Results 1 to 30 of 30
    Feb 01 2009
    Wes_R + R8 [113 pics]
    Hi everybody,
    Todays write up is on a Ibis White R8 with the silver side blade, very classy in my opinion. I had seen this R8 before near the area where I had grown up and can actually remember spotting it one night on my way to the Pacquiao vs Clottey fight(I asked the owner later to confirm it was him). Funny how a car you admire on the street just ends up in your drive way... I love it when life works out like that :).
    Anyway let's get into the write up.
    Here she is and a quick walk around of the car.
    I start with the wheels/engine/exhaust first, reason being things can get messy and you wouldn't want that mess with a clean already washed car. So we start with these areas first.
    Brake dust covered rim
    Applying Autoglym Custom Wheel Cleaner.
    Anything non acidic to clean your rim is best and one thing I love about this cleaner is it's ability to pull dirt out of the tire very well and with some agitation you can turn a brown tire back into black which is great for later on when you apply the tire dressing. You wouldn't wax a dirty car would you? But yet a lot of people dress their tires while they are still dirty not realizing brake dust gets on the tire to.
    Agitating the inner barrel with my EZ Brush.
    Cleaning the rim face with a microfibre mitt.
    And cleaning the caliper with my Race Glaze Brush.
    Cleaned up the exhaust as well.
    Here they are with some Chemical Guys Grime Reaper applied to them.
    Used my mini EZ Brush to clean in between the dual exhaust.
    And a 0000 steel wool pad to clean inside the pipes.
    Here is an after of how the driver's side looks.
    I didn't want to do an all out cleaning on the engine as I believe this is the same V8 from the RS4 and the coils are exposed, so to get them wet would mean problems. Yet I couldn't just leave the engine bay dusty because it is on display and will be looked at. So I used Optimum Power Clean cut 30/70 with water and wiped the engine bay down with a damp microfibre cloth getting clean areas that I could reach. Afterwards I wiped on Meguiars Hyper Dressing cut 20/80 with water for a natural finish.
    Here is an after pic of the engine bay.
    Just before the wash I wanted to clean up all the mesh vents & etc. So I took my Race Glaze Brush and the Optimum Power Clean and cleaned up all these areas first.
    After brushing out the vents I foamed down the car with Prep Wash to strip off any silicones that might have been applied to the paint. Doing this would help reveal the true condition of the paint stripping off any filler products that might have been hiding anything.
    Let it dwell for a bit while I prepared to wash the car.
    The two bucket method was used to wash the car. The reason for washing with two buckets is simple one bucket is water the other soap, after every panel you rinse off the dirt from your wash media in the water only bucket before you dip it back in the soap bucket. Doing it this way prevents you from dragging dirt all over your paint causing more swirls on the paint. Some can say that I am going to polish out the swirls any way but I feel it is backwards to induce more while I am washing.
    Natural Sea Sponge was my wash media.
    Dried off the car with my waffle weave towels and then brought it in to clay the paint.
    For those of you not to familiar with what clay does, it basically sheers out contaminants embedded in the paint. This can be raildust, fallout, or even just tiny dirt debris. If you wash your car and run your hands along the paint you will probably find that it is rough. What you are feeling is the surface contaminants.
    Riccardo Yellow clay was used. I had run out of lube which is usually Meguairs Last Touch cut 50/50 with water but this time it was just straight water.
    Paint was fairly contaminated but not terribly.
    Moving along I measured the paint to look out for any low spots or if anything had been repainted. I found the paint to be fairly thick with every panel being 170 microns or more with the average being about 200 microns. I found it funny that a stone chip I noticed still had paint in it instead of exposed metal, just to give you an idea of how thick the paint was as well Audi paint is known to be rock hard so that helps to.
    Feb 01 2009
    I masked up all the non metallic trim to protect them from getting burnt.
    Now we begin the surgery.
    I was hoping to just 1 step polish the paint but with Audi paint being rock hard I had to 2 step it to correct the swirls and then to jewel the paint to a high gloss.
    My process for the first step was Meguiars M205 with a Lake Country orange pad on the Makita rotary and here are the results I was getting.
    Before
    After
    Before
    After
    Before(I don't know what happened here, but it looks like brillio pad work)
    After
    Before
    After
    Before
    After
    Before
    After
    Before
    After
    Before
    After
    Before
    After
    Before
    After
    The tail lights were even swirly so I gave those a polish to.
