Page 243 of 971 FirstFirst ... 143193233241242243244245253293343743 ... LastLast
Results 9,681 to 9,720 of 38816
Thread: Winter Mode
  1. #9681
    Senior Member Four Rings Greedo's Avatar
    Oct 26 2009
    I leave by the second inning.
  2. #9682
    Oct 26 2009
    Senior Member Four Rings DownhillA4's Avatar
    Jun 23 2008
    Around
    Shitty angles, in for more pictures.
    Please donate, your username will be displayed on my vehicle during the 2013 RNA Rally!
    Anyone have a Boost Leak Tester for B6 A4? Will pay shipping.
  4. #9684
    Oct 26 2009
    Quote Originally Posted by DownhillA4 View Post
    Did it on purpose. I didn't realize how much I raised my front coils for winter. I'm going to lower them at some point today.
  5. #9685
    Oct 26 2009
    Brought the front down a bit. Would have went lower, BUT I'm an idiot and went the wrong way the first time round and raised the car. Then, for some odd reason, the hex bolt that is supposed to lock the adjustable perch in place on the passenger side, decided it wanted to turn and turn and turn. I can't really move the perch, so I'm not too concerned, but irritated. And to top it all of, my left front inner CV boot is leaking (or so I think). I swear this is the same axle I just replaced last year. Pics of the leak at the end for confirmation that's what it is. Looks like CV grease and it's at the bottom of the axle.
    But otherwise, pics. Lowered the car just shy of an inch. Will probably take it down a bit further to 23.5" GTF. I'm happy for now. The rear needs work - I'm swapping out to 6" Hyperco springs for more low.
    And the not so pretty pic
  6. #9686
    Senior Member Four Rings CoreyRS's Avatar
    Aug 07 2009
    Honda Hawk NT-650
    Mountain View, CA
    your first pic makes it look like crystal blue. no homo
    Buy my:
    | Brilliant Black Oettinger Rear | non-usp fog grills | soul black trim | AMB valve cover |
  7. #9687
    Senior Member Four Rings tankdeer's Avatar
    Aug 18 2009
    A Unicorn
    Portland, OR
    Needs more front spacer
    Clicky clicky: B7 2.0T Engine Part out
    2008 Ibis Ti Avant 6MT
    2006 DG Avant Tip - RIP
  8. #9688
    Dec 01 2007
    Atlas Gray Revo Stg.3 Avant, MK5 GLI
    Orange County, NY 10918
    Quote Originally Posted by Akronnnnnnnn View Post
    I want 18's for winters cuz I am gonna try and get S4 brakes this summer
    nice! That will be my goal when we put a new motor in the Camaro. Speaking of which, my dad was supposed to start pulling up the carpet to replace the floorboards this week.
    @TJ: no u
    S4's fit behind 17's
    Neil_
    Atlas Gray BT Avant... For Sale ..also ABT 3bar Grill NIB For Sale. avantneil@gmail.com
    Instagram: avantneil
  9. #9689
    Dec 01 2007
    TJ you need spacers to pull off that stretch!
    Neil_
  10. #9690
    Oct 26 2009
    I found some spacers local. 5, 10 and 20. 20s will be too much, but will 5s be too little? I like how 5s don't need extended lugs.
    The rear is perfect as far as I'm concerned.
  11. #9691
    Active Member Two Rings B6A4Avant14's Avatar
    Nov 14 2010
    B6 A4 Avant 3.0QM, Mk5 Jetta, 2011 Specialized Demo 8 II custom, Titus El Guapo, BlkMrkt Riot
    No where, and everywhere
    I got a new job!
    My name is Max, I ride lots of bikes.
    Check out Animals With Hats!
    10% of proceeds go to shelters in the NY area!
    http://www.animalswithhats.com/
  12. #9692
    Oct 26 2009
    Quote Originally Posted by B6A4Avant14 View Post
    I got a new job!
    Congrats!
    [I'd like a new job]
  13. #9693
    Senior Member Four Rings JoshDub's Avatar
    Oct 09 2008
    1990 Audi 90 Quattro 20V, 1989 BMW 325iS
    Looks like the diff seal is leaking. That doesn't look like OEM axle grease.
    The Awesome™
  14. #9694
    Oct 26 2009
    Quote Originally Posted by JoshDub View Post
    And what does that mean in terms of repair? Do it ASAP? Easy fix?
  15. #9695
    Oct 26 2009
    Josh,
    I'm on my phone and did a quick search - useless to be fair. I can't find info on a leaking front differential, just rear and center (unless the center is the front and I' dumb).
    I'm also confused becauase the only pics I saw all had the distinct coloration of oil. My leak is definitely gray in color. It doesn't feel quite as thick as CV grease, but also not as thin as oil.
