Page 3 of 3 FirstFirst 123
Results 81 to 104 of 104
  1. #81
    Senior Member Three Rings r0n's Avatar
    Apr 02 2004
    The City
    Quote Originally Posted by B8_RDC View Post
    Installed the intake yesterday. Really straight forward and took 20 min or so. Immediately noticed low end increase, as I take the same turn every morning and with the same throttle. This morning I had a holy crap moment as I sped off faster than intended.
    When I first saw the pic I said to myself that pipe is going to get really hot and going to need some kind of heat wrap. I guess you found that out. I would have done the same thing and probably go a step further by having it ceramic coated.
    Btw good to hear there's a noticeable difference.
    09 B8 Avant / Meteor Grey / Prestige / ADS / Mods in slow progress
    01 B5 1.8QTM -Silver/K04/IC Upgrade/GIAC 5 Prog/ABT Exhaust/ H&R Coils/ecodes w/55w ballast 6K/Short Shift/Porsche front brakes/Still Slow
    97 BMW E39 / White/ H&R Springs / Hartge 19" reps / 01 exterior updates / ecodes w/ 55w Ballast 6K
    72 Datsun 240z - Viper blue / 2.8 FI / T3/TO4 Hybrid Turbo / Haltech ECU / `12.05 @ 118mph / Hypertech coilovers / Wilwood Big brakes / LSD
    07 Suzuki GSX-R750 - Blue/Red
  2. #82
    Active Member Two Rings oc cc's Avatar
    Oct 14 2011
    OC
    This thread did not help my confusion at all..... so DOES it provide increased power? Or is all we have to go by just butt dynos?
  3. #83
    Senior Member Four Rings Okan509's Avatar
    Sep 30 2009
    Florida, Orlando/St.Pete
    I love how this thread is filled with dick jokes...
    (Alex)2010 Audi A4-Ibis White-Quattro-Sport Package-6MT - http://www.audizine.com/forum/showth...mods-pre-shoot
    Mods:Spacers-15mm-f/25mm-r, Debadge, 20% tint, black grill, clear corners, Plastidipped wheels, 034 high flow turbo inlet, intercooler pipe, AR Track rotors
  4. #84
    Sep 30 2009
  5. #85
    Apr 04 2011
    Jacksonville
    I did a lot with intakes in my Mitsi days. As my car went from a stock 195 hp to 400 AWHP I made many intake changes and tests. All I can say is, at some point above stock, ANY stock intake will be restrictive enough to not enable to turbo to spool, bite into the air, and actually suck it into the engine the air it needs as freely as it needs it. Do a milkshake test next time you are at McDonalds. Buy a yummy milkshake, and grab a swizzle stick (coffee stir-stick for this of you with lower IQ's)(JOKE), put it in the milkshake (taking the top off is probably easier) and take a big, phat suck! What do you get, nada! Now put your McDonalds Straw in the shake and take the same big phat suck, what do you get? Brain freeze! Why, the vacuum you are creating by sucking (turbo spooling) requires more shake flow than your intake (swizzle stick) can accommodate.
    At what point does our Audi need a bigger straw? I am not sure. In my Mitsi days we noticed 2 things when we actually hit the point of needing more pre-turbo intake flow. The turbo spooled faster (need a boost gauge and video camera or a data logger that can watch boost to measure), and we saw top end power did not tail off as much (need a dyno to test this). The funny think was watching the MAF was not a really good, clear indicator, though we all thought it should be. I also noticed once that changing my intake meant I needed to change the fuel parameters to maintain the same AFR in the top end and as the turbo spooled up (don't ask how I saw this if you think this thread I am writing is long and useless and boring, as explaining that would take even more time.)
    As for heat soak from the piping to the air......if you take into consideration the air velocity moving through that pipe and the surface area (amount of contact the air mass has with the walls of the pipe as it flows through) the heat soak effect is MINIMAL (wrapped or not). Plus, remember as soon as it goes through that pipe the air hits our little hair dryer of a turbo and gets super heated anyway (even the KO4 is a hair dryer, just one for CA Blondes vs Boot Camp Marines). The biggest and best way to cool that air is to do some kind of improved intercooler, as the few degrees it may pick up in the intake are immaterial in the big scheme of things. Now if, for example, the stock intake drew air from INSIDE the engine compartment, then in hot weather you might see a 50-100 degree drop in intake temps with a CAI, which would be material.
