Results 1 to 40 of 50
    Veteran Member Three Rings chris164935's Avatar
    Apr 18 2007
    2001 Audi A4 1.8tQM
    Orange Park, FL
    Wink Just Another Plain-Jane Build Thread.
    So, this build has been off and on for the past 3 years, but now that I'm finishing up school, I now have more time and money to put into this thing again. Some of these parts I've had for the past 3 years sitting around collecting dust or in use preventing various paper documents from blowing away. So, I've started this thread off with those parts first. Also, nothing in here is set in stone, so expect some changes to the build over time. Anyway, my goal now is to have it running before the end of this year.
    PARTS LIST*
    HEAD
    AEB Head With Massive Port And Polish
    CAT Cams 1003756 Solid Billet Cams
    CAT Cams Gold Valve Springs
    Supertech 1mm OS Intake Valves With Single Groove Keeper
    Supertech 1mm OS Exhaust Valves With Single Groove Keeper
    Rosten Solid Lifter Buckets
    Rosten Lash Caps
    Rosten Titanium Retainers
    ARP Exhaust Studs
    TURBO/EXHAUST
    Precision Turbo PT6266 CEA T3 .82 Turbine With Ported S Cover
    SPA T3 Manifold
    Borla Muffler
    Custom 3" Exhaust With V-Banded Sections
    BLOCK
    06A Block Bored To 83.xxmm
    9.25:1 83mm ?? Pistons
    144mm Pauter Rods
    ARP Custom Age 625 Rod Bolts
    Knife-Edged Forged Transverse 86.4mm Crank
    ARP Main Studs
    ARP Head Studs
    Fluidampr Harmonic Balancer
    DRIVETRAIN/BRAKES
    034 Track Density Motor Mounts
    034 Track Density Transmission Mounts
    034/Apikol Track Density Diff. Mount And Bracket
    Clutchmasters FX700 With Steel Flywheel
    JHM Solid Short Shifter
    Adam's Rotors Drilled/Drilled/Slotted, Gold Zinc Coated Rotors
    INTAKE
    2.5" Charge Piping
    Custom A/W Intercooler Setup
    SEM Large Port Intake Manifold
    ENGINE MANAGEMENT/FUELING
    Autronic SM2
    Autronic 500r CDI
    Innovate LC-1 Wideband
    Racepak IQ3 Display
    Racepak IQ3-To-Autronic SM2 Harness
    Bosch 1600cc Low-Impedence Injectors / ID1000 Injectors
    Twin Bosch 044 Pumps
    IE Dual Pump Surge Tanke
    -8an/-6AN Fuel Lines
    ATP Fuel Rail
    Fuelab Adjustable FPR
    *Parts list subject to change without notice.
    First, the car: a 2001 Audi A4 1.8tQM. Nothing too special; Hibiscous Red (one of my favorite colors ), stock wheels, Eibach lowering springs, and Bilstein shocks.
    Now, for the head. Basically, we took an AEB head and had it ported and polished. The seats were also cut to allow for the bigger valves as well as had brand new valve guides installed. Also, according to CAT Cams, some machine work may be required to allow free rotation of the cams. This had to be done for the exhaust cam. Assembly for the head has already begun, unfortunately, no snapshots of the work in progress just yet. In the end though, this head will be capable of 10,000+ RPMs, no sweat. Hopefully, the block will be able to keep up!
    As for the block, I had a forged 1.8t crank sent off to Jared at SCCH for knife-edging and balancing. I have the main caps and am just waiting on the arrival of my ARP main studs so that the rest of the machine work can be done. Pauter rods are also in the mail right now as well. When they arrive, assembly of the block can begin. I already have the pistons and brand new rings and wrist pins.
    And finally, some random pics of other go-fast parts.
    Piston Rings and gaskets.
    Autronic SM2.
    Wiring harness laid out and ready to be wrapped.
    Injectors.
    Various mounts.
    That's it for now; however, I still have plenty more packages coming in the mail this week!
    "You know you have a bad idea when Ford guys are making fun of you."
    "The Internet is dead."
    FS: Bullseye Power S372 1.10AR Divided T4 W/ Standard Cover.
