Results 1 to 26 of 26
    Registered Member Three Rings 10kredline's Avatar
    Feb 03 2007
    San Gangster Valley, CA
    Items for Sale
    VAG COM installation HELP, already searched this...Please help.
    Ok, so I decided to buy a vag com cable from ebay for $20. I'm trying to install it both windows 7 and windows xp but it won't connect when I click on TEST. The pc seems to recognize the cable though. The cables also came with vag 401 and I also downloaded VAG 704 a cracked version of it. Installed both version and tried on both OS's and it still won't connect to the car. I don't know if it's the cable or the software. Please help, I searched this up already.
    AEB 1.8TQM: F21 : UM Stage 3 : 3" MAF : Siemen 630cc : CX Racing FMIC : SSAC Test Pipe + RAI J-Pipe O2 spacer+ SSAC Full Exhaust : U-Shape Intake+AEM Dryflow : 034 2.0T Coil Conversion : Southbend Stage 2 : ST Coilovers : Walbro 255 Fuel pump : APR Snub
    Jun 30 2008
    Erie, Pennsylvania
    Got to device manager and find out what the com port is. You need the FTDI driver to make it work. Usually included on a little cd with the ebay cables, but you can get it from the ftdi website as well (virtual com port driver).
    Established Member Two Rings mnsirtee's Avatar
    Aug 19 2007
    los angeles
    Make sure drivers are install and working properly. Device and software/vag-com com port must match to work. FYI, vag com don't seem to work with 64bit operation system.
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    Items for Sale
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Veteran Member Four Rings FNK's Avatar
    Mar 07 2010
    Sherbrooke, Qc
    Is the cable connected to the car? Else you will never find the "Interface".
    Feb 03 2007
    Items for Sale
    Thanks for replying guys, I just figured out that you need to install FTDI in order for the ports to be recognized. ( Thanks Talky). Should it work better on Windows 7 or Windows XP? Will the cables work on VAG v. 704 that I downloaded?
    Jun 30 2008
    Erie, Pennsylvania
    For the ebay cables you want the new "vag-com lite" from ross-tech's website. I've always had the best luck with windows xp. The newer versions have too much crap for a simple diagnostic laptop, but you can make it work with some fiddling (ie: admin account, run as administrator, etc).
    Feb 03 2007
    Items for Sale
    On ross-tech's site, I know that I have to download VCDS-lite but which interface do I download?
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by 10kredline View Post
    I don't understand your question.
    - You go to www.ross-tech.com
    - Click "Download/Update" at the top of the page
    - Click "VCDS Lite" on the right side of the page
    - Scroll to bottom of page and click the download button
    - Install the software
    Mar 07 2010
    Sherbrooke, Qc
    The "Interface" you are talking about is your "car", if it's not plugged into your car, you will never have an Interface.
    Feb 03 2007
    Items for Sale
    Ok, thanks again guys. FNK, I sent a link to your inbox, go check it out. It's about the cracked version of 704.
    Veteran Member Three Rings DGAFxxx's Avatar
    Nov 27 2006
    Salt Lake Shitty, UT
    I have the driver if you need one, pm and I can email it to you. I also modified the driver to work with a bluetooth vag cable which I have been using. I've been in the process of writing an app for the ipad and bluetooth obd2 devices. Anyhow right now I've been using my vag com by remote connecting to a virtual windows os on my mac in my office. It works like a charm.
    Also you should buy the full version. Otherwise your cracked version will only be as good as a demo version unless you write a batch fille to come the d1-d3 bin files at a 1 second interval from another location.
    Hooray for boobies!
    Established Member Two Rings Roki18T's Avatar
    Feb 07 2009
    2000 Audi A4 1.8TQM
    Vancouver, BC
    It won't work 'cause of the drivers. I was stuck on this for a while but download the drivers and just drag and drop the icon onto the USB port in device manager and it'll install them for you (in Windows XP, can't say for any other OS).
    Feb 03 2007
    Items for Sale
    Ok so I partitioned my hdd to run on 2 OS, one for win7 and winxp. In xp, I just plug in the cable to the pc and it'll detect the cable then install driver right away? It seems like its not detecting anything.....
