Page 2 of 120 FirstFirst 12341252102 ... LastLast
Results 41 to 80 of 4798
  1. #41
    Established Member Two Rings nickg's Avatar
    Jun 07 2009
    Australia
    I was at service centre yesterday to add another litre of oil again, this is the second time
    car has done about 10,000 Kilometres, the first time oil light came on at 5000 Kilometres
    odd thing is, it never happened with my previous A4 B8
    2010 Ibis White A4 B8, Xenons, Nav, Sunroof
    Mods: %35 tint, 19"x8.5 ET35, H&R Springs, 5mm spacers on rear, S-line exhaust tips, Vagged
    Planning: S4 mirrors & grill, APR Stage-1, Vortex/Caractere body kit, Rear Optical PDC
  2. #42
    Veteran Member Four Rings DeMOROlized's Avatar
    Sep 18 2006
    2010 A5 2.0T
    GTA Canada
    Quote Originally Posted by Crucible35 View Post
    LOL....one quart is nowhere near 5 litres. 1 litre is .95 of a US quart. Not sure where you got the 5 litres from!
    Quote Originally Posted by Kavan View Post
    Thats what the rep at Canadian Tire told me, I put half of the 5L Castro in and the level only went up half way.. So it kind of made sense guess not.. Hmmmm
    That is much too high people forget 1 qt is 5LITRES!. That is alot! How many total litres does are cars hold?
    It's actually the other way around. 1 US quart = 0.95 litre, or 1 US gallon (4 US quarts) = 3.8 litre.
    Maybe the Canadian Tire guy meant 1 imperial (UK) gallon = 4.55 litre. Technically up here in Canada we were supposed to use imperial gallon instead of US gallon.
    1st Ring: 2002 Dolphin Grey B6 A4 1.8TqMS
    2nd Ring: 2006
    Moro Blue B7 A4 2.0TqMS
    3rd Ring: 2010 Phantom Black B8 A5 2.0TqM S Line
    4th Ring: TBD
  3. #43
    Veteran Member Four Rings Kay15's Avatar
    Jun 12 2009
    Audi A6
    Norway
    So then ^ I am right when I say I added almost 1 entire jug/bottle/what ever of oil the 5 L one, and the oil level was not at full.
  4. #44
    Veteran Member Four Rings Crucible35's Avatar
    Apr 22 2010
    13 Lawnmower Prem. Quattro
    Toronto, Ontario. Canada
    [QUOTE=DeMOROlized;5796714]It's actually the other way around. 1 US quart = 0.95 litre, or 1 US gallon (4 US quarts) = 3.8 litre.
    No...we're both saying the same thing.
    '15 A4 S Line Q Tip Monsoon
    '09 A4 Premium Q Tip Meteor (Gone)
  5. #45
    Apr 22 2010
    Really? WOW! You must have been way low in the oil dept....in fact, is this even possible? The enigine only holds about 5.5-6L. If you added almost an entire 5L jug and it's still not full that would mean you had no oil at all. Something wrong here.
  6. #46
    Account Terminated Four Rings
    Jul 04 2009
    2009 B8 Aruba Blue (discontiuned) 2.0T
    Something is wrong here. Just ge the dipstick for measurement, just in case.
  7. #47
    Jun 12 2009
    Audi A6
    Norway
    I think i drove about 4 days when it said add oil 1L continue driving.. I thought that Level was a meassure of being short 1L .. Hmmm could it be because I beat it out every so often, I did strech it out to about 40 less then topping out just to see what it had it in there did my own "Carbon Build up cleaning" =)
  8. #48
    Oct 16 2010
    Freeport, NY, USA
    Quote Originally Posted by mauja View Post
    Just had the low oil warning light come on. Looks to be down a quart. Have about 12500 miles on the car, and it has been 7500 miles since the last oil change. Will contact the dealer Monday, and post the results.
    Anyone have any thoughts about going 10,000 mi between oil changes? Seems a bit much, especially for a turbo. Although that is no excuse for a new car to have burnt a quart so quickly.
    So, I spoke with the local service department... They said the oil consumption was normal.
