Page 1 of 20 12311 ... LastLast
Results 1 to 40 of 774
    Veteran Member Four Rings AudiHere04's Avatar
    Nov 21 2005
    East Coast
    Precision 6262, 2.0 Build
    All fabrication done by Shawn @ Speed Freaks Fabrication and Arnold Lee @ Pag Parts
    So I've been on here forever. I have been putting this build together for a while now (2yrs ), but since the beginning I have consulted Shawn. I have also been following all BAT projects, learning and doing research. Thanks AZ.
    Specs of Car: 2004, B6 A4, FWD!!!!, 5spd manual...has 65k on clock.
    I got a donor head and block.
    Bottom End:
    Honed and Bored out to 2.0 (w/ torque plate THANKS SHAWN!!!)
    Decked, Hot Tanked, Balanced
    IE Rods
    JE Pistons 8.5:1 comp.
    2.0 FSI Crankshaft
    Billet Steel Main Caps
    ARP Main Bolts
    ARP Flywheel Bolt
    ARP Crankshaft Bolt
    Bearings, etc.
    Clutchmasters Twin Disk FX850 w/ flywheel (Thanks DTH/Vinny)
    Head:
    Assembled AEB CnC ported by Bob @ QED
    Ferrea titanium valves 1mm over (Intake and Exhaust)
    Ferrea Springs, Retainers
    CAT Cams 3658
    034 wrinkle coated valve cover
    ARP Head Bolts
    Forced Induction:
    Precision 6262 Turbo, .82 trim, billet comp wheel, ceramic ball bearing, v-band all around, anti-surge, polished comp housing.
    Precision 46mm Wastegate
    Precision 750HP Intercooler - For Sale
    Garret Core with custom endtanks
    Turbosmart 55mm BOV
    Snow Performance Stage 2, dual nozzle set-up
    Custom Tubular Manifold (Shawn @ 1552) - SOLD
    Hybird Log Cast V-Band Manifold by Pag Parts
    Custom Intake Manifold (Shawn @ 1552)
    R32 Throttle Body
    Custom IC piping (Shawn @ 1552) - For Sale
    Custom IC piping by Arnold Lee @ Pag Parts
    Custom Methanol Tank, trunk mounted (Arnold Lee @ Pag Parts)
    Fueling:
    Return System
    Custom Fuel Rail by Shawn @ 1552
    034 intank fuel pump AND Bosh 044 inline fuel pump
    Aeromotive FPR
    I'm tired of typing...more to come later
    Enjoy,
    Tony
    Buy My Parts!
    K03 w/ lines & OEM manifold - $300
    OEM FlyWheel - Best Offer
    Snow Performance Meth Kit - $400
    Saint Cloud, Fl
    Very nice, I was wondering when you were going to post these pics. I was chatting with Shawn the other day.
    Senior Member Four Rings HTA A4's Avatar
    Jul 11 2008
    2002 1.9L HTA3076R A4
    Illinois
    Yeesss!! I can't wait to see this thing run Tony! I've been talking to Shawn almost every day this week about your build. Sounds sick!
    Veteran Member Four Rings Dolphin18T's Avatar
    May 17 2007
    I assume the motor work is already done? What are the specs? You made a big leap if your sig was up to date before this!
    Looks beastly!
    -Ryan
    Maestro Tuned
    Now with slushbox-delete mod!
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    2003 2.0 PTE 5857 B6 A4 quattro 5spd, 05 E55 AMG
    Jacksonville, Florida
    Can't wait to see when this thing hits full boost. Journal or Ball bearing and .63 or .82 a/r? That thing is going to be sick that is for sure. What tuning, Maestro? Looks like you will even be able to fit a filter on that thing the way the turbo is placed which is awesome. I would love to have a filter on my 5857 instead of just a screen. One day I will lose this pos atp log manifold and actually get a better manifold.
    Better get yourself a good fuel pump (Bosch 044, aeromotive, or dual walbro 255) and some big injectors (1000cc)!
    ~David~
    I can help you with your 1.8t work (timing belts, etc)
    2.0 Billet PTE 5857 A4
    Those who say it can't be done should get out of the way of those who are doing it.
    119mph traps w/ 437whp/392wtq dyno jet power on 93 octane and washer fluid injection
    527whp/576wtq White Pano E55 AMG 11.69@120mph on street tires
    Saint Cloud, Fl
    Correct me if I'm wrong but isn't the 6262 slightly larger that the 35R with these new billet wheels ?
    Apr 24 2005
    Yes. It has 1mm larger inducer (62mm vs 61mm) on compressor wheel and same exducer (81.9mm vs 82mm) and the turbine wheel is bigger by 3mm (71mm vs 68 inducer) and pretty close to same exducer (61.9mm vs 61.6mm).
    ~David~
    Senior Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    02A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Quote Originally Posted by A4 TSCHUSS View Post
    Okay after I read all that my head and ears popped off...
