Lets try this again.....
GOt oil line hooked up yay!
Had to take turbo off and get someone to hold it and guide it down while i used some pliers to manipulate the flange into position. THey need to put something in the kits for these the stock lines are so stressed when everything is in final position.
Bolted up the stock drivers side lower intercooler hose
CHecked fitment with everything else
Hooked up actuator and signal lines
Bolted up motor mount. Is there a torque spec on these things?
Since drivers side is all done i put the vitton ring in the inlet pipe and mounted it up
Next was time for the tranny. I dont want sloppy seconds anymore, or the other 5 gears for that matter so i picked up a delrin bushing and a solid weighted linkage. yay notchy gears
Undone off the tranny
Popped the boot off and the washer out
Chopped the bottom off the cup as per spec
Installed new bearing and washer using a socket to evenly bang them down into place
Greased up and reinstalled
