Did you get those pliers Charlie? They are called Nutbuster by Channel Lock. Things are amazing, I used them on broken studs, stripped bolts and all kinds of stuff. Used them a lot when I was working on outboard engines to swap out the studs in the bottom of the powerheads. We call them stud pliers.
~David~
I can help you with your 1.8t work (timing belts, etc)
2.0 Billet PTE 5857 A4
Those who say it can't be done should get out of the way of those who are doing it.
119mph traps w/ 437whp/392wtq dyno jet power on 93 octane and washer fluid injection
527whp/576wtq White Pano E55 AMG 11.69@120mph on street tires
dont you love it when you find surprises like that?
you would shit with the shit i found on this motor/car
believe it or not when I ripped the motor out, it looked like it was rebuit... there was a stripped rod bolt before I EVER even touched it.... then I pull the pistons out and i swear to god the rings were upside down... the part that said "top" on the rings were on the bottom.
now this stripped bolt which im grinding off cause im a straight thug.
Not sure I can work on the car right now.... still drunk as shit from last night.
BetaAlphaTau member #1.5
R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
B6 A4 Avant, 2.0 Liter, 3071, Maestro
finally go around to working on the car around 6 tonight. Tranny is out and yes the rear main seal was leaking.... seems like one part of the seal, the lip was facing the wrong way so it was slowly leaking. Thankfully there was no oil on the clutch.
Took the rear main seal out and going to put the new one on in the morning and button the shit back up. Also cleaned more of the engine bay up with this foam bright shit that worked pretty good.
I will take some pics and also do a little DIY for the rear main seal since there are some people that ask about it.
You just put that seal in a few days ago, who wants to follow your DIY? lmao
ahahahah true... i thought I was 100% positive the seal was facing the right way (lips facing in towards crank on seal).... i checked it a million times... maybe just backed out or some shit. oh well.
good call on using your chest to wiggle that shit out. was A LOT easier than using a lift to be honest.
this project turned into quite the long weekend haha.
Glad to hear it's finished, time to enjoy.
yea... the weekend I started I finished the engine build but then went out of town for almost three weeks... then found a million things that needed replacing and was waiting for parts A LOT. Then this rear main seal thing sucked but I knocked that out last night and this morning.
I spoke to soon though cause when I was driving just now the waste gate are popped loose again so I have no boost. that is an easy 30 minute fix though.
Oh I know how it goes with these cars, and parts are always 2+ days away from the distributor. I schedule major services around long vacations and availability of my brother to lend a hand (more like drink my beer). Shit just detailing my car is a multi-day adventure.
Jon
go > show
Ich liebe mein Audi!
2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
Yea its part of the game.... when you think you have everything ready to go there is always more shit to get.
Today I have to go get a circlip for the wastegate rod and then a clip for the rear coolant flange temp sensor.
Right now 22 and like 3-5 degrees of timing. When I put the new tbody on I disconnected the meth. Then I did a drive to cali and turned down all the settings pretty low to cruise. Havn't turned it back up yet. Still need to go over 10 degrees of timing to see what this thing has.
