Page 1 of 27 12311 ... LastLast
Results 1 to 40 of 1043
    Veteran Member Four Rings MmmBoost's Avatar
    Nov 29 2005
    05 A4 USP Avant, 07 Suzuki GSX-R600, '69 VW Beetle w/ 1.9L aircooled turbo
    Edmonton, AB
    Arrow The Great Maestro 7 Tuning Suite Thread
    Since more and more people are jumping on the Maestro wagon, it seems as though we need a dedicated thread here on Audizine in order to discuss and help each other out.
    So Maestro users.......and potential Maestro users..........this is now your forum. Please feel free to ask questions, post findings, etc so everyone can read, learn, and help each other out.
    As well as posting questions, info, etc here.....I would also recommend signing up on the Eurodyne forum. There is a lot of good information there regarding features and trouble-shooting.
    I am also MmmBoost there... http://eurodyne.ca/forum/
    Some VERY informative threads....
    Maestro maps, axes, units, descriptions
    HOWTO: Scale the Flowmeter map for your custom MAF housing
    For you: An Excel spreadsheet useful for tuning <===== an AMAZING tool create by our very own, bananas
    public service announcement
    If you are trying to reset an entire map to zero corrections.........DO NOT set the entire map equal to "1" You must set it to at least 1.0001. Setting maps to 1.0000 will disable that map in the calculations and may have a very negative consequences.
    ~Chris
    Podi.ca Team
    My GT2871R build
    The Great Maestro 7 Tuning Thread
    Tumblr
    "Robert Bosch don't fuck around"
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    2.0 PTE 5857 A4 quattro 5spd, E55 AMG
    Jacksonville, Florida
    We definitely need this to be a sticky.
    ~David~
    2.0 PTE 5857 A4
    437whp on 93 octane and washer fluid injection A4
    505whp/550wtq on 93 octane E55 AMG
    Active Member Three Rings
    Dec 24 2009
    blackberry
    Here's everything already summed up http://forums.vwvortex.com/showthrea...Maestro+Tuning
    Nov 29 2005
    Edmonton, AB
    I'll answer this in here...
    Quote Originally Posted by jmw241 View Post
    Chris did you say your running a .31 constant on the 630's ?
    What battery voltage comp setting? I'm running .291 on the 630's
    At the moment I'm running Siemens Deka IV 630cc's, but I'll be switching to Genesis 550cc's because they have the factory-correct dual cone spray pattern as well as they are more easily controllable at lower pulse width.
    I was running a .031-ish constant, however, since rev 1.9.1 or 1.9,2 of Maestro, Tapp has "adjusted" the way the AMB engine uses/calculates/whatever the injecter constant. I am now running running a constant of .044255.
    What do you mean .291? there are 5 Voltages you should have numbers for.
    ~Chris
    Podi.ca Team
    My GT2871R build
    Tumblr
    Senior Member Four Rings alpinestar180's Avatar
    Dec 07 2009
    Trek 4500, 1972 kawasaki F6 125(for sale)
    north new jersey/boston, ma
    i'm very glad this thread was started because i intend on going with maestro soon. I know i dont have many mods, but i figure its better to buy a system that i can change depending on where i go with my setup than to spend money going back and forth between tuning companies as i mod. plus i like the customizability of maestro. does it come with a preset stock map? and does lemiwinks?
    holy shit i didnt realize that maestro was $1000
    maybe not.... =)
    anywhere to get it cheaper?
    2002 B6 A4 1.8TQM Sport suspension swap, RS4 rear Swaybar, joey mod, plasti-dipped front grills, and rear trunk trim.
    Diode Mod!!
    -Andrew
    Saint Cloud, Fl
    Yes it comes with a base map of your choice. There is a lot to learn.
    BUY MY CAR - HERE 2002 A4 AVANT
    Nov 29 2005
    Edmonton, AB
    Quote Originally Posted by alpinestar180 View Post
    I figured it was time. There are a lot of curious people out there compared to when I went with it. Documentation is VERY minimal so the more help we can offer each other as a community, the better.
