senior Member Three Rings Just_dizzle's Avatar
    May 16 2010
    jeep cj7 on 35's (for sale). toyota fj62, 71 bmw2002
    ABQ
    Motul 300 in tranny Motylgear 75-90 in Diff?
    May 16 2010
    ABQ
    how much does the tranny and diff take?
    May 16 2008
    South Texas
    Quote Originally Posted by Just_dizzle View Post
    2.9 liters for the trans and .95 for the rear diff IIRC.
    May 16 2008
    South Texas
    Rear diff lube isn't nearly as persnickety as the trans. Either would be fine.
    Jan 03 2010
    Gloucester Ontario
    i did the old fill till it leaks out and it damn near took 4 litres.... of course it was seeping out of the drivers side axle flange after i did that, so may thats not the best way. :)
    the measured way is best but that stuff flows soooooooo slowly..
    May 16 2010
    ABQ
    thank you scotty
