Results 1 to 40 of 59
    Dec 03 2006
    Singapore
    DIY S4 Waterpump and Thermostat Install + Supercharger Removed (Pics)
    The original early production S4 3.0TFSI Engines were delivered from the factory with plastic waterpumps. They have this tendency to fail after a while and the Audi have rectified this with a superceeded original upgrade part that is now a fully aluminum pump housing.
    have driven the car very hard at times and my original plastic pump/thermostat assembly has not failed to date (>10,000km). So this "upgrade" is purely a preventative measure on my part.
    All the 3.0TFSI engines rolling off the factory plant now use the new part, so if you have ordered a S4/S5sportback or other car equipped with a 3.0TFSI engine not arrived yet. You will be getting the new full aluminum pump.
    Here are some pictures of a DIY install of the upgraded water pump. At the same time the Singapore cars will also get a thermostat change also (tho the part number is exactly the same as the old one, no superceeded part). The factory protocol does not mandate that the thermostat be changed but the dealer here in Singapore has decided to take an extra step up and package the upgrade with both parts just to be on the safe side.
    One take home message here is that for genuine original parts, good to see that there is a continual improvement and rectification of problem issues. I am delighted to see that any such improvement are carried down to serial production also.
    Singapore dealer will take 2 days to do this upgrade for you. I strongly suggest you do not try this at home unless you have al the special tools, torque wrenches and knowhow to do the job. It can be real tricky at times as one connecting pipe is not easy to mobilize at all!
    The supercharger also needs to be removed to access the thermostat housing.
    here are the pictures of the job.......... hardcore DIY guys can try
    OLD VS NEW WATERPUMPS
    Oct 09 2009
    B8 S4, B5 A4 Stage 1
    Fremont, CA
    Great post, Decksurgeon! Informative as always. Interesting to finally see pictures of the updated and superseded water pumps.
    Delivered 12/31/09
    Audi 2010 S4 Meteor Gray 6MT
    Prem + // Nav // B&O // Sport Differential // 19" Wheels // Carbon Inlays
    Mods:
    License Plate LED - 1.03.10 // 6000K HID - 1.10.10 // Interior LED - 1.10.10
    Clearbra - 1.12.10 // 30% Tint - 1.12.10 // Hoen Endurance Fogs - 1.15.10
    JHM Short Shifter - 2.22.10 // Vagcom'd - 3.5.10 // HRE M40 19x9 - 4.6.10
    APR Exhaust - 4.6.11 // H&R OE Sport Springs 4.6.11
    Oct 11 2009
    S4 B8 SprintBlue S-tronic
    Russia
    Great thread and pictures, decksurgeon!
    Sorry for my English - I'm an ignorant Russian bear... just love Audis.
    Veteran Member Four Rings L0U's Avatar
    Sep 03 2009
    13 S8, 15 Macan Turbo, 04 Ducati SS1000DS
    deck, is there a way to see from under the hood wether we have the plastic, or the aluminum? or do you need to remove lots to even inspect?
    did you notice carbon in the intake, or is the car running mostly clean...unlike the rs4's.
    great post
    2013 Daytona S8, B&O, Bk alcantara, Solar, 360 camera, adaptive cruise,
    2015 Rhodium Macan Turbo, BK alcantara, Loaded.
    Veteran Member Four Rings NWS4Guy's Avatar
    Sep 29 2009
    2015 Range Rover Evoque 2010 Audi S4
    Quote Originally Posted by L0U View Post
    great post
    Deck, once again you rule!
    Lou, you should be able to clearly see the pump from the hood, it's got a pulley on it seperate of the SC system, and the black housing is visible
    I echo Lou, were you able to see any signs of carbon?
    Like a surgeon with a scalpel, my S4 is a precision instrument, with which I carve and dissect my way through traffic.
    2010 S4 Prem+, Quartz Gray, S-tronic, Sport Diff, B&O, Nav, Gray Birch
    StopTech ST-60 BBK - Stratmosphere intake - APR v2.2 Stage 2 w/pulley + exhaust, v2 Coolant System
    Alu-Kreuz, Apikol rear diff mount, 034 transmission mount
    Veteran Member Four Rings ahcow's Avatar
    Apr 26 2010
    Toronto, Ontario
    Anyone know if the dealer will replace this for you as a preventative measure or do you have to wait until it fails? I don't know which one I have but I got my car around April 2010 (not an in-stock car).