    Remember too the piping from the turbo to the manifold is like a very long straw. Here too gains can be had as HP increases. Going from 1.95" stock Mitsi to 2.25" before the FMIC and 2.5" after made a huge difference on my car, even at relatively low HP over stock. Experiment with this, take that McDonalds straw, slide another one on top so its now twice as long and take that same big suck.....its harder to get your prize (or the straw collapses).
    IMHO, based on the little I know about our cars, I would think if you are going to stage 2 APR Tunes w/full exhausts or above you should defiantly get some kind of CAI AND new intercooler piping (esp replace the stock, plastic sound chamber thingy post turbo), AND FMIC.
    The real bottom line, if you get it and feel a difference then enjoy it! If you get it and don't feel anything.....return it.
    OK off my soap box.......guess I had too much coffee this morning! :)
    2011 Ibis White Ti, Premium +, APR Stage 2 ECU, APR Full Dual Exit Exhaust, Carbino, dyno correct 248BHP-376 lb/ft, 40% 3M Crystalline "7 window" tint, 90% 3M Crystalline Windshield tint, 90% em Crystalline Sunroof tint, Curt 1.25" trailer hitch
  6. #86
    Active Member Two Rings brinesi's Avatar
    Nov 14 2011
    Sound clip, please?
    '12 P+, S-line, NAV, OEM Sport Package
    HR OE Sports, HR 15mm spacers, 3.2 Grill, Gloss Black painted surround
    Wincos 45 tint, Rieger replica rear trunk lip, VAG COM mods, Festoon LED license plate bulbs
  7. #87
    Active Member Two Rings STA4's Avatar
    Jan 12 2012
    Mississauga, ON, Canada
    After reviewing the airflow and dyno charts of various systems, I've decided that I will simply replace the stock filter element with a K&N filter charger and replace the turbo inlet tube (cheap and looks good). Then I'll put the money that I saved towards the Eurocode FMIC package. The stock intake seems pretty efficient.
    Peter
    2009 A4 2.0T Quattro Premium 6MT
    Meteor Grey/Black | B&O | STaSIS ECU/Exhaust/Springs/RSB/Rims | K&N Filter | Eurocode TIH/HFIP/IHK/HFC | Strat O2 Spacer | BFI OCC | Podi Boost Gauge | Rieger Rep Spoiler | LED Interior/Doors/Plate | 5000K HID Foglights
  8. #88
    Oct 14 2011
    OC
    Arrgg, so tempted to get this CAI.... why couldn't life be simple, damn you atmospheric physics! So the consensus is our intake is efficient enough?
  9. #89
    Active Member Two Rings AllBlackA4's Avatar
    Dec 01 2010
    i have the injen cai and i love it just saying...
  10. #90
    Jan 12 2012
    Quote Originally Posted by AllBlackA4 View Post
    Are you loving the induction sound or did you feel it on the "butt dyno"?
    Peter
  11. #91
    Active Member Two Rings blackavant's Avatar
    Jun 03 2010
    I had the injen intake on my car. The intake sound was great, but I could not get over the high pitch squealing/whistle sound from the turbo's compressor wheel spinning and also my millage went from 20mpg to around 15mpg city driving.I honestly did not notice a difference in terms of increased power but it did sound awesome after you get passed the squealing sound after 3k rpm. I had it on for about a month and took it off. Btw I still have the intake, if anyone is interested pm me.
    Here is a sound clip of the intake installed in my car:
  12. #92
    Active Member Three Rings rayray's Avatar
    Sep 17 2010
    '10 Audi Q5 Prem Plus
    San Antonio, TX
    Not convinced that this setup provides any gains, performance or sound. I get better sound from my K&N filter in the stock box.... just saying.
    -Ben-
    '11 A4 Prem Plus Quattro 2.0T | Teak Brown | Got sum mods | She got Vag'd | #lovethyaudisedan
    '10 Q5 Prem Plus Quattro 3.2L | Meteor Grey Pearl | Got sum mods | She got Vag'd | #lovethyaudisuv
    My Audi Fotos
  13. #93
    Dec 01 2010
    Quote Originally Posted by STA4 View Post
    i felt an immediate increase in low-end power
  14. #94
    Active Member Three Rings maga4's Avatar
    Aug 12 2011
    Olathe, Kansas
    Definitely has a whistle/whine to it, not sure if it is too much or not...