    I only noticed the fluid at the bottom of the inner axle - nothing seemed abnormal at the top (though that's most likely due to gravity regardless of what's leaking).
    You're the first to suggest a bad seal. I personally haven't a clue.
  16. #9696
    Oct 09 2008
    That would be the front diff. The center is at the end of the trans and the rear is, well in the rear.
    Since the axle side looks cleaner then the diff side I'd bet the diff seal is bad. Other wise wouldn't there be a leak from the boot to that area? And I think Audi may use a "life time" oil in that diff or it could share the same ATF fluid in the transmission, I am not sure. But judging by the darkness, the location, and the way it looks like it is leaking I'd say its the seal. Unless there is something I don't know about the way Audi seals that flange to the diff.
    Now I haven't replaced one on the A4 but it will most likely entail removing the axle, removing that flange, and hopefully popping out the old seal and installing the new one.
  17. #9697
    Oct 26 2009
    I'm leaning towards you being more correct. The leak is too consistent to be axle grease. It doesn't have the same charactersistics as it did when my rear boot went bad.
    I'll double check with my buddy. We were planning to fix it next weekend and put new springs in the rear coils.
  18. #9698
    Jun 23 2008
    Around
    I run 2010, B8 S4 calipers behind my 17" 5 Sport Spoke Wheels with no spacers.
  19. #9699
    Nov 14 2010
    and it dosent rub on the rim?
  20. #9700
    Jun 23 2008
    Around
    4mm of clearance.
  21. #9701
    Dec 01 2007
    there are plenty of 17" OEM wheels and aftermarket wheels that clear the larger brakes. Its only the HP2's that i run that i have a hard time finding wheels to fit.
    Neil_
  22. #9702
    Senior Member Four Rings Akronnnnnnnn's Avatar
    Jun 21 2010
    88 BMW 325ix, 90 Camaro RS w/5.7L V8
    Akron, OH
    I don't want to run 17's again though :p I need to buy new wheels anyway and I think 18's would look better.
    How much should I expect to pay to upgrade my brakes?
  23. #9703
    Dec 01 2007
    what brakes are you looking for? B6S4' are gonna run you around $450-$500 full front set. about $800 F&R
    or do B7A4 fronts and rears for cheaper.
    Neil_
  24. #9704
    Jun 21 2010
    Akron, OH
    I'll probably just do B7A4 then.
    -Brian
    RIP AK RAUDI
    FTWLTBDWICTW
  25. #9705
    Aug 07 2009
    Honda Hawk NT-650
    Mountain View, CA
    When one of my calipers seized, I looked into every OEM option under the sun. Its all pretty expensive unless you can find some miracle deals in a junkyard or the classifieds.
    Buy my:
  26. #9706
    Dec 01 2007
    i have an extra set of oem b7a4 rear rotors i'll let go CHEAP.
    Neil_
  27. #9707
    Jun 21 2010
    Akron, OH
    I can't do anything until this summer, and I wasn't even gonna upgrade my rears honestly
    -Brian
    RIP AK RAUDI
    FTWLTBDWICTW
  28. #9708
    Oct 26 2009
    New, lower springs ordered for the rear.
  29. #9709
    Aug 18 2009
    A Unicorn
    Portland, OR
    Yay
  30. #9710
    Oct 26 2009
    Yay
    You seem a bit lost. What are you doing in this thread?
  31. #9711
    Senior Member Four Rings evo_ski's Avatar
    Mar 15 2010
    Bothell
    HAHAHAHA
    I took my packasport off so I could save myself some MPG's, but I have to say I much prefer the look of the avant with it on. :/ oh well, at least I can now use my sunroof again.
  32. #9712
    Jun 21 2010
    Akron, OH
    He's allowed, our cars started their ST coil voyage around the same time.
    -Brian
    RIP AK RAUDI
    FTWLTBDWICTW
  33. #9713
    Aug 18 2009
    A Unicorn
    Portland, OR
    Just here to rub my Ti wheels and already installed shorter springs in your face.
  34. #9714
    Oct 26 2009
    My wheels are better than yours!
  35. #9715
    Aug 18 2009
    A Unicorn
    Portland, OR
    You still want mine
  36. #9716
    Oct 26 2009
    To run in the snow.
    You want mine.
  37. #9717
    Aug 18 2009
    A Unicorn
    Portland, OR
    They do look good in the snow
    I want yours to be real LMs
  38. #9718
    Oct 26 2009
    Give me your Ti wheels AND $3k. I'll get some real LMs then.
  39. #9719
    Aug 18 2009
    A Unicorn
    Portland, OR
    You can get real LMs for less than 3 grand.
    With tires: http://www.audizine.com/classifieds/...5-19x10&cat=48
  40. #9720
    Oct 26 2009
    I'd love them, but they are more than twice what I paid.
