The complete KW & ST product line is available from AMI at great prices!
Give us a PM, Email or Call with your suspension requirements & questions and we can help you decide on what KW / ST product is right for your driving needs and get you the best price on your new Coilover system!
Rely on our 12+ years of KW product knowledge and KW Germany Factory training to get you into the suspension you need
above: Glen @ AMI's 2002 Audi TT Q 225 with KW Clubsport Coilovers (Photo courtesy of the KW Suspensions USA homepage http://www.kwsuspensions.com)
Current KW Product Lines available from AMI:
Variant 1
Sporty Handling with factory preset damping
The ideal system for customers wishing to rely on the experience of our engineers to set the damper setting, yet determine their own degree of lowering. In extensive driving tests our engineers have set the dampers for the best balance between sporty driving, comfort and safety. The user is then free to decide the best height setting for their use and preference.
Variant 2
Sport Handling with adjustable rebound damping
This system intended for the experienced driver who does not only wish to determine the individual lowering of his vehicle, but also wishes to carry out setup adjustments. The adjustable rebound damper allows adjusting the pitch and roll behavior of the vehicle and therefore the driving pleasure can be adapted to the own requirements.
Variant 3
State-of-the-art technology from motor sports for more performance on the road.
The separate and independently adjustable rebound and compression damping allows for an individual suspension setup for different uses and preferences. The unique patented system with its two-stage valves allows a rebound damping adjustment (comfort) and a compression adjustment (driving dynamics) in the low-speed range while the high-speed range which controls the driving safety, is fixed.
Street Comfort
Is your sport suspension kit is too hard for you? Do you want a sporty yet dynamic suspension while retaining ride comfort? With street comfort suspension KW offers you the solution, you can create that sportive look while keeping as much comfort as possible. Long trips on the highway will be a pleasure; fun can be had on county roads.
With the individual height adjustable KW street comfort coilover kit a lowering of 10-40 mm can be realized, depending on the vehicle. This way the customer has the flexibility to improve the look, with consideration of bigger wheels and tires. At the same time the lowering has a positive effect on the driving dynamics and road contact. With discreet but effective lowering more spring travel will be left to combine a comfortable spring with harmonic damper, this way the best driving comfort is guaranteed. With this product KW offers the perfect compromise of driving dynamic and driving comfort.
Club Sport
KW Clubsport coilovers was developed for customers, who demand a better handling car when participating in track day events, but also require a setup that could be used every day.
The Clubsport was specifically designed for the Nordschleife using track day tires. By using the optional adjustable top mounts, the suspension geometry can be adjusted to the requirements of tires and the intended use. The mentioned adjustment options combined with the independently adjustable rebound and compression damping technology allow a suspension setup according to the vehicle load, tire characteristics and different track conditions. KW Clubsport meets every demand regarding a coilover for the usage on the road and the race track.
KW Clubsport suspension kits are independently adjustable in compression and rebound forces and include high performance racing springs. Racing top mounts are optionally available for further performance. KW Clubsport guarantees excellent handling, best performance, highest agility and fantastic lap times.
Competition Race Systems
The race program KW Competition has been developed for national and international motor sports. Today, KW Competition is successfully used by various race teams on many race tracks around the world. Our motor sports department has its unique structures and therefore can meet the high and quickly changing requirements of the customers in a flexible and target-oriented way.
HLS
The HLS provides additional road clearance for lowered vehicles.
When expanded, a range of up to 45 mm of lift is produced, thereby helping sport cars avoid road clearance difficulties such as speed bumps, road construction, etc. KW HLS is available as vehicle specific solution or individual conversion kit depending on the car model.
HLS is available in two different versions: HLS 2 which is fitted to the front axle and HLS 4 which can be attached to the front and rear axle and allows lifting the entire vehicle. The hydraulic cylinder unit is located on the coilover body between spring perch and spring. The advantage of a hydraulic system is that there is no compression (motion) of the extended cylinder unit (resulting in no unwanted additional suspension movement) while driving.
Whatever your Suspension needs, AMI & KW automotive have you covered!
