    Senior Member Two Rings jabicho's Avatar
    Feb 02 2010
    Muchos Bandidos, Spain
    Battery meter says itīs 70%...need to replace it soon?
    Hi everybody, one of the first mods I did with vag-com to my 2009 A4 was enabling the battery meter.The thing is that up to now itīs always said itīs 100% charged...until last month.It started with 90% and now itīs even at 70%, I havenīt done anything to the car so I suppose thereīs nothing there draining my battery.Yesterday I tried to recharge it but after 40 minutes the automatic charger I used said it was full ...although the battery meter on the car still says 70-80%, wonīt go higher than that.In case of having to replace the battery,do you know if any coding is required? I mean, can I just change it, erase dtc with vag.com and thatīs all? Any help is welcome...cheers
    A4 B8 Avant TDI 143 MY2009
    Senior Member Four Rings rlarsen's Avatar
    Mar 20 2009
    Copenhagen, Denmark
    Is there enough water on the battery ??
    Maybe you can see if the indicator on the battery is green or red - otherwise you need to take the screws off to check the water level - it should be ~ 1 cm. above the battery cells.
    Rene Larsen
    A4 Avant 3.0 TDI quattro tiptronic MY2009 - SOLD
    VCDS 11.11.6 - 12.10.6 Beta (HEX-USB+CAN)
    Senior Member Three Rings Comp4k's Avatar
    Aug 10 2009
    B8 A4
    Carlsbad, CA
    Quote Originally Posted by jabicho View Post
    I have no idea how that battery meter works, I had a dead battery and after I boosted it my battery bar was at 100%.....when really it should be really really low.
    Feb 02 2010
    The fact is that Iīve had a look at it and itīs difficult to tell, no "magic eye" and no "max-min" mark...this is what it looks like:
    Iīve also found a way to check battery status and alternator via va-com, itīs on module 19 (CAN-getaway)...do you think this is the module for coding the new battery if we replace the original one? Other Audi models had a separate module for the battery, but this apparently this is not the case on A4B8
    Measured value block 015:
    Alternator, electrical status (OK / not OK)
    Alternator, mechanical status (OK / not OK)
    Alternator, thermal status (OK / not OK)
    Vacant
    Measured value block 016:
    Alternator type (OK / not OK)
    OK = Alternator type known
    not OK = Unknown alternator type fitted
    Alternator manufacturer
    Alternator size
    Alternator controller
    Measured value block 017:
    Battery identified (OK / not OK)
    OK = Adapted battery known
    not OK = Adaption value not known
    Battery manufacturer (0-7)
    Battery size (0-15)
    Battery recognition (yes / no)
    yes = Battery disconnected, no = Battery connected
    Measured value block 018:
    Battery voltage
    Battery current
    Current from or into battery (-400A to +100A); positive current = alternator charging battery, negative current = battery delivering current = no battery charging by alternator *2)
    Temperature estimate, battery
    Battery sensor temperature
    *2) Active recuperation may also cause negative battery current. In this case there is no defect in the alternator.
    Measured value block 019:
    Battery charge in %
    Battery charge in %
    Corresponding to readout on MMI Car menu
    Battery ageing in %
    Derived from charged (0 % = very poor battery condition, 100% = very good battery condition)
    Battery ageing in %
    Derived from power output (0 % = very poor battery condition, 100% = very good battery condition)
    Measured value block 020:
    Current battery internal resistance in mW
    Standardised battery internal resistance in mW
    Battery internal resistance referred to theoretical internal resistance
    Tappable charge in Ah
    The higher the number, the better the battery condition
    Feb 02 2010
    Any more clues about what may be happening??
