Results 1 to 40 of 46
    Aug 06 2010
    Aurora, IL
    High-pitched whining noise from front part of the vehicle?
    Anyone have any ideas about what a high-pitched whining noise coming from the front of the vehicle could be? The pitch frequency of the noise increases as I accelerate, but if I let my car warm up for 10 mins or so the sound is barely noticable. I'd appreciate any ideas.... Thanks!
    Mar 11 2008
    RS4, 190e 16v, e46 M3
    check your power steering fluid.
    assuming I'm right, consider flushing/refilling it in the very near future as well.
    FRRG AZ Ring
    Veteran Member Four Rings CHECKERED's Avatar
    Aug 17 2008
    2005 B6 S4 DG, BMW 335i
    a canyon road in SoCal
    my money is on a busted wheel bearing
    B6 S4 Garage Queen: JHM Supercharger, JHM IM Spacers, Carbonio-JHM hybrid Intake, Fast Intentions DP&CB, CF Vented Hood. Mounts:034 Engine, Trans, Apikol Rear Diff, Coolers: JHM Oil, Power Steering & Trans. Susp:PSS9 Coilovers, Hotchkis F&R sway bars, Brakes: B7 RS4 Front (w/JHM LW rings) & JHM BBK Rear, StopTech SS lines.
    Daily Driver: BMW E92 335i Coupe, JB4 Stage 3 Piggyback w/Flash, Meth Injection, Intercooler, Charge Pipe, Quaife LSD 12.1@117mph
    Aug 31 2010
    09 R1 Track Weapon
    Greenacres, WA
    Need details, is it speed related? or Engine RPM related?
    05 B6 S4 Avant 6MT
    06 Touareg V8
    09 Yam R1, full race
    71 Honda Z50 88cc (pit bike of death)
    64 Ducati Mountaineer 90 (in restore mode)
    Established Member Two Rings fujii13's Avatar
    Oct 14 2009
    Albany, NY
    High pitched whining sound from the front of your vehicle? Did you run over your wife?
    the fuj.
    Aug 06 2010
    Aurora, IL
    Quote Originally Posted by fujii13 View Post
    No it was my girlfriend lol.
    Its Rpm related. If I step on the gas the frequency of the noise will change if I'm in neutral or drive.
    Aug 06 2010
    Aurora, IL
    Just check the power steering fluid and it's not low. Looks clean.
    Oct 16 2008
    97 Jetta VR6, 87 5000 Turbo Quattro, 05 S4 Avant, 98 Cherokee, 83 GTI, 06 Sierra 3500 Duramax
    Parker, CO
    Quote Originally Posted by LeeRoyRx View Post
    if you're hard on the accelerator do you hear it? is it only through a certain rpm range? you did mention worse in cold...with your windows down can you hear it better or pinpoint location?
    i don't have answers, however, have a sound..wouldn't call it a whine, but maybe a hiss around 3 to 4k rpm...i don't hear it when i'm on it hard, and can't hear it with the windows down which is strange..only hear it with the windows up..maybe around passenger footwell area...is yours the same or different?
    also, when was your serpentine belt replaced or has it been?
    Veteran Member Four Rings bmc333's Avatar
    Feb 12 2009
    NoVA
    I too have this same whine going on and it changes frequency based on throttle position (gets higher with more rpm/boost)...