    Registered Member Four Rings CrtchRktRcr's Avatar
    Feb 25 2009
    CRF50
    Scottsdale AZ
    soooo jealous. Looks great so far.
    AEB B5 A4, QUATTRO MANUAL SPORT-H&R,FORGE,1BAR,5BAR,BOOM
    xbox live: Cr0tchf4i
    ["im in the computer lab and some dude with about 8" just sat down next to me -S4Jet"
    WWW.ASKMY2CENTS.COM
    Senior Member Four Rings flynnr's Avatar
    Sep 22 2008
    1969 chevelle SS 454 convertible
    Minnesnowta (Roch)
    awesome
    1999 Audi A4 Avant 1.8tqm
    JE pistons/ Scat Rods/ Built AEB head (8500rpm)/ GT2871r/ 034 IIc Standalone/
    034 Tubular Mani/ full 3" Exhaust/ Racetec FMIC/ Stg 4 Clutchmasters/ V&S shift kit/
    H&R Coilovers /H Sport sways F&R/ AR racing 330mm BBK & S4 rear brakes/S4 HID's
    Senior Member Three Rings anmagro's Avatar
    Sep 14 2008
    98 Audi A4 2.8 30V 5spd Quatto
    MORE PICKS OF THE CAR! great color.
    Black On Black 98' Audi A4 2.8L 30V 5spd. Quattro "Esabell"
    BBS RK's - Zimmerman - Vogtland Sports - Thrush Welded Cat-Back - DDM 6000 - Reigar RS4 - K&N Spectre - EbaySS - SpeedTuning Stage I
    You know your an Audi freak when you check audizine before you leave rather than facebook
    Oct 06 2004
    Minnesota
    Great build. Moved for you
    AZ B5 & MW Moderator: PM me with any concerns or questions
    '99 Audi A4 1.8T Holset HX35W- Widebody- Matte Green -PVW 11.09
    R135
    246
    Senior Member Three Rings DonnieDark0's Avatar
    Mar 02 2009
    bs 54
    north america
    Cant wait to hear what it sounds like , especially at full boost. goodluck to you sir.
    ACE
    CELison - "would you rather go fast or have your car look stupid when you park?" - hahahaha
    Apr 18 2007
    2001 Audi A4 1.8tQM
    Orange Park, FL
    Quote Originally Posted by anmagro View Post
    This is all I got... She's covered in dust right now. The other A4 is my daily.
    Jun 14 2007
    Connecticut
    Awesome color for so much HP. Real understatement!
    I have the Apikol rear diff mount in street density, I wonder how much worse the race density is. I have T/D motor/tranny mounts everywhere else, but was told to stay away from the red bushing as its really harsh.. Probably just opinion though.
    VAST Performance Stage 3 B5 S4 | Videos
    Apr 18 2007
    2001 Audi A4 1.8tQM
    Orange Park, FL
    Oh, I'm sure it's gonna be rough. But I'm not really worried about all that. This is gonna be my fun car; not really a daily driver.
    Senior Member Three Rings Jc61990's Avatar
    Aug 22 2008
    99.5 Audi A4 1.8TQ
    Long Island, New York
    very nice build. just one question this is the first time ive heard of it or seen it done, whats the purpose of knife edging the crank?
    JC | 1999.5 Brilliant Black A4 1.8TQ
    3" 034 Downpipe | 034 HF Cat | Forge 007 | Double Din Swap | S4 Steering Wheel | Burberry Plaid Trim | Bilstein Sports | H&R Race Springs | ECS Coilover Kit
    E-codes | DDM 4500k 55w HID | Samco Hoses | FMIC | GlowShift Elite Boost/Vac | Innovate LC-1 | Auto Tech Pod
    Registered Member Three Rings
    Aug 10 2009
    Rochester, NY
    That's what the color of my car is supposed to be when its all shiny....*Sigh*
    2002 B6 A4 1.8tqm: TurboSmart DV, 2871 Elim, ATP Manifold, Revo Tune, 630cc injectors
    Senior Member Two Rings GaroBlu's Avatar
    May 13 2009
    '00 S4 / '02 GTI VR6
    Vienna, Austria/ San Diego, CA
    Looks like a killer build! Glad to see that you actually have a knife edged (or boat tailed as I learned) crank. That shows that you are paying attention to detail and I respect that.
