Results 1 to 7 of 7
    Jan 13 2011
    Montrιal
    2010 A5 2.0T - 1st gear and reverse won't engage
    It's much worst when it's cold, but also happens when the engine is @ running temperature. I have to play with the shifter, try to engage second and only then will the first engage.
    I told the service dept when I went in for my first maintenance after 8000km, but they told me there was nothing abnormal about it. Should I ditch that dealer and go to another one ? Is it really something to worry about ? Frankly, if my transmission won't break, it's not THAT important, but it is damn annoying and doesn't reflect the money I put in the car...
    Jun 21 2005
    Milton, Ontario
    Are you rolling while trying to get it into 1st gear or reverse gear? Sometimes the car has to come to a complete stop or almost to one before being able to get it smoothly in gear. Try double-clutching without rev-matching when getting it into 1st or R. For example, when still rolling at walking pace, clutch in, stick go into neutral, clutch out, clutch in, stick go into first. Same for reverse.
    – Steve
    2005 A4 Avant 1.8T Quattro MT
    • Comp Turbo Billet T3/T4 4756 • SPA clone manifold • Turbosmart ultragate • Forge 007 DV • 034 SPA 3" downpipe, de-cat & muffler delete • AEB head & intake manifold • EV14 750cc @ 4bar • Snow Performance Meth injection • Eurodyne Maestro • Bilstein PSS9 • OZ ultraleggera matte bronze w/Conti Extreme Contact Sport • B5 S4 front brakes • 034 street density engine mounts • JHM B7 RS4 LWFW + clutch
    Feb 01 2011
    Chicago
    I thought you were never supposed to put it in reverse while moving. At least in the MKIV VW 5 speeds that was a huge no no
    Jun 21 2005
    Milton, Ontario
    Quote Originally Posted by intoflatlines View Post
    Even if you tried, our tranny's have gear lock out, you won't be able to engage reverse. Unless you were rolling at a very crawling pace like 2 kph.
    – Steve
    Jan 13 2011
    Montrιal
    No, i'm not rolling when it happens, it's when I'm at complete stop that it happens. When I'm rolling, though, going from 1st to 2nd almost ALWAYS (like 9/10 times) makes scratching noise, as if the gear have troublle engaging. They do engage, but I sometimes have to push real hard. Doesn't do that for any other gear transition, only 1st to second. I've to gear up at different RPMs and the problem is there at all times.
    Mar 01 2011
    2005 Porsche Boxster, 2010 A4, 2000 F350
    Cazenovia NY
    It sounds to me like your clutch is not releasing all the way. If the input shaft is still turning or trying to turn when you attempt to put the car in gear (1st of rev), it will not go in smoothly if the clutch doesn't competely disengage. It will shift into the other gears when you are moving because you can match the engine speed to the transmission better. I'm not very familiar with the A5 clutch but if it is hydraulic, it might need to be bled. Your dealer is giving you the "tough love" treatment. There is something wrong with your car and it is probably very simple. It amazes me how poorly so many dealers treat their customers after they spent so much money on the vehicle. Try another dealer. Maybe there is one out there that cares.
    Veteran Member Four Rings audifirst's Avatar
    Feb 08 2005
    C5 A6 Avant, VW Golf TDI
    Ontario, Canada
    Items for Sale
    go to another audi dealer