    2015 S3 - Panther Black P+ / LED Lights / B&O / APR Stage 1 ECU & TCU / APR Turbo Muffler delete / CTS Turbo Inlet/Discharge/Intercooler Pipes / X34 Intake / Superpro end links / VWR springs / 35% Tint / ED CF rear diffuser / 034 CF engine & fuse box covers / ECS CF battery cover / BBS SR's
    Aug 06 2010
    Aurora, IL
    So I'm going to try and reclarify because details are key! So it's a whiny somewhat high pitched noise that appears to be coming from the front of the vehicle. I've started to notice it more as it has gotten colder (15-32F). If in neutral I can make the frequency of the noise get higher, but I really notice it when I'm driving, especially at low speeds. Seems like once I reach 35 or so it goes away. At work I park in a a parking structure and after my shift is over I try to let it warm up for 10 mins or so because if I don't my car sounds like it's whistling while I drive. Somewhat annoying as people are probably wondering what the heck that noise is too. I've also noticed my heat in the vehicle is messed up which may or may not be related. I don't really know a lot about cars so I apologize for being vague, but I really do appreciate everyone's help. My local dealer in the past has had trouble diagnosing problems for me, so I'd like to be able to point them in the right direction. Thanks guys
    Veteran Member Four Rings UnstableOS's Avatar
    Jul 23 2009
    2012 S4
    United States
    Account Terminated Four Rings
    Feb 29 2008
    When was the last time the serpentine belt / idler pulley / tensioner was replaced?
    Aug 06 2010
    Aurora, IL
    Exactly like that. Thanks for finding that. I guess I used the wrong search terms...
    Veteran Member Four Rings staticuxo's Avatar
    Sep 16 2008
    Items for Sale
    mine does that too when it's very cold in the mornings.. disappears after 5 mins. i changed my serp belt also...
    SQ5 - SEPANG BLUE | BLACK OPTICS | KW SC | AWE | ROC-EURO | VORSTEINER V-FF 103 21x10.5 | CONTI DWS06 295/35-21
    PREVIOUS:
    B7 S4 AVANT 6MT | B8.5 S4 6MT | B8 S4 S-TRONIC | B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
    Established Member Two Rings james.bigouette's Avatar
    Oct 26 2009
    2005 B6 S4, 2007 VW GTI STG 2+
    Odenton, MD
    do you have a dynavin, haha i have alot of high pitch whine.
    haha
    Established Member Two Rings 1000whp's Avatar
    Sep 01 2010
    B7 S4 Sprint Blue
    MA
    Quote Originally Posted by SKareKrow View Post
    Quote Originally Posted by staticuxo View Post
    did changing the serp belt help?... how many miles when you changed it?
    Veteran Member Four Rings mad70sx's Avatar
    Mar 12 2009
    Silver '04 S4
    Lil Rhody
    Did you guys replace the idler and tensioner pulleys when you replaced the serp belt? Sounds like one of the pulleys doesn't like being cold.
    JHM Tune ~ JHM Version 2 Headers ~ FI/JHM 2.5" Exhaust ~ Bilstein PSS9 Coilovers ~ BBS CH
    Aug 06 2010
    Aurora, IL
    Quote Originally Posted by joeycuccaro View Post
    Tensioner and serp belt was done about 3 months ago when I had the valve gaskets replaced. Think it needs to be re adjusted?
    Established Member Two Rings S4mser's Avatar
    Jun 27 2010
    Northern New Jersey
    mine does the exact same thing! goes away after it warms up though. cannot figure it out
    Jul 23 2009
    2012 S4
    United States
    A few things.. If you have the JHM 10mm intake spacers this seems to happen more often it seems. Check to ensure your intake manifold is sealed properly, more than likely some of the bolts have loosened. The whistling seems to be a gasket that is contracting when cold and once the engine gets a bit warm it expands and the whistle stops.
    Aug 06 2010
    Aurora, IL
    Quote Originally Posted by james.bigouette View Post
    haha
    No James. No aftermarket parts.
    Oct 07 2010
    vacuum leak/leaking intake manifold gaskets...IMO
    ben
    '05.5 B7 S4 6spd - 'new' car...JHM parts coming soon
    '04 B6 S4 6spd - JHM - GONE but not forgotten
    '05 duramax - really fast
    '68 vw beetle - way slower than both, but it has 4 wheel drive and a chevy 5.3 LSx V8 in the back
    Established Member Two Rings avant1's Avatar
    Jun 20 2009
    97gtivr6T, 97jettavr6,95jettavr6,95cabrio
    New Jersey
    idler pulley going bad? was it changed also? mine did that noise also till my idler pulley seized.
    May 15 2010
    Daily Driver: Stock '05 S4... Toy: NOT Stock Miata for going really, really fast around the track!
