Results 1 to 19 of 19
    Jan 02 2010
    PA
    symptoms of bad maf sensor?
    I have a 02 3.0. My Cel keeps coming on as a steady light not flashing at all. Some of the codes are random mis firing. I think one might have been something with the cooling system. My euro mechanic told me it might be a bad maf sensor. What are the symptoms of this? I don't have any of the codes on hand.
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    well the easiest way to check if a MAF is bad.
    Start the car
    Pop The hood
    Unplug the maf.
    If the car idles the same with no difference.... then your MAF is probably bad.
    If the car starts to shake and idles funny... then your MAF is probably fine.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Jan 02 2010
    PA
    I just got my cel turned off, so if i unplug it will my cel come back on?
    Senior Member Three Rings Dubdaze's Avatar
    Jan 20 2010
    03 a4 1.8t
    Tampa Fl
    Quote Originally Posted by Audi Skate Snow View Post
    Start the car
    Pop The hood
    Unplug the maf.
    Every vw/audi ive seen runs perfect with the Maf unplugged..
    If the maf is bad and the car runs bad then when you unplug the maf the car will run better
    Veteran Member Four Rings b4a41point8t's Avatar
    Jun 06 2009
    Los Angeles, CA
    Items for Sale
    ^ from my experiences they don't run the same. Similar but noticeably different/bad. Try the maf test and go from there. Do you have vagcom for data logging? That's the easiest test.
    Jan 02 2010
    PA
    Quote Originally Posted by b4a41point8t View Post
    Unfortunately i don't. I bought a crappy $20 ebay one. worked for one time, now it wont work.
    Mar 31 2004
    CA
    Quote Originally Posted by Dubdaze View Post
    you will pretty much notice no change if the maf is bad and then you unplug it. the computer then gets reading from MAP sensor when MAF sensors go out. If your MAF is good with no problems... and you unplug the MAF while the car is running then with out a doubht.... 100% for sure your car will idle like shit.
    Jan 02 2010
    PA
    Ok i just unplugged it, it seems to run a bit worse. my esp light came on. Now i plugged it back in esp light is still on, and cel just turned on .its running like its unplugged. What the hell happened?
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Give it time to re-adapt - stop engine - restart its not a video game.
    U might need to disconnect battery to reset the ECU.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Jan 02 2010
    PA
    disconnect the MAF cable with the car on and then plug it back in. Turn the car off and then turn the key in the "ON" position (the furthest position without turning the car on) for 2 minutes. Then start your car and drive it a couple miles.
    The ESP light may still be on but should go off during driving or after the next time you start your car and drive again. You can't always just turn the car on and off as the ECU needs to have consistent readings from the MAF to signal the light to turn off.
    Thats what i had to do to fix it. after i drove for a few miles esp went off and car ran fine again.
    Mar 31 2004
    CA
    yea ESP light will go off after it cycles. on a good note it doesnt seem your MAF is bad if it started idling like shit
    Jan 02 2010
    PA
    Yeah i dont think so. When i took it for a ride and stop my car would shut off/almost shut off or stand around 500rpms then steady at about 800 or so
    Veteran Member Three Rings teg2audi's Avatar
    Apr 23 2008
    Portland, OR
    i'm guessing vacuum leak. If the ideal is shit and jumps around that would be my first guess. No boost gauge by chance?
    Black 04 Audi A4 1.8t
    APR Stage 2+, Koni FSD/Eibach, OEM USP Wheels
    Member # 15 of Coalition of The OEM+ Audi Owners.
    Jan 02 2010
    PA
    my car has no boost. its a v6 3.0. and my car only did that while my maf was disconnected/being reset.
    Veteran Member Three Rings BerNur's Avatar
    Jan 31 2009
    Brandon FL / Astoria NY
    Items for Sale
    sorry to thread jack.. but is there a main reason a maf would go bad? or just a life span?
    Mar 31 2004
    CA
    Quote Originally Posted by BerNur View Post
    lifetime... and mostly just dirt particles building up on the film. A lot of times you can clean them and they will be fine again. The only real way to tell if a MAF is on its way out is to log it and see if it is getting the correct readings it should be (correct for turbo you have or software)
    Mar 31 2004
    CA
    Quote Originally Posted by teg2audi View Post
    That is my next guess. Although it would be a lean code that would probably just stay on constant until fixed/cleared. Could be plugs or a list of possibilities. hard to tell with out being with the car and checking it out.
    Active Member Two Rings leo536's Avatar
    Mar 12 2009
    B6 A4
    Dallas, TX
    Ok, so I'm also having a similar issue with the idling, misfires, car rpms dropping and almost the car dying (some cases it would.) What else could go wrong to cause this? With my 02' 3.0L, spark plugs and gaskets were recently changed, and the coil packs were changed maybe about a year ago due to a recall. If this is helpful, when I had my MAF plugged in, you could hear a thumping noise coming from the intake, kinda sounded like the throttle was gasping for air, but after awhile it faded. And after reading this, I think my MAF might just be bad, because there is no difference in the idling when I have the MAF plugged in and unplugged.
    02 Audi A4 3.0
    Registered Member One Ring Skinnyskins's Avatar
    May 06 2013
    Ogden, Utah
    Sorry for this, but my car has stalled out and I don't think I'm getting the proper mileage. Not to mention it doesn't have the original gas cap from Audi. That's when the light started coming on.
