Results 1 to 37 of 37
    Registered Member Four Rings
    Aug 10 2009
    Manassas, VA
    Items for Sale
    Engine is really hard to turn over by hand.
    I put brute rods into my engine myself, when the engine was on the stand, if I oiled the cylinder walls I would turn the crank by hand very easily with a breaker bar on the crank bolt. When I put the head/oil pan on, same thing.
    I got the engine into the chassis a couple weeks ago, and today I go back to work on it. I get the timing belt and starter connected. I tapped the key to see that the engine would turn over, it did! Great...so I put the front end back together, and get everything connected and go to start it, and it starts for less then a second but then promptly died. The issue was that the wiring harness for the front plastic clip got wound around the fan, so I unwind and untangle everything. Nothing is severely damaged, but when I get everything sorted out and go tot start it...nothing. The solenoid just clicks. I take the front clip back off and the crank is amazingly hard to turn by hand.
    At the beginning of the day it wasn't so bad...even when I got the timing belt on it seemed to turn fine. When putting the timing belt on it aligned the timing mark on the cam gear to the valve cover, and the mark on the crank pulley to the mark on the lower timing belt cover.
    What is the issue!? It will have about a 50-90 degree patch in the rotation where I can turn it easier (not easy) then the rest, but every here the started can't turn it. I simply refuse to believe I did anything to the valves, but I don't know what the issue is. I tried everything I could think of. If this is something internal to the engine that has to do with my rod install I am going to be forced to sell off this project, so please help!
    Car is a 1998 3071 1.8TQM fx400 brute rods.
    Build:
    http://www.audizine.com/forum/showth...build-starting
    John
    BAT B6 A4: GT3582, built AEB head, supertech hardware, inconnel valves, port and polished, IE rods, Spa manifold, Fully rebuilt 01E with JHM kit, s4 drivetrain, custom 3" exhaust, Bilstein PSS9, 3.0L A4 brakes, and the list goes on..
    Waiting to install: S4 Rear Bumper, B6 S4 Rear Brakes, 18z front calipers, USP front lip, USP Door Blades, Black Interior, JHM Short Shifter
    Looking to buy: 034 Rear Swab Bar + End Links, Black S4 Recaros, S4 Door Blades, Black B7 Center Console
    Stage 2 Banner Advertiser Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Remove the spark plugs and try again.
    www.purems.com
    San Diego, CA | mike@purems.com | Twitter! | Facebook
    Your Source for everything APR, HRE Wheels, Brembo, TSW, Rotiform, VMR Wheels, Stern, Evolution Racewerks, Clutchmasters, South Bend, Carbonio, VWR, Gruppe M, OSIR, and much more!
    Aug 10 2009
    Manassas, VA
    Items for Sale
    Quote Originally Posted by Mike@PureMS View Post
    Did it. I tried to see if some WD-40 down in the cylinders would help, but it didn't. (only volatile thing I had around)
    First thing I thought of was compression. I re-oiled the cams to see if that was it but it's not.
    Feb 26 2010
    NOVA
    remove the starter and try again.
    Veteran Member Four Rings black99.5a4's Avatar
    Jun 26 2008
    00' Noggy Stg2
    Middle of a Cornfield, PA
    are you sure the trans is in neutral when you're trying to turn the motor?
    '00 Nogaro S4 - TIP, Ebay turbos, Ebay inlets, Ebay stage 2 tune, OBX manifolds, OBX exhaust
    For all your OEM Audi needs
    Aug 10 2009
    Manassas, VA
    Items for Sale
    Quote Originally Posted by black99.5a4 View Post
    Yup.
    Quote Originally Posted by guy022077 View Post
    Try what again? The starter was never off, I just connected it electrically.
    Veteran Member Four Rings terraflata's Avatar
    Sep 14 2008
    '97 Audi 1.8TQM '97 Acura Integra 2002 Dodge Durango
    Chambly, Quebec, Canada
    Items for Sale
    I had trouble turning my engine over on the stand because I had inversed a rod cap, but seeing as you didnt have this issue on the stand I cannot be sure what is causing your issue. does it basically bind partway through the rotation?
    MontrealAudiClub
    Jun 26 2008
    00' Noggy Stg2
    turn it one way and then the opposite and see if its easier to a point.. you might of set your timing off and bent a few valves, now you're not holding compression and while tryign to hand crank it, you're binding on the valves.
    Feb 26 2010
    NOVA
    i thought the starter was off and you put it on, maybe it slung out and got stuck when you tried to start it.
