Results 1 to 18 of 18
    Site Moderator Four Rings AvanTTix's Avatar
    B6 A4 1.8T Avant, MKI TT 1.8T 225hp Roadster
    San Francisco, CA
    B6 A4/S4 - Symphony II to RNS-E (OEM DVD based Navigation)
    This write-up documents the process of upgrading from Symphony II to an RNS-E whether it's a Euro unit (8E0 035 192 C & D) or a US unit (8E0 035 192 E & F).
    for a complete list of all the differences btw a Euro unit and a NA unit, please check this thread on NavPlus... be aware that the price is significantly different btw a Euro unit (US$1,500) vs. a US unit ($2,000+), however apparently it is possible to modify a Euro unit to operate like a US unit (see the following NavPlus thread).
    please note that you will need a patch NA map DVD to work with the Euro RNS-E...
    i cannot guaranty these instructions may be applicable to those upgrading from a manufactory installed RNS-D (partial or full)...
    although such upgrade might appear daunting, it is absolutely not. no electronic skills are required to perform this upgrade, no mechanical skills either. the whole process is really straight forward.
    the actual shape of the Symphony II and RNS-E (and RNS-D) is the same, thus the RNS-E fits right in the opening of the Symphony II w/o the need for any kind of modifications... that's indeed another story of you've got a Symphony I...
    further to an RNS-E unit the following parts are needed:
    - RNS-E adaptor:
    this adaptor is designed for a non-Bose system and is ready for the CD changer... make sure you order the adaptor that meets your needs.
    - Diversity and Radio antennas adaptor:
    be aware there's another style of adaptors out there, but i would recommend not getting this one... if you do, you'll have to find a way to secure the diversity antenna in its connector, and the Radio antenna adaptor will need to be jammed in to stay plugged in...
    i had that adaptor at first, and decided to get the dual one, which fits perfectly... so imo, avoid the one pictured below...
    - GPS antenna:
    here's a couple of places where you can source these from:
    . AudiZine classifieds
    . NavPlus classifieds
    . Euro-Parts in the States - run by BayrischerS4 from NavPlus
    . Kufatec in Germany - beware of shipping costs...
    - OEM Manuals:
    these can be obtained from Audi of America and Audi Canada Technical Literature Ordering Center, and at US$5 per publication, these are quite cheap imo...
    (...continued...)
    San Francisco, CA
    B6 A4/S4 - Symphony II to RNS-E (OEM DVD based Navigation) [Part II]
    Now on to the actual process of installing the RNS-E unit...
    i believe the pics are self explanatory, especially since i've annotated all of them... i also apologise in advance to all the purists out there if i have not used the proper terminology!!!...
    - Symphony II Connections:
    - Fuse Box Cover:
    (...continued...)
    San Francisco, CA
    B6 A4/S4 - Symphony II to RNS-E (OEM DVD based Navigation) [Part III]
    - Knee Bolster - Removing:
    - Knee Bolster - Re-installing
    San Francisco, CA
    B6 A4/S4 - Symphony II to RNS-E (OEM DVD based Navigation) [Part IV]
    - RNS-E Unit Connections:
    - RNS-E Connector Adaptor:
    - Diversity Antenna:
    - Diversity and Radio Antennas Adaptor:
    (...continued...)
    San Francisco, CA
    B6 A4/S4 - Symphony II to RNS-E (OEM DVD based Navigation) [Part V]
    - GPS Antenna:
    - GPS Antenna Location:
    - RNS-E Connections:
    - CD Changer Connections:
    wire the CD Changer harness (part number: 8E0 051 592) following the instructions provided w/ the harness w/ the only exception that the wires should be plugged in directly the Connector #1, do not use the connectors provided w/ the harness... then as far as the ground wire goes follow the instructions below...
    finally the next step is to VAG the car so that it acknowledges the RNS-E unit... accessing "Module 17 - Instrument Cluster" isn't necessary if you've already had an RNS-D installed and programmed before...
    now time to put your car back together, so just follow the above instructions in the reverse order...
    Stéph - Moderator
    MY2003 B6 A4 1.8T Avant
    : DenimBlue||Ebony||5-Speed MT||Quattro||Premium Package||Sport Package
    MY2002 MKI TT 1.8T Roadster: BrilliantWhite||RedAmber w/ Baseball Optic||6-Speed MT||Quattro||Premium Package||Audio Package
    San Francisco, CA
    Re: B6 A4/S4: Symphony II to RNS-E (OEM DVD based Navigation)
    for those of you looking for the pics, i had to switch internet providers and unfortunately the pics went down by doing so... but you can still see all of them by checking out my corresponding "Symphony II to RNS-D to RNS-E" Fotki album... the pics are stored in the order of the installation iirc...
    Stéph - Moderator
    Jul 28 2008
    Audi A4 B7 , Volvo 360 Turbo
    Sweden
    Hi
    plz can u upload all the picture again
    i realy need this guide
    //Bolle
    Senior Member Three Rings S4King's Avatar
    Aug 01 2009
    Houston, TX
    Need to re-host the pics.
    Active Member Two Rings Headsock's Avatar
    Oct 02 2009
    Boston
    is there any way we can get the pictures back?
    San Francisco, CA
    Alright, finally got around to re-linking all the pictures...
    Stéph - Moderator
    Active Member Two Rings CKS's Avatar
    Sep 28 2009
    Truckee, CA
    Wow, not sure how i missed this post when i just did mine, this is great! Thanks for the link to the manual. I have a Q unit in my B7 S4. Do you happen to know which manual want?
    2008 AUDI A3, A4, TT NAV PLUS RNS-E ENGLISH
    or
    2005 AUDI NAVIGATION PLUS RNS-E OM ENG
    Senior Member Four Rings BASARAB's Avatar
    Mar 01 2010
    2004 Audi A4, 2004 Saab 9-3
    Farmington Hills,Mi
    Quote Originally Posted by AvanTTix View Post
    I was just about to say, "wow, pics are working now?!" Awesome tutorial
    Apr 11 2010
    CO
    awesome writeup, where can I get these wiring harnesses and also antenna adapters...Also I have BOSE, they make an adapter for it as well?
    New Member One Ring
    Apr 26 2010
    Ducati 848
    Elk Grove, Ca
    Wow, great post. Love the details including the pictures. Definitely will have to give this a go one of these coming months.
    Nov 17 2009
    Boulder Colorado
    I have a question about the harness; Do the passive front speak connectors have the same connection on both sides? Could i run the symphony connector straight into the RNSE? I have a bose adapter, but a non bose car.
    Active Member Two Rings okhan's Avatar
    Sep 24 2008
    Halifax NS
    Fantastic DIY AvanTTix! Here's an updated link to the Audi Technical Literature Centre.
    K&N filter, StaSSis Streetsports, 034 HFC, Milltek Exhaust, Autospeed FMIC, Apikol snub-mount, RS4 rear sway bar, USP front, 18" BBS CH, B7 brakes, S4 door blades, TT225 injectors, Forge 007, K04-15 Turbo, Unitronic Stage II+, RNS-E, Fiscon BlueTooth, TT-S MFSW, RS4 pedals and shifter
    Active Member Two Rings A4QuattroV6's Avatar
    Jan 16 2011
    Reno, NV
    update pics please some won't load and I will be doing this soon myself :)
    Feb 20 2010
    Michigan
    Where can you buy wiring to run the GPS Antenna from the RNS-E unit to the shark fin on the roof?
