Results 1 to 14 of 14
    Feb 01 2009
    Wes_R + Testarossa [126 pics]
    Hi everybody,
    First off I want to say a big thank you to Sakimano for recommending me to the owner of this car.
    Basically Sakimano had seen one of my other write ups and was impressed enough to recommend me to one of his co-workers which led to this detail. I received a call from the owner wanting to set up a full detail prior to putting it into storage. It was already cutting it close as the only available date I had was in the second week of Dec. ..... but who can say no to a Testarossa and wait until spring(not me ). A cool thing about this detail was I got to drive the car since the owner wanted me to pick it up and drop it off when done, I have to mention while driving the car in the beginning I was a little nervous lol.
    Any way this detail happened in Dec. 09 and I am now finally able to share it with you. Hope you like it
    Here she is
    lol yes that is a dog biscuit
    In defense of the owner he said it was I while since it was detailed and the last time it was just a quick job
    So getting started I dusted the car down to get in the tight areas. At the time I was using a Megs Slide Lock Brush but it gave out on me and I had to take what was left and wrap it in a rubber band, but it still did the job
    I then vacuumed the entire car
    Then gave everything an APC wipe down
    At the same time I used my foam stick to get in the tight areas that my fingers couldn't reach
    Got in the tight areas of the prancing horse on the hood and trunk latch and here are some before and afters
    Before
    After
    Before
    After
    Got in the even tighter areas with a q-tip
    Had to scrub a few areas with the fine side of my Triple Duty Brush like...
    The cassette tape holder buttons
    And the "PRESS" on the seat belt
    Before
    After
    Feb 01 2009
    Scrubbed the door sill
    And the pedals, no dressing was applied after the clean up as common sense is I don't want the pedals slippery
    Before
    After
    Pretty much everything in the interior is leather. So I leather cleaned and conditioned everything... the seats, dash, doors, and roof
    Gliptone was what I used
    Scrubbing away with my leather brush
    Leather conditioned by hand and massaged it in to the leather
    Doors
    Seats
    Roof
    I let it soak in for a bit then wiped off the remainder for a nice natural finish.
    Did I mention it was cold!!!
    Brought the tool bag, owners manual, and jack inside for a cleaning.
    Tool bag was dirty and disorganized
    Cleaned up the bag with some APC and the tools as well
    Clean and organized
    Leather cleaned and conditioned the owners manual bag
    Cleaned the bag the held that jack etc and wiped down the jack and tools
    And here they are ready to go back in the car
    I took these pics at the final end of the detail but felt it was appropriate to put them here. These are the finished pics of the interior.
    Now getting started on the exterior I start off with the wheels.
    P21s Wheel Gel was used to clean the rims which is non acidic
    Let the rims soak while I attended to the engine bay
    I didn't get to aggressive on the engine bay but still did the best I could. Here is a before and after pic
    Before
    After (still a little wet from the dressing)
    Artsy fartsy shot
    Feb 01 2009
    Moving on to the rims
    Getting in the inner barrel with my handleless EZ brush
    Behind the rim
    Cleaned the rim face with a micro fibre mitt
    And used a foam stick to get in the lug nut area
    Rinsed down the car
    And sprayed on Prep Wash to strip off any silicones
    Then washed the car using the 2 bucket method and a natural sea sponge
    Rinsed my sponge off in the water only bucket after every panel or a half a panel
    Dryed the car off and brought it in to clay bar it.
    Riccardo Clay was used
    Pretty contaminated
    Measured the paint to see what I was dealing with. The owner had told me that the whole car had been repainted
    Masked off the rubber trimmings
    And here is what I was up against under 500w halogen lighting
    Did a quick test spot to find a combination that worked and here are the results
    Now for a few before and afters of the body panels
    Before
    After
    Before
    After
    Feb 01 2009
    Before
    After
    Before
    After
    Before
    After
    And a 50/50 shot
    Single stage paint really clogs my pads up so I had to change them frequently
    All the tight areas my rotary couldn't reach I did by hand with on orange lake country pad and M105 then a white pad with M205. They did not end up perfect but still a huge improvement to how they were before
    This was a full paint correction so the few deeper scratches I wetsanded with Micro Mesh sand paper to either round off the edges of the scratch to make it less apparent or to completely remove the scratch.
    After all the compounding and wetsanding I finally jeweled the paint with a white Lake Country pad and P085rd. Here is a shot of me jeweling the paint.
