Results 1 to 40 of 43
    Jul 21 2008
    Boston
    spark plug replacement
    does the B7 DIY still basically apply to the B8?
    http://www.audizine.com/forum/showth...te-for-B7-A4-s
    Account Terminated Four Rings
    Jul 04 2009
    2009 B8 Aruba Blue (discontiuned) 2.0T
    Thanx for the post. I need to check my plugs here, I am running on the rich side here, the cold days are coming. I am already hearing my exhaust poping on deceleration.
    Jul 21 2008
    Boston
    It was actually a question regarding whether the B7 DIY outlines the basic process for the B8. Coming on 35k miles on my end and would like to do the change myself.
    Jul 04 2009
    It dosen't make much of a difference with our B8. Do you have access to a sparkplug socket? And remember to be gentle with the wires and clips connecting to the coil pack, they could be brittle, especially in cooler climate.
    Jul 21 2008
    Boston
    Thanks for the warning. Figured it would be similar. Just didn't want to miss out on any nice to know tips specific to our b8's. Still have to find a torque wrench and a sparkplug socket. Only have the 1/2in drive torque wrench which i use for the wheels.
    Senior Member Three Rings Kavan's Avatar
    Jun 12 2009
    Audi S4 2011 3.0T
    T.
    How many KM do they suggets spark plugs at? 90 or so?
    Registered Member Two Rings
    Aug 19 2010
    Foxoboro/ma
    anyone have pics of this diy? Those new E3 plugs are suppose to be great
    Jun 12 2009
    Audi S4 2011 3.0T
    T.
    http://www.partsgeek.com/catalog/200...park_plug.html
    which spark plugs do we use for the Audi?
    Also, could we not use NGK Platinum/Iridium plugs?
    Jul 21 2008
    Boston
    Quote Originally Posted by Kavan View Post
    35k miles, so about 56k km (for the 2.0 engine at least)
    Jun 12 2009
    Audi S4 2011 3.0T
    T.
    Can anyone suggest the type of spark plugs we should use for a 2L 4 C. OEM? NGK? BOSCH?
    Jul 04 2009
    well, depending on your tune. IMO, BOSCH OEM plugs will do just fine.
    Senior Member Two Rings eaniemeanie's Avatar
    Feb 22 2009
    MB C300,1971 911E Targa, 05 Pathfinder.
    Temecula, CA
    I thought the OEM were bosch or NGK? They're switching from one to the other according to the dealer, I can't remember which was switched.
    Long gone ->(2009 Audi A4 Premium current odo 95,000)
    Service history 85K miles.:85K miles......
    Jun 12 2009
    Audi S4 2011 3.0T
    T.
    I have the APR Stage 2. I am looking at NGK Iridium Laser cut or BOSCH. You guys tell me =) ?
    Jul 21 2008
    Boston
    Quote Originally Posted by eaniemeanie View Post
    Called a local dealer and they stated the OEM's were NGK. However, seems like I didn't get the correct part number. Any info on the oem NGK part number? For some reason can't seem to find this information anywhere.
    Jul 04 2009
    B8 A4 2.0T Audi part # is 06H-905-601A the # on the plug itself is PFR7S8EG and this is a NGK plug.
    Jul 21 2008
    Boston
    thanks for the part numbers...ordered from sunsetaudi.
    One thing, anti-seize - any point in sourcing the copper based compounds vs. the generic aluminum/copper/graphite permatex "advanced formula" found at your local pepboys?
    Jul 21 2008
    Boston
    Found this DIY video on youtube: http://www.youtube.com/watch?v=eN-XW2gqd_E
    Was still a little unsure of how the wire harness tabs work but the video makes a little more sense out of it.
    As well, emailed NGK and they stated they advised against using any anti-seize:
    "With NGK plugs we do not recommend using anti-seize. The zinc coating used on our plugs is all that's needed to prevent corrosion and plug seizure. Just install the plugs dry and you'll be good to go."
    Feb 22 2009
    Temecula, CA
    Changed mine on Thursday night. Piece of cake!
    Jul 04 2009
    ^^how does your old plugs look like. would you mind snapping a quick photo or 2. just for a comparison?
    Feb 22 2009
    Temecula, CA
    Quote Originally Posted by naemcivic View Post
    I want you to know I had to dig through todays oil change on the Pathfinder to find the plugs (they were only underneath a couple paper towels...)
    I was having rough idle in the mornings and now the car is much much smoother. I'm guessing I fouled up a plug when my intake blew...
    Jul 04 2009
    Thanx for sharing the pix. Yeah, I remember when your intake manifold gave away. Indeed, your plugs looked fouled. Looked like it ran abit rich.
    Feb 22 2009
    Temecula, CA
    Yeah I'm not sure aboutthe lean theory. I do know that in the mornings it idled like a crap box abut after the engine heated up it was better. The plugs were toast for that reason. I would expect to change them every 35K miles.
    Jul 21 2008
    Boston
    "successful" change on my end as well. Though still, was a real pain detaching the wiring harness. Like the guy who made that first DIY i linked to, I ended up breaking one of the clips. Basically spent about 30 minutes getting the wiring harness off and about 15 minutes actually changing the plugs. Need to buy a 90degree pick for next time.
    One thing to note, like eaniemeanie, I pulled out Bosch plugs. But the oems that I ordered and installed were NGK's. No noticeable difference on my part as of yet. In fact, no noticeable difference period after changing out the plugs so far. A bit disappointed given the effort spent in detaching that wire harness.
    Feb 22 2009
    Temecula, CA
    Quote Originally Posted by userbbc View Post
    Yeah but better to have no differentce than some. I was running pretty rough for a while....
