Page 1 of 3 123 LastLast
Results 1 to 40 of 82
    Dec 16 2010
    Salt Lake City
    Graphite Carbon Fiber Di-Noc and Piano Black MMI Surround Pics
    These pics are pretty bad but I thought I would show my progress to date. I am covering all the silver trim in graphite (color) carbon fiber vinyl. I also painted the MMI surround in Rust-O-Leum brand Black Lacquer spray paint. The job was easier then expected...except for the shifter trim which was a pain in the ass. More pics to come when complete.
    Dec 16 2010
    Salt Lake City
    The MMI surround has a lot of smudges because I hadn't cleaned it before the pics. It looks about perfect in real life.
    Senior Member Four Rings Sandeman's Avatar
    Feb 15 2009
    2003 MB SL500
    where the horseman roams
    look great!
    [CENTER]
    ♥ Wheel Whore ♥
    Senior Member Four Rings hender's Avatar
    Sep 13 2009
    2010 A4 2.0T
    Mississauga, Ontario
    good job around the MMI especially, those silver pieces really add a lot!
    sweet multi-spoke stock 17"s | 20% tint | crackfiller | few scratches where I closed the garage door on the bumper | 4x4 ride height | matte black hood | di-noc CF interior trim | plasti-dipped parts | pirated vag-com | 50lbs of sound equipment | couple of small stone chips on the hood | APR stg 1 | RS-Mesh Grille
    Active Member Two Rings genep's Avatar
    Nov 12 2009
    silver carbon fiber on the doors look really great. how would you rate this mod? caveman-easy, medium, or ninja?
    2009 A4, 3.2L Quattro, Prem Plus, Sport Package, Navigation
    19x10 Forgestar F14, Toyo Proxes 255/35/19, Eibach Pro Kit, Hoen fogs
    Dec 16 2010
    Salt Lake City
    Quote Originally Posted by genep View Post
    I would say everything was caveman-easy except for the removal of the trim piece by the shifter. The removal of this piece to recover it in Di-Noc was a giant pain...so "ninja" on that one.
    Dec 16 2010
    Salt Lake City
    Here is a pic of the MMI from a distance with OSIR silver trim rings around the edges of the 2 pieces.
    Registered Member Four Rings Okan509's Avatar
    Sep 30 2009
    Florida, Orlando/St.Pete
    Nice, Can you not wrap that center piece without taking it out of the car?
    (Alex)-2010 Audi A4-Ibis White-Quattro-Sport Package-6MT
    Mods: H&R Spacers-20mm-f/25mm-r, H&R Sport Springs, 20% tint, TI Grille, clear corners, black SP wheels, EUROCODE HFIP and HFTIP, aFe intake filter, AR Track rotors, VAGGED, Roc-Euro SS, etc.
    Jul 21 2008
    Really like the MMI surround. Was there sanding involved before and/or after spray painting?
    Dec 16 2010
    Salt Lake City
    It seems to me that you really need to take it out to do it right. It would be possible without removal but the final product wouldn't be as professional. IMO.
    Dec 16 2010
    Salt Lake City
    Quote Originally Posted by userbbc View Post
    No sanding...the only prep was to clean it and make sure it was free from dust. The black lacquer is not like other spray paints...you put it on a little thick and use less coats. I also used a clear lacquer top coat of the same brand.
    Veteran Member Four Rings Hockenheim's Avatar
    Jul 09 2007
    Phoenix
    Looks awesome
    Jan 04 2010
    Nevada
    Wow the paintjob on the MMI surround looks great... if that's as easy as you say I'll definitely be looking into this!
    2010 Audi A4 - 2.0T Quattro - 6MT - Phantom Black - Prestige - S-Line
    Forum Moderator Four Rings MiracleWhips's Avatar
    Jun 02 2009
    San Francisco
    Quote Originally Posted by benspeed83 View Post
    Minus the color, this looks very similar to the RS3 Sportback interior trim.
    STaSIS ECU & 23mm RARB / AWE FMIC & Exhaust / Eurocode IP / Carbonio / 034 TIP / 20% Tint / S5 Mirrors / Rotiform MIAs 19x8.5 / Hankook 255/35 / H&R Avant Sport Springs / RS6 Pedals / Hoen Fogs /Stoneguards / ecodes / A4L Fog grills
    Dec 16 2010
    Salt Lake City
    I found that the edges were chipped in a few places on the piano black MMI surround. I fixed it with some light touch-up but I now realize that I should have primed the plastic before I sprayed the lacquer. Just a heads up for anyone else considering this mod.
    New Member One Ring PHP154's Avatar
    Jan 22 2011
    Bury St Edmunds/Suffolk/UK
    The black surround looks great. How difficult is it to remove for painting?
    A4 2.0 TDi S-Line Executive 170PS, Phantom Black, 19" Double Spoke Alloys, Xenon Lights, Parking System Plus, HDD Sat Nav, Phone Prep & Heated Seats
    MODS
    Needle Sweep, Lap Counter enabled, S4 Mirrors, RS5 Pedals.