    New: 2016 S3, Sepang Blue, Sport Seats, S-tronic, Tecknik, LED
    Old: 2010 S4, Brilliant Black, Magma Red Nappa, S-tronic, Nav, Sports Differential
    Mods: Strat Intake, 35% Ceramic Tint, RS5 Pedals, BE GTS-AV, Hawk pads, Alu Kreuz, Vag-com, APR Exhaust
    Registered Member Four Rings marty was here's Avatar
    Nov 10 2006
    335 750 & a titanic
    new york
    i wish there was still rep
    cause id rep this hard! thank you so much!!!
    We have a black president... Racism is dead.
    -JPT
    I have a real sore throat...feels like I've been deepthroating gorillas.
    mister_tu
    Hey, I just read this (and this is crazy), but take your two cents, and fuck off maybe?.
    audia
    Sep 29 2009
    Quote Originally Posted by ahcow View Post
    There are rumors of a TSB for this, though until one happens, doubtful the dealer will do it.
    Veteran Member Four Rings HyperM3's Avatar
    Mar 20 2004
    Lawrenceville, NJ
    Items for Sale
    Great post!!!
    13 HD FatBob
    17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/BMS JB4/CTSTransMount/034Intake/034Strutbrace/034RearSwayBar/034RDPipe
    16 S6 (gone)
    14 S6 (gone)
    14 S6 (gone)
    13 S6 (gone)
    10 S4 (gone)
    ACNA Lifetime Member - 26690
    Dec 03 2006
    Singapore
    great post
    thanks Lou, yes, very easy to spot the old plastic waterpump - it is black....so you will see a black edge where it mounts into the V6.
    the new ones are all metal, u cant miss it. just pull off the front plastic cover that says "V6 3.0TFI" and you should be able to see it.
    Quote Originally Posted by NWS4Guy View Post
    No signs of carbon at 12,000km. to see inside the intake runner flap (closed position). you have to open it.
    do not force it open [danger of damage], what you need to do is put a vacuum tester to the actuator that opens these flaps, once u apply the vacuum the flap will open and you can then use a torch and look down the intake runner to the intake valve.
    what i must also let you guys know is that i specificall run 98RON only and nothing less, the gas used is "CALTEX Platinum" only with that techron cleaning agent that is advertised heavily here in Singapore by fuel company.
    No TSB here locally, the dealer just does it to keep the S4 owners happy cos after the 1st few cars coming in, they decided to replace all the old waterpumps to prevent complaints since the S4 here is priced like the GDP of a small african nation after taxes.
    Sep 03 2009
    sweet. no carbon! Looks like it would be fairly easy to pop the charger after 30,000 and do an inspection. Time to go check my pump.
    Veteran Member Four Rings nick71692's Avatar
    Jan 16 2008
    2010 S4, 2005 A4 USP, 2008 BMW 650I Conv. Sport, 2013 Jetta GLI
    Ohio and GTA
    Items for Sale
    Great Post
    2005 Dolphin Grey USP
    USP CLUB MEMBER #210
    2008 Ibis White S-Line A4 6mt, Stasis Exhaust (Gone)
    2010: S4, Ibis White, S-Tronic (Gone)
    2011 MKVI GTI 4 Door, Carbon, DSG (Gone)
    2012 S4, Monsoon Gray, 6MT (Gone)
    2014 S4, Glacier White - fully loaded
    Dec 03 2006
    Singapore
    remove completely the intake pipe (+one vacuum line to intake pipe) from the airbox. then unplug all the mess of connectors on the back of the S/C. there are quite a few, 3 for the solenoids, one for the throttle body, one for the bypass flap, one for the charge air pressure sensor. you will especially find that the connector for the bypass flap cannot be slid out easily as its blocked by the metal plate holding the 3 solenoids...so what i did was to dismantle the entire plate and go grind a small notch on it so that infuture the bypass flap connector can be easily slid out without taking out the 3 screws that hold the black metal plate with the 3 side-by-side solenoids.
    then disconnect the bunch of vacuum hoses also. then the SC is ready to come out. you will need 2 people - one of each side to lift the charger straight out.
    the 6 nuts are 20nm when you put the SC back into the car. observe diagonal tightening rules.
