Results 1 to 22 of 22
    Nov 08 2008
    '07 S4 6MT, '05 A4 Ultrasport (sold and missed)
    Minnetonka, MN
    07 S4 Power Steering Issues?
    Probably once a month, when I start my car, the power steering doesn't seem to be work. I can move the wheel back and forth, but there is absolutely no power steering assistance. If I turn the car off and back on, it usually starts working the second time, but there have been a few times where I've had to start it 3 or 4 times. Anybody else have this issue? The car is still under warranty, but if I take in, there's no way they'll be able to replicate the problem because it happens so infrequently. Just curious if this is a common issue or not?
    Senior Member Four Rings P0234's Avatar
    Jan 11 2010
    Need a B5 Avant!!!!
    NoVA
    Its happened to me once, but I've only had the car for two months. I turned the car off and back on and it was fine again. Curious if this is a common issue.
    Senior Member Four Rings dparm's Avatar
    Apr 24 2009
    2005 S4 sedan
    Chicago, IL
    Next time the steering goes out, drive straight to the dealer so they can see it.
    Maybe check if the Servotronic module under the dash is a little bit loose?
    2005 S4 saloon 6MT
    Senior Member Four Rings beemercer's Avatar
    Aug 14 2008
    05 Jeep GC 5.7 Lmtd. QDII - Oh-One Fat-Body Four-Two
    Central Mass
    ^seconded on the Servotronic relay and fuse, sounds like its not turning on and boosting steering at low speeds.
    RIP Sway
    _________
    JHM
    AMA
    Veteran Member Three Rings ABT B7's Avatar
    Jan 27 2007
    MB C350 4M
    Alberta
    I have the same issue and it is happening more and more recently. Usually when I turn the car off and start it again its normal again. Any others have any suggestions?
    Mods: Tinted Window (18%), H&R Sports Springs, 19" Vellano VSi, LED License Plate Lights + City Lights+ Interior, Neuspeed Catback, K&N Drop in, RS4 Grille, Gloss Black Filler Plate, Oettinger Roof Spoiler, Painted Reflectors + Rear Valance, 6000K HID Fog, 6700K D1S, JHM SS, TTRS Steering Wheel, Apikol rear differential mount, JHM Intake Spacers, Tinted Tail Lights (50%), AWE Tuning Down Pipe, Pzero Nero 245/35/19
    Future Mods: JHM LW Rotor+ Pulley+ IM+ Tune, StopTech Brake Pads + SS Line
    Active Member Two Rings kelseysautobody's Avatar
    Mar 03 2009
    Cape Cod, MA
    I've had my car for about three months and it's happened to me three times on my 07. I've checked the 641 (i think) relay under the dash and seems to be good and tight. I haven't heard of any other year having this problem yet. Turn the car off and back on and its normal again.
    Senior Member Four Rings SquiddyB6S4's Avatar
    Apr 24 2010
    Central Florida
    Relays are easy to test, and most end-user fuses can be visually checked.
    -Jason
    2004 B6S4 6MT - Apikol Snub Mount, Piggie Pipes, Magnaflow Cat-Back, JHM Tune with Launch Assist; Squid Rear LSD #01
    1996 Lexus LS400 - Bone stock, >225k miles, runs and drives pretty much like a new car
    1985 Honda VF700F - Lots of mods - 12 seconds flat
    "This weather is nuts. But it's a great day if you're a duck. Or an Audi." ~Me
    Senior Member Four Rings mbgt72's Avatar
    May 18 2008
    2003 Jeep Wrangler
    Nashville TN
    Quote Originally Posted by dparm View Post
    Quote Originally Posted by beemercer View Post
    I also agree to check this. I would suggest pulling the 641 relay (relay that control servotronic which, as said, boosts power steering at low speeds) so that you can tell if you truly do not have power steering, or just not have the extra help from the servotronic. Because not having servtronic the first couple times probably feels like there is no power steering, but you should feel a difference from the servotronic being disengaged vs there actually being NO power steering assist. Without power steering on a car that's equipped with it, it's gonna be tough to do even basic movements of the wheel, much much different from not having servotronic engaged.
    Also check your ps fluid level. Mine was really low before and you could burn up the pump without enough in there.
