Page 1 of 5 123 ... LastLast
Results 1 to 40 of 179
    Stage 3 Forum Advertiser Four Rings Max@034's Avatar
    Jan 13 2009
    Fremont, CA
    Max@034's B5 A4 V6 Build Thread - 6 speed swap, turbo soon, etc
    I've modified this first page for folks just checking it out; a lot has happened since i posted this 6 months ago. The car is about to be on full standalone engine management via a 034EFI Stage IIc, along with a single turbo conversion on the stock AHA motor, running 10+ psi and going for 400whp. Theres been a lot of technical discoveries about the potential robustness of the AHA/ATQ, granted some things are addressed, so check it out:
    A few folks suggested I started a build thread for my B5. So this is a build thread for my '99.5 B5 A4 2.8L V6 Quattro. You don't see many of these with a lot of mods on them, but I got the car for dirt cheap, I like being different, and I've fallen in love with it. Despite my 100+ mile a day commute, and my absolute constant abuse of this car, it has held through besides a marred input shaft on the 5 speed V6 transmission. However, after 8k miles of even more abuse under the hands of me, it finally got to the point where something had to be done about the noise the tranny was making. Not wanting to just throw in another long ratio V6 tranny, I decided to do a 6 speed swap to an 01E transmission from a B5 S4.
    The transmission is just the first part of this cars journey; the next thing on the list is a Precision 5857 single turbo. I wanted to catalog the modifications the car undergoes, along with dyno runs, etc. Having owned a 2.8L before, I wanted to see what the potential of this engine is. Everyone is always so quick to jump into to say "go buy a 1.8T or an S4". But some of us like our little underrated 2.8's and selling/buying a car is a lot of annoyance.
    The new transmission is great. I really like the shorter ratios, and it revs about 250-300rpm lower in 6th on the highway. I had an RS4 clutch in there previously, but for some reason this new S4 clutch feels a lot better. Car feels a lot faster with the shorter ratios too.
    So here is a mod list, then a list of the necessary parts for the 6 speed swap, and then some pictures.
    Current EDITED Mod List:
    - 01E 6 speed transmission and associated drivetrain (more below)
    - B&M short shifter
    - 034Motorsport custom 2.8L tune
    - 034Motorsport Street Density transmission mounts
    - 034Motorsport poly snub mount and cage
    - 034Motorsport Street Density rear diff carrier bushings
    - 034Motorsport X34 Cold Air Intake
    - 034Motorsport Adjustable Upper Control Arms
    - 034Motorsport Adjustable Rear Swaybar endlinks
    - 2.5" custom catback exhaust w/ resonator and Vibrant Stealthpower dual 3" outlet muffler
    - 034Motorsport High Flow Cats
    - Stasis Ohlins Mototsport Coilover suspension
    - Porsche Boxter 4 piston front brakes with A8 312mm rotors
    - B5 S4 rear brakes with vented 252mm rotors
    - 17x8" Rota Torque rims w/ 255/40R17 Conti tires
    - Full exterior S4 conversion (nearly complete)
    6 Speed Swap Parts:
    - 01E transmission from a B5 S4
    - 01E bellhousing spacer (DON'T FORGET)
    - 01E shifter linkage, stabilizer bar, and crossorod (there is an early/late version)
    - 01E clutch and flywheel and pressure plate
    - 01E throwout bearing release arm
    - 01E transmission mount brackets (bracket from tranny mounts to tranny housing)
    - 01E shifter box and shifter (you can use 5 speed, but you'll have to push down to get into 6th)
    - 01E driveshaft heatshield
    - B5 S4 rear diff from 6 speed
    - B5 S4 driveshaft from 6 speed
    - B5 S4 front axles from 6 speed
    - B5 S4 or B5 A4 V6 uprights (to fit the S4 axles)
    About to be Installed:
    - Precision 5857 turbo with .82AR
    - 034Motorsport 034EFI Stage IIc standalone engine management
    - 034Motorsport Plug In Engine Harness, motorsport spec coated/sealed
    - Large FMIC w/ custom piping
    - B5 S4 intake manifold w/ 30v DBC throttle body
    - 034Motorsport Phenolic transistion intake manifold spacers
    - 034Motorsport 2.8L exhaust manifold flanges for single turbo conversion
    - AEM methanol injection kit
    Notes: B5 A4 rear axles fit if you swap flanges on the rear diff. Reverse light is a 5 pin Bosch female on the V6 tranny; it is a 2 pin Bosch female on the S4 transmission. Heatshields for axles can swap over; driveshaft heat shield does not. Everything else swaps right in.
