Results 1 to 19 of 19
    Veteran Member Three Rings Beemer832's Avatar
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    EuroDyne Maestro Tuning Suite - Looking for some more first hand info
    hey guys,
    been out of the Audi scene for a bit, but starting to get back on track and finish my gt3071 project. When i walked away from the forums a few months back, EuroDyne had just released its tuning suite for the B6 chassis but it wasn't available for b5. I see we are now supported and this looks very enticing. My questions start off with, how easy is this to learn? How safe is it to learn on? I have never been involved in tuning a car, but would do the necessary research and have resources available to ensure nothing becomes unsafe for the car.
    Also, am I correct by assuming the stock ECU, sensors, and harness are kept intact, and all changes are made through a vag-com like USB dongle that interfaces the stock ECU to a computer running the correct software?
    Thanks guys, and I hope to revive my long lost thread or just start a new one in the near future.
    Thanks
    Josh
    -josh
    98 AEB 1.8t Laser Red
    garage parked again.......
    v-band 3071r on the way
    APR Stg 3 for AEB engine for sale
    will include cat back exhaust, DP, and intercooler setup
    Link
    Senior Member Three Rings Papa Stone's Avatar
    Jul 25 2008
    Chev Z71 DD
    San Juan PR
    The way i look at this is that Maestro when used on the base map is safe (is basicaly a of the shell software), but once its being played with, its like a Programable ECU (can be dangerous when not knowing what you are doing). Also, its important to know what ECU you have. As I understand 3.8 version of the ecu, have limited access on the features of maestro (like live dataloging and other features), if you are 5.9 or higher you'll have more control of you ecu..
    official AWE/GIAC dealer in Puerto Rico
    Chevy Silverado Z71
    Audi A4 Avant(Project Scary)
    http://www.audizine.com/forum/showthread.php?t=270772
    Active Member Two Rings The*Fall*Guy's Avatar
    Sep 13 2009
    98 B5Q 28rs(SOLD) 2001Jetta
    Illegal Alientown PA
    Quote Originally Posted by Beemer832 View Post
    hey guys,
    Thanks
    Josh
    ehttp://forums.vwvortex.com/showthread.php?4613781-Maestro-7-Tuning-FAQ-DIY-hard-data-and-advice-thread-
    I have it, its great, and nothing to be scared of.. IMO its worth it just so that you never have to buy another flash. Chris will mail you whatever flash you want for free as long as you own Maestro.. As many times as you want.. You can also datalog with it, and e-mail the logs to him, and he will adjust the map, and e-mail it back.. No worries.. You can disable airbags, emissions schit, etc as well. Its really the only way to fly.... check out this thread..
    Active Member Two Rings esee135's Avatar
    Jun 21 2008
    I was also looking at Maestro. It looks pretty powerful from the website. This is in comparison to HPtuners for GM LS motors. Tuning isn't too bad so long as you read a lot, and make small changes at a time. Everyone said I couldn't learn how to tune ecus by myself then I bought HPtuners for my truck and taught myself. It took a while but I got good enough that I remapped my ecu for my truck when I swapped out my 5.3L for my 6.0L v8 and it works pretty good, and I run sometimes 50 degrees tdc on my timing at some points on 87 octane with no knocking.
    Tuning is only scary when you do stupid things like change your timing by +20 degrees without any thought out reason. Buy it, go slow and have some fun.
    Senior Member Four Rings black99.5a4's Avatar
    Jun 26 2008
    00' Noggy Stg2
    Middle of a Cornfield, PA
    I prefer ls1edit if you wanna talk about that genre..
    Meastro is FAR different from ME5 to ME7.. so depending what your setup is as to what the software is really going to do for you.
    '00 Nogaro S4 - TIP, Ebay turbos, Ebay inlets, Ebay stage 2 tune, OBX manifolds, OBX exhaust
    For all your OEM Audi needs
    Jul 25 2008
    Chev Z71 DD
    San Juan PR
    FYI..
    Engine Code
    Year / Model
    AEB
    1997/1999
    Quick Tune No
    Map Switching No
    Measuring Blocks Yes
    Map Tracing Yes
    Histograms Yes Yes
    Check/ Clear Codes Yes
    High Speed Logger No
    Throttle Body Adaptation No
    However with a newer ECU ME7 you get everything
    Chevy Silverado Z71
    Jun 26 2008
    00' Noggy Stg2
    you're missing also that me7 has injector wizard and full control over the emissions.. secondary 02, evap, etc. stuff that ME5 does not have (02's dont have the control either if you wanna get technical but you get my drift).
    there are also further differences but the 2 above, are big things to most.