    When you order the software/tuning suite, you have to read your ECU and send the file in with your mods. You then get a base file back which is written for your injectors and ECU and I believe turbo size (give or take).
    It's a decent place to start.....but it's not perfect and needs work to make things run very well. I'm a bit anal though.......so I am constantly tweaking and changing things to make it even better.
    ~Chris
    Podi.ca Team
    My GT2871R build
    Tumblr
    Veteran Member Four Rings nein-reis's Avatar
    Feb 01 2008
    B6 A4 GT3076R
    Uintah, Utar
    maybe not.... =)
    This is not for you, sorry. Its 1000.00 at its cheapest, and thats a bargain for what it delivers. Also, the base map is for big turbo's... its not designed/intended/or working with stock lowly modded cars. Its a great program, but not a magic horsepower finder. If you find yourself spending 5-20K on a motor build turbo build in the future, then it is for you. If not, it will do nothing for you. This is not a system that was made to tune your K03/K04 system, and if you don't realize this... you should honestly stay away ...far away from it.
    -Tyler-
    Built AEB/IE Cams/2.0 stroker/GT3076/6MTQ
    Eurodyne M7 ~Dan Shank super tuned
    Nov 29 2005
    Edmonton, AB
    Quote Originally Posted by nein-reis View Post
    jmw241 is having some success using Maestro on his K03 until he gets his BT build done. I give him props for that...... tuning that twitchy little turbo must be a nightmare.
    To add to what Tyler said though......if you're not the least bit patient, I would not recommend Maestro.. I just counted tonight......I've been through 123 revisions to my file to experiment with different values and variables to see how they effect things.
    Tuning is a bit of a black art. There are no instructions to follow........so once you get it loaded......it's up to you to make it work and you only get out what you put in.
    ~Chris
    Podi.ca Team
    My GT2871R build
    Tumblr
    Dec 07 2009
    i am probably almost as anal as you, chris... ALMOST (just not nearly as experienced lol) I don't want you guys to think that I am just jumping on the maestro band wagon because it sounds cool. I know i would be spending lots of time tweaking. I am not looking into maestro because i think its the best solution for my k03 (and the K03 is not my end goal), i am looking into it because i plan on doing a build, and i don't want to dump 400-600 dollars (that i know i can save) by getting a flash, when i will want maestro down the road when i do the build. If i get it now and become well versed in its operation, it will be much easier to deal with when i DO finally start my build. Im just thinking in terms of my longer term goals.
    I would hate to go APR 1+ and then get a BT setup 6 months later and have to toss the apr software and injectors (or lose money in a resale)
    maybe it's just another inevitable expense of owning a b6
    Diode Mod!!
    -Andrew
    Veteran Member Four Rings nofearhawk's Avatar
    Aug 31 2007
    04 1.8TQ
    Chicago, IL 60601
    I have maestro on my almost completely stock car at the moment, stage 1 file from tapp.
    I'm also building a motor in my living room though, so in the meantime I'm just playing around with little things here and there. I wanted the ability to read and clear fault codes, upgradeable, and not have to rely on someone else's schedule to tune/fix/get my car running the way I want.
    I will say though, if you don't consider yourself tech/computer savvy, maestro is not for you. There's no instruction manual or anything, you have to rely on past peoples experiences and some insight here and there from tapp.
    BTW you can get it for 900 shipped, and USP said they would be willing to sponsor a group buy (check group buy request forum), I couldn't wait around but you can see my thread there.
    1.9L GT3071r 517 trans
    Mods: Eurodyne Maestro 7 / Stasis Alcon 355mm Mono6 / 034 Billet Fuel Pump 005 / Neuspeed snub mount / RS4 rear sway / Custom Magnaflow 14581 exhaust / INA adapters with FSI coilpacks / Thor Skidplate / CF S4 blades / DTH CF Roof Spoiler / RD led lp / Smoked sidemarkers / 3k HID fogs / 35% tint / Symphony II+
    Jun 21 2005
    '05 BAT B6; '06 Civic EX
    Milton, Ontario
    great thread, make it sticky! Thanks MmmBoost.