    2011 A4 Premium+, Quattro, 6MT, 18" OEM 5-spokes, Nav, Black/Black
    APR Stage 1, 35% Tint, Eibach Pro-Kit, Vag-Com, Gloss Black 3.2 Grille, Hoen Endurance Fogs, LED Interior/License Plate Lights, Strat Short Shifter, BFI Catch Can, Eurocode TIP/TRUFit Kit/HFIP, Hardwired V1, Rieger Lip Replica
    '91 Audi 90s Quattro, 5MT, White, stock
    Past: '98 A4 1.8TQ, Tip, Red / '99 A4 1.8TQ, 5MT, Black, Sport
  15. #95
    Dec 01 2010
    you get used to its not not that bad
  16. #96
    Active Member Two Rings gunsmoker's Avatar
    Oct 24 2011
    2007 IS250
    Mansfield,MA
    I decided to go with the aFe Pro Dry S filter and the stock box. Based on their data this one is better than their oiled filter (Pro 5 R) in terms of filtration and has the same flow. It's dry, not oiled, and is also washable. Ordered it yesterday so I can't say how it performs yet. It's a little bit more expensive than K&N - $65 shipped. I was going to go with the Carbonio, but looking at it - $450 for an oiled filter and some carbon fiber cover looks like a joke to me.
  17. #97
    Senior Member Three Rings A4 Centaur's Avatar
    Jun 05 2009
    2008 Ducati 848, 1199 Panigale on the way
    Colorado Springs Colorado
    Intake discussions. Interesting.
    When I was doing this in a previous life I discovered that a flow bench and the results need to be shown to prove any actual gains.
    The Tdi forums and any other number of performance forums have beat this subject to death. I don't have an answer, but a smoother idle, and quicker spooling should be the added benefit of a mod like this.
    I think I will give it try seems to be an easy mod. Had something similar on my A4 Jetta Tdi. Worked well.
    Black B8 A4 Avant S-Line Prestige Package, Tiptronic 8 speed, V1, Vogtland Coilovers, APR 91 & 93 ECU Upgrade, VMR RS4 Reps, and more mods to come!
  18. #98
    Sep 14 2006
    05 A4 1.8T CVT, 09 A4 Avant
    Loma Linda (SoCal)
    I don't know about the B8, but it's been proven by immediate before/after dynos that Audi's stock intake system is pretty damn good (well at least in the B6/B7). All of the different aftermarket intakes in the B6/B7 actually lost power except for the Carbonio which was pretty much a tweaked version of Audi's stock air box. Like I said, I don't know if Audi's intake design improved or is now worse, but it looks pretty much the same to me, so I'm assuming our stock unit is sufficient. Possibly getting a TIP and the IC pipe may improve throttle response, but the stock ECU and CAT are mainly what needs to be changed to make noticeable power. Next thing you'd want to do is get a larger turbo/fueling and a FMIC. In a few years I'm sure guys will be building these engines and making a lot of power and by THAT point, you're most likely going to be needing a cone fliter with a good heat shield.
    One of the main reasons I won't put one on my avant is because the MPG's will suffer.
    -Thomas
    USP CLUB MEMBER #16
    B6 A4 CVT-APR Stage1+/Forge TIP/neuspeed exhaust/Eibach springs/Hyperboost DV/Ecode FMIC/B5S4 brakes/vdo boost gauge/Podi/APR snub/rs4 rear sway/
    B8 A4 AVANT-REVO stage 2 (stock CAT)/DMH electric cutout/Stud conversion/Enkei 18x9.5 ET40/VMR 710 19X9.5 ET33/H&R OE Sports/
  19. #99
    Jan 12 2012
    Quote Originally Posted by A4 Centaur View Post
    No one is saying that aftermarket intakes are a hoax. Some cars come with very restrictive intakes (long paths, lots of bends, sound boxes, restrictive elements, warm air, etc.) and there are gains to be had with a CAI. The question here is how much does a CAI help our car. It's a ram air configuration with a few bends before the turbo inlet. I'm sure that there are some gains to be had, but is it worth the money? I think the Carbonio intake looks amazing, I like that it's not LOUD, but just can't justify the cost for what seems like minimal gains.