    Jul 25 2008
    Chev Z71 DD
    San Juan PR
    I just played with a Me5 Maestro and Maestro 7..
    I feel very tempted to converting my car to ME7 just for the extra features you get!!
    makes the car REALLY EASY to tune
    Chevy Silverado Z71
    Senior Member Three Rings dowsett6's Avatar
    Sep 10 2008
    99.5 1.8t BT, 97 1.8t
    Ontario
    ME5 also doesn't have the fancy no lift shift, and 2step features
    Jun 26 2008
    00' Noggy Stg2
    Quote Originally Posted by Papa Stone View Post
    i hope you've actually used the search function and looked that up. i've discussed it a TON of times..
    Jul 25 2008
    Chev Z71 DD
    San Juan PR
    No I didn't but.. you don't have to be a prick and point it out..
    All I did was and observation about this because I actually have used both systems (being a Eurodyne dealer).. and you had to answer with a prick comment.. This is the second time you come and said shit (the first was the ECU comment that I was wrong and I apoligized), I am really getting tired of your attitude. Can it dude and just let other people give comments and enjoy the forum.
    You don't know it all.
    Chevy Silverado Z71
    Jun 26 2008
    00' Noggy Stg2
    i'm far from being a prick. maybe you should dig the sand out of your vagina and be the one to relax.. i am simply pointing out that going me7 is far more difficult then an afternoon swap of a couple of things. i also dont think i know it all, but you're are a DEALER of products and you dont know half about what you sell. (ecu comment implied there.. dont tell someone, after being told you're wrong, that you arent wrong.. i wouldnt of posted on that thread had i not of know FROM EXPERIENCE that i was right... i'm not like 85% of the people here who post about shit they dont know)..
    Unlike most, i've researched for months the me7 swap, bought harnesses and sat in my shop and gone over both to see where they differ.. i repinned 96 pins to make a ME7 cluster work in my ME5 analog clustered car.. full lcd works. I was going this route so my tuning software would actually be worth the money i'd spend on it, but canned it to get the car running again.
    Remember, there are people on this forum that actually post when they know what they are talking about.. or who have actually tried and completed, or tried and know how to most of the shit. If you'd stop, sit back and LISTEN to what people are telling you.. you'd probably know a whole more about shit.. even the shit you "sell"
    Jul 25 2008
    Chev Z71 DD
    San Juan PR
    Blah blah blah.. You r still a know it all prick ..
    Deal with it.. I know what it takes to swap a ME7 and I know is no sunday picnic. But it might be worth it is you want more control and more options is you have a ME5 if you have the skill and the time.
    All I did was give my experience on this forum, and you jump on it.. like you just did
    If you want to continue this, PM me .. Or maybe I'll get in a plane, go to PA and visit you personally
    Chevy Silverado Z71
    Veteran Member Three Rings aaronamerica's Avatar
    May 31 2005
    Dallas
    Is anybody here still running this software?? Any details any luck with it, I'm looking to getting this software and just run the base tune but would like to see more user details and opinons
    1998 Audi A4 built 1.8t Quattro--Eurodyne Maestro---870cc tune---Custom Elim Gt3076---on E85 Gas---044 Bosch Drop in fuel pump---Street tuned by me---402awhp 387tq---12.2@118mph on 19" wheels
    2003 Audi Avant 1.8t Quattro 5speed--19" Staggered iForged Daytona Wheels
    Jul 25 2008
    Chev Z71 DD
    San Juan PR
    I am trying it out.. I can tell you about it in the next weeks .. I heard USP also has killer software for the AEB engines
    Chevy Silverado Z71
    May 31 2005
    Dallas
    Keep me posted....what setup are you running?
    Jul 25 2008
    Chev Z71 DD
    San Juan PR
    Audi A8 V8 flow meter (2001) model year
    PSI prototype Kit:
    16G T25 turbo
    Oil lines
    3 inch DP
    FMIC
    630 cc injectors
    3 inch DP
    Chevy Silverado Z71
    May 31 2005
    Dallas
    Cool how do you like it so far
    Sep 13 2009
    Up