  9. #49
    Sep 18 2006
    2010 A5 2.0T
    GTA Canada
    [QUOTE=Crucible35;5797928]
    Quote Originally Posted by DeMOROlized View Post
    No we are not. I am saying 1 quart = 0.95 litre (which means 1 litre is a little more than 1 quart), while you are saying 1 litre = 0.95 quart (which means 1 quart is a little more than more than 1 litre).
    2nd Ring: 2006
    4th Ring: TBD
  10. #50
    Apr 22 2010
    I stand corrected....
  11. #51
    Senior Member Two Rings RaudiA4INCHATT's Avatar
    Jun 21 2009
    Chattanooga, TN
    Gonna update this thread a little bit. Had the low oil light go off yet again a few days ago. Took the car in once again as well. Told my SA of the frustration of having done this so many times over the period of time I have owned this car. He recommended I call Audi Customer Relations. So, I plan on calling them later this week and seeing where this takes me.
  12. #52
    Senior Member Two Rings eaniemeanie's Avatar
    Feb 22 2009
    MB C300,1971 911E Targa, 05 Pathfinder.
    Temecula, CA
    Quote Originally Posted by Ryan327 View Post
    Most cars make some kind of ticking sound when you shut them off, it's the metal for the catalytic converter cooling down. I think our car is excessive with all the ticking and think it has to do with the huge pan that covers a large area in the front/middle of the car. I wonder if its the pan itself expanding/contracting causing it or if something is dripping on it...a lot of time mine makes that sound while its running almost like something is dripping onto it and then being burnt off right away. A/C condensation is my guess....I'll have to see if it still does it even when I don't use the a/c.
    The "ticking" sound after you shut your car off is normal....all cars do it and the delaer is correct. It's metal cooling. They can't get rid of that.
    Yes it's the heatshields and cats. All the cars we have do it.
    Quote Originally Posted by IndiAudi View Post
    Its not there on the X5, CR-V, C300 or ES 350 (2007/08/09). Why would it be there only on the Audi?
    It's not. Depends on how the car is designed and if the heat shields actually get real hot. It's not on the X5 since they most likely fell off within the first couple weeks of owning the vehicle.
    Long gone ->(2009 Audi A4 Premium current odo 95,000)
    Service history 85K miles.:85K miles......
  13. #53
    Jun 21 2009
    Chattanooga, TN
    Yet another update on my oil burning issue. Took my car in to the dealership yesterday for yet another top off. I had put on just over 2000 miles since my last top off. Today, I decided to go ahead and call Audi Customer Relations. After we spoke they advised I go in for yet another oil consumption test (my third). I'm really hoping I can get some idea of what is happening since the mileage is becoming less and less between top offs. Anyone have any ideas as to how I can get this problem resolved or am I just stuck with it?
  14. #54
    Sep 13 2009
    2010 A4 2.0T
    Mississauga, Ontario
    keep us posted, Raudi- - I'm having pretty much the same issue. im working on a good solid bit of data before going in and really complaining (issue only started becoming an issue some 6 months ago, so i have a chart of every fill up...how much, how many kms, etc. and will throw it in their face
  15. #55
    Nov 06 2009
    2017 RDX Black on Black AWD
    NYC / DC/MD/VA
    I have a feeling the increased consumption is directly related to how hard you drive your car and how much the turbo spools.
    Just a hunch though.
    -cW
    2015 S3 Mythos Black on Red Magma Leather - AGM580 - Bilstein B14 - AWE DP - Eurodyne - aFe
    Gone - 2014 Audi A5 2.0T - 2013 S4 3.0 -2010 A4 2.0T
    New Build Thread: http://www.audizine.com/forum/showth...-Magma-2015-S3
  16. #56
    Veteran Member Four Rings cory_can's Avatar
    Mar 05 2009
    Calgary, AB
    Items for Sale
    -cW
    Don't think so....it just seems hit or miss. Strange how some have excessive oil consumption while others hardly any. 90% of the time I drive city and fairly "aggressive" on the gas/boost and my oil consumption has been quite low.