    Aug 10 2009
    Manassas, VA
    Items for Sale
    That's what I was thinking but the timing was dead on when we got the T-belt on, it feels easier for about 90 degrees or less of the cycle but then it gets very hard to turn. I am leaning into the breaker bar with my body weight. (2 foot bar, I am 230) Would I be able to even turn it if a valve was in the way? And how can I check without pulling everything apart?
    Quote Originally Posted by terraflata View Post
    On the stand and before all this, it wasn't nearly this hard, I am fearing it is a valve issue....
    Is there a way to have it looked timed via the marks, but it is really like 1 cycle out of timing?
    Jun 26 2008
    00' Noggy Stg2
    pull the coils and plugs.. i think you have and its still just as hard.
    I would say you are hitting a valve just right to bend it slowly if you're still slowly getting it to crank with that 2 foot bar.
    How far apart was your head? you might of stuck your cams in 180* out, or your cam gear 180* degrees out. If you've replaced the head, you might of bought one with a bent valve.
    You can do a compression test if you have 0 compression, you can all but blame it on the head.. but you'll need the starter in the car.. put foot on gas while cranking, get out and read gauge.
    Aug 10 2009
    Manassas, VA
    Items for Sale
    I did, still just as hard.
    Head was never apart, took out the 10 head bolts, pulled it off, put it aside, put it back on.
    The issue is the car won't turn over. The starter doesn't have enough torque to spin the engine.
    Since the cam gear > timing gear isn't 1:1 could I have put the cam gear a single rotation out of timed? I wouldn't think so since the cam gear is the bigger gear.
    Jun 26 2008
    00' Noggy Stg2
    you can align the crank pulley twice while turning the motor and cam gear only once.. the other time the timing mark on the crank lines up, the cam is 180* out.
    I would pull the VC, try to get the cams to the timing point and see if the arrows on the back of the cams, match the spots on the rear cam sprokets.
    Veteran Member Four Rings chris164935's Avatar
    Apr 18 2007
    2016 Audi A3 2.0tQ; 2001 Audi A4 1.8tQM
    Orange Park, FL
    Items for Sale
    No metal tapping noises were heard during all this?
    Is the clutch pedal stiff?
    There was a guy with a similar problem on Vortex; turns out his pistons were hitting the oil squirters.
    "You know you have a bad idea when Ford guys are making fun of you."
    Jun 26 2008
    00' Noggy Stg2
    they would break off as soon as he cranked it over, if the motor started at all.. A guy on vortex did this buy installing his pistons backwards. Also had middle intake valve indents in each one.
    You did stick the valve relief on the piston and both rod bearing tangs on the same side of the block, which would be on the intake manifold side.
    Aug 10 2009
    Manassas, VA
    Items for Sale
    I just ordered 2 head bolt sets from ECS via UPS 2nd day air so that I can try to pull the head this weekend and see if I messed anything up in the top end...
    I haven't seen any interest from anyone who would wanna buy this off of me so I might as well dump more money into it.
    -John
    Feb 26 2010
    NOVA
    2 head bolt sets? no arp, whats up with that?
    Apr 18 2007
    Orange Park, FL
    Items for Sale
    Quote Originally Posted by John Gutmannnn View Post
    -John
    OUCH! Are there no local VW or Audi dealerships? It's only like ~$40 for a head bolt set from the dealer... And no 2nd day air shipping charge!
    What price were you looking for for the car?
    Active Member Four Rings onemoremile's Avatar
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Wow. I got head bolts, head gasket, and valve cover gaskets for 94 from the dealer. List is 156 or 158.
    Jim
    I Do Werk.
    Veteran Member Three Rings prodrive's Avatar
    Feb 24 2006
    1999 Audi A4 1.8TQ
    Istanbul,Turkey
    is your clutch new ?
    Just A4 ... A4 which we know
    2.0L - HTA35 - Cat3658 -Autronic EMS - Autronic 500R CDI etc..
    Feedback: Clicky
    Established Member Two Rings brockallentaylo's Avatar
    Apr 29 2010
    2007 530i sport, 2000 F350 CC
    Crescent, OK
    Quote Originally Posted by prodrive View Post
    Good point, flywheel bolts could be too long if so.
    "Hey, what kind of party is this? There's no booze and only one hooker"
    Senior Member Two Rings Rickz96's Avatar
    Feb 24 2008
    2K A4 1.8TQ Tip
    Ohio
    Did you turn the bottom rotating assembly 360 degrees and it was bind free before the head install? And rotate the entire engine at least 3 full turns after the timing belt install? If so, then you say it started and the promptly died right? I would say it is time to open it up and find out where the problem is. I would start by taking the head off and seeig if the bottom will rotate, if not take the oil pan off and find out what is binding her up.
    Aug 10 2009
    Manassas, VA
    Items for Sale
    Clutch is brand new but the engine was turning fine beforehand so it can't be this.
