    Dec 01 2010
    canada
    smart key problems
    Smart Key has worked properly in the past now when I approach my 2009 avant I can no longer unlock/lock the car with the key in my pocket.Any suggestions or is this a dealership issue.
    Active Member Two Rings pierreb's Avatar
    Q5 P+/nav 2.0t Tip
    NH
    Quote Originally Posted by sliner32 View Post
    try replacing the battery
    Account Terminated Four Rings
    Jul 04 2009
    2009 B8 Aruba Blue (discontiuned) 2.0T
    it is not the battery problem. this happened to me once, the dealer replaced a sensor for the door handle under warranty.
    Link to my experience with this issue: http://www.audizine.com/forum/showth...key?highlight=
    Active Member Two Rings bakin1's Avatar
    Mar 17 2009
    2009 A4 S-line Misano Red
    Sacramento, CA
    Similar thing happened to me. Can you still use the push button start? For me, they replaced the door module and antenna I think.
    2009 A4 Misano Red S-line
    Jul 04 2009
    ^^Yes, Engine Start/Off button and trunk still work. But door lock/unlock function is disabled when sensor/module fail.