    Jan 13 2009
    Fremont, CA
    Also, while I know its more "feasible" to buy a 1.8T or an S4... I already own those cars. I wanted to do something different and fun with the V6, that will give me about 250whp with 8 or so psi. Kit is all planned, just need to get the S4 working before I tackle any other projects.
    Senior Member Three Rings Ldiaz12's Avatar
    Sep 18 2009
    Lynn, MA
    I'm glad you chose to be different, another reason to visit the forum. That intake ....will it work fine with the 2.8 12v? I really like it.
    Laser Red A4 12v
    Current Mods: Bored XTB, KN filter, Darintake,
    Soon to come: PP IM, Bored MAF
    Senior Member Four Rings somebody5788's Avatar
    Aug 13 2008
    Indiana
    Sweet project =D, looks to me like an early 99 not a 99.5 though. How can I get a job at 034 so I can just do a project like that??? lol.
    Just be sure your oil system is in top shape (I recommend sea foaming it or something) Also I'd recommend meth injection as well as a quality front mount. 250AWHP is about the limit for this engine before the pistons fry but I think with some precautions it's possible to get on a daily driver and not have any long term side effects.
    Might check out scaudi.com even though you are looking into a turbo they have more information then anyone about boosted 2.8's. And there are several with built engines (usually from blowing them up at 10 psi...)
    -Nic
    2011 Honda CBR250R - gas sipping toy
    2001.5 Audi S4 - APR 93/100 | 710n's | EvoMS intake | RS4 clutch | RS4 Grill | Plasti-Dip'd center console | Podi gauge pod | VDO boost gauge | TSX-R clear lenses
    1994 Suzuki RF900R - It needs some love but it'll get there!
    1994 Jeep Grand Cherokee - rattle canned OD green Zombie Response Vehicle
    Active Member Three Rings brettj20's Avatar
    Nov 20 2010
    everett pa
    its about time someone wants to do something with a v6
    Senior Member Four Rings geeky's Avatar
    Nov 02 2008
    Boulder & Seattle
    Nic, is the the actual pressure thats causing the piston issues or the volume of air being moved? on that note, how much air does a G1 or G2 move, anyone have a graph I can look at?
    1999 Audi A4 1.8TQM AVANT (Current)
    CXracing FMIC | APR Ecu | Podi Gauge Setup | eBay SS kit | DieselGeek Skid Plate | ST Coilovers [slammed at 23" gtf]
    Soon to be installed: FT Kit | 440cc Green Top | GIAC 440cc File | CM FX300
    1997 Audi A4 1.8TQM (SOLD) | 2001 Audi A4 1.8TQM (SOLD)
    Active Member Four Rings coolgraymemo's Avatar
    Jun 10 2010
    Northern California
    i like that sound...
    - Memo
    SSR Comp. STaSIS S/S. GIAC. Forge. Valeo E-Codes.
    Apr 27 2010
    seattle/WA
    that exhaust sounds great man, i look forward to the rest of the build.
    2001.5 A4 TQM
    Unitronic Stage 2/APR exhaust/2.5" test pipe/Intake
    JHM Shifter/solid linkage/AWE DTS/034 Weighted Delrin knob/Apikol Rear diff mount
    ST's/Keskin KT1 18x10ET25 18x8.5 ET30 and some stretch
    2.1L 9.5:1 Stroker/Built AEB head/PAG 5857 kit... under construction.
    Active Member Two Rings v3n0m's Avatar
    Sep 23 2010
    Kent, WA
    Yeah nice project, and i think, so far that is the BEST exhaust I've heard on a b5 a4. Thats my opinion, not even close to ricy. Thats the exact exhaust i want, to sound like a v12, and not a rocket.
    Veteran Member Four Rings Silverstreak98's Avatar
    Dec 11 2006
    Minnesota
    Looking forward to following this thread Max!
    Also curious what modifications, if any, you had to make to the intake to get it to work for you 30V? It looks great, I'd probably buy one in a second if it wasn't a hassle to make it work.
    Senior Member Three Rings shokwav09's Avatar
    Jul 26 2009
    alot of ideas with never enough cheese
    kansas city, missouri
    when you said everything else swaps right in, does that include all fasteners and bolts?
    since i was a child, everytime i saw a lamborghini, it represented a mans risillience to oppose an imperfection. and i swear god blessed ferrucio and his honor to stand the trial of time through ingenuity.