    Veteran Member Four Rings Voltrons_Head's Avatar
    Sep 14 2009
    Philly
    The amount of original content on this forum never ceases to amaze me. Thanks!
    Sep 29 2009
    Great info again Deck. Due to DI, do you really think that Techron helps all that much since there is no way for it to wash the intake valves though? Granted I agree that using the best fuel possible is always a boon.
    Dec 03 2006
    Singapore
    IMHO, the techron does not really help (maybe mentally LOL!)....cos the engine is DI in the 1st place so no fuel ever hits the intake valves.
    but so far so good. have another 2.0TFSI at 50,000km and the valves look fine too. must qualify that my engine gets fed new Audi only original oil every 5000km (3106miles)
    i think its all about the blow by scavenging of the crankcase breathing system, the RS4 has the most sophisticated one with triple vortices.
    the TTRS inline 5 is pretty sophisticated also and our S4 system is also not a pushover.
    Audi use a contractor called PolySwirl (TM) for the fine oil separators that utilize the cyclone principal
    Sep 29 2009
    If the RS is the most sophisticated, why does it have all the CB issues?
    Dec 03 2006
    Singapore
    If the RS is the mostsophisticated, why does it have all the CB issues?
    Good question! I know more than a few 50,000+km RS4s here. No issues except for the vacuum line on some. But that was a TSB issued on that.
    Remains to be seen if the inline5 of the ttrs will have the same or will the polyswirl do its job???
    Nov 10 2006
    335 750 & a titanic
    new york
    correctly if im wrong, but isnt the 3.0t running hotter than the TTRS and b7 RS4?
    benz is doing this with their direct injection vehicles also......
    -JPT
    mister_tu
    audia
    Sep 29 2009
    Quote Originally Posted by marty was here View Post
    Not sure about the TTRS, but it's set about 10 degrees F hotter than previous models yes.
    Jul 28 2010
    Great post Deck Surgeon.
    I have a couple of Noob questions.
    1. Why is the outlet side of the supercharger brown in color?
    2. What does the hotter running engine mean for carbon buildup?
    Thanks.
    Veteran Member Three Rings sf_loft's Avatar
    Apr 17 2010
    San Francisco, CA
    Is there a way to determine based on build date without opening the engine cover? Mine is a 2010 with a Feb build date (I'll double check again)
    2014 BMW F10 M5 Competition Package
    Retired: 2010 B8 S4 - flickr - Ibis | Black Silk Nappa / Carbon inlays | Prestige | S-Tronic | ADS | Driver Assist | Sunshade
    Sep 29 2009
    Quote Originally Posted by Rhytid View Post
    Thanks.
    1. The PCV valve (Positive Crankcase Ventilation) recirculates unburned exhaust gasses back into the supercharger for entry into the intake to for reburning - this is an EPA mandate from Waaaay back when, my 1968 Mustang had a PCV valve. Hence the green text on the same pic you refer to, which shows the dump valve for large oil particulates which are recirculated into the SC drop out of the air and pool in the bottom of the SC, to be scavenged by the oil recovery system.
    2. Since DI (Direct Injection) engines shoot the fuel straight into the cylinders instead of across the top of the intake valves, fuel doesn't wash these valves to clean off deposits of the above mentioned unburned exhaust gasses. Over time these harden and disrupt airflow or even the proper seating and seal of the intake valves. Increasing the engine temp allows these valves to get a little hotter than previous models, which (in theory accordin to Audi) should be enough heat to bake these deposits off before they can harden there.
    Quote Originally Posted by sf_loft View Post
    Why not pop it off? It removes in less than a second and sits on there like a tupperware top - just pops off and on.
    Jul 28 2010
    NWS4Guy, thanks for the explanation.
    I have heard before that synthetic oil "ashes" as opposed to "cokes." Is that not true or does that not apply when it is not in solution?
    Sep 29 2009
    I have not heard of this, but if you can find evidence this is true, it might be a large part in deciding what type oil to use (I personally prefer synthetic anyway).
