Results 1 to 14 of 14
    Veteran Member Three Rings braker15's Avatar
    Nov 14 2008
    2000 S4 Nogaro Blue
    S.Florida
    Items for Sale
    Whining noise from the rear!?
    I've noticed a light whining noise from the rear of the car, whenever the car is in motion,
    whats the deal? is it normal?
    thanks
    2000 S4//GIAC Tune//AWE Intake//AWE DTS Bar//Cross,Drilled Rotors//18" RS4's AtItalia//Bridgestone//Pioneer Navi//more to come
    Gone: B6-APR stage II+/K04-015/ER sport fmic/Genesis 380cc/Forge 007/Magnaflow 16601/R8 reps/Prosport gauge/Koni Coilovers/K&N/badged
    Veteran Member Four Rings yungcotter's Avatar
    Jun 09 2010
    Queens
    Items for Sale
    Might be a bearing thats shot.
    -Theo
    2015 S4, Daytona Gray, DSG, Sport Diff, CTS Intake, HRE FF15, Pilot Super Sports, Bilstein PSS 10, E-Codes
    06 A4 2.0 T, Quartz Gray, Quattro, Tiptronic. OLD
    Nov 21 2009
    Arcadia/CA
    Items for Sale
    does the sound change with speed?
    b5 s4 semi-noob...b5 a4 super-noob
    '01 a4 avant http://www.pbase.com/sy0296/b5_a4
    '01 s4 avant http://www.pbase.com/sy0296/s4
    '88 m3 on going project http://www.pbase.com/sy0296/e30_m3
    '02 m3 681rwhp 110oct + meth http://www.pbase.com/sy0296/m3&page=all
    Aug 17 2009
    Pittsburgh
    wheel bearings, wheel balance or tire tread, cv joint needs greased/axle replaced, locked up caliper, rear diff oil needs changed
    Sep 14 2005
    NC
    Items for Sale
    I have the same issue. Let me know what you find
    Veteran Member Three Rings tosh2.7's Avatar
    Sep 12 2009
    Nogaro stg 3- 00' S4(dead but being rebuilt), Silver stg 3 00 S4 GF 2010 civic
    new york
    Items for Sale
    I know in my buddies s his turbos are shot and you can hear them coming from what sounds like the rear.
    *but thats only when accelerating/fluctuating boost
    Vast tested. Driver approved
    BUY my BBS REs
    tosh2_7 on instagram: Get at me
    -RAY-
    May 16 2008
    South Texas
    Quote Originally Posted by braker15 View Post
    thanks
    It could be a million things... Rear diff, propeller cv joint. Propeller shaft bearing, transmission or even tires or rear axles.
    Registered Member Three Rings AwdOwns's Avatar
    Aug 17 2008
    2015 Audi S3. 2009 Bmw M3.
    PNW
    Check your rear diff fluid level and make sure its not super low or close to empty. They like to whine like a supercharger when their low on fluid.
    Mine currently is sitting due to the same problem it sounds like your having and will be worked on today as I finally have some time off work.
    E92 M3 (tune,pulleys,i/e,suspension etc)
    8V S3 (sold)
    C4 S4 (sold)
    B5 S4 (sold)
    B6 S4 (sold)
    C5 A6 (sold)
    Established Member Two Rings BostonBlkS4's Avatar
    Jun 10 2009
    Boston / Utica NY
    i had / have this same problem. Rear passenger wheel bearing was shot, and replaced that. Now this week, the drivers side decided to die as well.
    Couple easy ways to check if this is your issue as well:
    1. Jack up your car so the wheel on the side you think is making noise is off the ground. Grab the tire at 9 and 3, and try to wiggle it back and forth. there should not be any movement. if you can move it, then your wheel bearing is gone.
    2. listen to it while you're driving. this isn't quite as accurate, but if it makes more / less noise when you're turning / the steering wheel isn't straight ahead, then its likely your bearings as well. but i recommend using the first option to make sure you diagnose the problem accurately.
    Also, i'd replace them in a pair (ie do both rears at once). apparently its pretty common for the other to go shortly after one goes.
    hope this helps
    Nov 14 2008
    2000 S4 Nogaro Blue
    S.Florida
    Items for Sale
    hey thanks guys!
    how hard is to do the bearing?
    Nov 14 2008
    2000 S4 Nogaro Blue
    S.Florida
    Items for Sale
    Quote Originally Posted by AwdOwns View Post
    yeah its also pretty loud like a supercharger in the first gear only. might be low on fluid??
    Veteran Member Four Rings seanj130's Avatar
    Sep 05 2008
    Pittsford, NY
    It is obviously the Third turbo.. You know, he is the one with a rear mount turbo!
    Best,
    Sean.
    Best regards,
    Sean.
    Paying someone to install parts and bragging about it being fast, is like watching someone
    bang your wife and being proud to raise their kids.
    Active Member Two Rings armadaray's Avatar
    Oct 29 2010
    Loudonville, NY
    id say wheel bearing for sure. my friends s4 and another friends a4 both have to have both the rears done. its so obnoxious on the highway
    Sep 14 2005
    NC
    Items for Sale
    how much estimte for wheel bearings? ....
