Results 1 to 40 of 65
    Forum Moderator Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    Catalog of motor issues/Catastrofic motor failure, information/count update 12/03/11
    Hey guys after my motor tear-down post and many months since then Ive been contacted by many a member with issues and pictures of there motor and its issues.
    This thread is for anyone that had to replace a motor for any issue. Please PM me or feel free to post or E mail me. justincredible099@yahoo.com.
    What I hope to do is help find and expose the issues, miles and damage that we are subject to. In my findings Ive came up with some serious, serious finds.
    We are going to dispel one more myth right here today. At this point the weakest point in your motor...... IS YOUR PISTONS. That's right your pistons. Its not the rods its the pistons. Ive seen two motors with broken rods. They were both stock with bad cylinder wall scoring. You can see where the piston was binding up and then the rod just let go.
    If your building your motor for power and you don't change your pistons your wasting your time. Even though we have strong rods it would be foolish to not get both new rods and pistons. The rods are strong but they have to kneck down to fit the stock piston. A new rod and piston combo would solve the weak rod and piston issue.
    We all have read about issues with cylinder wall scorching?? what do you think is doing that? Its the skirt of the piston expanding too much. Ive seen it on several motors. Piston swell is nothing new and if you had cylinder wall scoring you might have witnessed it first hand.
    So with that being said I would like to start a log of people here that have had motor issues. Serious motor issues. Please Feel free to post pictures and share stories.
    Before reading below, please keep in mind the following. Some if these issues may have been from improper service by the owner. There are THOUSANDS and THOUSANDS (looking to get finnal production numbers) Of B6/B7 S4's and the largest collection of them are on this site so this may seem like alot but its a small fraction of the issues colllected into one area.
    We can add a category if needed but the starting list looks like this.
    Cylinder wall scoring or weak compression
    04/ 3
    05/ 7
    06+4
    Cylinder head damage / dropped valve / valve stem leak
    04/ 4
    05/ 4
    06+
    Lost piston / motor debris
    04/ 2
    05/ 5
    06+
    Bad cam tensioner/follower or adjuster
    04/ 6
    05/ 2
    06+
    Broken timing chain or guide
    04/ 5
    05/ 4
    06+
    Broken rod
    04/4
    05/ 2
    06+3
    This is a quick list Im looking through my notes for more causes. PLEASE feel free to share and I don't like to sticky my own work but if this gets going and you guys want it let me know we can put this up top for all to see.
    Post still in the works.....
    Comments or related posts to continue this thread are located here
    thoughts and feed back
    If you don't have haters, then you're not kicking enough ass.
    AMA and YES! Together we can all defeat 2.0t and 2.7t crime...
    And lastly for the grammar police that are bound to step in
    I came here from Germany in the 6th grade. I could not read or write a lick of English. I am working to get better. Thanks and sorry. I always try to edit my posts for the best grammar and easiest reading.
    Jul 24 2008
    chicago
    Digging for pictures to put here.
    Examples.
    Bent valves. Picture of the cylinder heads and the valves.
    Picture of piston damage from valves hitting them
    Picture of missing roller in roller rocker
    Picture of Cylinder wall scoring
    Bad motor debris total piston damage
    Broken rod.
    Aug 21 2009
    CA
    Justin, thanks again for your dedication.
    Edit: this thread will scare me since my warranty ends in 31 minutes.
    Registered Member Two Rings Abwasserleitung's Avatar
    Jan 30 2010
    Central WA
    2004 B6 S4 6MT Build Date 10/03 41k miles
    Purchased 2/10 - Diagnosed 5/10 - New Engine/Car Returned 8/10
    Engine replaced due to:
    Cylinder wall scoring and weak compression (20% loss on two cylinders)
    Bent Valve stems
    Broken timing chain guide
    Senior Member Four Rings SquiddyB6S4's Avatar
    Apr 24 2010
    Central Florida
    Quote Originally Posted by Abwasserleitung View Post
    Bent Valve stems
    Justin, your statement about piston swell is making me wonder which came first here. I wonder if the pistons swell, causing undue stress on the timing chain, which may actually cause some or most all of the timing chain area issues we see on these cars. Or are they unrelated? Just some food for thought.
    Also, I suggest that you put at the end of the list an approximate number of actively-posting members with B6/B7 S4's on this forum. Say, the number of members who have more than about 10-20 post count, and have posted something in the past 30 days. This just to keep from counting people who aren't active any more, and keep from counting the kid that joins, asks one question about a car he doesn't actually own, then never shows up again.
