Results 1 to 7 of 7
    Veteran Member Three Rings Redg2's Avatar
    Jun 28 2009
    Philly
    My car is making a weird noise coming from the back, it Weird noise coming from rear
    my car is making a weird noise coming from the rear, it almost sounds like a grinding noise. Btw it is a quattro. Now the odd thing is that the noise goes away momenteraly when taking left turns, im thinking its either a bent axle or unbalanced wheel? You guys have any other ideas
    Registered Member Four Rings CrtchRktRcr's Avatar
    Feb 25 2009
    CRF50
    Scottsdale AZ
    Wheel bearings or bad axle.
    AEB B5 A4, QUATTRO MANUAL SPORT-H&R,FORGE,1BAR,5BAR,BOOM
    xbox live: Cr0tchf4i
    ["im in the computer lab and some dude with about 8" just sat down next to me -S4Jet"
    WWW.ASKMY2CENTS.COM
    Mar 15 2007
    2001 A4
    seattle
    If it goes away when you turn left it's your wheel bearing.
    Active Member One Ring Gambit0714's Avatar
    Oct 29 2010
    My other AWD: 79 Chevy C30 Full time 4x4
    Suffolk, VA
    Wheel bearing
    Veteran Member Four Rings BlackLock_A4's Avatar
    Sep 14 2009
    San Jose
    break pad hanging up? No - I guess that wouldn't matter if you were turning.
    How fast are you going when you hear the noise? A good test for wheel bearing is to find a windy road, if it gets louder when you turn right - AND goes away/ gets quieter when you turn left, then you know it's your left wheel bearing.
    2001 1.8TQM
    Speed doesn't kill. It's that damn sudden stop.
    Established Member Two Rings toxinr's Avatar
    Nov 24 2009
    soon to be Stanford...
    left rear wheel bearing..
    Hunting for my next car... And my next apartment...
    Jun 28 2009
    Philly
    any good wheel bearing kits you guys recomend? i should of thought of that earlier since the wheel bearing going bad is kinda common...thanks fellas
