Results 1 to 15 of 15
    Veteran Member Four Rings pOrKcHoP07's Avatar
    Oct 13 2007
    '85 E30 318i
    Yonkers, NY
    Update: Wipers stuck in the middle of the windshield!
    New Issue:
    So I had the issue of my wipers stopping in the middle and it turned out to be that the nut on the linkage was loose. With the help of manguyen, I was able to get it back to normal. This worked for a week and now my wipers move really slow...I think the linkage has seized due to rust etc so I will need to "refurbish" it.
    I am a noob and searched, but what's the fuse number for the wipers? Everytime I start my car they attempt to move and I feel that I will burn the motor out with the seized up linkage.
    Old Issue:
    So my windshield wipers function correctly except they do not return to their resting place on the bottom of the windshield. I searched and apparently it is out of alignment and I need to realign the nut or linkage? I looked at the wiper arm and the right one look like it popped out..I can see a white threaded piece etc...
    Does anyone have a DIY to realign this? From what I read: pull cover on the top of the engine bay and adjust the nut...but I think there's more to it then just that.
    I don't think it's the motor or transmission as it works correctly...
    I appreciate the help!
    2003 Audi A4 1.8T Quattro
    AKA: masterforu2nv
    Current Mods:
    Debadge. 3000k DDM Tuning HID Fogs. 5000k DDM Tuning HID Kit. AWE Exhaust. Window/Fog Vag Mod. VMAXX Coilovers. Enkei Raijins. Adam Rotors. Hawk HPS Pads. SS Brake Lines. RAI Testpipe. Racetec FMIC. JHM SS. Motoza Stage 1 Chip.Evolution Racewerks TIP.
    Oct 16 2006
    Naperville
    Items for Sale
    this happened to me, its quite and easy fix. if you take out the rain tray and look in to the wiper linkage on the driver side. you should see like a brass nut, losen that and rotate those arms 180 degrees. wish i could explain better, but there is a DIY on here. that nut tends to loosen and the wipers stick in the middle.
    Oct 13 2007
    '85 E30 318i
    Yonkers, NY
    Quote Originally Posted by manguyen View Post
    I have everything off except the rain tray. In order to remove the rain tray I need to remove the wiper arms right? I took off the nuts etc but the wiper arms won't come up..I think once I have the arms off I can get to the rain tray and then tighten down the nut
    AKA: masterforu2nv
    Current Mods:
    Oct 16 2006
    Naperville
    Items for Sale
    i'll be back in 5 mins, im going to run out to my car and snap a picture for you
    back:
    you should see the nut, the little brass arm should be facing to the left, if you wiper is in the middle, you'll see if facing towards the right. i messaged you my number if you need help. its the nut thats in the center of the picture thats back a little ways
    Oct 08 2009
    Mass
    Items for Sale
    Your main wiper linkage is probably seized.
    Oct 16 2006
    Naperville
    Items for Sale
    ^^^ nope, his wipers still work. just default position is up.
    read this, dont click link in the thread
    http://www.audizine.com/forum/showth...t=stuck+wipers
    Oct 13 2007
    '85 E30 318i
    Yonkers, NY
    Manguyen you are the man! Thanks for talking me through it..The hardest part was getting to that nut!
    Everything is dandy now!!!!!
    AKA: masterforu2nv
    Current Mods:
    Oct 13 2007
    '85 E30 318i
    Yonkers, NY
    Does anyone know what fuse to pull for the wipers? The linkage seized up and I don't want the motor to burn out.
    AKA: masterforu2nv
    Current Mods:
    Oct 16 2006
    Naperville
    Items for Sale
    wtf, your wiper system is going to S%#T.....
    Oct 13 2007
    '85 E30 318i
    Yonkers, NY
    haha yea it is!
    AKA: masterforu2nv
    Current Mods:
    Aug 04 2009
    2004 A4 1.8T Dolphin Gray
    Quincy,MA
    Ok, so I have the same original problem as the OP, my wipers are stuck in the middle. So I have followed exactly what you guys are saying and it doesn't seem to be helping... I feel like an idiot....
    I took everything off, got to the nut, turned the nut so it brought the brass arm around to face the left like manguyen's picture. Then I bolt it everything back up make sure the wipers are in the right spot. After I turn the car on the wipers work but stop right in the middle again. I go and look back under the hood and the arm has moved to anywhere between 12 o'clock and 3 o'clock.... I made sure the little nut was tight, but the more I try and tighten it the more the linkage moves... I made an opposite force on the linkage so I could try and tighten the nut and the linkage would stay put... and I still got the same result. Am I missing something?????
    Help would be appreciated! Thanks!
    Apr 12 2007
    Milwaukee
    remove the wiper arms and pull the linkage out for better observation
    May 23 2008
    Denver
    Quote Originally Posted by OhhFourA4 View Post
    I just did this fix this week.
    Don't use the little brass nut to move the wipers.
    Loosen the brass nut then use a crescent wrench to grab the brass rectangle piece. Make that piece completely parallel with the 2 torx screws on the bracket. Then tighten that brass nut back down.
    If you only use the nut to move the whole wiper linkage, you are still turning the motor. That's why you need to loosen the nut on top and sort of lift and turn that rectangle piece.
    Looking to trade/sell my JL Audio 500/1v2 amplifier - BRAND NEW still in box + wiring etc... for TT225 injectors
    Veteran Member Three Rings AvantJunkie's Avatar
    Jul 17 2009
    Too much shit.
    Longview, WA
    Quote Originally Posted by pOrKcHoP07 View Post
    It's #36--green 30 amp, middle row, second from the bottom. Hope this helps.
    **Brett**
    2002 A4 Avant 1.8TQM Brilliant Black/Platinum with some stuff.
    My car and I have a lot in common--we're both kind of old and slow, but still manage to look pretty fucking cool.
    Aug 04 2009
    Quincy,MA
    Quote Originally Posted by turboSpartan View Post
    Looks like its fixed! *crosses fingers* lets hope it stays that way! Thanks for the advice turboSpartan! And thanks for the initial write-up manguyen!
    Saved me the embarrassment of looking like an idiot with my wipers up 24/7 and the cash of getting it fixed elsewhere!