    Feb 07 2009
    2000 Audi A4 1.8TQM
    Vancouver, BC
    For XP you have to manually install the drivers. I tried for so long to have it detect and install them automatically - it does not work. Just download the drivers and drag and drop the icon on the USB port in the device manager window. That will install the drivers. That's how I got it to work when all else failed.
    Nov 27 2006
    you wasted your time and space by partitioning your hard drive. any version of VAG-com works fine on Windows 7. And if you had issues you could just change the compatibility mode to XP.
    Hooray for boobies!
    Feb 03 2007
    Items for Sale
    Well, the reason why I partitioned because I wanted to use win7 for school, but heard that the cracked vag com that I downloaded works well on xp, I don't know if that's true or not. The cables are from ebay, not the original rosstech cables...would that make a difference?
    Feb 26 2011
    Phoenix/AZ
    hi, so how can i get my hands on a cracked version for vag-com ?
    Veteran Member Four Rings csosnowski's Avatar
    Sep 05 2010
    Kegerator and brewing equipment.
    Bend, Oregon
    look around for vag-com 409.1, seems like its the last version that is stable with the fdti based cables. (torrent sites-dont get a virus lol) most of the time with win7 vag-com wont 'see' the ftdi port because the drivers were not written for windows 7. they might be compatible, but not written specifially for it.
    and fwiw, the fdti drivers do not work well with 64-bit windows 7 (even with compatibility mode) due to the digital signature enforcement. there is a workaround with the dseo (driver signature enforcement overrider) software and test mode but its still hit or miss at best. 32bit windows its doable.
    I made a 80gb partition on my laptop to run win7 for school and winxp for vag-com and etka/elsa and runs without a hitch (32bit winxp).
    2001.5 S4 Avant Sport 6MT - Brilliant Black - Nogaro Alacantra - SOLD
    2000 A4 Sedan Sport 1.8TQM - Hibiscus - Tan two-tone - All stock - SOLD
    2000 A4 Avant Sport 1.8TQM - Silver - Black
    2004 A4 USP Avant 1.8t 6MT - Silver - Black cloth
    2001 Allroad 2.7t - Atlas Grey - Grey / grey
    2003 RS6 - Avus Silver - Black / CF
    Oct 21 2005
    y
    Search for the cracked version of vcds-lite. It works perfectly with win 7. Although your anti-virus will think the crack is a virus, well any crack for that matter.
    409.1 won't work with win7 even in compatibility mode.
    Jul 21 2012
    Raleigh, NC
    Exclamation
    Quote Originally Posted by ricekikr View Post
    I have tried everything discussed here and other threads - This is what I have - http://scantool.imechatronics.com/va..._interface.htm
    I have Windows Vista - the cable appears as recognize in the device manager, still Vag-COM won't communicate with it - what's wrong?
    Sep 05 2010
    Bend, Oregon
    did you install the driver from the ftdi website?
    what version of vag-com do you have?
    Senior Member Three Rings Jimmy G.'s Avatar
    Nov 08 2010
    Metrocard
    The Brook
    GUys anyone get this to work on Win7?
    ive tried version 409.1 and 311.2 both cracked, no go . Ive also changed the compatibility method and no go. any ideas?
    Audrey the Audi
    Veteran Member Three Rings bw86's Avatar
    Dec 06 2008
    2.0L 058
    LI
    I use it on win 7. Installed fine. (409.1)
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
    2008cc - PTE6262 - Lugtronic - ID1700Xs - IECVA1s
    --> first start <--
    Veteran Member Four Rings howardfootball's Avatar
    Oct 20 2010
    '57 Ford Thunderbird
    MD
    It has worked fine for me on Win7. When you are selecting ports, pick #3. That's what worked for me.
    Senior Member Two Rings dennej1985's Avatar
    Jul 23 2012
    Wyoming
    I'm having this same issue. 409.1 will not even start up. The drivers for the cable say they are installed and working properly. I have windows 7 64 bit. Tried compatibility settings and the program will not open. Thoughts?
    Past 2003 A4 Quattro Avant 1.8t, 5 MT
    Present 2012 A4 Quattro 2.0t 6 MT |Prestige|S-Line|Sport|Titanium|B&O|VMR|AFE|GFB-DV+|