    I turned the bottom end at least 3 or 4 full rotations while it was in the car and it was fine, after for research and talking to people I am thinking it has something to do with the rod bearings, I noticed when I was putting it all together that the crank got a lot tighter when the rod caps were torqued down. I also used bare hands to handle the bearings and only put a thin coating of oil on during assembly so I may have bound something up. So I guess I will be pulling it apart again this weekend to check it out. I might order a set of new bearings as well just in case.
    BTW 2 sets of head bolts and 2 day shipping = $44.30
    Why do I need ARP Head bolts? I have never seen significant proof to say you need anything other then OEM head bolts. I have only seen 1 case I believe where a head lifted off the gasket.
    Feb 24 2006
    1999 Audi A4 1.8TQ
    Istanbul,Turkey
    There is no need for head bolts if you are under 550hp range ,but a good set of tangless coated bearings would be nice.
    Feedback: Clicky
    Feb 26 2010
    NOVA
    i only suggested it because i thought stock bolts were more that 44 bucks. and if you need to remove the head again youll be out 3 sets of head bolts. thats almost a set of ARP's
    Aug 10 2009
    Manassas, VA
    Items for Sale
    You can reuse ARP bolts? I thought all head bolts were stretch bolts.
    Feb 26 2010
    NOVA
    arp's are not stretch bolts, so long as they are installed correctly you can use them over and over. and you can certainly mess up and reuse them without worrying or needing to replace them. i assumed thats why most people go to them.
    Veteran Member Four Rings Haenszel20v's Avatar
    Oct 05 2008
    B6 A4 USP - B5 VR6T Avant
    Buffalo, NY
    As I said on rocdubs a month ago and you brushed me off, before you put it in the car, where it would have been a MUCH easier issue to fix.
    Quote Originally Posted by haenszel View Post
    your rod caps are on backwards/wrong rods.
    Or you didn't assembly lube them. You shoudl be able to turn the crank by grabbing it with your hands, no need for a breaker bar.
    10.201@143.42mph -- Full Weight
    Sep 12 2008
    South Central PA
    oh, snap.
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Aug 10 2009
    Manassas, VA
    Items for Sale
    Quote Originally Posted by Haenszel20v View Post
    Like I said a month ago, once I lubed the cylinder walls it was very easy to turn by hand. Also, I DID assembly lube them, apparently just not enough. I double and triple checked all the rod caps while assembling and they were correct, I only did a single rod at a time so there is no way caps go switched, as well have having unique IDs stamped into both the rod and the cap to check.
    I didn't "brush you off" I just checked the thread and I did respond to your comment. I didn't state then I lubed everything because I knew that I did lube them. People make mistakes...chill dude.
    Feb 26 2010
    NOVA
    when an "oh snap" goes wrong ^^
    Aug 10 2009
    Manassas, VA
    Items for Sale
    He pointed out on rocdubs after my response assembly lube is thicker. I wasn't aware of this, so I ordered new rod bearings and assembly lube, I thought it would be fine lubing it with just clean motor oil. This is only my first time doing it so...my bad. Let's see what it all looks like when I open it up.
    Sep 12 2008
    South Central PA
    I lubed the shit out of my rod bearings with 30W non detergent oil, mine worked fine. all my friends that have built multiple engines use the same stuff and they have never had any problems
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Aug 10 2009
    Manassas, VA
    Items for Sale
    I used 5W-30. I didn't know any better. Guess it might have been too thin.
    Aug 10 2009
    Manassas, VA
    Items for Sale
    I took everything apart on Friday. Cylinder #1 journal is "scored". It looks etched, just a different finish, but you cannot feel an edge or a dip. Cylinder #2, 3 and 4 journals all look the same as when I took it apart, I took pics of the first and second journals to post, but they are still on the camera. Installed new rod bearings and LOADED it up with wheel bearing grease I had (Eric and Chris confirmed it was safe to use) and I was amazed at how easy it was to turn after everything was torqued.
    I went back and checked all the bolts like 2 or 3 times each bolt because I couldn't believe how easy it was to turn. I got it started up at 12:30 am on Saturday night (Sunday morning). The idle was not stable but that is likely another issue, time to pull an axle off the parts car and start tweaking to get this drivable.
    haenszel, you were right, it was an issue with lube. I did lube it before, but being a noob at all of this, obviously not enough. I never felt what "easy" was when I took the engine apart and didn't have any experience with this before hand, so it was hard to judge when initially assembling.
    Let my mistakes teach anybody who hasn't done this before.
    Feb 26 2010
    NOVA
    cool, glad to hear something good.
    Jun 05 2009
    sucks
