Senior Member
Four Rings
Originally Posted by
Spooled1.8
Timing belt kit is on its way from blau parts, as long as it gets here in time I'm going to try and wrap this thing up in time for vaginal fair
LOL, good luck. You only got a couple days now.
Three Rings
I'm hoping it can get here by Thursday. I can work on it all night, and I have off work all day Friday. Even have sat morning before the show. I think I can pull it off, we'll see!!!
-Pete
2001 Imola Yellow S4 EPL/TiAL S605
-Evolution Racewerks Intercoolers with Carbon fiber shrouds.-EBC Redstuff Pads-EBC Rotors-RAI Motorsport 3" Downpipes-AWE Twin 1 Exhaust-AWE DV1 DV's-AWE Center Vent Boost Guage-AWE DTS Bar-Advanced Automotion Rebuilt Trans-Southbend Stage 4 Clutch-Fidanza LWFW-ASP Engine Mounts-034 Motorsport Trans Mounts-Apikol Rear Diff Mount-KW Variant 3 Coilovers-
Three Rings
Car should be running tonight, will keep you updated. Quick question in case I can't reach EPL, what did you 605 guys gap your spark plugs to?
-Pete
Senior Member
Four Rings
Spooled1.8
.025
Senior Member
Two Rings
Evilevo
.025
X2
Senior Member
Three Rings
Evilevo
.025
X3
2008 A4 Avant Spec. Ed/Ibis/Oynx/Sport/6-speed
2001.5 S4 Avant/Pearl/Oynx/Tial 605/6-speed......Sold
Three Rings
Gapped em to .025, thanks guys.
Here's another question for you, I cut the lower outlet pipe 35mm(1.5") by cutting the end of the pipe off with the original bead and spokes, cut 35mm off and welded the end back on it. This is the outcome...
Shouldn't that bracket still bolt up??^^^
98a4 showing this thing some love....
-Pete
Three Rings
Went with ER Intercoolers & carbon shrouds. Engine is in and almost everything is together, car will be running this week :) Quick question, when you guys put the fuel rail on after the injector install, do you guys push down until you feel or hear something or does it seat properly after you bolt it down?
-Pete
Three Rings
-Pete
Stage 3 Forum Advertiser
Four Rings
Make sure you clean them!
As far as the outlet pipe, My driverside outlet pipe didn't bolt up after modifications needed for it to fit. Bolting it would be wise if you can figure something out, since it will help the likliehood of it blowing off. However, since you have the bead still, probably be fine. Otherwise, you could use a Fab Tab or something similar?
Glad to see everything is getting finished!
Three Rings
Will do Max, thanks for the advice! I shortened the pipe a tad bit so it now bolts up, I'll let you know how that goes tomorrow.
-Pete
Three Rings
Took forever to washout those IC's until they were free of all shavings/metal particles.
-Pete
Three Rings
Spooled1.8
Insane to think how much shit they leave in there...wonder if anyone has installed without washing
VAST PNW Reseller
REALTOR specializing in residential real estate throughout the greater PNW!
Three Rings
The one intercooler was def worse than the other, in total I think it took about 1.5 hours
-Pete
Three Rings
-Pete
Senior Member
Four Rings
Finish this ****** already
Three Rings
If I go to the Grand Prix tomorrow then it wont be running until WED, If I dont go, it'll be running tomorrow...
-Pete
Senior Member
Three Rings
Senior Member
Four Rings
Spooled1.8
I'll be at the grand prix tomorrow and sunday
Active Member
Three Rings
So, did this thing ever get finished? I'd like to know the end results...
'01 Black Audi S4, Stg2
'88 Grey Audi 100, StgS(tock)
If you haven't left blood or tears on it, you're not trying hard enough...
Three Rings
It's done, I just need to get the clutch line bled and replace the plastic basket in the shifter cup. As soon as I got home from H20 last week I caught the nastiest sickness in a while, I didn't go to school or work for 2 days and I'm still trying to get rid of it. When I get out of my finance class at 2 today I'll prob go ahead and work on it.
-Pete
Active Member
Three Rings
Ah, sorry to hear about you bein sick, sucks. Hope you get over it soon. Bet your immune system will like you more once you get some logs done... :P Can't wait to see some numbers on this thing.
Three Rings
Bosch 044 Fuel Pump & Drop in kit on the way from 034 Motorsport.
Aquamist HFS-3 and 4QT Tank with Cap on the way from EPL.
Today was a good day.
-Pete
Three Rings
She's alive!!!!!! Sounds sooooo good, I missed that sound :) have to clean up the garage now:
Still need to look over everything before I take it out and have any fun with it. Needs tires most importantly.
-Pete
Active Member
Three Rings
Three Rings
As you can see, I was paranoid about everything since this was the first time it was started in over a year lol.
-Pete
Three Rings
Runs perfect! Registered it yesterday, tires and inspection tomorrow. Finals next week, after that I'll install the fuel pump and Aquamist and head up to EPL finally.
-Pete
Four Rings
Spooled1.8
Looking good Pete! This may have been answered but how aggressive do you want to get with the tune?
Three Rings
As aggressive as tony see's fit. I have no rods but I'd like to get the most out of it as possible.
-Pete
Four Rings
Spooled1.8
What did you wash it out with, hose and air compressor?
Three Rings
Water first, then compressor.
-Pete
Thats one thing that bothers me about those and maybe other intercoolers. I understand the debris is a by product of the manufacturing process, but after paying that much sure as heck they could put some time into cleaning them out for you. Maybe its just me. Of course who would not spend time cleaning them, its good insurance. But to see that much debis that it required 1+ hour to clean means there was alot.
Anyway, nice build. Hope to be doing this one day soon.
Four Rings
Looking forward to the results!
And yes, the amount of material typically present in those intercoolers is disappointing, and unfortunately not a new thing by any means.
I had to spend 2 hours cleaning mine with a combination of water, alcohol, and air.
Three Rings
Yea it was a massive pain in the ass. My buddy that's been helping me along the way built me one of those DIY pressure testers that awe has on their website. I think I have a massive boost leak somewhere. Torque ramps up and car hits15psi and then just bleeds it all of after 5000rpm to redline. When I get back from Pittsburg on Monday I'll report back my findings.
-Pete
Max@034
2 hours... Maybe too much alcohol. JK I know what you mean.
Four Rings
I know its been a while but I am interested in knowing what the results were. I just ordered a 605 kit on Friday, I will be going with stock rods for the time being as well. Congrats on getting it up and running, I can't wait to do the same.
Three Rings
So far so good. Everything is pretty much done, I'll probably have to wait until spring break to get the car dyno tuned though. 18 credits in college+ full time job= no life lol.
-Pete
Four Rings
Same here 16 credits, 46 hours a week at work plus wife and kids. No fun, I feel your pain.
Three Rings
Haven't updated this in a long time.
Put 3,000 miles on the kit so far and its running great. Also installed the Aquamist HFS-3 kit (and the 044 Fuel pump has been in for months now). Everything working perfectly.
Oil change tonight using some nice motul fluids.
Dyno tune @ EPL on Monday 4/2/2012. It's been a long time coming, I'm very excited at this point.
Will report back with dyno vid and numbers on Monday, stay tuned!
-Pete
Four Rings
Great, looking forward to the results.
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
Forum Rules