    -Steve
    '05 B6 A4 Avant T3/T04E 50 trim • 4:1 diff • FX400 6-puck • PSS9 • 18x8.5 BBS RC w/ Conti Ext DW
    Senior Member Three Rings pape's Avatar
    Nov 30 2008
    MIA
    Ok I have a question. my friend with his 2003 1.8t A4 has the maestro. he was actualy one of the first ones to get it before it went on sale for the B6's
    Now his going to sell the car an put it back to stock. Is there any way I would be able to buy it from him or swap ecu's. I drive a 2002 1.8t A4 both are 5speed
    Senior Member Four Rings Dan[FN]6262's Avatar
    Sep 12 2008
    E30//B6 A4
    South Central PA
    *this needs sticky action
    in for when I get connection with my ECU again lol
    |||The Awesome™
    |||CompTurbo 6262underconstruction
    |||1.8Liters of Fury
    |||36psi+Meth
    "nein-reis: My butt"
    Dec 03 2005
    audi, chevy, jeep, lots and lots of bicycles
    connecticut
    Quote Originally Posted by MmmBoost View Post
    If you don't have the time to dedicate to tweaking maps but need a custom written file there are tuning sources out there that can do this for you (ASP, Avalon, EPL, etc..). That is what I did because I just do not have the time to tweak things. It would have taken me a few months with the time allotment I have if I were doing it on my own with Maestro. It took ASP less than a week to write and modify my files that are on my ECu. Changes from here are less than a day of dyno and street time. Maestro was also not available when I needed it (1-2 years ago).
    -Doug
    2002 A4 2008cc GT-3076R turbocharged Avant
    397awhp/371awtq on straight 93oct and 96*F ambient
    You too can have this kind of power if you click here
    Dec 03 2005
    connecticut
    Quote Originally Posted by pape View Post
    Best to call Eurodyno and talk to Chris directly about this. I am not sure if anything will transfer since the 2002 is a completely different set of base maps. Go straight to the source for answers..
    -Doug
    Senior Member Four Rings jmw241's Avatar
    Feb 23 2009
    Cranston RI
    I run a .0291 injector constant right now, with the same 630's. So you jumped up from .031 to .044 since the latest update? That's a big jump, what changes have you noticed?
    I will update later on with the voltages I'm currently running, I never made any changes to them from the base 630 file.
    -Justin
    | EURODYNE Maestro | GTX-3071|
    Nov 29 2005
    Edmonton, AB
    No with the new version my number jumped. It doesn't run any different, just somehow the software calculated it different.
    I've been slowly lowering my Minimum Injector Pulsewidth and it seems to be leaning up my idle to where i want it.
    ~Chris
    Podi.ca Team
    My GT2871R build
    Tumblr
    Senior Member Three Rings 613B6's Avatar
    Jul 29 2009
    2004 A4 6MT
    Street racing in Ottawa
    I dropped by battery comp table by about 20% and idles like perfect again even with low load. The only ill effects is I'm seeing more o2 correction (positive) than before. Going try half those values on the way home...
    i
    Feb 23 2009
    Cranston RI
    Thanks a lot Chris. You gave me tons of help and it paid off.
    It was a bitch, but I enjoied every bit of it, learned tons and had a blast doing so. It does not run perfect, and there is alot left to make this ko3 tune perfect, Im hoping to be gtx-3071 within a week. I had planed on original having a BT on the car 2-3 weeks ago and that's why I stoped making big changes to the ko3 file.
    To Anyone that wants to tune their Ko3 with Maestro. First off, im willing to help anyone, give screen shots of my maps ect. But know this, I tuned my ko3 with a big ass fmic. I don't see 21-22 psi until 3k or slightly after that and then it's 22 psi till 4k then it tapers down to 15 psi by 4700 an. 13 by 5200.