  17. #57
    Nov 06 2009
    NYC / DC/MD/VA
    I know turbo's burn oil a little more than NA engines.
    Anyway, it could be the Cam Cover Seal seepage some of us have...
    -cW
  18. #58
    Mar 05 2009
    Calgary, AB
    Items for Sale
    -cW
    That would do it....my engine compartment is very clean around the seals (and everywhere else). Unfortunately, (right now) cleaner than the outside :)
  19. #59
    Nov 06 2009
    NYC / DC/MD/VA
    I would suggest other folks look at their engine compartment and check for this if you have consumption issues.
    -cW
  20. #60
    Veteran Member Three Rings ddun's Avatar
    Jun 06 2009
    Stanton, CA
    i have the same seepage and appears to be the same amount based on your pictures/blakes thread about it. i have about 21000 miles. change oil every 5k, only topped it off twice. once right before the 10k oil service change, and another right before the 20k mark. never got the low oil message, but per MMI the level was close to the bottom limits. only needed to top off about 1/2 quart to get back to full.
    iirc, there appears to be a film of oil lining on my intercooler pipings when i did the FMIC install a long time ago and im still not burning as much as you guys.
    some oil cosumption is normal for any car, even new. but the amount some of you are consuming id be concerned and pissed and make my dealer do all kinds of test for making me come back every 1k just top top off my oil.
    2009 A4 2.0T Quattro Prestige S-Line
    APRtune, Carbonio, Downpipe, K04: AWE FMIC : STaSIS ARB : EuroCode TRUfit, exhaust, Alu-Kreuz : E-Codes : H&R Street Performance Coilover : S5 brake kit : Adam's Rotors : Hawk PC : HRE : Snow Performance water/meth
  21. #61
    Jun 21 2009
    Chattanooga, TN
    So, I took my car in today for YET another top off. My last top off was December 31st. That makes it a month and a half of driving time. I recorded my mileage from the last top off as well and my mileage was at 41,694 when the light went off. That put me in the 1700 mile ballpark for mileage between top offs. After I went to Audi I decided to call Audi Customer Relations for another update with my case. I was told by Audi that Customer Relations would have to call to authorize another oil consumption test. Yet when I call them they give me the run around. The guy told me he would have to call the dealer and talk with the service manager about my visits and prior oil consumption tests. He then informed me it is within normal parameters to have to top off oil every 1200 miles with 1 quart of oil! Seriously?!?! I have never in my life had to do that to a car of mine with the exception of an '86 CRX Si with 200,000 plus miles. This is an '09 A4 for goodness sake! I am at loss as to what to do anymore. Anyone out there with any helpful ideas? I'd really appreciate some help. Thanks guys and hope you all don't ever experience this problem with your car.
  22. #62
    Veteran Member Four Rings k9lovr's Avatar
    Aug 30 2009
    14 ML350 Bluetec, 17 MKVII
    Fredericksburg, VA
    Mine is around 1 quart every 2500 miles. Also I am currently running my tune in factory mode to see if increased turbo or tune causes increased consumption
    Current: 14 S4, Prem +, DSG, Navi, XPEL Ultimate, VMR, AMS, AWE, ECS Intake, P3, ECS RS4 Grill, HR OE, SPC Uppers
    Past: 09 A4, Ibis, CTS, APR, Eurocode, StopTech, AWE, H&R, Eurogear, Lusch, OSIR, VMR, Etc.
  23. #63
    Active Member Two Rings B8noobi3's Avatar
    Dec 22 2010
    2014 SQ5 Prestige
    IL
    I used to have a g35 cpe which had known problem of oil consumption in the vq35 engine. When I bought it, I did the opposite break in procedure of what people usually do i.e. Low rev until 1 k miles or so on. I did quite a few redline runs during the first 100 miles and every often until my first oil change. Long story short , the g35 never gave me any oil problems. Every 5 k miles change, there was less than a cup oil consumption .
    Next car was a 2008 BMW 335i. Drove it like a stole it right off the dealer, considering it's a blast to drive with that twin turbo (no it's not a lease lol). 15 k miles later , ready for first oil change( BMW recommendation ) , the level was still up there. So turbo is not the blame here.