    Established Member Two Rings Leo's Avatar
    Oct 03 2009
    2010 S4, 2005 997 Cabriolet, 2008 A6 Avant, 2011 Yamaha Apex SE
    Montreal
    Quote Originally Posted by decksurgeon View Post
    Oh well, it's black. 17,000km's... let's hope it doesn't fail.
    Sep 03 2009
    Quote Originally Posted by Leo View Post
    same, black plastic. 14,000kms, and going on a 4000km road trip vacation...hope it hangs on.
    Senior Member Two Rings Nadrealista's Avatar
    Jan 09 2009
    2001.5 Audi S4
    Falls Church, VA
    deck did you take any pictures of the intake valves?
    May 11 2010
    2013 X1
    Awesome job deck. Thanks.
    Jul 17 2009
    Venezuela
    The PCV redirects to the cylinders the evaporation fumes of oil from the crank not exhaust anything lol
    Sep 29 2009
    Quote Originally Posted by leviathan18 View Post
    Yes, was thinking about EGR when I was typing PCV, thanks for catching that!
    Veteran Member Three Rings Rabbit222's Avatar
    Jan 22 2010
    2014 SQ5
    South Africa
    Deck you rule! Thanks for another informative post!
    2015 Sepang Blue S3 sedan / revo2 / Milltek / H&R / BBS CI-R / Forge Motorsport CF Intake system /
    2014 Monsoon Grey SQ5
    Active Member Two Rings Biggame's Avatar
    Jun 20 2014
    Sydney
    Items for Sale
    sorry to revive such an old thread, but my thermostat just died and I need to do this.
    The pic regards the diagonal tightening rules when tightening the supercharger bolts doesn't work. Can anyone repost the pic or explain how the supercharger should be bolted back.
    Senior Member Four Rings DGVR6's Avatar
    Aug 03 2014
    TV and a sofa
    Brooklyn
    Quote Originally Posted by Biggame View Post
    20 nm
    According to the picture start with the middle nut closer to the oil cap.. Opposite side after, 3rd would be nut on the opposite side (oil cap side) closest to the radiator, 4th would be opposite side closest to the throttle body, 5th is opposite (oil cap side), and 6th speaks for itself
    Last edited by DGVR6; 01-26-2015 at 05:01 AM. Reason: Hopefully I detailed it a bit more to your understanding
    C7.5 S6 P+ Mythos Black
    11.079@125.16 100oct Stage 2 100 File
    11.284@121.29 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 11.978@117.71 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Jan 14 2009
    2014 S4 2006 Passat Wagon 00 B5 S4 POS Honda
    pasadena md
    Items for Sale
    just start with the middle and work your way out then go back over and recheck the tq again. Simple and easy.
    Jun 20 2014
    Sydney
    Items for Sale
    Thanks DGVR6
    Quote Originally Posted by DGVR6 View Post
    20 nm
    Senior Member Three Rings Sukks2bu's Avatar
    Mar 12 2013
    Milton Ontario
    This is what audizine should be like all the time. great thread, thanks for the info.
    Subed
    2010 AUDI S4 DSG DRIVE SELECT UNITRONIC STAGE 2+
    Jan 29 2013
    2011 Q5 2.0, 124" HD Dyna Wide Glide
    Philadelphia, PA
    I'm curious how long this takes
    2010 Phantom Black S4 Prestige DSG, Silver Nappa, APR stage 1, Milltek Non-res, AG M510s, BC Racing BR series coilovers
    Veteran Member Three Rings Casius's Avatar
    Aug 14 2007
    Ottawa, ON, CA
    Takes the dealer two days to do this? Seems pretty straight forward.
    Love threads like these
    In terms of the CB issues, the RS4 is probably really bad because the motor is tuned to be run hard and not really to putt around town. I think there's something to the heat in the motor so in theory cars up north should have way higher incidences of CB than hot climates
    2010 VW GTI
    Previous cars:
    2003 A4 1.8T APR Stage 1+
    Quote Originally Posted by jayts View Post
    Charger can be pulled off in less than 30 minutes if you know what you are doing. I've had mine off 4 times now for various reasons. Getting at the front screws for the hardline for the thermostat is a pita.
    The charger is fairly heavy and if you have a helper it makes a huge difference.
    There are 10 kinds of people in this world, those who know binary and those who don't.