    I think this would help keep it in perspective, how common or rare these sorts of issues are. For instance, saying that there have been 10 motor deaths might sound intimidating, but if we have 1,000 owners on this forum who are running along just fine, all of a sudden 10 motor deaths is nothing new or special from any other car. If we only had 50, then yes, 10 motor deaths would be just crazy.
    -Jason
    2004 B6S4 6MT - Apikol Snub Mount, Piggie Pipes, Magnaflow Cat-Back, JHM Tune with Launch Assist; Squid Rear LSD #01
    1996 Lexus LS400 - Bone stock, >225k miles, runs and drives pretty much like a new car
    1985 Honda VF700F - Lots of mods - 12 seconds flat
    "This weather is nuts. But it's a great day if you're a duck. Or an Audi." ~Me
    Senior Member Three Rings deviant-customs's Avatar
    Jan 15 2009
    04 S4 07 R1 87 K5
    CO
    2004 build date 10/03
    Cam follower fell apart
    41k
    Don't Drink and Park. Accidents Cause People.
    Veteran Member Four Rings drew's Avatar
    Jul 27 2004
    Gone: 996TT stage 3, E46 M3
    so cal
    2005
    High oil consumption and scored cylinder walls
    New long block by cpo at 86K miles
    05 S4 6MT Light Silver/Black-Silver Alcantara
    Registered Member Two Rings slo s4's Avatar
    May 11 2009
    04 S4
    Houston, TX
    Great idea, thanks again for everything you are doing to advance our poor little unloved platform. "Slow" V8s are starting to not be so slow due to you, and people like you.
    Senior Member Two Rings EssPhore's Avatar
    Jun 01 2008
    2005 B6 S4, 2007 KTM EXC 450
    So Cal./I.E.
    2005 CPO
    High oil consumption, several scored cylinders
    Engine replaced at 75,000
    -Sean-
    Senior Member Three Rings Bpitz15's Avatar
    May 07 2008
    2001 Dodge Dakota 4x4, Yamaha YZ250F, Honda CB900F
    Hartford County, CT
    2005 6MT.
    New shortblock and rebuilt heads due to high oil consumption from leaking valve seals and scored cylinder walls.
    I've heard the cyl wall scoring could be from improper break-in from the first owner. The car had 41k.
    Items for sale PM me for details:
    A6/Allroad 4.2 V8 top end
    Feb 01 2008
    ann arbor, MI
    04 100K miles, catastrophic #8 failure. I never seen the original motor, but the audi tech i spoke with said he could see the rod though the spark plug hole.
    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    112K Miles - High oil consumption but cause hasnt been determined yet.
    2005 Audi S4 Avant 6 Speed - JHM Headers, Magnaflow exhaust w/ X Pipe, JHM Lighweight Flywheel, Stage 4 clutch, JHM 93 Tune , H&R CO's, Stern Motor Mounts
    Buy my motor! http://www.audizine.com/forum/showth...-Audi-S4-Motor
    Jul 24 2008
    chicago
    Quote Originally Posted by dparm View Post
    Curious, as my latest oil analysis showed above-average aluminum. Blackstone speculated this was from the pistons but also thought it could just be from the repeated autocross/track days it saw.
    Keep em coming guys. Im updating the list. This kind of format makes it very easy for me and others to read... Thanks guys
    2005 CPO
    dparm. Try running a 100% pure synthetic. Amsoil/ELF Along that kind of brand. Then let us know. From what Im seeing. Even if people do have aluminum in the oil. The Higher Syn oils seem to help stop or Control this better
    Jul 17 2010
    New Orleans
    very sweet thread. I will be watching this one close. I have experienced very low fault rates with the chain 4.2, however if I run across anything pertainent I will share.
    Audi Master Guild Technician
    Registered Member Three Rings AndyGs4's Avatar
    Jan 26 2010
    Right here.
    04 Build Dec 03.
    Disintegrated a piston in Cylinder #4.
    2004 S4
    JHM Headers - FI Catback - K&W Coilovers - JHM B7 LW Flywheel - JHM LW Pulley - Apikol Snub - 19" Neuspeed RS10s - Stern MM
    Audis - 86 5000CS Turbo sold at 150K - 95 A6 sold at 177K - 00 Jetta 2.0 got hit at 220K
    Resto - 55 Chev3100 Stepside - 68 Mustang Coupe - 73 Mach 1
    ...w.w.w...e.u.r.o.a.d.d.i.c.t.i.o.n...n.e.t...
    Senior Member Four Rings BCsniper's Avatar
    Jan 29 2010
    B6 S4 6MT Avant, B6 3.0 Avant 6MT (for sale), C5 A6 2.8 (needs fixing)
    north ga
    I am kind of shocked at how many of you have had to have your engine replaced at one time or another.
