Results 1 to 19 of 19
    Established Member Two Rings sparkx's Avatar
    Apr 07 2010
    2008 rabbit, 2002 a4
    San Clemente, Ca
    vibration issue and tires feel out of balance around 70-80+mph
    Alright hear me out please. I've checked everywhere on Google and on all Audi forums and I cant seem to figure out what the heck is going on with my car. I have consulted too many mechanics to count and they cant seem to figure out what is going on. I have found that unless you drive an Audi you don't know what goes on with them. Anyway my b6 02 starts feeling like the tires are out of balance at around 70-80+. I have had it aligned, balanced, rotated and even got new tires and rims. Still no fix please if someone knows what might be wrong or has experienced this same anomaly post something. Also I have lowered it and put wheels spacers and its neither.
    A4 B6 afe cold air intake, magnaflow catback system, test pipe, H&R sport springs, koni yellows, blacked out oem 17's, H&R 8mm spacers, EBC rotors and Green stuff pads
    Veteran Member Three Rings achilleas101's Avatar
    Mar 09 2010
    2015AcuraRDX
    Falls Church, VA
    have you always had this problem? what kind of tires? I know Contis sometimes have minor 'flat spots' when cold, but once they heat up it goes away. I experienced this with my old stock ContiSports. I've heard other summer tires have it too, but it's been constant from day one, and keeps happening after a long time of continuous driving, then i don't know what to tell you.
    Apr 07 2010
    San Clemente, Ca
    no i have nexen tires theey are 235/45 zr17s and its all the time thanx though bro
    Veteran Member Three Rings akalito's Avatar
    Jun 09 2010
    2005 B6A4 USP
    Rockland/NNJ/Buffalo
    Items for Sale
    are you on aftermarket wheels? maybe you need hubrings or maybe one of your rims have a slight crack. check your wheels out
    Stage 2 Banner Advertiser Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    Worn control arms can cause that issue as well, typically the front upper control arms require replacement at around 70-90k. Also make sure you install spacers and wheels in the air with zero load on the tire, use the E-brake or have someone step on the brakes and tighten the lugs to 89 Ft-Lbs first in a star pattern, followed by a circle. Be sure that you get 6.5 turns of thread engagement on the lug bolts. Be sure that you are using the correct ball seat or cone seat lugs for the wheel.
    Achtuning is the largest stocking APR and Hartmann dealer in North America!
    Check out our Blog at ACHTUNING.com!
    Facebook.com/ACHTUNING!
    Twitter.com/ACHTUNING!
    Sales@Achtuning.com 1-877-722-4886
    Apr 07 2010
    San Clemente, Ca
    Quote Originally Posted by akalito View Post
    someone else was saying something about the hub rings. where are they and what do they do?
    Apr 07 2010
    San Clemente, Ca
    Quote Originally Posted by Skyler@Achtuning View Post
    what do u mean by the zero load i cant just slap them on and drive? shit i wish someone would have told me that before i put them on and as they are stock 17s i had the 15s on but upgraded to the stock 17s . would that be considered aftermarket being that they originally had 15s and are set for the that size and i lowered it on koni yellows and h&r sport
    Senior Member Two Rings jdigga99's Avatar
    May 13 2010
    BMW 330i
    Katy, TX
    I'm thinking it's time for my control arms to be replaced...my suspension squeaks SO much and there's a slight wobble at higher speends sometimes.
    "I'm in a silver bullet, caviar in the guts. 4 rings in her nose, a 3.0 on her butt..."
    Audi 3.0 group |VMR 19" 708's| Adam's Rotors - Race F&R|
    Veteran Member Three Rings AvantinUSP's Avatar
    Jul 28 2008
    Items for Sale
    take off your spacers and drive to see if you have any vibration. if there is and you know your wheels are balanced and not bent it could be your axles. or even put on your old 15's and see if you got vibration.
    Senior Member Three Rings Coyote USP's Avatar
    Oct 03 2008
    '78 Honda CB750K
    Dallas
    Items for Sale
    Wheel bearings?
    USP CLUB MEMBER #123
    The Awesome™
    Kyle
    Apr 07 2010
    San Clemente, Ca
    thanx you guys ill try taking off the spacers and see if its that. also ill check the wheel bearings but if anyone else knows what it might be or know what it is please let me know
    Dec 31 2010
    Berwyn,IL
    Yeah check all suspension parts. What happens does the steering wheel shake or the whole car and is it dependent of speed or engine RPM cause it could be a drive line vibration.
    Apr 07 2010
    San Clemente, Ca
    Quote Originally Posted by Rausch View Post
    the steering wheel shakes and u know how when u have a wheel out of balance and yer car vibrates? thats what it feels like. its based of speed not rpms cuz it doesnt do it through out 0-55 and u feel a slight wheel shake between 55-60 then. and at around 73-80+ its bad
    Oct 08 2009
    1966 mustang sprint
    Atlanta
    When I got new wheels and tires they balanced them for me, I drove it a few days and at 75+ it started to vibrate....went back and had them rebalance them after the tires had gone through a "heat cycle" you could call it. Problem solved.
    ecodes, 034 hfc, custom 3"downpipe, 3"mid pipe, 2.5" splits, magnaflow mufflers, quad exhaust, revo stg II tune, K&N drop in, EvoMS diverter valve, TSW Nurburgring wheels.
    Jan 24 2007
    sounds like you have worn control arm bushing like Skyler@Achtuning said. Like everyone said check your suspension for any wear like tie rod ends and control arms. Also it could also be tires have flat spot too, you said your wheels were balance was it road force balance? If not try road force balancing the wheel to see run out and radial spec, if they are out the shop has to force match the tires and rims.
    Veteran Member Three Rings NuVega's Avatar
    Feb 06 2010
    2009 Audi A5 3.2L V6
    Las Vegas, NV
    If they are aftermarket rims, check to make sure the centerbore is the same as factory, if not, that is probably the cause of the vibration. I have A5 replicas, and they have a centerbore of 66.1 or something like that, and the factory centerbore of a B6 is 56-57, at speeds you mentioned I was getting vibration. I had to get centerbore adapters, and afterwards vibration gone. Check into that possibly.
    May 21 2007
    13 S4
    Northshore, MA
    Items for Sale
    take the wheels and spacers off and clean the hubs of any rust/corrosion. also, how old are the nexen tires? those tires are junk and could be a culprit.
    and of course, check suspension components.
    -Nate
    Current: 2013 Ibis White S4
    Mistake: 2008 BMW 135i
    Previous Audi: 07 Ibis White A4 S-Line Ti Package [SOLD]
    B7A4 Build Thread: http://www.audizine.com/forum/showth...58#post7310258
    Apr 07 2010
    San Clemente, Ca
    found out what it was its my control arms the bushings are cracked and worn. all four of the top arms look like i took a meat grinder to them. thanx u guys u helped a lot i just went into the shop and told him what to look for cuz the first time he didnt notice anything. then what do u know he said he must have missed that the first time. hahaha anyway 600 dollars later good as new.
    May 21 2007
    13 S4
    Northshore, MA
    Items for Sale
    i would stop taking my car there.
    -Nate