    Good luck!
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    Fast Audi sedan, Slow Subie wagon
    SL,UT
    good to see all this going into a Quattro car this time
    Site Moderator Four Rings onemoremile's Avatar
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Just make sure that crank is still perfectly balanced if you are intending to spin high revs.
    Senior Member Three Rings Oceanside's Avatar
    Dec 12 2008
    2001 A4
    St Pete FL
    We Can stop here, Florida is BAT country!
    AWM BAT A4 / AGP D42 .48 / Tapp 630 / IE Rods / LwFw+ S4 SB / APR Stealth / Garrett-Precision 450 / 2001 FWD Highway Menace
    Apr 18 2007
    2001 Audi A4 1.8tQM
    Orange Park, FL
    I suppose it's time for an update... Haven't been able to get too much done since I've been super busy recently with school, work, and a wedding (not mine, although I'm sure my girl wishes )! Mostly, I've just been waiting on more parts, which some have arrived.
    But, before the pictures, I do have a quick question: Did the FSI motors not run thrust washers? My #3 main cap does not have a provision for them...
    Okay, now some pictures!
    Some friction shims; one for the crank nose and another for the flywheel.
    CATCams cam gear.
    ARP head studs.
    ARP main studs on the block. Was using them to make sure the main caps would fit. They don't. Lol. A tiny bit of shaving to the block will be needed for the caps to fit.
    And here is what I'm talking about with the thrust washers.
    But enough of all that, here's the stuff that I'm really excited about!
    RacePak IQ3 digital display dash.
    Also got the interface cable so it will work with my Autronic setup.
    And lastly, my brand new Pauter rods with rifle drilling and ARP Custom Age 625 bolts.
    Senior Member Four Rings lowandslow4now's Avatar
    Jul 12 2008
    08 GLI,08 Jeep, 99 MK3 jetta VR6
    Palm Beach,Fl
    Nice build so far. I am assuming its going to be a drag car. If it is what times are you shooting for?
    034 Stage 3 BT, Unitronics,H&R,etc,etc
    Apr 18 2007
    2001 Audi A4 1.8tQM
    Orange Park, FL
    Hmmm... I know what I'd like to run, but I don't want to speculate yet.
    I am looking to get into the NSCRA Outlaw Street class though based on my car's setup: http://www.nscra.com/outlaw-street
    And the IFO: http://www.importfaceoff.net/race_rules.htm
    Probably run in the Forced Induction Sport or Forced Induction Pro class.
    Senior Member Four Rings Gaberossi's Avatar
    May 12 2009
    Volcano Black Audi A4 pte5857, YZF R6-no longer running, 95 Toyota pickup
    Parkland,FL
    i cant wait to see this car at NSCRA....I am at almost every event in south florida....good luck man i will be watching your build as it goes along...do werk son
    also where do you go to school and what career are you shooting for?
    99.5 A4 1.8tMan AEB FWD-SouthBend Stg 4 (4puck)clutch-SB LWFW-Stern Control Arms -830cc -Custom USP 3in exhaust/DP - PTE5857 Ball Bearing Turbo- JE Pistons/IE Rods-EurodyneMe-Coilovers-AWE DTS-034 Mounts-Team Dynamic Wheels-BFG KDW2-and a whole lot more..-Sleeper-USP Motorsports #1 Shop!-VEI SYSTEMS[Currently employed]
    Click>>>>>My Build Heel-Toe'n the b5 everyday =P
    Senior Member Three Rings shokwav09's Avatar
    Jul 26 2009
    alot of ideas with never enough cheese
    kansas city, missouri
    the race pak is an awesome touch. im using aim sports
    since i was a child, everytime i saw a lamborghini, it represented a mans risillience to oppose an imperfection. and i swear god blessed ferrucio and his honor to stand the trial of time through ingenuity.
    Apr 18 2007
    2001 Audi A4 1.8tQM
    Orange Park, FL
    Figured I'd throw you guys a bone. So, here's a quick update. Progress on the build has slowed again (what's new...) because the holiday season sucks me dry! But, it's slowly but surely coming along.
