Page 2 of 2 FirstFirst 12
Results 41 to 65 of 65
  1. #41
    New Member One Ring timmmy's Avatar
    Oct 18 2010
    S4K, RSS6 etc etc
    NH
    S4K race car : BHF V8 motor now is a V6
    Hi All,
    The 05 BHF motor in my S4K race car lost chunks of both cyl 5&6 pistons last weekend. Confirmed wiht a Boroscope.
    I dropped this motor into my 4K, motor was from a 2005 S4 cab, stored motor for a few years. Prior to initial startup cold compression was goodish (150ps +/-10 across all 8). Ever since first startup I have been struggling with excessive deceleration blowby btu had not rechecked compression. Proir to last weekends event I checked compression cold and found cyl 5&6 were down to about 120si cold. Ran the track event and by the end of it the hot compression on those two had dropped to 90psi :(
  2. #42
    Forum Moderator Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    Quote Originally Posted by S4-ORCE View Post
    not idling and being driveable at all in which was believed it was a timing chain tensioner & guide issue.
    2004 Manual.
    Build date is 10/03
    Mileage is little over 80K
    Adding information broken chain guide
    If you don't have haters, then you're not kicking enough ass.
    AMA and YES! Together we can all defeat 2.0t and 2.7t crime...
    And lastly for the grammar police that are bound to step in
    I came here from Germany in the 6th grade. I could not read or write a lick of English. I am working to get better. Thanks and sorry. I always try to edit my posts for the best grammar and easiest reading.
  3. #43
    New Member One Ring
    Apr 30 2010
    Estonia
    2004 BAS motor (its Allroad, but same block as BBK, only cams differ)
    produced 2003/10
    150k miles, first 120k using long-life oil with 18k mile OCI in germany. Alot of highway miles.
    Burns oil, 1qt/400miles. PCV renewed for good.
    Compression measured 13.5bar in all cylinders (14 is new)
    Borescope showed cylinder walls are oily and dark, scoring wasn't visible.
    had chain rattle at startup 1-2 sec.
    Did chain service, replaced the chains, guides and tensioners. Rattle almost gone (still 0.5sec occasionally)
    Found a broken upper center chain lower left guide (079109469AA). http://www.audizine.com/forum/showth...2-with-cams-on
    Replaced the valve stem seals, valve guides not replaced.
    No change in oil consumption at all.
    Seems that its the stuck or worn oil rings or sludged oil channels.
    Decided to live with that.
  4. #44
    Active Member Two Rings sharmut's Avatar
    Feb 13 2011
    Livermore CA
    2004 B6 S4.
    Sorry no build date.
    Mileage - ~108k
    Issue - Severe misfire. Swap the coil packs around, error code moves to various coil packs not relevant to the change. Compression test revealed NO compression in cylinder 1. Scope indicated leakage at the valve. Did not pull the motor apart to determine root cause, although I suspect it's the tensioner. Sold to local buyer willing to put in the time for a project car for 5k as-is.
  5. #45
    Jan 08 2011
    NH
    build date was late mid 2004- vehicle is a 2005 M/T 6 88k now on clock had 84k when i purchased on jan/3/2011 issues that i have addressed /or still having since purchase.
    Changed all plugs oil coolant thermostat and water pump.
    Throttle position sensor
    both fuel lvl sensors
    clutch
    glove box still broke.
    compression test showed the following:
    cylinders 1-4 130psi
    cylinders 5-7-8 are about 110psi and cylinder 6 is at 90psi
    at this point this vehicle is undrivable do to cyl. #6 fowling out the plugs with oil, burning about 2quarts every 300miles.
  6. #46
    Aug 31 2010
    09 R1 Track Weapon
    Greenacres, WA
    Spose i'll fess up.
    2005 B6 S4 Avant, 6MT
    86,000
    Build date I think was October of 04.
    Dropped a valve while cruising down my street at about 2500 rpm, only symptom was it started to misfire badly, no other weird sound.
    Took out the head and the block, somehow the valve head and stem (2 separate pieces) were spit back through the intake port into the manifold without damaging the valve seat, or the port.....Keepers are still in the spring retainer...very very strange stuff.
    Prior to this, the middle chain guide was broken and replaced.....I was able to drive it about 15 miles....no other damage in the engine, cam timing was still spot on....it was its time I guess.
    05 B6 S4 Avant 6MT
    06 Touareg V8
    09 Yam R1, full race
    71 Honda Z50 88cc (pit bike of death)
    64 Ducati Mountaineer 90 (in restore mode)
  7. #47
    New Member One Ring
    Mar 15 2011
    lishui
    Great idea, thanks again for everything you are doing to advance our poor little unloved platform.