    Senior Member Four Rings Dan[FN]6262's Avatar
    Sep 12 2008
    02 A4, 94 GMC, 06 450R
    South Central Pa, Dundalk MD
    are you going to make a custom manifold for the single turbo, or just pick up the OEM V6 single turbo exhaust mani that audi produces?
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
    Aug 13 2008
    Indiana
    Quote Originally Posted by geeky View Post
    Supposedly it's the pressure. I'm not entirely sure. I would think it's the heat myself as they actually melt lol. But supposedly its because the ring seizes.
    -Nic
    Veteran Member Four Rings .Mad Hatter.'s Avatar
    May 07 2007
    Quote Originally Posted by somebody5788 View Post
    This, awesome either way though Max!
    Aug 13 2008
    Indiana
    How much would an exhaust like that run for my supercharger?? lol
    -Nic
    Jan 13 2009
    Fremont, CA
    Quote Originally Posted by Ldiaz12 View Post
    Its the passenger head that causes a bit of a fitment problem. I just jammed the heatshield in there and it stays in place nicely, lol.
    Quote Originally Posted by LightSwitch View Post
    Quote Originally Posted by v3n0m View Post
    I'm quite fond of the sound myself. I'm excited to get some turbo noise in there. My S4 is hands down one of the best sounding cars I've heard, and thats not just to stroke my ego lol.
    Quote Originally Posted by Silverstreak98 View Post
    The heatshield itself fits in there pretty good; it won't bolt up, and its a bit of a squeeze at the front end, but as you can see, it looks great. Its not a factory fit like it is in the S4, but nice. However, there is a problem; the MAF. The 2.8L MAF uses a MAF with a 4 bolt flange, so you need an adapter plate. You can see my adapter plate in the photo.
    Quote Originally Posted by shokwav09 View Post
    Pretty much. Swap the axle flanges on the rear diff, all the bolts can be reused, the driveshaft support bolts up, etc etc. You'll need the shorter hardware for the transmission brackets, and the hardware for the throwout release arm, and hardware for the linkages, etc. But the major stuff bolts right up.
    Jan 13 2009
    Fremont, CA
    Quote Originally Posted by Dan[FN]5857 View Post
    I was thinking about trying to grab one of the OEM pieces, but it is going to be so easy to fab up some flanges for the stock manifolds and run the pipes up from the collector/downpipe flanges. I'm going for a used turbo, and as many used components as possible to keep cost down since this is just the initial setup.
    Quote Originally Posted by .Mad Hatter. View Post
    Oops! I am teh sux
    Depends on the shop you use. I have high flow cats, an AWE 2.5" bullet resonator, and the Vibrant Strealthpower 2.5"**>dual 3" muffler.
    I used that specific muffler because it is the same one I use on my S4 (albeit the one on my S4 is 4" instead of 2.5");
    Active Member Two Rings Trisha90's Avatar
    Aug 07 2009
    Minnesnowta
    that video is of your S4??! nice, my boyfriend found this video a couple weeks ago and really wants to do this, 4" sounds really good
    Sep 12 2008
    Quote Originally Posted by Max@034 View Post
    that was my thoughts also.
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
    Jan 13 2009
    Fremont, CA
    Quote Originally Posted by Trisha90 View Post
    Yep my baby. That was on K03's. The car is now on GT28R. Should be interesting to hear what it sounds like when its done.
    I am itching to do the turbo! I almost wish my S4 was working more so I could do the A4 project, then to be able to drive the S4 finally after months of it being down. It is looking more and more simple to me. Plus, I am having turbo withdrawal.
    Senior Member Three Rings Coopa's Avatar
    Apr 20 2009
    Fit Eddie v3
    Longmont, Co.
    This!^ Gt's in s4s are just insane.
    Looking for some decent condition ST's or Vmaxx's.
    Jan 13 2009
    Fremont, CA
    Quote Originally Posted by Coopa View Post
    Should be a lot of fun. Originally, it was going to be my track car, but now I've decided to keep the S4 as the daily driver, the A4 V6 as the beater, and my A4 1.8T as my racecar. I've still got 1 more A4 chassis I dunno what to do with. Shooting for about 500whp as the starting point.
    Classic: owning 4 Audi's and only 1 works.
    Veteran Member Three Rings bandit's Avatar
    Feb 18 2006
    Allentown PA
    I really like the fact that you're trying to do somthing new but I don't see the point of having a GT'd s4 and a turbo V6 A4 as a daily driver or beater so to speak. I'd just keep the A4 clean and maintained and not have to dump cash into both cars when they break.