    Senior Member Three Rings SpeedETC's Avatar
    Oct 29 2007
    2004 Audi S4, 2004 VW Touareg
    Poquonock
    2004 with an 02/2004 build date (purchased new - currently 114k miles).
    High oil consumption developed at 110k. Compression normal, no cylinder scoring. Found a broken chain guide when after the motor pull. Replaced all the valve stem seals, chains, guides, tensioners. The consumption has dropped.
    Oil changes were done every 5000 miles.
    Senior Member Three Rings littleredwagen's Avatar
    Jan 08 2008
    2001.5 S4
    05 S4 6MT
    Valve Guide failure in Cylinder 8(ovaled out) and subsequent valve seat damage, High Oil Consumption in Cyl. 8.
    engine had 86k on it
    Second V8 has high oil consumption in cyl.3 leading to misfires due to fouled spark plug.
    Second motor is 04 V8
    -Matt
    2001.5 S4 Imola Yellow
    Past: 2005 S4 Avant 6spd Brilliant Red, 2007 VW GTI, 2004 Jetta GLI 1.8T
    Jul 24 2008
    chicago
    Thanks to everyone that has and is posting there information here. Please encourage other members that you know have had issues or if you find old posts. Please have them put there information here or feel free to post a link to past posts with people and there story's.
    If any one wants to comment or continue a discussion please make it in this post
    Motor failure conversation post
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '07 A4 2.0T
    Boston
    2006 w/ low compression and oil consumption (1 qt/500 mi). Currently at 74k miles. Test results (dry and wet):
    Cyl 1: (D) 110, (W) 150
    Cyl 2: (D) 125, (W) 170
    Cyl 3: (D) 110, (W) 148
    Cyl 4: (D) 125, (W) 170
    Cyl 5: (D) 140, (W) 177
    Cyl 6: (D) 135, (W) 170
    Cyl 7: (D) 123, (W) 147
    Cyl 8: (D) 125, (W) 150
    Noticed excessive carbon on all pistons. Cylinder walls were fine, no scoring. Suspecting piston rings are stuck, performed a piston soak to clean up the carbon. Monitoring oil consumption now, logging level via vag-com and dipstick every morning. So far it looks promising at 250 mi since doing the clean up.
    2011 A4 2.0T Quattro AT8 | Quartz Gray | Black || Premium + | Nav | Titanium || APR Stg II | APR Turbo-back Exhaust | 034 Turbo Hose | Huper Optik | Blinder M27 | 9500xi
    2007 A4 2.0T Quattro AT6
    1995 90 Quattro Sport 5-speed
    Previous Cars:
    '06 S4 25quattro
    '05 1.8T Quattro 6-speed (plenty of mods)
    May 30 2007
    MA
    ^^ Does Lee think its the oil collection ring getting gummed up? The deviation of your numbers is interesting.
    May 03 2005
    '07 A4 2.0T
    Boston
    Quote Originally Posted by SuperAvant View Post
    Yeah we think its the rings that are stuck. So far the oil consumption seems to have gone down. I will know in 200 mi whether it still consumes a quart. But so far I've been checking the level every day since we did the test and there is little to no change.
    Previous Cars:
    '06 S4 25quattro
    Dec 23 2009
    MA
    05 52K with scored cylinders found by compression test. Oil consumption 1 quart every 800 miles
    Active Member Two Rings MaudiS4's Avatar
    Jan 03 2009
    1999.5 AUDI A4 2005.5 B7 S4
    Laurel MD
    04 97500 miles Cylinder #8 1 Intake valve broken / Piston damaged
    Jul 27 2004
    so cal
    j, you should sticky this
    Senior Member Four Rings jfunkey's Avatar
    Jan 21 2009
    R32 B7/S4....2000 2.7t gone :(
    putting you into the wall
    Quote Originally Posted by drew View Post
    2nd... Drew knows best and Im in 100% agreement with him.. Also please keep trimming the posts for the extra stuff.. The conversation stuff works well in another thread.
    I like how this is just the list... Great work
    JHM war machine. Total transformation. JHM/Tune/headers/intake manifold.
    My B7S4. Faster then my old RS4 and First B7 S4 in the 12's
    AMA member
    USMC member (active)
    Facts first member. Built and supported by many
    May 31 2010
    West Coast Master Audi Tech
    Put down one more for rod and scored walls.
    B7 48000 miles
    bad rod through block and scored walls
    This should be a sticky.
    Ive seen lots of issues that are on the list. I feel it would be wrong to share any more then what I have first hand experience with.
    People should know that there are issues with any motor in any make of car. There is not a issue so large that there is a recall or dealer worry.
