Results 1 to 10 of 10
    Oct 30 2010
    Grand rapids, mi
    Heating On One Side Of Air Vents Only??
    I have a 2003 Audi A4 and for some reason regardless of the temperature setting on the display, it only puts out cold air on the drivers side air vents. The passenger side air vents work as normal when the temperature is changed. Any ideas on why this could be happening?
    Thanks,
    Tim
    Veteran Member Three Rings BerNur's Avatar
    Jan 31 2009
    Brandon FL / Astoria NY
    Items for Sale
    do a coolant flush or before you do a flush scan the hvac with vag-com or go to autozone to get scanned for codes
    Jun 08 2008
    Calgary AB Canada
    Items for Sale
    Coolant flush wont do anything. Sounds like the blending door isnt working. You can try scanning your car with VAGCOM to see if theres any errors that pop up as stated above
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Veteran Member Three Rings sxman69's Avatar
    Oct 04 2009
    08 CRF250R, BLKMRKT Mob, Giant Glory DH
    Auburn, CA
    I have the same symptoms. Got some errors with the HVAC motors or something like that, but at least the heating is on the drivers side.
    -Sam
    New: 2009 Mazdaspeed 3 GT
    SOLD!!!! Staggared AMG Monoblock // Podi // Magnaflow // Forge // Kicker // Kenwood // JHM stud conversion // Tint //15mm H&R spacers // Hardwired Passport 8500 X50 // 034 Wiring Harness // Hawk HPS // 034 Blockoff Plate // MKIV Euro Switch
    Veteran Member Four Rings bigblue's Avatar
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    Pull the stereo out and remove the hvac controls and push all the plugs in on the hvac controls. One of mine was loose so it would only blow burning hot air in my girlfriends face when I turned the ac on.
    05 USP 1.8t A4 Tip | F4L FrankenTurbo | TT225 Injectors | Apikol SMIC | Powergasket | Forge 007 | 034 HFC | 034 Motor Mounts | Stern Transmission Mounts | Apikol Rear Diff Mount | APR Snub Mount | B5 S4 Front Brakes | AWE boost gauge | K&N Filter | 2.0T Coils
    Oct 08 2009
    Austin, TX
    I have a similar problem - hot/cold mixing and side/side control is inconsistent. To get (mostly) consistent cold AC I put my temp controls (both sides) to "LO" and not rely on the auto temp/fan control - just adjust fan control manually. Seems like the climate control system mixes in hot air on the passenger side otherwise and it blows lukewarm regardless of the temp settings.
    How to I scan the climate control codes? Same OBDII connector under the driver's footwell?
    I'll also have to try the trick of removing the control unit and reseating connectors...that sounds a lot simpler than replacing vent/flapper motors and sensors...
    2003 Audi 1.8T Quattro
    2007 Saab 9-3 Aero 2.3T
    2001 Ducati Monster 900Sie
    1998 Saab 900S 2.0T Stage 1+ (sold)
    Jan 31 2009
    Items for Sale
    replacing the flapper motors is not that hard you unscrew the glove box and unscrew the flapper motor unplug it replace it then reverse order thats it.. you just have to know which 1 is at fault..
    Oct 08 2009
    Austin, TX
    Are all the flapper motors accessible from behind the glove box? I thought I would have to pull apart the whole dash...that would be very nice.
    I can hear various clicks and other noises behind the glove box after I turn the car off - they go on for several minutes. I figured maybe the motors were trying to get back to a parked position and are obstructed or something. Any one know if there is any kind of diagnostic guide and explanation of fault codes on-line? I haven't found much on this forum about these problems.
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    My car clicks for awhile after I shut it off too and I don't have any faults stored in hvac.
    Oct 08 2009
    Austin, TX
    Did some research on the site about reading my own codes - will the cheap fleabay VAGCOM cable and freeware software work to read the climate control codes, or do I need the real Ross-Tech version?
