Four Rings
Ok heres the truth about the APR software now that Ive had it a week.
Im liking it more and more. Ok, no news to report but its just getting better and better to drive. Im getting a baseline for gas mileage. Stock I could get 280 - 300 miles a tank. So far, its on par if not slightly better, unless Im just better at squeezing more miles out of a tank. Of course, this is inconclusive still but Ive had a few drinks and Im restless.
B5 S4, B6 S4, D3 A8, B7 A4, B8 S4
Senior Member
Three Rings
You should be getting better gas milage with the tune. If it is just using more boost pressure that was being wasted before, it should require less throttle.
2010 S4 Prestige, Meteor Gray, S-tronic, B&O, Nav, Silk Nappa, Gray Birch, RS5 Pedals, RS6 Shift Knob, Hardwired V1, APR CPS Coolant Separator (Ordered), EuroCode Alu Kreuz (Ordered)
AWE Intake
2009 Q5 P+, 3.2, NAV, Brilliant Black, Beige Milano Leather, Ash Wood, Hardwired V1
I have HEX-USB+CAN Vag-Com cable if a local member needs some mods
Three Rings
So what's the deal with the 91 tune? They have said in other threads that there was a programming glitch in the 100 & 91 tunes. Does this affect your tune? Or/and all other Cali tunes that they have done with the 91 oct?
Four Rings
Four Rings
It appears that I am getting better mileage, but like I said, its still too soon to say for sure but so far this 1/4 tank shows there is.
Senior Member
Four Rings
Do you have the 91 tune? If so you need a reflash from what Keith said they discovered.
Like a surgeon with a scalpel, my S4 is a precision instrument, with which I carve and dissect my way through traffic.
2010 S4 Prem+, Quartz Gray, S-tronic, Sport Diff, B&O, Nav, Gray Birch
StopTech ST-60 BBK - Stratmosphere intake - APR Stage 2 w/pulley + exhaust
**** Have USB HEX-CAN Vag-Com cable if you need someone local to mod you ****
My Fuelly mileage
Stage 2 Banner Advertiser
Four Rings
Not all ECU codes need a reflash. His car had a pre and post flash dyno any everything is perfectly on par as far as power increase is concerned. (67 WHP increase)
EuroCode Tuning, Inc.
1872 Del Amo Blvd Unit A
Torrance, CA 90501
310-294-8108
2012 APR United States Dealer of the Year
NWS4Guy, can you provide a link to what you're referring to?
Four Rings
2nd
Senior Member
Four Rings
Jimmy's car is good. There were a few ecu's that were shipped back to the customer without the ecu being flashed properly. Only affected 91 & 100 octane tunes.
Senior Member
Four Rings
Seriously. I like it better now that I've had it for a week. Now I know the sweet power spots.
Registered Member
Two Rings
2nd
It's too bad this forum has such little traffic, because threads like this get lost and don't get answered.
I am curious about this tune and any issues that may be associated.
Senior Member
Four Rings
Thanks for the bump I confess I don't come here often.
The first handful of 91 and 100 octane flashes had the remapping of the engine timing in, but NOT the supression of the supercharger's bypass valve's opening, so the extra boost was still being bled off and was not present. APR stepped in very quickly and addressed this, since they know with 100% certainty, every ECU they flashed and what it was flashed with, they were able to contact anyone with the sub-par ECU flash and get them fixed.
No damage was done to any ECU, and this was all corrected within just a few days, the actual impact was likely less than a dozen vehicles before it was caught.
Reference: http://www.audizine.com/forum/showth...=1#post5732598
My Fuelly mileage
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