    Because of how the turbo spools, and spike/tappers off so dramaticly and only over 2k rpms it makes tuning and the driving characteristics of the car a bit rough. Part throttle around 3k took a little while to smooth out, but the fmic made this easier to tune tbh. It's going to be harder to tune on a stock smic because you wi spike sooner, so you will need to really smooth out the boost pid table to account for that.
    Also, there are different ways to tune, or different methods. I know that I tweaked the boost pid table alot at first, while both Chris and Chris did not.
    All in all it is definitly possible to tune a ko3 with maestro. My biggest fear though is that we will start to see people attempt to tune ko3's with Maestro, when that person has no business doing so. I spent months learning about the basics of hardware first where I had a very solid understanding of how different components of the car function. If you don't understand what an n75 valve works, or what sensors the car uses to calculate desiered a/f, and the list goes on. You need a great understanding of the hardware first IMO, then you need to learn how the software will control that hardware. It's very easy to screw something up, I rememer when I first started tuning, I was adjusting my injector constant, first thing i messed with. I stead of giving the car a 3% injector constant I gave it 30%, obviously when I went to go start the car she did not fire up, wicked wicked rich.
    Keep in mind if you asked me what an cam chain tensioner, map sensor, or 02 sensor was 12 months ago I would have been confused.
    Now I'm pulling cams, and tuning my car......you can lean this stuff, it's just a matter of how much time/dedication you give it.
    -Justin
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    This definitely needs to be updated on the first post daily as well. Trying to read 30+ pages on the maestro on vortex is ridiculous.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Active Member Two Rings lave3k's Avatar
    Apr 30 2009
    03 A4 1.8t, 03 Honda 954rr
    FTC, Colorado
    The Battery Voltage Compensation table is in milliseconds, while the injector constant is in ms/%.
    The battery voltage compensation table is the best place to adjust for injector latency, while you need to insure that your minimum injector pulse width is sufficiently low with injectors that large, its not a great way to adjust idle fuel.
    I'd recommend reading your idle and partial fuel trims after driving the car 20+ mins between tweaks:
    Take your idle % correction and multiply it by your injector constant % * ms/% => ms This is the fixed ms time you need to add or subtract from the battery voltage compensation to correct for injector latency. At first just do it across the whole range.
    Take your partial load % correction and simply scale your injector constant by it. If you repeat this process a few times you should be able to bring your idle and partial fueling into agreement. Don't over react to small changes as you can go back and forth chasing nothing and the fuel trims will always be shifting a little. Once you have worked this out, then move on to injector correction tables to fix specific problems at certain rpms.
    Feb 23 2009
    Cranston RI
    Quote Originally Posted by lave3k View Post
    I don't know who you are, where you came from or what you just said (I'll read into it later when I have time to understand/figure it out)
    But rock on! This looks like solid information and is exactly what we need! Thanks bro!
    -Justin
    Jul 29 2009
    2004 A4 6MT
    wow great info! thanks!
    B6 A4 - 12.3@111mph | Maestro | 2871r Elim | Drop-in Rods | Pump gas + meth
    MkV GTI - Project 130mph traps..
    Dec 03 2005
    connecticut
    He tunes motronic based ECUs via hex editors and the like (like all other motronic custom tuners.)
    -Doug
    Dec 03 2005
    connecticut
    Give it time. It'll happen. This is a risk Eurodyne took when releasing this front end. I am sure they are covered legally should someone do blow up their engine due to lack of knowledge when modifying maps and try to press legal action towards Eurodyne.
    -Doug
    Veteran Member Four Rings bananas's Avatar
    Jun 13 2005
    1999 A4 Avant 1.8TQM
    Minnesota
    Quote Originally Posted by champion View Post
    let me just say that I've been reading that thread (up until a couple months ago) and there are a lot of misinformed individuals posting there
    '03 A4 1.8TQM 337WHP/355WTQ (93+meth) | My car's Mods | Fancy Pants™ Turbo Club Member #001
    Nov 29 2005
    Edmonton, AB
    Quote Originally Posted by bananas View Post
    Agreed. I don't even go back there to see if anyone has written anything worthwhile or helpful
    ~Chris
    Podi.ca Team
    My GT2871R build
    Tumblr
    Jun 13 2005
    Minnesota
    Hey man, nice to see you in here :) Did you ever get a TunerPro xdf out of WinOLS or post your summary/analysis somewhere?