    Sold that and now I'm in a 2011 a4. But this time I didn't do the usual heavy foot procedure because there's no whiplash when I gas it lol I know it's a more conservative car. I'm at 2500 miles now and it's not time for my first payment yet. Wish I could have seen this thread earlier .
    Everyone should know that every problem we complain to the dealer , 96% of the time the answer is " it is Normal ". Unless the car is stranded and not operatable. Example - took the BMW in for :
    Me: "most of the time stereo does not save bass and treble when I restart the car again."
    Dealer: does the stereo work?
    Me: yes!
    Dealer: well it's NORMAL for it to sometime reset itself due to its calibration
    Me: " can I push you off the chair and hope you land on your chin because your an idiot ( speaking in my mind that is)
    Dealer service advisors are manufactures lawyer I think sometimes , the more they refuse complaints or problem the more bonus they get..
  24. #64
    Established Member Two Rings ScoGold's Avatar
    Dec 05 2010
    Boston, MA
    I'm really worried about this.
    Purchased my 2009 A4 3.2 @ 14k and they performed the service (including oil change) at that time. Today I just hit the 5k mark where I would normally change the oil. The MMI is saying that I have 2800 before next service interval and the oil level is OK. I called AoA and they didn't have a clear answer as to when I should change my oil next (25k as per scheduled maintenance or 22k when my car 'tells me to').
    What's everyone's suggestion? Should I try putting in a quart now or is there anyway to check the oil since I know it doesn't have dipstick.
    Has anyone had long-term experience with only changing the oil every 10k?
    2009 Audi A4 3.2L Quattro Automatic
    35% Tints, Blesk License Plate LEDs, Yokohama Avid ENVigor 245/45-R17
  25. #65
    Senior Member Three Rings som3's Avatar
    Jan 09 2007
    Tokyo
    on my car, low engine oil warning came on @ 1,500km (950miles)...added 1qtz.
    i am at around 2,500km (1,500miles)...the engine oil level (on MMI) is about 1/5.
    my dealer told me, the oil consumption is pretty heavy till 5,000km (3,000miles).
    my 1.8T(GTI) didnt not have any issue of consuming oil this bad. pretty annoying.
  26. #66
    Jun 21 2009
    Chattanooga, TN
    My thought process is that I can't keep this car past its warranty. My car has shown me it likes to drink the oil. I bought my car CPO so I have a 6yr/100,000mile warranty but that doesn't mean I'll keep it after that. Audi Customer Relations called me tonight and said he called the dealer too late so it will be next week before I hear anything now. What kind of idiot calls a dealer 1 hour before close? Didn't help that he didn't know Tennessee is in the same time zone as Michigan(duh!). Right now it looks I will have to continue to drive my car until it decides to burn oil at an irregular amount. Then, after my engine is finally replaced I will still be screwed because who really wants to buy a car that has had its engine replaced? Sounds like a "lose lose" situation for me.
  27. #67
    Jun 21 2009
    Chattanooga, TN
    Ok, so I heard back from my dealer today. I'm going back in Thursday for another oil consumption test(my 3rd!). I hope this test finally lets me know what is going on with my oil burning. Fingers crossed!
  28. #68
    Active Member Two Rings bradthoc's Avatar
    Jan 04 2011
    2016 VW Jetta S
    Lake Havasu City, Arizona
    Quote Originally Posted by NJRoadFan View Post
    Keep in mind that "normal" in Audi speak is burning off no more then 1 quart per 1000 miles. Oh, and you'll get the same runaround and stories if you buy a VW.
    I have owned several VWs and have had put roughly 2500 miles on my 2011 A4. I have never had an issue with burning oil and a light coming on *knock on wood.*
    Brad
    2011 A4 Avant; Premium Plus, Titanium Sport Package, Tint, Stasis Exhaust
  29. #69
    Jun 21 2009
    Chattanooga, TN
    Quote Originally Posted by bradthoc View Post
    I hope you never have to experience this problem. Most unpleasant.