    First, got this in the mail a couple weeks ago, but been too busy or lazy to take pictures of it.
    And now, another exciting new twist on this build. Going a new route with the intake manifold. This build may be slow but the release of the SEM manifold is even slower... Soooo, I picked up this little gem:
    ADR intake manifold with 1600cc fuel injectors and ATP fuel rail bolted up.
    The inner diameter of the runners are 40mm each, so my best options so far are GSX-R 600/750 throttle bodies or CBR 929. Between a used set of ITBs and the manifold, it's only about ~$300 versus the SEM's $800+ manifold.
    Apr 18 2007
    2001 Audi A4 1.8tQM
    Orange Park, FL
    Quick teaser: Picked up some throttle bodies for $47 shipped.
    Mar 09 2004
    nw michigan.
    Quote Originally Posted by chris164935 View Post
    oh hell yeah.
    Jim - Moderator
    I Do Werk.
    Mar 09 2004
    nw michigan.
    Are you going to fit a newer cam tensioner and do the little trick 034 did with their race car? Should help get that turbo spinning a little earlier.
    Jim - Moderator
    I Do Werk.
    Apr 18 2007
    2001 Audi A4 1.8tQM
    Orange Park, FL
    Quote Originally Posted by onemoremile View Post
    I've thought about it; not sure how reliable the tensioner would be pushing high RPMs though. Most likely just end up using a non-VVT tensioner to start... Definitely got enough things going on with this build for now.
    Senior Member Four Rings Seerlah's Avatar
    Dec 05 2007
    Ummmm, update? And you are going to run 4 TBs? One on each runner?
    I hate it when my car acts like a little bitch, treating me like the bitch
    FS:Brand New K&N Air Filter RU-3700 (3" inlet, 5" base, 4" tall, 4 5/8" top), Brand New 3" Injen (Amsoil) Dry Filter Setup with Heat Shield, Brand New OEM 06A Oil Pump, Used Greddy Intercooler...throw me some offers
    Active Member Three Rings jaychen's Avatar
    Feb 19 2011
    Brisbane
    One would assume so Seerlah, Quad throttle bodies aren't new designs. Nissan GTiR's have this setup in Australia. Crazy fast cars with minimal work done, 350hp at all 4's in a car that weighs 1100kg (2400lb). A lot of boys here that are on their P License (restricted from driving turbo till they have had their license for atleast 3 - 4 years) run them on NA SR20's and do quite well.
    Just want seat time again, that's all.
    Apr 18 2007
    2001 Audi A4 1.8tQM
    Orange Park, FL
    Project is on hold for a while. I am finishing up school, starting a new job, etc., etc. I am considering a simpler turbo setup in the meantime with the same motor build, just a T3-based turbo since it's simpler to get a T3 manifold, and running just 1 TB for now. I don't know. We'll see.
    Senior Member Four Rings Wet0willy01's Avatar
    Nov 17 2008
    05 USP, 68 Camaro, 00 Cavalier
    Lancaster, PA
    -Andrew
    2005 Dolphin Grey Ultra Sport
    HTA3582R 1.8L
    AEB IECVA1
    Agtronic Motorsport
    PARTS FOR SALE
    Apr 18 2007
    2001 Audi A4 1.8tQM
    Orange Park, FL
    Very nice but is only for transverse cars...
    Nov 17 2008
    Lancaster, PA
    shoot, I completely missed that. Sorry. But I'm sure Markku could do a t4 variant of the manifold he currently offers with a v-band. I can vouch for the quailty of his craftsmanship.
    http://www.agtronicmotorsport.com/gallery/andrew_1.8t/
    Good luck, looks like a solid project.
    -Andrew
    HTA3582R 1.8L
    AEB IECVA1
    Agtronic Motorsport
    PARTS FOR SALE
    Senior Member Four Rings Dan[FN]6262's Avatar
    Sep 12 2008
    02 A4, 94 GMC, 06 450R
    South Central Pa, Dundalk MD
    this is totally boss.