    Apr 07 2007
    B6 A4 3.0 (Wife's Ride)
    Mountain View, CA
    I was afraid this would happen to you when you said earlier 'no sanding'
    Painting requires proper surface prep.
    Suggest you remove the trim piece, strip the paint (#240 grit 3M wet/dry sandpaper), then sand w/#320 and #400 grit, prime, THEN paint.
    Takes more time, yet permanence & appearance will be worth it
    Dashboard trim removal tool set (plastic) are available from ECStuning and Harbor Freight.
    Cheers
    2009 3.2L Sedan BB/Beige. VMR V710 Gunmetal 19" Rims. Exterior Chrome Trim painted Quartz Grey. LED ROW tail lights. KW V1. H&R RSB. StopTech PosiQuiet Pads, Painted Calipers. HOEN Xenon Match Fog Lamps. Fog Grilles converted to S-Line look. Stone Guards. Modified Votex Rear Diffuser. LED interior lights, cup holder lights & door pocket lights. RS4 Pedals. Remus Mufflers.
    Dec 16 2010
    Salt Lake City
    The chipping only happened at the top edge where the plastic surround touches the underside of the dash. It happened as a result of me installing before the paint was perfectly dry. I did a slight touch up and you can't even tell.
    But, I am sure some type of prep like sanding or priming would be very beneficial as advised. I highly recommend the mod and I am very happy with the way it turned out.
    Jun 02 2009
    San Francisco
    The OSIR trim really helps the look, otherwise the MMI might be too shiny.
    I just wish the OSIR trim matched the interior aluminum trim pieces, instead of the silver rings around the gauges. I returned mine because of that.
    Senior Member Four Rings NPuter's Avatar
    Oct 27 2009
    2007 MBZ CLK350 Cab
    Miami, FL / Boone, NC
    I just picked up some rust-o-leum black lacquer to do this mod. Your results look amazing!
    I assume the clear lacquer is necessary to make the trim glossy? Was the straight black lacquer not glossy enough?
    How many coats did you apply?
    I can't wait to do this :)
    Nick (NPuter) ~ Brilliant Black 2010 B8 A4 2.0T | Build Thread | S-Line Front Bumper Conversion | Drive Select VAG-Com Codes |
    flickr: NPuter | Instagram: nputer
    Sep 30 2009
    +1
    Senior Member Three Rings jbradle7's Avatar
    Jan 09 2010
    1973 Triumph TR5T
    St. Louis
    The quality of your work looks great! Just my 2cents... the gloss black MMI panel does not tie in to any other pieces (from what I can see in the photos), have you considered using the same Di-Noc film on the MMI surround that you used on the door pieces etc.?
    Active Member Two Rings UnsavedOne's Avatar
    Nov 08 2006
    2010 A4 Avant Ibis, 2007.5 Aprilia Tuono R
    Wadsworth, OH
    Awesome mod. It looks great!
    Sep 30 2009
    Quote Originally Posted by jbradle7 View Post
    I don't think it really needs to tie in
    P.S.: for those of you possibly inspired to do this from this thread, someone please do a write up on how to remove the MMI surround :)
    Sep 13 2009
    2010 A4 2.0T
    he's right - I had the CF di noc on my MMI surround, but took it off because it was too busy...that and it started peeling
    matte black via plasti-dip looks waay better and it follows a black theme through/through. CF DInoc is still on door / dash trims.
    i owe ya one for the headlight assembly although you may not like the method i chose LOL. it sounds careless or dangerous but you really can't f*ck it up.
    i only took the faceplate off the MMI surround. this made it way easy to work with. i did such by taking a tiny flathead and just gently prying around the sides. you'll hear the glue cracking as you go around. i don't think it's possible to crack the plastic, the glue is by far the weakest connection.
    afterwards, use whatever adhesive you like (I used good ol' krazy glue, there may be better out there) to stick it back on. i know some people used epoxy - seems overboard, but it's all up to you & how much work you wanna do.
    this method, to me, seems way easier than removing the whole thing, masking off the glossy black surround (screen area) etc. etc. like others have done.
    FWIW the plastic is nothing but glued on there, not evenly or anything - just looks like someone did it by hand at the factory... you can tell because the glue will still be on there :) so you're literally re-doing what was done at the factory.
    Senior Member Three Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    Sorry to ask it here aswell, but does anybody knows the partnumbers of the dashboard surround (left vent cover + mmi cover) for the A4 B8?
    Planning to buy a new set to paint them black (and keep the old ones as backup).
    Would be much appreciated as my dealer couldn't find the numbers s:.
    Nov 05 2009
    '09 B8 A4 2.0t quattro
    FL
    benspeed, did you get a parking brake error afte removing the mmi surround? I don't know if it is a coincidence but the day I took it off, the car started having a parking brake error every time I start car.
    Dec 16 2010
    Salt Lake City
    Sorry for the late responses guys...here goes.
