Results 1 to 15 of 15
    Veteran Member Four Rings todd1010's Avatar
    Jun 17 2004
    Jacksonville, Florida
    Has anyone installed the Stern adjustable camber/caster kit on their A5/S5?
    I only got about 20k on my first tires and believe these would increase the life of the next set of tires by about 10k.
    2009 S5 Ibis White-Magma Red Interior
    Loaded with stuff
    Jul 27 2010
    Singapore
    I've heard about this product too. Where can it be purchased?
    Is there a rear camber kit also?
    Account Terminated Four Rings
    Oct 18 2008
    Delray Beach, FL
    There IS a rear camber kit, but it's not necessary. Only our fronts are non-adjustable. I got mine 2 weeks ago for $550 shipped.
    Jul 27 2010
    Singapore
    Quote Originally Posted by greensto View Post
    I guess I should rephrase my question, and my thought process on the matter. Does lowering 1 to 2 inches on the B8 cause Rear Camber to be out of factory range even with adjustment, and necessitate an aftermarket solution? 3 inches or more?
    Oct 18 2008
    Delray Beach, FL
    On my B7 A4, I had even wear on my rear tires when lowered. I only had wear on my inner front tires without the Sterns.
    Jun 17 2004
    You can get them at PureMS. I'll contact Mike and see if he can do some kind of group discount on these.
    http://www.purems.com/products/product.php/II=2940
    Loaded with stuff
    Jul 27 2010
    Singapore
    Quote Originally Posted by todd1010 View Post
    Thanks for the info. There are even installation instructions on the website too. However, it doesn't advise on the relative lengths that the two upper arms should be adjusted to get a given camber of the wheel.
    What I mean to say is, since both upper arms, when lengthened, reduce negative camber. How would you know the best combination to get, say, a degree change in camber?
    Jul 27 2010
    Singapore
    Stage 2 Banner Advertiser Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    The arms are delivered in a length equal to the factory control arms. It's up to the alignment shop to work with you in determining an appropriate camber/caster/toe setting to achieve the desired handling, and tire wear you're looking for. There is no alignment spec that works perfectly for everyone, as everyone has slightly different requirements.
    These arms allow you to dial in more camber and caster for optimal handling, or dial it out to save tire life.
    While we unfortunately can't do a group buy on these, if you're interested in them, give us a call and we'll be happy to help out with competitive pricing.
    Senior Member Three Rings JimmyBones's Avatar
    Apr 03 2010
    NOVA
    That is honestly not that bad if you don't drive like a grandmother with the factory Dunlops. The front camber is normally not touched because it stays in spec for a long time unless you hit a massive hole or have to have the engine removed since the normal front camber adjustment is sliding the subframe sideways to equalize the front camber.
    I say buy some Michelins or Continentals and they should last a lot longer.
    Ex-Audi Tech - Looking for sidework. Vag-Com equipped and PM questions.
    2004 S4 6MT - Current Fun Car - Wavetrac LSD rear diff, JHM LWFW and St4 clutch, trio shifter, 4:1 center diff, LW crank pulley, USP metal slave cylinder with SS line, Stern race engine mounts, 034 Motorsports race trans mount, Apikol snub mount and race rear diff mount.
    2000 A6 2.7T 6MT - Current Daily Driver
    2004 S4 6MT Cabrio - Totaled
    Aug 08 2010
    shreveport
    is there any camber adjustment with the factory camber arms? Im needing to add camber to match my fronts better
    Active Member Two Rings confinedz's Avatar
    Jan 13 2010
    Palm Harbor, Florida
    just beware that when ordering the Stern part that there is a lead time and it's not on the shelf!! I have been waiting for 3 weeks plus :(
    Senior Member Four Rings BlkS5's Avatar
    Nov 20 2009
    2010 MB Blk/Blk E350 Sport
    La Quinta, CA
    20k? That is great! I got only 12k and figured I would have to buy tires every year.
    2007 A6 , Blk/Blk/Sport - Traded for S5
    2009 S5 6M , Phantom Black/Tuscan Brn/Loaded - Totaled
    2009 S5 6Tip , Phantom Black/Blk/Loaded - 30* tint/KW ADS Coil Overs, Überlegenes Stabilisatoren System, HR 10/20 Spacers/RS5 instrument trim/ClearBra/BB Sport Exhaust/AWE S-filter/Hoen zenon/Blk Ops Grill & Valence/LoJacked/trunk panel net/led's
    Mar 13 2010
    Laguna Beach, California
    Stern control arms solve S5 vibration issues?
    Just wondering if anyone thinks that adding these arms will allow you to dial out the vibration issues that seem to haunt the S5?
    Senior Member Four Rings Wah's Avatar
    Jul 07 2009
    Lebanon
    ^^^Doesn't seem that it would help as ExhaustNote has the camber kit and he still experiences vibrations; as do I :(
    2010 PB A5 Quattro | 2.0 TFSI Stronic | Piasini Tuned (252 awhp / 321 ft-lbs) | EC FMIC | EC HFC | Alu Kreuz | Custom CB Exhaust | APR Intake w/ Trufit Hose | AWE Gauge Kit | ST Coils | RS6 Wheel | RS5 Pedals | Stronic Knob | H&R | HOEN Fogs | Rieger | Tints | HID & USP LEDs