    Before
    After(this was after one hit, to correct it better it required a second hit)
    I gave the car a wipe down with ipa alcohol cut 50/50 with water and then jeweled the paint with a grey 3M backing plate, a white Lake Country pad, and Menzerna PO85rd.
    Here is a shot of me jeweling the paint.
    And the results of my work.
    After a couple hours of jeweling the paint and completing the last step I finally unmasked the car.
    Feb 01 2009
    Dusted out the crevices.
    And then gave the paint a 2nd ipa wipe down to clean off the polishing oils.
    Here she is cleaned up. No wax yet but still a nice gloss because of the jeweling.
    As well before doing my last steps I double checked the paint with my 3M Sun Gun which omits the same spectrum light as the sun.
    No swirls.
    On to the waxing now to protect the new finish.
    Wax for the day is Swissvax Concorso.
    While the wax was curing I cleaned the windows with my Glass Master Pro and Stoners Invisible Glass.
    Dressed the tires with Blackfire Long Lasting Tyre Gel which was applied then wiped off later for a natural finish. And I applied Poorboys Wheel Sealant to the rims to protect against brake dust and the exhaust as well.
    Poorboys Wheel Sealant on the rims
    An after pic of the rims and tires.
    And Poorboys Wheel Sealant on the exhaust.
    And an after pic of the exhaust.
    I wiped off the wax and rolled it out to inspect it under the "light of truth".
    Perfection(not really lol, there were a few deeper scratches but we got close enough)
    Now the after pics and the fruits of my labour.
    As a quick explanation, I did not adjust the white balance on my camera properly so the pics have a blue tinge to them but to be honest I kind of like it as it makes them look artsy fartsy. Anyway you be the judge.
    I really like the gloss in this pic, not bad for a white car huh.
    Feb 01 2009
    You can't have the engine exposed like this and not take a pic of it.
    I really like the composition in this pic.
    I thought the reflection on the hood was crazy, it looks like another dimension in there.
    A couple of those "cool guy" pics. No dry steering was involved in these shots.
    I like the way the hood looks in this shot.
    The gloss in this shot looks crazy too.
    And the money shot.
    I hope you enjoyed reading through and seeing the transformation, as well as picked up a couple things on the proper way of taking care of your car.
    All comments are welcome and any questions feel free to ask.
    Cheers,
    Wes
    Veteran Member Four Rings nick71692's Avatar
    Jan 16 2008
    2010 S4, 2005 A4 USP, 2008 BMW 650I Conv. Sport, 2013 Jetta GLI
    Ohio and GTA
    Items for Sale
    Nice write-up that car is pure sexy
    2005 Dolphin Grey USP
    USP CLUB MEMBER #210
    2008 Ibis White S-Line A4 6mt, Stasis Exhaust (Gone)
    2010: S4, Ibis White, S-Tronic (Gone)
    2011 MKVI GTI 4 Door, Carbon, DSG (Gone)
    2012 S4, Monsoon Gray, 6MT (Gone)
    2014 S4, Glacier White - fully loaded
    Established Member Two Rings fas4tt's Avatar
    Apr 30 2009
    Great job as usual!
    Senior Member Three Rings SilverThing's Avatar
    Dec 26 2007
    cars & stuff
    Long Island, NY
    Wow! great work! Love that car.
    Rides:
    '06 S4 Avant, silver/black w/ alcantara, w/ V8 goodness - new DD (finally back in an S!)
    '07 A4 Avant 2.0TQ S-line & Ti, I-white/black (unicorn?) - w/ APR goodness, old DD, now beach-mobile
    '93 BMW 850ci, FE Red/Black - major garage queen
    Previous:
    '01.5 S4 Avant, Silver/Onyx (Sold...miss it a whole lot )
    '98 BMW 328ic, Cosmos/Grey/Black (Sold...miss this one a whole lot, too)
    Jan 27 2010
    South Florida
    sorry for the noob question, but what is "jeweling" the paint?
    Veteran Member Three Rings hiwords1's Avatar
    Sep 13 2007
    PA
    how long did it take? did you get the defects out by hand or high speed buffer?
    Present: 2010 Audi A4 2.0TQ Tip. Mods: APR chip, clear bra side mirrors and headlights, krautoparts.com interior/lic plate LEDs, and VAG COM mods
    Past: 2001 Audi A4 2.8QM. Mods: H&R race springs, CC mod, tinted tails, RS4 mirrors, ST chip, and VAG COM mods. Traded in
    2002 Honda Civic EX auto. Totaled
    Feb 01 2009
    Quote Originally Posted by nick71692 View Post
    Thanks, pure sex indeed.