    If you want to keep the car healthy, Use a full synthetic oil and change your oil in accordance to your driving style
    The issue with the tension-er, There is a sleeve where the tension-er rises and falls as needed. Its a wearable part, good oil and regular changes should keep that part healthy for a long time
    After Years of working on the Audi and telling Technicians what to do. I'm hoping my suggestions can do the same for you
    Senior Member Four Rings beemercer's Avatar
    Aug 14 2008
    05 Jeep GC 5.7 Lmtd. QDII - Oh-One Fat-Body Four-Two
    Central Mass
    ^Similar advice as to what a gentleman who works in the OEM and aftermarket industry gave me. It just sucks getting a used car with an unsure history.
    RIP Sway
    _________
    JHM
    AMA
    Senior Member Three Rings manhattanprjkt8's Avatar
    Jun 22 2008
    Lots of blown out mounain bikes
    pennsyltucky
    X-Post From the Engine Pull Thread I Posted
    Wanted to put a quick thread up outlining my recent experience with my 2004 4.2 S4…I know there have been tons of threads regarding chain tensionors and a motor pull.
    About 2 months ago I began experiencing some concerning issues with the car
    - Start up noise began to get noticeably louder, it always had some but this was increasingly loud.
    - Began have a click occasionally coming from the engine at low idle speeds
    - Noticed adding oil a bit more often than normal but nothing to concerning.
    Like I said above nothing was so concerning that I felt I needed to take the car to the dealership right away. That is until the engine light came on…I had the car at the dealership 4 times and they did multiple things to the car. Coilpacks, fuel injectors, and a carbon clean each time resolving the code it was throwing but the light would come on days after getting the car back.
    One day the engine light came back on and began flashing the car basically went into limp mode, so I shut it off and had it flat bedded.
    The Bad News – ‘Sir we are going to keep your car for a while and it is going to get rather expensive’, I knew exactly what that meant. I just received my car back the other day and here was the basic summary of repairs:
    2 Cracked Tensioners
    2 Bad adjusters – which caused the leaking oil.
    After the motor pull it did get rather expensive but not to the level I expected, dealership treated me great and it was about as much of a positive experience as you could expect from news like this…
    Jul 24 2008
    chicago
    Thanks guys updated
    Jul 19 2010
    Issaquah
    2005.5 S4 bought at 63K miles from used car dealer - turned out #5 cylinder wall scored, compression down to 50psi, high oil consumption, borascope confirmed scoring. Replacing engine.
    Aug 14 2008
    Central Mass
    Quote Originally Posted by Tony951 View Post
    With some killer goodies .
    I saw you tried to PM me, I emptied my PM box so now I can receive messages.
    RIP Sway
    _________
    JHM
    AMA
    Forum Moderator Four Rings SoCalS4Avant's Avatar
    Jan 24 2008
    B8 A4 Avant, Touareg V8, E30 318
    Pasadena, California
    We're going to sticky this up top while we look to catalogue these issues, as well as call atention to potential issues for new/future owners. Please add info as neded. We can update the original post as it comes in.
    Dan - Moderator/Wiseguy
    EuroBerge
    Jul 24 2008
    chicago
    Quote Originally Posted by somethingcorp View Post
    whhy did my post get deleted? fail....
    Please post questions and comments in the thread created for such.
    http://www.audizine.com/forum/showth...ormation-count.
    Sep 22 2009
    05 s4 avant,71 ghia
    nn va.
    05 avant #2 piston missing
    Aug 14 2008
    Central Mass
    Quote Originally Posted by vwrcer View Post
    SHIT! Was this prior to the blower or after?
    RIP Sway
    _________
    JHM
    AMA
    Jun 25 2010
    holland michigan
    Brand new short block at 64k
    9 quarts of oil per 3 weeks
    Scoring of three cylinder walls
    Now have 3k miles on new short block - running good so far
    Senior Member Three Rings 93hrdtptt's Avatar
    Aug 21 2008
    2004 S4-Nogaro Blue 6spd, 2000 Yamaha R6
    Bergen County, NJ
    '04 1 quart per 300miles.
    cylinder 6 + 8 scored, low compression, oil on plugs - 5,6,7,8
    Jul 24 2008
    chicago
    Quote Originally Posted by vdubinteriors View Post
    Year please
    Jan 14 2009
    2006 S4
    pasadena md
    I have a 05.5 b7
    with 80K on the clock and she runs great and i
    burn 1 qt about every 1500 2000 miles or so.
    i have some timing chain rattle at cold start up for a few seconds when the oil is worn out. I run mobil 1 0w40. I love this car and would'nt trade it for anything unless it was an R8 lol I think proper break in with the new owner is key with these motors