    Peter
  20. #100
    Aug 27 2008
    League City, TX
    Quote Originally Posted by gunsmoker View Post
    Interesting. aFe claims 58% higher flow than stock. Please give us an update and impressions once you get it installed.
    Current : 2009 Quartz/Black A4 - 6MT/Sport Pkg/Prem+ : EC Intercooler, 034 turbo inlet hose, Interior LEDs, Lic Plate LEDs, A4L fog grills, B&O Tweeters, Vag-Com tweaks
    Gone : 2001 Ice Silver/Black A4 - 5MT FWD/Prem Pkg
  21. #101
    Oct 24 2011
    2007 IS250
    Mansfield,MA
    Quote Originally Posted by B8_Jim View Post
    I installed the aFe Pro Dry S filter today. It does look like having a greater flow than the stock one once you see the stock thing with its fluffy front side. There is little change in the engine noise, just some slight whistle for a second when you push hard on it and you have to listen carefully to notice it. As far as any noticeable performance increase, I can't say I saw that. I'm running with a fuel cleaner right now and a Sunoco 93 gas, because I couldn't get to a Shell station - that may be a factor. The outside temperature as well. I can't figure out what type of weather makes this engine run better. You would think cold and dry, but I have had a better experience with warm and not very dry. Plus the ECU is playing some games I can't figure out either. Before I got my Stasis ECU tune, I could make the wheels slip by dropping the clutch at 4k RPM. Now it's very very hard to do that. Soon after I had the tune installed, I noticed that after dropping the clutch at 4k, I had to struggle to get the throttle all the way down for the short time before it hit 6k. What I mean by that is that it got quicker. It's been over a month since then and it seems now that I have an ample amount of time to do that. Has it gotten slower or am I quicker now or am I having carbon build-up issues? All that said, I can't notice a performance difference due to a higher flow filter among all those other things. Buy that filter - I doubt that the carbonio and the injen are any better.
  22. #102
    Senior Member Four Rings Wah's Avatar
    Jul 07 2009
    Lebanon
    It sounds good although the constant whistling may get annoying considering you're driving a B8.
    2010 PB A5 Quattro | 2.0 TFSI Stronic | Piasini Tuned (252 awhp / 321 ft-lbs) | EC FMIC | EC HFC | Alu Kreuz | Custom CB Exhaust | APR Intake w/ Trufit Hose | AWE Gauge Kit | ST Coils | RS6 Wheel | RS5 Pedals | Stronic Knob | H&R | HOEN Fogs | Rieger | Tints | HID & USP LEDs
  23. #103
    Senior Member Three Rings a4_bob's Avatar
    Mar 13 2010
    Atlanta/GA
    I've felt the same way after having two B8s with ecu tunes and various perf mods. I always questioned whether it was the ecu or me getting used to the mods - you've tracked it more to the car.
    2011 B8 A4 2.0T Quattro Tip Premium+, Sport Pkg, Nav, B&O | Meteor Gray, Black+Walnut interior
    Go: APR Stage2, Eurocode HFC, Custom exhaust, 034 Turbo Inlet Show: Spacers, Side blades, Blindspot Mirrors, PlastiDip Grille, FormulaOne Pinnacle 35% Tint, VCDS tweaks, Festoon license plate LEDs
  24. #104
    Oct 24 2011
    2007 IS250
    Mansfield,MA
    Quote Originally Posted by Wah View Post
    No, it's not constant. Only when you push real hard. Can't hear it if you are just cruising or if the radio is on. I'm sure my wife wouldn't notice it. It's not anywhere near the sound you can hear on soundbites from open CAIs. It doesn't mean to me it's much more restrictive, because it looks like it's capable of a much higher flow than the stock one. I think it's the stock box that muffles the sound. You can't see through the filter like you can with an oiled one, but it's pretty close and if aFe claims it has the same flow as their oiled filters and is washable and doesn't need oiling, it seems like it's the best compromise between performance, noise, usability and price there is. For $65 shipped it won't break the bank just to try it out. It begs the question why would anyone buy an oiled filter then. Will see if this technology will displace the oiled stuff or it will turn out the flow is not as good.