    Apr 30 2009
    FTC, Colorado
    Yeah.... I ended up not going the TunerPro route and instead of open sourcing the whole thing I went to the dark side. What can I say don't look at me...I'm a monster!
    Anyway I'd like to help out with some summary/how to on here. Have you shared your magical data plotting/sorter sheet? -that thing is fantastic.
    Feb 01 2008
    B6 A4 GT3076R
    Uintah, Utar
    Short answer... no. You cant run files from other years of B6 in a 2002 ECU. Ask me how I know? Well, Chris (bananas) and I once made the mistake of loading his 03+ plus file into my 02 ecu and it bricked it. I had to send my ECU to Tapp in Canada to fix my new paper weight back into a working ECU. And you will not be able to run the 02 ECU in your 03 car. I did, but its a different circumstance and a rare dealer happenstance I was able too.
    -Tyler-
    Veteran Member Four Rings AudiHere04's Avatar
    Nov 21 2005
    East Coast
    Isn't the initial read file your stock ecu file or whatever you had pre-maestro?
    Buy My Parts!
    K03 w/ lines & OEM manifold - $300
    OEM FlyWheel - Best Offer
    Precision 6262 Turbo - $1300
    Feb 01 2008
    B6 A4 GT3076R
    Uintah, Utar
    Quote Originally Posted by AudiHere04 View Post
    Yes there is, I assume your thinking I should have just loaded that again right? That would of been nice, but when I said it bricked it... it really did. Not only are the files different, they are in different places. So when I flashed the wrong ECU files on it, it moved it all around. Neither Maestro or the car could read it, so it was completely unresponsive to anything.
    -Tyler-
    Feb 01 2008
    B6 A4 GT3076R
    Uintah, Utar
    And that brings up another point.... Maestro can eff your shit up if you screw up. There are NO safety rails in place, so if you tune it to lean out like crazy at high RPM unkowingly... it will go ahead and assume you know what you want and do it.... bye motor. So be careful, and always double check your work. Learning by playing works, but can be a disaster.
    -Tyler-
    Stage 3 Forum Advertiser Four Rings Sales@RAI's Avatar
    Jun 22 2009
    Dundalk, MD
    Well because of this I think an external wideband should be standard regardless if you plan on making over 300awhp
    -Dan
    Keep up with us on facebook and connect with us on Google+
    Sales@raimotorsport.com
    Nov 30 2008
    MIA
    Would it be posible if we swapped. ECU's, Cluster's, and immobilizer chips???
    Feb 01 2008
    B6 A4 GT3076R
    Uintah, Utar
    I cant say... I'm thinking no. I'm not sure if you can swap clusters either... mileage issue?
    Also, when I put my new ECU into my car a good friend who worked at a unnamed dealership did a live connect with Audi tech in the shop to recode my cluster to the new ECU... (big reason being I was 2003 3.0 and swapping a 2002 ecu in) to get it all to be happy together.
    -Tyler-
    Dec 14 2004
    Norway
    While I do see your point I believe the ME7 has fairly many safeguards against blowing up your motor..
    But of course, it can happen, and yes you need to be careful..
    Dec 03 2005
    connecticut
    Quote Originally Posted by Hansi View Post
    There are safeguards but this software allows you to make drastic changes to maps. Drastic changes in the wrong direction without the proper knowledge of the ramifications will results in engine failure.
    It is inevitable that this will happen. That day will come as Eurodyne sells more and more of these tuning suites.
    -Doug
    Dec 14 2004
    Norway
    I agree, however, I think common sense should stop you from making drastic changes if you don't know what you are doing, hehe..
    But enough about that, great thread.. I am sure this is the future, even with that slight chance of blowing something up (if you lack the common sense mentioned)