    If I understand u correctly measurements are:
    hot-side inducer/wheel/exducer
    cold-side inducer/wheel/exducer
    MODS
    Do u have the Bentley or Dealership Manual & Tools it takes to work on YOUR car properly? Or...
    Are u just going to continue to wing it & keep expecting manna to fall from AZ?
    Apikol>Snub/Diff APR>ExhTIP-TB hoses,Stg3 AWE>DV
    JHM>ShortShift-the works
    Misc> 18x8x9 235/265;HSport S4 barsTT225;Bosch-F6DTC;CarbonioV2+V6Intake Inlet;HFC;Podi-P2;ATP mani;GPopK04;034mounts
    SPEC>Stg3+,LWFW
    STaSIS>328/305mm,40/60,SL
    Personal Motto>Walk Softly Carry a Big Stick
    Senior Member Four Rings JEENYUS's Avatar
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    "...definitely tits!!" - old guy
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    Fast Audi sedan, Slow Subie wagon
    SL,UT
    wow! no expense spared for this! can't wait to see it all completed. good luck!
    Senior Member Four Rings MMMB00ST_A4's Avatar
    Mar 31 2009
    BT B6 A4, 06 Suzuki Hayabusa
    Raleigh, North Carolina
    Sick!
    That is all...
    -Brandon-
    Mods: APR STG III+ / Labree Split DP / Full APR Exhaust w/ 4" tips / E.R. Comp FMIC / Authentic Oettinger F/R Bumpers / FK Badgeless grille / 19" iForged Daytonas / B6 S4 Calipers / KW-V2 Coilovers
    -12.9 @ 104mph-
    Dec 03 2005
    audi, chevy, jeep, lots and lots of bicycles
    connecticut
    Who assembled the head?
    EDIT: Nevermind. It says 'assembled'. I only read 'ported and polished'.
    -Doug
    2002 A4 2008cc GT-3076R turbocharged Avant
    397awhp/371awtq on straight 93oct and 96*F ambient
    Tuned by Autospeed Performance
    I am selling an Authentic B6 Sportec Front Bumper. PM me for info.
    Veteran Member Four Rings krew53's Avatar
    2003 1.8BT quattro
    L.A./Ventura
    Good god man!! That looks amazing!
    Stage 3 Forum Advertiser Four Rings Sales@RAI's Avatar
    Jun 22 2009
    Dundalk, MD
    lol.
    Tony, glad you finally posted this. Btw, I can get you some B5 passat/A4 trannys. Just saying... lol.
    Registered Member Four Rings A4ringedONE8T's Avatar
    Feb 17 2005
    Sarasota, FL
    That's sick, looks great!!! Wish I had a setup like that!!!
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Im thinking, as sweet as that build is, why waste it on FWD? Are you planning on doing a AWD conversion or just buying alot of front tires! Its gonna boil them at 15-18psi, if not less! And what about tuning?
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Apr 24 2005
    Quote Originally Posted by A4ringedONE8T View Post
    That's sick! Looks great! Wish I had a setup like!!!
    Hey numnuts, I called you twice today and left a message after getting your pm.
    Edit: I didn't even realize this car was FWD
    ~David~
    Jun 21 2005
    B6 Avant
    Milton, Ontario, Canada
    Quote Originally Posted by dirtybrd View Post
    Yeah, read this then looked up at the OP's first post and discovered that it was FWD....wow.
    Nov 21 2005
    East Coast
    Quote Originally Posted by 7speed View Post
    Thanks Sam, I've been busy with work...funding this thing is twice as hard.
    Quote Originally Posted by HTA A4 View Post
    Yea I bother him at least 3 times a day...lol. He's prob sick of me by now.
    Quote Originally Posted by Dolphin18T View Post
    Looks beastly!
    As the car sats before i pulled the engine, the sig is up-to-date. Right now my sig should say "engineless" but yea its been machined, etc.
    Ball bearing, .82 a/r. I am leaning towards Maestro for now, and thinking about 1000cc injectors (unless Shawn advises otherwise). We will run either a screen (which makes it looks sexy or a filter.
    For now it stays FWD...i told clint that it would be great to compare how FWD stacks up against AWD. Shawn had no prob putting the power to floor before, besides I get tires wholesale and ECS has $500 trannys.
    Yea i had Bob do it, CnC ported and polished head...
    Buy My Parts!
    Nov 21 2005
    East Coast
    Damn skip....YOU DID IT! lol
    Buy My Parts!
    Senior Member Four Rings BARRY's Avatar
    Nov 02 2007
    AE86 20v, UZZ30, 2002 A4 B6 1.8t
    Silicon Valley, Ca
    damn...i've read a lot of build threads on these forums, but your build puts a smile on my face.
    great build list!!!
    if you're not scared to do so please post cost sheet for how much you've spent. going to be planning my build within these next few months.