    In regards to the clear lacquer: the black was great by itself and I don't think the clear made any difference in shine or depth of color...maybe just a bit but you will be fine without it.
    In regards to removal: both pieces just pop right out...no screws, no glue, no problem. Just pull them out carefully and with some force. They will just pop out.
    In regards to match: the Di-Noc was too busy on the MMI surround. The black looks much better. I was inspired by the new RS5 interior. Look it up...Audi chose the same thing.
    One other note: prep the plastic with some type of primer before applying the lacquer.
    Dec 16 2010
    Salt Lake City
    Quote Originally Posted by gtg196w View Post
    Yes, I did get the parking brake error light after the MMI removal. I used my Singapore knock-off VAG-COM to remove the warning light and it never came back.
    Dec 16 2010
    Salt Lake City
    Audi RS5 disagrees with you.
    Nov 05 2009
    FL
    lol... Agreed. For anyone doing this mod, the OSIR trim is a MUST. I tried it without, and it doesn't look quite right. The trim really makes the piano black pop. If you'll notice, the RS5 uses a similar design strategy; their brushed metal trim is along that center ridge of the MMI surround piece. Since us a4/s4 guys don't have that, the OSIR trim is as close as we'll get. The only drawback is that discontinuity in the bottom transition from the mmi surround to the tacometer surround is further accentuated by the OSIR trim (I don't know about you guys, I feel like that discontinuity was a pretty major goof by audi).
    Forum Moderator Four Rings Stubek's Avatar
    Feb 13 2004
    2007 Honda Element SC
    Santa Clara, CA
    I hate that silver piece that comes with the car, its like Audi realized last minute they needed trim. I wish it matched my piano black, so this is on my list. Happy to see you testing methods for me. Thanks!
    Kevin - Moderator, Audizine
    2011 A4 Avant Meteor Grey/Black, Titanium Package, Prem+ Nav, B&O. Euro LED Tail Lights, Tint, LED license plate lights, LED interior lights, custom sub, lots of VAG updates, Eurocode Alu Kruez, Hotchkiss F/R Swaybars
    Build thread: http://www.audizine.com/forum/showth...ead?highlight=
    Feb 22 2009
    Ottawa
    How is that paint holding up as far as attracting dust and scratches?
    Oct 27 2009
    2007 MBZ CLK350 Cab
    I have all the materials sitting in my garage ready to go... I just have to find the time to actually start it...
    However, I still need the purchase the osir trim pieces...
    Sent from my Nexus One using Tapatalk
    Nov 05 2009
    FL
    AHHH... so mine is bubbling up like a mofo. lots of tiny (1mm) bubbles. Is it just the florida heat? anyone have any suggestions? I didn't prime the air vent, and that side seems better than the mmi piece. HELP. at this point I am ready (reluctantly ready) to drop 2 grand for the entire rs5 instrument cluster+trim. Something about the metal accent divider in the rs5 mmi surround is really appealing to me anyway:
    http://www.ridelust.com/wp-content/u...5-Interior.jpg
    Active Member Two Rings Kthing's Avatar
    Jun 04 2009
    Unfortunately, the MMI surround from the RS5 won't fit our cars. It looks very similar but their are slight differences.
    Nov 05 2009
    FL
    even if i replace the whole instrument cluster? not just the trim? my plan was to replace everything including the gauges. If there are discrepancies in overall dimensions, or the tab locations are different, I would really like to know (if anyone has a clue on that).
    Stage 2 Banner Advertiser Four Rings matt@oCarbon's Avatar
    Oct 19 2004
    Glendale, AZ
    I have both sets of pieces here and can take some measurements for you, but I can say for certain the trim is different and is not interchangeable. It might be possible if you replace cluster, but you'd still have to double check on the actual dash as well.
    oCarbon.com | 623.239.1500 | Glendale, AZ | matt@oCarbon.com| blog | facebook | twitter
    Senior Member Four Rings aznpxdd's Avatar
    Feb 16 2009
    2012 Alpine White BMW X1 (China)
    LA/Dongguan/Taipei
    Matt, let's show them how real silver CF trim looks :P
    -Jeff
    2009 Ibis White A4 2.0T
    Gloss Black Grille | CF Filler Plate | 19x8.5" Dark Gunmetal VMR v701's | Black Calipers | ST Coilovers
    OSIR Trunk Spoiler| H&R 5mm Spacers | 5k DS3 HID's | Luminics Fogs | VAG-Com | Silver CF Interior | K&N Intake
    Painted Front Splitter | Gloss Black Roof | Hardwired V1 | OSIR CF Rear Valence | AWE Quad Tip Exhaust
    Nov 05 2009
    FL
    Quote Originally Posted by aznpxdd View Post
    lol
    Quote Originally Posted by matt@oCarbon View Post
    matt... that would be awesome. maybe :
    1. distances between tabs
    2. length and width (from my perspective depth wouldn't really matter... as long as it's not a blatant difference)