    Quote Originally Posted by fas4tt View Post
    Great job as usual!
    Thank you!
    Quote Originally Posted by SilverThing View Post
    Quote Originally Posted by exclusivett View Post
    Jeweling the paint is basically the process of polishing the paint to a high gloss.
    Quote Originally Posted by hiwords1 View Post
    It took me about 26hrs, and I used a rotary polisher which I believe you can see me using in one of the pics.
    Feb 04 2008
    04 A4
    Dover, DE
    the write up is excellent. It seems like you do great work, good luck with the business--
    Veteran Member Four Rings TH85's Avatar
    Oct 02 2006
    2008 A4 2.0T
    Chicago
    dang!! i am impressed.
    cam you let us know where you purchased the wax and tire dressing?
    thanks!
    koni fsd/eibach suspension
    Senior Member Three Rings iceboss23's Avatar
    Jul 18 2009
    2010 S4, 2001 allroad
    Silver Spring MD
    Items for Sale
    Hey Wes, thanks for the great write up... I really appreciate the time you put into taking copious pictures (tape ball, really?), explaining your process so we all can learn something from it, and giving your thoughts on methods and products.
    Keep up the good work.
    Feb 01 2009
    Quote Originally Posted by NateW View Post
    Thanks, I appreciate it.
    Quote Originally Posted by TH85 View Post
    thanks!
    Wax came from DetailersDomain.com and the tire dressing came from properautocare.com
    Quote Originally Posted by iceboss23 View Post
    lol the tape ball... I don't know just a random thing I guess. Glad you enjoyed the write up.
    Account Terminated Four Rings
    Jul 04 2009
    2009 B8 Aruba Blue (discontiuned) 2.0T
    hi, how much do you charge by the hour? I would like some work done on my B8.
    Feb 01 2009
    Sent you a pm.
    Veteran Member Three Rings casuso's Avatar
    Sep 19 2006
    Mexico
    So no need to use M105 for corection? Only M205, nice to see you ggot everything done with the least aggressive method.
    Congrats on the job and the write up. Bravo!
    A4 B9 Tango Red Sline FWD
    Dec 07 2008
    Harrisburg, PA
    Very nice!!
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    Car looks great, nice detail!
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Feb 01 2009
    Quote Originally Posted by casuso View Post
    No M105, and least aggressive method working is always a win.
    Quote Originally Posted by JRMSLINEA4 View Post
    Very nice!!
    Thank you!!
    Quote Originally Posted by gotboost View Post
    Veteran Member Three Rings formula1guy's Avatar
    Apr 14 2009
    B8 A4 Avant S-line,2010 A4 prem + w sport package
    Northern California
    Wow, I thought I took my time and put a lot of care into detailing my car. Your attention to meticulous detail has inspired me to learn how to REALLY detail a car. Nice work!
    Dec 19 2007
    York, PA
    any reason you used pb wheel sealant on the exhaust tips? reason is that i have it at home...maybe ill have to start doing that.
    Feb 01 2009
    Quote Originally Posted by formula1guy View Post
    Thanks, glad to hear I inspired you! DetailingBliss.com is a good place to learn the basics.
    Quote Originally Posted by n7plus1 View Post
    Just to protect them and keep them cleaner a little longer. The owner came by to have it cleaned up for a wedding this week and the tips were so easy to clean this time around.
    Senior Member Three Rings Collantes_C6's Avatar
    Jan 18 2008
    A6 C6 S-line & Passat V6
    Richmond Hill Canada
    Hey, I'm very very impressed! Would you be able to do the same to my C6 A6?
    Established Member Two Rings cjernigan's Avatar
    Jul 20 2010
    Auburn, AL
    That's incredible, you do great work. That car looks better than when it was new.
    Oct 08 2010
    Lake Tahoe, CA
    Great care! Great car! Nice write-up, thanks
    Previous
    2009 GT-R | 700HP
    2008 S5 | Ibis White
    2008 A5 | Matte Gray
    Jul 16 2009
    Beautiful work!
    Nov 01 2009
    Clifton,NJ
    Great job!
    Feb 01 2009
    Quote Originally Posted by cjernigan View Post
    Quote Originally Posted by ecrew16 View Post
    lol Thanks!
    Quote Originally Posted by robbar25 View Post
    Beautiful work!
    Thank you!
    Quote Originally Posted by phil@detailersdomain View Post
    nice job
    Much appreciated Phil, I know you understand my pain.
    Quote Originally Posted by pavlo1994 View Post
    Great job!
    Cheers!