    Dec 12 2006
    Charlotte,NC
    a turbo that is capable of 500+ and your FWD is a waste. I had FWD and AWD on the same car and the difference is huge. Good thing making these car AWD is not bad at all probably cost you the same as that turbo you bought.
    MK4 GTi 1.8T converted to AWD
    New 1/8th mile 7.36@102mph-27psi 93 octane, no meth
    New build times 23psi pump 11.9@126mph-96mph in the 1/8th
    04' A4 1.8t frontrak converted to quattro, was RWD for a lil now its quattro finally
    2011 JSW Tdi 6speed manual
    Dec 03 2005
    connecticut
    Quote Originally Posted by AudiHere04 View Post
    Good luck.
    -Doug
    Mar 21 2006
    Lakeland, FL.
    I'm thinking of switching to Maestro also. But they only list the A4 as 03 and up, mine is 02. I email them but got no response.
    I'm back bitches!
    Mar 08 2010
    Sterling Heights MI
    Awesome build!
    Dec 03 2005
    connecticut
    Chris,
    I inquired into this about a month or two ago and the answer was that Maestro is not available for the 2002 ECu at this point in time. I forget who's thread I posted it in but I did post my email reply from Chris Tapp.
    -Doug
    Senior Member Four Rings Dan[FN]6262's Avatar
    Sep 12 2008
    02 A4, 94 GMC, 06 450R
    South Central Pa, Dundalk MD
    I can't wait to how this turns out.
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
    Sep 12 2008
    Chris,
    I was under the impression that you can get a beta version for the 02 ecu?
    my car is an 02, and I want Maestro
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
    Registered Member Three Rings BAB1990's Avatar
    Jun 26 2010
    My car is a 02 and running maestro?!
    I don't believe so.
    http://www.eurodyne.ca/supported_vehicles.php
    Sep 12 2008
    A4 1.8T 2001 - 2005
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
    Jun 26 2010
    I sent Chris the .mstro file read from ECU the other day and he sent me my tune this morning. I asked him if he had any issues with the 02 ECU and said he finalized some issues with it a while ago and was no problem.
    Dec 03 2005
    connecticut
    Quote Originally Posted by BAB1990 View Post
    So you were one of the 'testers' that he told me he had for the 2002 ECu. Cool beans!
    Again, about a month or two ago the answer was it was not available. Obviously progress is being made so I guess both Dan and Chris are in luck.
    -Doug
    Nov 21 2005
    East Coast
    Good luck.
    I've heard things as well, but i believe lady luck is on my side Doug.
    So whats up with the rear clip from Greg's car? think i can get it for a future AWD swap.
    Don't worry Shawn i'm just going to keep it im my garage to see how FWD holds up.
    BTW i have slicks for the front already.
    Buy My Parts!
    Sep 12 2008
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
    Dec 03 2005
    connecticut
    My experiences have not been too favorable. I truely do wish you the best and I hope your experiences are better than mine have been.
    You are one of the half a dozen people that wants the drivetrain for either a FWD to quattro swap or an automatic to manual swap. I still have a few more mods to sell (alcons, motorsports, mtm exhaust and RS4 wheels). Once those are sold then I can start thinking about OEM stuff like the quattro drivetrain. Send me an email and I'll think about it.
    -Doug
    Feb 17 2005
    Sarasota, FL
    The 3076 at 28psi with FWD and 235's on my HRE's hooked up better than my Roadster does now @ 515whp with 275's in the back. I'd gladly put this build on a FWD A4 if it we're me. AWD = break shit, especially tranny's which I think plenty have proven here. Stick with the FWD for a bit, see how it performs and how it holds up. If you can get some 245 or 255 DR's in the front and keep them on all the time you'll be alright IMO
    Feb 17 2005
    Sarasota, FL
    I can't tell you how long Tony and I talked about the building of his motor. Tony choose to do it local to him, I hope that everything motorwise works out as well! I offered to have it done local here by me, the same place that did Anthony's machine work and I would have personally assembled it all but he had trust in who he was working with. When the machine shop doing his block said a torque plate wasn't needed with his motor for machining I almost had a heartattack! I don't know how many times I told him "Tony, no, thats not acceptable!" the night I got that phonecall. haha I shipped my tq plate out right away to Tony so luckly we aborted that disaster!
    Nov 21 2005
    East Coast
    no worries shawn...i'll send the engine coming out the car to you and we will bore it out bigger!!!!!
    Buy My Parts!
    Dec 03 2005
    connecticut
    You know I am not questioning your work, Shawn. I am just giving Tony a forewarning. I am sure both you and he have done your homework but from what I have seen, work is hit or miss coming from BobQ. I've had a bad experience and a good experience. Friends of mine have had both bad and good experiences. It is the luck of the draw I presume.
    There is great promise in Tony's vehicle. I hope he has a relatively smooth road ahead and wish him the best.
    -Doug