    Enjoy yo self
    Senior Member Four Rings NeedingAnAudi's Avatar
    Mar 16 2009
    99.5 A4 1.8TQM 00 A6 Widebody
    Lombard, IL
    Quote Originally Posted by bandit View Post
    Your logic doesn't make sense since Max works at 034. They can't keep their hands off anything
    Brilliant Black B5 ..... 15k on Street Built Engine
    Strictly Pleasure/Zero Clearance/Stretch Your Legs
    Alex
    Will work on Audi/VW in Chicagoland
    Feb 18 2006
    Allentown PA
    Quote Originally Posted by NeedingAnAudi View Post
    Seems dumb to slap a turbo on a N/A V6 just to run 6psi
    Enjoy yo self
    May 07 2007
    Seems dumb to slap a K04 on a 1.8t just to gain 30hp, but guys do it.
    Edit: noticed your sig. after I typed that...even more applicable now.
    Senior Member Four Rings Euromike's Avatar
    Oct 03 2008
    B5's
    Pittsburgh
    a RELIABLE 6psi
    not all of us can afford 2.7TT's blowing shit up all the time lol
    Summer: 99 Laser Red 2.8QM. Freshly Built Engine ** 6 Angle Valve Job ** K&N Intake ** Full Custom Stainless Magnaflow Exhaust ** LED Fogs ** HID's ** Facelift Lights F/R ** BBS RC's ** Black Leather Swap ** Debadged ** RS4 Gril ** Sony H/U w/ 2 Volfenhag 12's.
    Winter: 98 Santorin A4 quattro 5sp. ** Facelift Lights F/R ** Debadged ** Magnaflow ** K&N Intake ** LED Fogs ** HID's ** Avus S4's (FOR SALE)
    Apr 20 2009
    Fit Eddie v3
    Longmont, Co.
    I see this evolving into something more than 6psi & smallish turbo at some point.
    Senior Member Four Rings Turbo Nerd's Avatar
    May 12 2009
    Built A4, 08 Charger R/T
    Detroit Metro Area
    I swear I laughed so fu*king hard I spit mt. dew on the computer lmaoooo
    B5 Casa A4 with a built motor that isn't in the car and a PTE 6262 BB .83 A/R that going sing lag city b*tch lag lag city b*tch.
    Sep 12 2008
    Im loving having boost. I just threw a PTE6262 on my 1.8
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
    Feb 18 2006
    Allentown PA
    PC-16 is a little more than 30hp bud, and its called "budget" for a reason.
    Enjoy yo self
    May 07 2007
    It's actually not much more than 30 (over a chip)...and you can do an elim. turbo for just about the same price.
    AAAAAAAAAAAAAAAAnyway.
    Feb 18 2006
    Allentown PA
    uhh no. Chipped hp on a 150hp 1.8t is 197ish, PC16 is 265 and almost 300 ftlbs. Apparently canadians can't do math.
    Enjoy yo self
    May 07 2007
    Don't get upset. After exhaust and all the stuff you need for a K04 anyway, you are about 30hp more with a k04. Hell, even 50hp more, you're in pretty deep for a minimal return... :)
    Sorry Max...back on topic. This build is unique, and at the VERY LEAST, some of the 2.8 guys will have a good resource for their options.
    Feb 18 2006
    Allentown PA
    It's ok Hatter I'm not upset, I know math is tough and everything.
    Enjoy yo self
    99.5 A4 28RS 1.8TQS VolcanoBlk
    Vancouver, BC Canada
    I like the way you still have those rear badges on hahahaha. (so stealthy, sleeper look until they hear your exhaust)
    SUBSCRIBED to this awesome build.
    David L.
    www.VancouverAudiClub.ca
    99.5 A4 GT28RS 1.8TQSM Volcano Black & 99 CW Acura Integra Type-R #0010
    Go-Unitronics/GT28RS/ATP/Bosch/Bailey/HKS/Blitzkrieg/FMIC/Southbend/Fidanza/Greddy/Innovate/Walbro
    Footworks-Roti BLQ/Flik LEX/Bilstein/Eibach f800 r900/Neuspeed/034/Stern/APR/Redline
    Misc-Porsche/S4 rear/Goodridge/Motul/Rieger/A!/Ecodes/RS4/V&S/Sparco/Podi/Blitz
    Soon-Eurodyne/Siemens/SnowPerformance
    Sep 12 2008
    this conversation is/was hilarious.