    High pitched whines coming from the passenger seat is usually wife/girlfriend. From the front of the engine, I vote for something serp belt related. When the miata is in track prep, the passenger seat is missing and things are so much more quiet...
    -h
    Account Terminated Three Rings JohnnyAlQaeda's Avatar
    Sep 22 2009
    Colorado Springs
    its the tensioner and pulley shit, mine does the same thing only when its cold. no big deal. if you replaced them recently then you have nothing to worry about. just deal with the noise.
    sounds kind of like one of those whistles where you pull the plastic piece out and it changes pitch right?
    Jun 27 2010
    Northern New Jersey
    Quote Originally Posted by JohnnyAlQaeda View Post
    YES!
    Veteran Member Four Rings Wusty's Avatar
    Mar 07 2010
    '17 C63s AMG
    Quote Originally Posted by 1000whp View Post
    I'm curious as well to know if changing the Serp Belt solved the whistling. Mine does it as well in the cold mornings. Goes away after a few minutes
    once it's warmed up.
    Jul 23 2009
    2012 S4
    United States
    The sound in the vid I posted is not the serp belt.
    Mar 07 2010
    '17 C63s AMG
    Do you know what the fix was for this?
    Feb 01 2008
    04 Audi A4 cab
    Chicago
    Items for Sale
    The whistling is the accessory belt tensioner / idler pulley. I had the same thing before I swapped them out -goofy whistling till about 1800rpm or so. There's even a TSB out for that.
    I have 10mm spacers also, no whisting.
    Jul 23 2009
    2012 S4
    United States
    Quote Originally Posted by halik View Post
    Very possible. However, my whistling was caused by a loose intake mani so that is just another thing to check.
    Sep 01 2010
    B7 S4 Sprint Blue
    MA
    How much should it cost to replace the serp belt tensioner and the idler pulley? Mine does the whistling sometimes for a min or so on cold startups. It also has the cold start clanking sound so I am looking into replacing serp belt tensioner, idler pulley, and possibly the chain guide to see if that addresses my issues.
    Should anyone be worried about the whistling and the cold start clanking?.... I mean, a lot of these S4's have it, but can any of these cause catastrophic failures?
    Mar 07 2010
    '17 C63s AMG
    From my research, belt costs $20, Idler Pulley is $40 and Belt Tensioner is $120 from JHM. I've heard install is up to 3-3.5 hours from an Audi Dealer? Hopefully its really not that long from an indy shop. Thats a quick $550-$650.
    Sep 22 2009
    Colorado Springs
    do it yourself, its not that bad at all
    Sep 01 2010
    B7 S4 Sprint Blue
    MA
    I don't have a garage... Doing it myself in the subzero weather isnt really an option :(
    Wusty - have you get yours fixed? I am more curious to know the repercussions of not doing anything about it.
    Sep 22 2009
    Colorado Springs
    mines been doing it for a year and i havent touched it, its not an issue until you throw a belt and your batt dies
    Mar 07 2010
    '17 C63s AMG
    I haven't done mine yet. I just started noticing it about a month ago. I'm bringing my car into a local indy shop to get some misc things done to it and i've been considering
    just having them do it at the same time. I want them to give me an idea of how many hours the labor is, then I might pull the trigger and have them do it.
    Sep 01 2010
    B7 S4 Sprint Blue
    MA
    Quote Originally Posted by Wusty View Post
    I see. Would you mind telling me what year and how many mileages on your S4?
    Do you plan on doing the timing chain and water pump at the same time when you are at it? When are those things due for replacement anyway?
    Mar 07 2010
    '17 C63s AMG
    05.5' 54,500 miles. I wasn't planing on doing timing chain and water pump? Belt, pulley & tensioner are due for service at 75,000k I heard.
    Veteran Member Four Rings Fade2Black's Avatar
    Nov 27 2008
    Black B6 S4
    Springfield NJ
    Can you change the idler pulley with out pulling the bumper?
    The democracy will cease to exist when you take away from those who are willing to work and give to those who would not.
    – Thomas Jefferson