    And the results of my work
    Unmasked the car
    Dusted it down and got in the tight crevices.
    Gave it an alcohol wipe down to clean off the polishing oils
    Then double check my work with my 3M Sun Gun
    Perfect
    Applied Swissvax Concorso
    While the wax was curing I attended to some other areas
    Sealed the rim with Poorboys Wheel Sealant
    Dressed the tires with Blackfire Long Lasting Tyre Gel which after being left on for awhile then wiped off leaves a beautiful finish
    Here is an after pic of the tires and rim
    I couldn't get the exhaust perfect but still made an improvement.
    Before
    After
    Feb 01 2009
    Now finally after 50+ hrs of work, -10 weather, and the first snowfall of winter here are the finished pictures.
    First up some shots of the sun on the paint
    And my last 3 favorite pics.
    I delivered the car to the customer right after taking the pics. Even though it had snowed the roads cleared up and it was a beautiful sunny day(remember for the Toronto/GTA guys it was a real mild winter for 09/10). I looked like a nut though driving the shiniest Testarossa you ever seen in December, and did not now how to hold my face with everyone staring lol.
    Hope you enjoyed the write up!
    Wes
    Veteran Member Four Rings ahcow's Avatar
    Apr 26 2010
    Toronto, Ontario
    Nice work!
    When should I book a time with you for spring? Say around early May....
    New: 2016 S3, Sepang Blue, Sport Seats, S-tronic, Tecknik, LED
    Old: 2010 S4, Brilliant Black, Magma Red Nappa, S-tronic, Nav, Sports Differential
    Mods: Strat Intake, 35% Ceramic Tint, RS5 Pedals, BE GTS-AV, Hawk pads, Alu Kreuz, Vag-com, APR Exhaust
    Veteran Member Four Rings Crucible35's Avatar
    Apr 22 2010
    13 Lawnmower Prem. Quattro
    Toronto, Ontario. Canada
    That is awesome, great work! ......bet you were hearing the Miami Vice theme in your head during the whole process.....I did just looking at the pictures!
    Do you ever allow people to watch you work?? Like watching an artist at his easel.
    '15 A4 S Line Q Tip Monsoon
    '09 A4 Premium Q Tip Meteor (Gone)
    Feb 01 2009
    Quote Originally Posted by ahcow View Post
    Nice work!
    Sent you a message.
    Quote Originally Posted by Crucible35 View Post
    lol I didn't really get into Miami Vice, I'm more of a Knight Rider guy. I don't really do well with people staring at me(drives me nuts), but if your interested to learn I could teach you for the right price.
    looks awesome!
    Nogaro/Nogaro '01 S4 Avant 6MT
    '00 1.8t Avant | '93 RS2'd S4 | '99.5 1.8t | '01 1.8t | '95.5 S6 Avant
    Established Member Two Rings bluerocket's Avatar
    Jan 20 2009
    2005 S4
    Ontario
    Items for Sale
    Wes, That is some amazing work you did there. The car looks gorgeous! I will certainly be coming to see you come spring time!!
    Account Terminated Four Rings
    Jul 04 2009
    2009 B8 Aruba Blue (discontiuned) 2.0T
    got to meet Wes today. going to book an appointment for a full detail soon.
    Dec 22 2009
    2008 A4 Avant
    Items for Sale
    One of the wrenches in the tool kit is backwards! Give him his money back!
    Seriously, beautiful restoration though!
    Current: 2008 Ibis White Ti S-line A4 Avant 2.0T 6MT
    Black Alcantara S4 Recaros | RS4 Grill | S4 Mirrors | JHM Short Shifter | RNS-e + OEM BT | BBS CH reps | Michelin PSS | KW V2 | F+R S4 Brakes | RS4 Sway Bar | 034 RSB End Links | APR Stage 1 Tune | JHM Downpipe | B7 S4 Exhaust | Apikol Snub + Differential Mount | 034 Street Density Motor + Trans Mounts
    Past: 2005 Brilliant Black A4 Avant 1.8TQMS | 2004 Arctic White S4 Avant
    Feb 01 2009
    looks awesome!
    Quote Originally Posted by bluerocket View Post
    Looking forward to it :).
    Quote Originally Posted by naemcivic View Post
    Looking forward to it also!
    Quote Originally Posted by phil@detailersdomain View Post
    looks good
    Thanks Phil.
    Quote Originally Posted by PNW Avant View Post
    LOL Thank you!