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
    Senior Member Three Rings anmagro's Avatar
    Sep 14 2008
    98 Audi A4 2.8 30V 5spd Quatto
    wow! this is great! i cant wait till you get this figured out with the tune and everything!
    please please if there is a single request for us 2.8 guys in this build, it is to try and have the turbo run on the stock internals and see what kind of power numbers you can get from there! and if all is well, show us your dam tune! tuning has always been the biggest problem for the 2.8 weather it be in a supercharger or even turbo.
    lookin good with the exhaust keep it up!
    Black On Black 98' Audi A4 2.8L 30V 5spd. Quattro "Esabell"
    BBS RK's - Zimmerman - Vogtland Sports - Thrush Welded Cat-Back - DDM 6000 - Reigar RS4 - K&N Spectre - EbaySS - SpeedTuning Stage I
    You know your an Audi freak when you check audizine before you leave rather than facebook
    Senior Member Four Rings viceprp's Avatar
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    I once thought doing a k04 would be a great mod but then I noticed the little gain that you get out of that snail. The only benefit that you get is the low end torque and the additional 30whp with a loss in mpg. The difference in your build costs is probably $300 and Mad will get an additional 80miles on his tank than you. So in ~32 fill ups, ~8 months, Madd will make up that "lose" and you will be the one throwing money away from that piss poor mileage. Also, Mad also as 30+whp then your k04 and matching torque. Making his DD, mathematically, a better choice. Maybe you should have put the time in to figure that out on your own.
    Max, we look forward to the numbers that the 2.8 pushes out. Like some of the 2.8er's have said, post up some stock block friendly numbers and a tune with it. Will you guys be making a kit once all is said and done?
    ATW 1.8TQM | SCAT | FX400 | GTcougaR | AEM Standalone | Meth
    PM ME: Parting out all Stage I parts
    STEVE
    Jan 13 2009
    Fremont, CA
    Whoa there fellas! Don't get your panties too much in a bunch!
    K04 on the 1.8T is perfect for most folks who just need a bit more top end and a slightly more reliable turbo setup (pushing 16psi through a K04 is more reliable then pushing 16psi through a K03). However, yes, it is barely more to start throwing on a GT Eliminator, but you are opening up the possibility of more issues simply by running more power.
    The point of this build is not practicality (none of my projects ever are, except for my track car possibly), but moreso the fact that I don't know how to leave anything alone. So instead of dropping in a VR6 with a GT35R on it, I figured doing a small, easy, and low pressure turbo kit would be a great alternative.
    I am obsessed with boost; especially displacement with boost. The 2.8L V6 is pretty fun already, and its been enough to give me 3 speeding tickets in the last few months and the top end power is just fine, but I feel there is a lack of low end power. I have a very long commute that involves about 3000 vertical feet of elevation gain on the way home in a short period of time.
    A GT2871 running under 10psi should be plenty to give me a nice horsepower boost, but without much risks. While the AHA/ATQ isn't as robust as the 2.7T APB, it isn't a piece of crap either. I have plenty of faith that even my 175,000 mile engine will be ok. But the other reason I want to do it, is simply to find out and to help the community. I want to know what the max power output is the 2.8L can handle, and superchargers just aren't the same so I do not think its fair to compare. I firmly believe a turbo 2.8L can put down more power safely then a supercharger. However, I also have the advantage of working with a dyno, so I can get the car tuned very safely.
    I will be running our 034Motorsport Wideband Controller, which besides being awesome and having barometric pressure correction, it also has EGT so I can keep an eye on everything and make sure nothing runs to hot and lean.
    As I've mentioned a few times, the goal is simply 250whp, which is a bit of 300bhp at the motor. This is about the power of a Stage 1 B5 S4, and having owned and driven many Stage 1 S4's, they are at a perfect power level for daily driving. Considering I don't track this car at all, I'm going to be running a fairly small intercooler, but for safety, I will be running meth injection too.
    You my friend could not be more correct. My original plan was to pickup an A4 and use it as the daily driver, and make my S4 the weekend/track car. However, awhile back I decided that I wanted my S4 as my daily driver, since the car is surprisingly comfortable with the Ohlins Motorsport suspension and such. What this means is that eventually, this B5 2.8L V6 will become the project car. I also made this decision since my S4 has a clean title, and my A4 has a salvage; I'd rather have the project car be salvage.
    Quote Originally Posted by viceprp View Post
    Part of this project is to check out the viability of producing a kit. Making one isn't going to be that difficult, but unless we can sell 10+ a year, its probably not something we will produce on a larger scale. Doesn't mean the kit won't be available on a semi-custom basis, but we won't know anything until I finish my own and see how it runs. So if it ever is going to be available, expect it to be a year away.