    When I first inquired about plugs (when I was going to do my 55K, but then finding out the dealer replaced them at 35K) Sunset Audi told me that the dealer OEM was switching from Bosch to NGK.
    Senior Member Four Rings UmIsThisThingOn's Avatar
    Jun 03 2009
    1954 Deluxe Sunroof Volkswagen
    Northern VA
    Did anyone replace their coil packs when replacing the plugs?
    Just curious if I should go ahead and order them @ the same time as the plugs.
    Tschüß!
    Ðave
    ____________________________________________
    2010 Brilliant Black A4 Sline • Hüper Optik • Alu Kreuz/ÜSS • Hankook V12's • 034 HiFlo Turbo Hose • EC HFC • Milltek • ST-40 BBK
    Pending: Black Grill • Höen H11 • EC Intercooler
    Wish List: New Wheels • ECodes • EC Short Shifter
    Senior Member Four Rings coolwater's Avatar
    Nov 06 2009
    NYC NY
    Quote Originally Posted by UmIsThisThingOn View Post
    Most vendors will tell you to do both, but that's salesman speak.....
    Where are you buying em?
    -cW
    2010-A4-Q-TIP / BB - Black Int / Halogen to Bi-Xenon E-code / A5 Sline Y Wheels - Conti DWS
    GIAC ECU Stage 2(-) / STaSIS Exhaust / Eurocode Turbo Inlet / HR OE Sports/S4 Shocks / ALU Accents / LED Bulbs / Fog Rings / Reiger Style Trunk Spoiler
    AR rotors / StopTech Street Pads
    Future Mods: Side Blades / Eurocode HFIP / FMIC
    Build Thread =>http://www.audizine.com/forum/showth...m-build-thread
    Feb 22 2009
    Temecula, CA
    Are they cracked? Why spend $100 for no reason?
    Jun 03 2009
    Northern VA
    -cW
    I figured it was just a sales thing. I usually buy my Maintenance stuff from ECS.
    Nope - not cracked. Good point.
    Just plugs it is then.
    Tschüß!
    Ðave
    Feb 22 2009
    Temecula, CA
    I'm on my second set of plugs and they are fine. i expect to replace those on the next oil change(95K). My coils look fine. Never trust a person who makes money the more you spend on "maintaining" your car.
    Senior Member Three Rings MYFASTA4's Avatar
    Sep 03 2009
    MKV R32
    MIAMI
    that diy is really close, the only difference that i can tell is that we only have 1 screw holding the conectors to the coils
    after 31k miles
    Senior Member Three Rings k9lovr's Avatar
    Aug 30 2009
    08 Tahoe - 20% tint
    VA
    Awesome pics, Thanks for posting. This will make it alot easier for me. I will be doing this very soon.
    Current: 35% Tint, Gloss Black Grille, APR, Eurocode, StopTech, Powerslots, AWE, H&R, Eurogear, Lusch, OSIR, VMR, Hankook.
    Sep 09 2009
    09 RDX
    LongIsland
    Thanks for the pics MYFASTA4, so from them based on the coil packs they need to be replaced. Is there a regular maintenance mileage that they should be changed at?
    Based on ECS is their STI packs any better then factory? They also have a tool to remove them is it necessary?
    http://www.ecstuning.com/Audi-B8_A4-...gine/Ignition/
    Thanks in advance
    B8 A4 2.0T 6MT
    6K HID(low) 3K HID(fog)* AEM Boost Gauge* Cup-Holder LED's * S4 Grille * 20% Tint all * Tint Headlights * Eurocode FMIC * JHM Shiftier * DiNoc front spliter * Rain Sensor Mirror * JL W3 - XD600/1 * QI45
    Sep 03 2009
    MKV R32
    MIAMI
    I didn't get the tool just take your time taking them off , maintenance schedule doesn't say but I might replacement at 70 or 100 miles
    Sep 09 2009
    09 RDX
    LongIsland
    Sounds good I am ways away from that. So how about those E3 spark plugs?
    B8 A4 2.0T 6MT
    Sep 03 2009
    MKV R32
    MIAMI
    Not e3 , idle is smoother :-)
    Sep 09 2009
    09 RDX
    LongIsland
    Quote Originally Posted by MYFASTA4 View Post
    ? please explain
    B8 A4 2.0T 6MT
    Aug 30 2009
    08 Tahoe - 20% tint
    VA
    Thanks all who have contributed to this thread...very helpful I did mine last night and they were a piece of cake...after 34k they had pretty good amount of use....
    Active Member Two Rings wabbit23's Avatar
    Mar 20 2011
    2010 Jetta TDI
    San Diego, Ca
    after 31k miles
    I just changed my plugs out at 28k and they looked the same. Oh, and for those who are still unsure of the factory plugs, I pulled out NGK and replaced them with Bosch Laser Iridiums. No difference really. It idles a little smoother but I also did my oil change at the same time so I'm hoping for a little improvement in my Hp as well as MPG's.
    Mine- B8 A4 PremPlus Quattro 6MT- StaSIS Exhaust/ StaSIS ECU/ 034 HFC & Strat 02 Spacer/ Eurocode HFIP/ 034 Turbo Inlet/ Black 20x9" RS6 Reps/ Goodyear Eagle F1/ Tint
    Hers- MKV Jetta TDI- Smoked lenses/ Tint
    Registered Member Two Rings pandacover's Avatar
    Dec 11 2011
    live in china, business in USA
    any more detailed pics?
    Audi RS6 C5 sedan
    car cover motorcycle cover
    pandacover
    Mar 20 2011
    2010 Jetta TDI
    San Diego, Ca
    Okay so I've been on the Bosch plugs for a couple days now. It feels as if I'm missing some hp. It also seems as if the idle has gotten progressively worse.
