Results 1 to 15 of 15
    Jul 30 2010
    GA
    Remove Instrument Cluster
    I found this excellent tutorial on how to remove and clean the instrument cluster. My question is that should I remove any fuses or the battery before removing the instrument cluster.
    TIA for any assistance.
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    Can you show us the tutorial too...?
    Thanks
    Audi A4 in an RS4 body powered by ToM's Garage
    Mike
    DUH! an Audi
    los angeles, CA
    no, from what i know you do not. however do not turn the ignition on with the cluster off might throw a code.
    doctor, to remove the cluster: there is a cover above steering wheel, remove that...it will expose 2 torx bit screws, from there remove those and just remove the cluster thereafter.
    when removing, move one side to the right and then remove the plug, then do so to other side.
    Jun 02 2008
    Greece
    Quote Originally Posted by Quattro View Post
    That is what I know....I wanted a new cluster with higher speedometer numbers....not sure if it would work though from another car or needed a new setting / coding...
    Mike
    Jul 30 2010
    GA
    Quote Originally Posted by Doctor View Post
    Thanks
    Hi Doctor,
    http://www.audiworld.com/tech/int64.shtml
    Jun 02 2008
    Greece
    Excellent write-up. Thanks a lot :)
    Mike
    DUH! an Audi
    los angeles, CA
    only way, you could an rs4 or s4, but you would have to buy one brand new, then program at the dealer (mobilizer)
    Senior Member Two Rings Dubwars's Avatar
    Feb 28 2010
    06 A4 S-Line, 07 Cervelo Soloist Carbon
    St. Paul, MN
    Does anyone know if you can purchase just the clear plastic "window" of your cluster assembly? I don't know what the actual name for this piece is, but the previous owner of my car scuffed it up a bit and I would love to put a new one in if it was relatively inexpensive.
    Jun 02 2008
    Greece
    Or a used one....I would really like an RS4 one...
    Mike
    DUH! an Audi
    los angeles, CA
    From my understanding you can not reprogram the miles on the cluster. So the only way you are able to reprogram the miles is brand new. Unless you find a used cluster with the same miles as what you have you are set.
    Jun 02 2008
    Greece
    Guess again....You can lower your mileage as much as you desire....hahahaha.... :D
    Mike
    Jul 19 2010
    1992 Mazda Miata
    New York
    The Vag-Tacho program has an option for you to set the mileage on the cluster. The option in the menu was mileage/kilometer correction.
    Established Member Two Rings Humble tree's Avatar
    Aug 25 2014
    Salt Lake City, UT
    Items for Sale
    Quote Originally Posted by itzsleepy View Post
    So all one needs is vagcom?
    Do what thou wilt
    Veteran Member Four Rings p0isin's Avatar
    Dec 23 2011
    massachusetts
    Vagcom is not the same as Vag-Tacho
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by Dubwars View Post
    Before you do that, get some of that Meguiar's Plast-X stuff most auto parts stores sell. Take out the cluster and polish the bejesus out of the clear lens while you watch some dumb TV show.
    11 A4 Q, Prestge, Black
    95,000 miles, APR Stage 1
