Results 1 to 3 of 3
    Established Member Two Rings jimbro's Avatar
    Mar 05 2010
    02 Denim Blue Avant
    HI State
    Aftermarket alarm, factory key fob?
    I don't know if this is the right forum but I wanna know if its possible to run an aftermarket alarm with the factory key fob. If so, how is it done? This is for a 02 a4 avant 1.8tqm.
    Feb 07 2008
    04 silverado V8, 06 Touareg V8, 03 S6 V8, 03 RS6 V8TT
    The boonies, near Seattle
    You would need a compustar alarm. If I remember correctly, they have alarm arm & disarm inputs so you can trigger the alarm with your factory fob.
    It would definitely be some work to get it working like you're envisioning, and the range would be as limited as your factory fob, obviously.
    What I chose to do with my car was use an aftermarket key fob and use a factory valet style key so I didn't have to carry a useless flip key.
    -dre
    Jul 26 2008
    Brisbane, Australia
    Quote Originally Posted by jimbro View Post
    Yes, we have units available here that are designed to be either add-on alarms to factory units or to oem locking systems without alarms. They are triggered in different ways but the most common is via the number of flashes of the indicator when switched on and off.
    I have had no experience with these. I would rely on a quality installer for advice and fitting. I prefer 8520 solution of using an aftermarket alarm/key fob and using a factory key.