  8. #48
    New Member One Ring
    Feb 21 2011
    Vancouver, BC
    2004 B6 S4 6MT
    64,000 miles
    Build date: 11/03
    Had the chain rattle at startup and Bank 2 Cam adjuster just went.
  9. #49
    Senior Member Three Rings poopypants's Avatar
    Jun 18 2007
    B6 S4, '64 GTO, '00 CBR929RR
    Ontario, CA
    2004 B6 S4 6-speed
    103k mi.
    Build date: 02/04
    I bought mine CPO at 45k mi. nearly 4 years ago on June of 2007. First issue with the engine were failed coil packs around 65k mi. Afterwards, long block replaced under warranty around 75k mi. after abnormal rattling sound near the heads and a slight depreciation in performance. Turned out to be several bent valves. Prior, the old engine was eating about 1 qt of oil every oil change (10kmi). Never did a compression test. I have just under 30k mi on the new engine and very little or no oil consumption. There is a strange muffled rattle below 1200 RPM on all gears. Any ideas?
    "If no one has been offended by what you have done, you need a larger audience."
  10. #50
    Registered Member Two Rings MD4Babes's Avatar
    Aug 08 2010
    2006 S4, 2011 R8 v10, 2010 Sierra Denali, 2011 Infiniti Qx56
    Allentown, PA
    2006 s4 b7 with 38k miles
    Burned about 1 qt every 1500 miles
    Scored walls and broken 5 rod. Engine replaced with rebuild with 22k. still burns 1 qt every 1500 miles
  11. #51
    Active Member Two Rings MS203's Avatar
    Apr 09 2011
    B6 S4
    New Canaan, CT
    2004 S4 (B6)
    39k miles..
    whats broke/needs fixing:
    -right motor mount
    -left control arm
    -fuel filter
    -intake manifold was blackened
    -fuel injection lines
  12. #52
    Apr 11 2011
    reston,va
    add scored cylinders at 33K to the list. 2007 B7 S4 motor headed for the dumpster.
    While at the shop, another car/ engine was on its way to the dumps. Same car, low mileage.
    Audi needs to figure out what they did wrong here. I would love an explanation.
  13. #53
    Active Member Two Rings Arkaid's Avatar
    Jun 20 2010
    B6 S4, E46 M3
    CA/ CT
    2004 S4
    Not sure on exact build date, but definitely late 03 sometime
    64k miles
    Driving in traffic and the car completely shut off like the battery was dead. No compression on any cylinders, pulled the motor and found that one of the pulleys in the back (cam tensioner maybe? Can't remember) had actually sheared off of its shaft and the valves and piston heads got absolutely rocked. About an inch of play on the pulley itself. Engine is being replaced with one out of an s4 cab.
  14. #54
    Senior Member Two Rings AngeloB5.5's Avatar
    May 09 2005
    2005 B6 S4 Avant 6MT
    Oceanside, NY
    add me to the list....
    2005 S4 Avant
    42k miles. I do not have much history. I purchased with 36k miles. Changed oil immidiately.
    Burning 1qt every 400 miles
    cyl 5 and 7 were scored the worst. other cyl had some minor scoring. Chain rattle got significantly worse in my short time as owner. Traces of guides found in my oil pan. compression was poor on said cylinders. exhaust valves leaking as well. Motor is a mess in every way
    being replaced with brand new motor... out of pocket. Warranty denied claim
  15. #55
    Sep 09 2011
    2005 b6 S4 cab
    Just found this thread while searching Google for my car issues... here goes:
    2005 b6 S4 Cab bought used 2/10 from a non-audi dealer, ~98,000 miles on the clock. Bought a 3 year extended warranty from Preferred Warranty Inc.
    It's been consuming oil, maybe 1-2 quarts every 1500mi or so.
    CEL came on yesterday (fyi, engine currently has 120,800mi), took it to an Audi shop, they said cylinders 5 and 6 were misfiring, oil on the plugs, carbon build up as well. They replaced plugs and coil packs, CEL still on showing low compression in 5 and 6. They're currently investigating the cause of the low compression.
    I'll post with an update when I find out more - hopefully my extended warranty will cover the repair/replacement of the engine (it should.)
  16. #56
    Oct 07 2010
    catastrophic "failure", 107k miles, threw a rod. THIS WAS DUE TO THE ENGINE INGESTING WATER FROM A LARGE PUDDLE. This was not the engines fault. Up until I drove through the puddle the engine ran perfectly and basically didnt burn any oil. Maybe 1/2 quart every 4-5k. Really sucks because it seems like I got a "good" one, considering it didnt burn any oil and had minimal timing-chain rattle at almost 110k miles. :(
    Ben
    '04 S4 6spd - jhm
    '05 duramax - really fast
    '68 vw beetle - way slower than both, but it has 4 wheel drive and a chevy 5.3 LSx V8 in the back
  17. #57
    Sep 09 2011
    Update on my 2005 b6 S4 cab with 120,800 miles on it.
