Good to hear someone else actually drives his A6. Pray tell how you managed to break your P/S pump. Was it cavitation?
Yes, I go on drives just about every weekend. This was my first track day, and first skid pad time post-Skip Barber and in my own car. Having purposely broken traction in the dry (with the help of our dear friend Mr. Handbrake), I knew what I was up against, despite the assistance of tarmac lubrication. The rear end really doesn't like to get loose, but at full lock, pulsating the throttle, I did manage to get a modicum of slip, though never enough to need to countersteer. After one of my runs, as I slowed down and turned to get back in line, I noticed that my steering assist had disappeared. Upon further inspection, I found metallic flakes in my fluid. So, if by cavitation, you mean the impeller got loose and chewed up some of the pump internals, then yes.
Cheers! :-)
- JediJoker
"Das Boot" / 2001 Audi A6 2.7T quattro sedan:
- RS4 clutch kit / 710N diverter valves
- Bilstein PSS9 coilovers / Hotchkis Sport anti-roll bars / 034 Density adjustable front upper control arms / 034 Track Density front strut mounts
- O.Z. Superturismo LM 18" x 8" / Michelin Pilot Super Sport 235/40ZR18
- Hella E-code xenon headlights / LED tail lights (ATL-254-LED-CR-LT) / Facelift black rear license plate trim
Swapped out the crossovers for the right ones for my front components, ran 14gauge speaker wire from my amp to said crossovers, put in mid bass drivers to the rear doors (no tweeters), reconnected said rear speakers to head unit power, blacked out immobilizer light in my cluster, and recalibrated needles in said cluster.
I hear ya, you should see my girlfriend drive my car, she misses potholes like its life or death and takes it easy with these crazy angles when she pulls into and out of places, i have her trained pretty good lol
That reminds me, I need to teach my gf how to drive, and how to drive stick.
Nice, I a few weeks ago did some spirited driving on Geiger Grade (Road to Virginia City, Nevada) along with Ferrari, Lambo, Porsche, Ton of Audis and my slotted/drilled rotors helped immensely.
Replaced the trans mounts and did some vag-com adjustments. Found I don't have oil leaks, I have PS fluid leaks at the steering arms (where's the damnit smiley?) Cleaned up the underside of the car, put everything back together and went for a drive. Still have to recondition the drivers side headlight, will prollie do that tomorrow.
On thursday I replaced a CV Boot and control arm, today I sadly just got to drive it. Scared the shit out of my cousin who used to drive a 2.8 though haha.
Oil change @ 147,800mi...Castrol Syntec 5W40/OE filter...topped-up fluids, inspected undercarriage, & cleaned lower engine...noticed a small drip of oil from the oil cooler housing, so time for a new seal. Might as well replace the original oil cooler hoses while I'm there...does it ever end??
UberTeile
1999 C5 Avant - Jaspis/Lago...Der Kindertransporter und Über Kombi...llAudi Sport"Vorsprung Durch Technik"
Leaking coolant everywhere on garage floor....
Faulty water pump.....3 years since timing belt job, warranty only 12 months on pump.
Forced to do another timing belt service.
Indy does it for $650 as a token of good faith and an early xmas gift.
Could have been $1200 ticket, but indy treats me with kindness.
Thankful me.
Dave - Moderator Issue? send me an email One of my favorite philosophical tenets is that people will agree with you only if they already agree with you. You do not change people's minds.
-Frank Zappa
Thankful me.
Installed new inside door panels. Rocking a factory plaid pattern on my door cards. Woot. Door shaving next....its official now, my A6 is a project car! :)
ripped her apart for a TB job, doing upper gaskets as well. Dropped my damn Chain tensioner and broke a pad, wtf! It was going so smoothly too :( could be worse I guess, new pads on the way.
Sorry to keep you all waiting....
Pics as requested
Plaid door panels - Front door
Rear door
And the 1st stop in my door shaving process. Rub strip gone...door handle next.
This is a work in progress and will continue to change weekly until i finish up this spring.