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
    Apr 18 2007
    2001 Audi A4 1.8tQM
    Orange Park, FL
    Alright, here's the deal. I miss the car so much that I have decided to go with a T3 turbo setup to save some money and time with less fabrication work. Trying to fit 3" intercooler piping, a 4" downpipe, and the T4 turbo itself was going to take up a lot of time and money. So, I just purchased a new Precision T3 turbo that I think pair nicely (for a T3 turbo, anyway) with the engine build. Now, fitting a 3" downpipe and 2.5" intercooler plumbing will be a lot easier.
    Also, now that the SEM manifolds are in stock, I have picked up one of those as well. This will save a lot of time, money and headache with having to build a plenum for ITBs and tuning the damn thing.
    Anyway, here's a list of what is changing (also updated on the first post):
    9.5:1 83mm CR Pistons
    SPA T3 Manifold
    2.5" Charge Piping
    80mm Godspeed Throttle Body
    Bosch 044 Fuel Pump
    Custom Surge Tank
    Another big change is we are going with CP Pistons. I have been having a lot of problems with JE's pistons cracking near the wrist pins (8 pistons in total, all in the same spots); these are mostly hairline fractures. So, it is time to move on to another brand. I have heard MANY good things about CP and their pistons. Plus, I was able to grab a set of their 9.5:1 83mm pistons from a place overseas for $600 shipped, which is great considering the places that sell them here in the states charge $675 without shipping and do not have them in stock (it was actually by luck that this shop had them in stock).
    As a reference, when I grenaded my stock engine and melted the piston in cylinder #4 (stock piston), it got messed up pretty bad, but it did not crack in the areas where all my JE pistons have cracked.
    But moving on. Most of the stuff in the new list is coming soon. However, I do have the SPA manifold in my possession. Man, is it gorgeous.
    Also, a box of a bunch of random parts to assemble the motor and brand new sensors for the SM2.
    Apr 18 2007
    2001 Audi A4 1.8tQM
    Orange Park, FL
    Another project we are working on putting together is called a reluctor interface. This circuit will let us use the stock crank sensor with the SM2. What the device does is converts the magnetic sensor's output signal from a spike wave to a square wave signal. The SM4 has this built into it; but the SM2 does not. These are available online or from most Autronic dealers, however, they want $150 or more for them! The device itself is relatively simple.
    Between buying the components, circuit board, etching solution, case, etc. it will cost less that $50 to make. The toughest part is going to be getting the proper resistance set on the variable resistor.
    Apr 18 2007
    2001 Audi A4 1.8tQM
    Orange Park, FL
    And, lastly, the issue with the forged 06F main caps. I have not worked with this motor before (it is the 2.0T FSI motor for those who were wondering), so why the #3 cap does not have a provision for thrust washers was somewhat baffling.
    Pictures from earlier of what I am talking about.
    As it turns out, the 06F motor does use thrust washers. The block itself has provisions for thrust washer and then the main cap acts as the top half of the thrust washers. We figured this out 2 ways: searching through a parts database similar to what the dealership uses and through testing.
    For the testing, we installed some old used main bearings, the crank, and bolted down the caps. Without the lower thrust washers installed, the crank was able to walk by just pushing on the nose with your hand. After we took everything apart, we put thrust washers in the lower half and re-installed everything again. This time, we could not get any movement out of the crank, even using a small pry bar. So, if anyone is interested in forged billet main caps, stealing some from an 06F motor is a viable and affordable (only cost me like $150 for all the caps) option.
    Apr 18 2007
    2001 Audi A4 1.8tQM
    Orange Park, FL
    Well, my baby just arrived today. I'm so EXCITED!
    Now we are just waiting on the turbo and for my lazy ass to take the block to get the new main caps align bored.
    Apr 18 2007
    2001 Audi A4 1.8tQM
    Orange Park, FL
    Came home from work late last night and went into the garage to find my Bentley repair manual, and happened upon this as well!
    Of course, once you've owned a 72mm turbo for a few years, then every other turbo looks like a baby to you. Lol.
    Top: S372. Bottom: PT6266 SP.
    Sep 12 2008
    Could you take a picture of the inside of the SEM?
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
    Apr 18 2007
    2001 Audi A4 1.8tQM
    Orange Park, FL
    Ask, and you shall receive!
    Sep 12 2008
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