  30. #70
    Jun 21 2009
    Chattanooga, TN
    Took the car in for my oil consumption test today and was asked for the first time whether I had ever chipped the car. Most odd that they would ask that this time. I told them no but am worried they might find out. Will see what happens.
  31. #71
    Veteran Member Three Rings orttauq's Avatar
    Mar 11 2007
    B5 S4/B6 A4qm spt pkg
    poughkeepsie, ny
    Quote Originally Posted by RaudiA4INCHATT View Post
    So you're looking for answers yet you're being deceptive about what's done to the car? That makes a whole lot of sense.
  32. #72
    Established Member Two Rings archrenov8's Avatar
    Nov 22 2007
    '12 GTI, Black over plaid
    Halesite, New York
    And you will get the same response from MB. I had the same issues with my ML350, consuming a quart every 1,500 miles or so once it hit maybe 50,000 miles.
    Glen on Long Island- '17 AR Prestige with DAP, Cold & Warm packages, Inlay Gray Oak, Monsoon Gray over Black.
    Previously '14 VW JSW TDI, Black over Cornsilk. Prior to that '11 A4 Avant Premium+ Nav, 18" Sport, Exhaust Tips, Grill Strips, Meteor Gray over Black.
    Husband has '12 VW GTI, 4 door Black over Plaid.
    "The physician can bury his mistakes, but the architect can only advise his clients to plant vines." Frank Lloyd Wright
  33. #73
    Dec 05 2010
    Boston, MA
    About once a week I get a message when manually checking the oil level via MMI that says 'Replace oil'. Then after 5 minutes of driving it goes back to oil level OK.
    Any idea why this may be happening? I wonder if it is related to this other people have been mentioning. I will be bringing it in for service in the next few weeks for the routine 25,000 mi service.
  34. #74
    Active Member Two Rings brokes4's Avatar
    Sep 13 2009
    vista ca
    so i called the dealer regarding the oil level being on half on the mmi and they also told me that its normal and that i should only take it in when the oil light comes on. oh and my a4 only has 1500 miles...
  35. #75
    Jun 21 2009
    Chattanooga, TN
    Well, took my car in today to finish up my 3rd oil consumption test and surprise, it was still within factory specs. Oh well, I have a full warranty for 6yrs/100,000miles. I'm just going to continue to drive it and top it off whenever the light comes on. Wish I could have had some closure but it doesn't look like I will get any. On a plus note, I ordered the updated sunroof bar as mine is the solid piece and not the "newer" one. This should fix the wind buffeting that I experience whenever my sunroof is open. It cost me $160 but will be well worth it.
  36. #76
    Veteran Member Four Rings UnstableOS's Avatar
    Jul 23 2009
    2012 S4
    United States
    Wow, a lot of oil being burned by some of these new cars.
  37. #77
    Active Member Two Rings 2SwiFt29's Avatar
    Mar 29 2010
    2011 BMW M3, Audi A4
    San Gabriel, CA
    Does the dealer usually charge to top off the oil for you?
    2010 Audi A4 2.0T Quattro - Premium Plus w/ Navi - Ibis White w/ Black Interior
    2011 BMW M3 Coupe - Alpine White w/ Coral Red Interior
    Previous: 2006 Lexus IS350 Black Onyx w/ Sterling Gray Interior
  38. #78
    Established Member Two Rings Aud!'s Avatar
    Jan 31 2011
    MY11 A4, MY07 Q7, MY10 Prius, MY05 H2
    Rancho Cucamonga
    Quote Originally Posted by Granz View Post
    What's abnormal in the oil consumption? I run through a quart between oil changes. It was my understand that was normal.
    Yup
  39. #79
    Jun 21 2009
    Chattanooga, TN
    Quote Originally Posted by 2SwiFt29 View Post
    No. My car is still under warranty so they top it off free of charge.
  40. #80
    Jun 21 2009
    Chattanooga, TN
    Quote Originally Posted by Aud! View Post
    Yup
    I'd understand a single top off but I usually have to top off my car 3 times between oil changes.