    Cylinders 5, 6, and 7 all show well below factory spec. on a compression test. I believe the numbers for all three were in the low 70's. Leak down test revealed the exhaust valves, piston rings, and piston travel were causing the drop in compression in all 3 cylinders. Waiting on the warranty company to see about a replacement engine per the audi techs recommendation.
  18. #58
    Active Member Two Rings V8S4Ryan's Avatar
    Jul 22 2011
    04 nissam murano,11 dk clevland bike
    Havelock Nc
    2004 s4
    early build date. 117k miles
    the day before i heard a ticking noise checked oil a quart low. added oil and went on had a slight tick still. the next day tick got real bad. called a few people that are trust worthy mechanincs and confirmed it to be a lifter tick. will update with the outcome for sure. motor burned about a quart every 3k miles.
  19. #59
    Active Member Two Rings travw3's Avatar
    Feb 26 2011
    Huntington Beach
    An update new motor 79,xxx not sure the exact reason.
  20. #60
    New Member One Ring
    Sep 10 2010
    Boulder,CO
    2005.5 high oil consumption and almost 40% lost in each cylinder
    Total bullllll
    Bought the car with 67,000 from third party but had a dealership check it out and they passed it on to me, within a week of having it started to mis fire. Did the coil pack recall, still nothing compression test showed 30-40% leakage in each cylinder. Boroscoped and was told engine was toast, valve leakage and cylinder wall scoring in all but #8 . I actually was able to email Johan president of Audi of America all he offered was cost on the engine. I've been screwed here, just replaced the engine. Since having the engine in, been back to the dealer at least 12 times and they've replaced every gasket intake manifold, oil pan even dropped my tranny back out three times. Heading to school today after dropping it off last week started mis firing.
    Engine replaced at 69,000
  21. #61
    Senior Member Four Rings SquiddyB6S4's Avatar
    Apr 24 2010
    Central Florida
    Quote Originally Posted by B00sted20VUSP View Post
    It basically boils down to this....The engine is great for a period of time, then it just falls apart. Dont know if its because of faulty parts, or poor assembly or poor break-in. From my experience with this engine i will personally NEVER own this peice of shit 4.2 misfiring/oil burning/leaking junk. People shell out money for a car that should not blow up at 40-50k miles, lost countless nights of sleep fucking logging misfires, checking my dipstick, Monitoring Fucking insanely high 12% long term fuel trims on one side of the motor ONLY. The car is amazing when its running well, which is ONLY during a full moon and when the suns nuclear activity is at its peak when all the planets are aligned. Finally did a borescope test to the cylinder walls.....Started laughing and traded this junk in!! LS7 or GO HOME!!!
    This post is generally for the posting of actual problems/reports/etc. The discussion is handled in a separate thread. I have responded to this there. Conversation of Catastrofic motor failure information count
    -Jason
    2004 B6S4 6MT - Apikol Snub Mount, Piggie Pipes, Magnaflow Cat-Back, JHM Tune with Launch Assist; Squid Rear LSD #01
    1996 Lexus LS400 - Bone stock, >225k miles, runs and drives pretty much like a new car
    1985 Honda VF700F - Lots of mods - 12 seconds flat
    "This weather is nuts. But it's a great day if you're a duck. Or an Audi." ~Me
  22. #62
    Jul 24 2008
    chicago
    valuable as always squiddy valuable..
    Thanks and yes guys this is a RECORD only post. please lets drop the comments in the comment post.
  23. #63
    New Member One Ring
    Feb 01 2012
    Ottawa
    I have an 05.5 S4 Avant with an apparant tensioner issue. I have ~80K miles on the car. I service ahead of requirements, not after. 2 weeks before the failure I had services performed and no diagnostic errors. I have two 0 compression cylinders on one bank. The rest is normal.
    My oil consumption was about a litre every 3K.
  24. #64
    Registered Member Two Rings zero_one's Avatar
    Oct 06 2009
    83 VW Rabbit GTI | 09 VW Routan
    Delaware
    2006 (1st half 2006 build date I believe) B7 S4 6MT CPO was consuming about 2.5 quarts per 1,500 miles last year with about 42K miles on the odometer. Now with 56K, it’s consuming about 2.5 quarts every 800 miles or less. Scored cylinder walls. Long block getting installed this week under warrantee.
  25. #65
    Active Member Three Rings J0HN_R1's Avatar
    Jul 05 2010
    completes me...
    Calgary, Alberta
    Engine failure @ 152,000 km (95k miles), mechanic says most likely the guides.
    Car's been in the shop for 2 weeks now, haven't talked to him since the initial over-the-phone estimate.
    Luckily the car still has warranty until 160k KM..! And timing chain & guides are covered.