    2005.5 S4 MT6 l JHM Parts: Stg 1 Supercharger, Long Tube Headers, IM, SS Trio, LW Front Rotors, LWFW, Stg IV clutch, 4:1 Diff, Stern Motor Mounts, Snub/Trans/Diff Mounts, F.I. Res B6 Exhaust, Pedals &Weighted Shifter l H&R C.O. 24.75" G-F, 034 Adj UCA's, H-Sport RS4 Rear Sway l Hawk HPS Pads, SS lines & SuperBlue l Fly'sV4 LEDs l 15% Tint, 50% Front l VMR V710 GM 19" & Enkie RPF01's l JL 10W7, Focal Components l V1 Mirror Display l
    Apr 24 2010
    Central Florida
    ^Not to mention with a car this heavy, manual steering would be very difficult at slow speeds. I'm sure you still have power steering or you'd have gorilla arms by already
    -Jason
    Nov 11 2010
    Chicago
    This problem comes and goes for me. Sometimes a restart works and sometimes it doesn't. It never lasts more than a minute, but it is definitely concerning to me.
    Nov 08 2008
    Minnetonka, MN
    Quote Originally Posted by mbgt72 View Post
    It's definitely not the servotronic, it's the power steering. I came from an A4 that had no servotronic, and this is way heavier than that was. I actually gave a thought to trying to drive it the dealer while the issue was happening last time, but quickly gave up after trying to make a few turns in the parking lot I was in.
    New Member One Ring
    Sep 06 2010
    Dallas, TX
    I have had this issue a few times. One time I was a block from the dealer and drove it over with the issue and when I shut off the car in the service lane the problem stopped. They looked at it and topped it off with ps fluid. It has happened a couple times since then but is hard to reproduce on que.
    May 18 2008
    2003 Jeep Wrangler
    Nashville TN
    Quote Originally Posted by A4Ultrasport View Post
    I think you still need to give this a shot. I would imagine Audi engineered the power steering system different on a B6/7 S4 with servotronic being standard vs a B6 A4 that had servotronic as an option. With the weight difference over the front wheels due to the V8 vs inline 4, I still feel there's a chance you could be having issues with servotronic. Literally it takes 5 min to pull that fuse and plug it back in, so just reach in and grab it.
    When you're at ~25mph+ with this "problem" is it still extremely difficult to drive? If so then I would agree that there is an issue with PS and in that case it would actually be hindering you from being able to turn rather than acting neutral.
    Also have you checked PS fluid level yet???
    Jan 27 2007
    MB C350 4M
    Alberta
    PS fluid level seems okay. This problem comes and goes. It is definitely a concern since I still warranty and I want to get it fixed before the warranty is over.
    Active Member Two Rings S4fun's Avatar
    Jul 21 2010
    San Antonio, TX
    I have the same issue on my 08 S4. Usually I have some power steering, it's just not boosted to the level it normally is. I've never shut down the engine and started it again, the power always has come back to the steering after 20 seconds or so.
    New Member One Ring
    Dec 13 2009
    Pittsburgh, PA
    Same problem here with my '07 S4. Comes and goes, but seems to be happening very frequently as of late. My problem does not go away if I drive regardless of how long. I have to turn the engine off and back on and its fine. Fluid level is normal, I guess I have to check the 641 fuse. If that dosent fit it, back to the dealership
    Jan 27 2007
    MB C350 4M
    Alberta
    The challenge is we have to go to the dealership right the way while power steering is gone. After we shut it off its back to normal again.
    New Member One Ring
    Feb 07 2012
    Seattle/WA
    Anybody ever figure this out. I suspect it may be some relay since I was able to show the dealer. They retrieved a low voltage warning code on a relay.
    After they reset the code all was fine until I restarted the vehicle once I returned home and the problem reappeared.
    Active Member Two Rings nicotino15's Avatar
    Jul 24 2011
    dallas
    I was going to add the comment to stop shutting your car off and turning it back on to fix it as when this happens to my 07 S4 it simply goes away after I move forward a few feet and pick up a few mph. I guess some of you are saying it won't go away even once you get going though...
    This is a very common issue, the first time it happened to me I searched and there are a lot of threads on this of people with the same problem, sometimes changing the relay fixes it sometimes it doesn't. Seems like it is so infrequent most people give up trying to fix the problem.
    Senior Member Three Rings crabpot's Avatar
    Apr 16 2008
    2008 Chevy Silverado 1500
    Mill Creek, WA
    Definitely happen to me every once in a while.
    Nov 08 2008
    Minnetonka, MN
    As the original poster, I can say I've just gotten used to this. Still happens, but fairly infrequently (less than once a month). I've stopped restarting and instead just drive for 10 seconds or so and the power comes back.
    I was a bit alarmed at first, but as long as it doesn't happen more frequently or last longer, I'm not too concerned. Oddly, I actually enjoy the heavier steering feel a bit for the whole 10 seconds it lasts...
    New Member One Ring
    Feb 07 2012
    Seattle/WA
    Quote Originally Posted by nicotino15 View Post
    Correct, it does not go away. While moving at a 30 mph or so it becomes easier but once you are in parking-lot speed it again becomes difficult. It's as if there are 3 ratios and the one set for slow manuvering (the quickest ratio) is not functioning.
