Results 1 to 20 of 20
    Active Member One Ring VRockzNY's Avatar
    Feb 13 2010
    New York
    B8 A4 HID Fog and low beam trouble
    I bought a 6000k HID kit from HID Concepts since I saw them promoting on Audizine, but I noticed after 5 minutes the lens gets so hot that you can't even touch them, and also, inside the lens seems to be getting a little cloudy. I was thinking of just replacing them with Hoen bulbs. Plus I changed my low beams to 6000k with bulbs from HID Concepts and to me it seems like there's a haze. I'm not sure if it's cheap bulbs n i dont know what to do now! Does anyone have any similar experience? thx
    Veteran Member Three Rings ACowabunga's Avatar
    Feb 24 2010
    OC, CA
    I don't know. I replaced my bulbs with the 6000k from HID Concepts and I haven't had the issue to which you are referring. Have you ensured that you sealed the rear of the headlight assembly properly? I have heard of other members changing the bulbs and not sealing the cover snuggly. I did my homework on this issue and I can't say that there have been any issues of "cheap bulbs" because I did not want to end up replacing my ballasts if they did go bad because of the install. I hope this helps. Good luck.
    2010 Audi S5: Meteor Grey || Tuscan Brown
    Feb 13 2010
    New York
    Quote Originally Posted by ACowabunga View Post
    Thanks I'll take a look to see, but the major issue is that I have a kit from them in the fogs as well and the fog light lens seems to be clouding up. Even this morning I looked at the fogs and the lens seems slightly hazed. I'm not sure if the fogs were made to handle HIDs, but i see a lot of people here have them.
    Veteran Member Four Rings DavidB8's Avatar
    Nov 06 2009
    Oakville, ON, Canada
    did you get 35w or 55w?
    Reaching Me:Please don't ask me questions on the forum or send me private messages as it may be a while before I respond.
    If you need something email me directly at David@audienthusiasts.com I don't frequent this forum very often.
    www.audienthusiasts.com
    Feb 04 2010
    Ottawa, Canada
    Quote Originally Posted by DavidB8 View Post
    10$ Canadian tire money that its 55w :)
    2014 Ibis RS5 w/ Ti. Package AWE Track Edition, ECS 15/10, 034 Transmission Mount, 034 Solid Sway Bar, 034 End Links
    Nov 06 2009
    Well it could explain the heat and discolouration of the lens
    Stage 2 Banner Advertiser Four Rings
    Oct 27 2007
    NA
    Hey,
    This is Mike from HID Concept.
    sorry to hear that you are having some issues.
    This is actually the first time, hearing any issues related to our HID kits for such matters.
    Did you get Blesk HID kit for your fogs? Believe or not, we've been carrying Blesk kits for appx. 2 years and we have not had any defective issues as of yet.
    As far as the fog lamp getting cloudy, it sounds like something may be melting inside the fog lamp, which usually happens when either bulb is not mounted/placed properly or the bulb may have something on the glass part that is being melted on it.
    I suggest you to remove the fog lamp and check if the bulb was mounted incorrectly.
    BTW, does this cloudy problem happen on both sides of fog lamps?
    I also pmed you.
    Thank You
    HIDCONCEPT.COM - We Specialize in OEM/Aftermarket automotive lighting products.
    E-mail: info@hidconcept.com
    T: 1-888-579-5917
    F: 347-474-7348
    Sep 13 2009
    2010 A4 2.0T
    Mississauga, Ontario
    I bought some bulbs from eBay, the ******s sent me a wrongly-labeled 100W bulb so it melted my goddamn housings. not happy about it, but whatever.
    moral of the story: buy from HIDconcept, even with this isolated incident.
    Aug 20 2009
    Do any of you guys know what bulb would be the best replacement for my stock halogen bulbs? Not looking for a bulb to provide 'looks', I'm looking for the bulb that gives me the best vision and road illumination - the roads in SoCal are going to s**t and I need to see these damn potholes BEFORE I hit them.
    I've research Silverstars (osrams seem like they might be too bright), Phillips, etc - but can't find any concrete information on which one is best. Also, I don't want a bulb that's going to piss off all the other drivers and have them flashing me, or get the CHP pulling me over
    Any advice would be greatly appreciated.
    2013 Audi S4 | KW V2 | VMR 710 + 5mm | V1 Hardwire
    Veteran Member Four Rings NWS4Guy's Avatar
    Sep 29 2009
    2015 Range Rover Evoque 2010 Audi S4
    Quote Originally Posted by mattstorm View Post
    For fogs, I went with Hoen Endurance, which are the very yellow bulbs, they work great for what they are meant for - illumination of the road in fog and low light/hih dispersion scenarios.
    HID fogs are for looks not for results.
    Like a surgeon with a scalpel, my S4 is a precision instrument, with which I carve and dissect my way through traffic.
    2010 S4 Prem+, Quartz Gray, S-tronic, Sport Diff, B&O, Nav, Gray Birch
    StopTech ST-60 BBK - Stratmosphere intake - APR v2.2 Stage 2 w/pulley + exhaust, v2 Coolant System
    Alu-Kreuz, Apikol rear diff mount, 034 transmission mount
    Veteran Member Four Rings B_Boy's Avatar
    Nov 24 2008
    2014 Infiniti Q50S, 2016 Audi A3
    Items for Sale
    i can chime in here on this. i have a 35w kit 6000k on my fogs and they eventually fogged up and discolored a bit.
    well today i took the housings off to clean them (got so sick of the fogginess) with just water and guess what? the shinny stuff on the inside came off.....WTF?!
    conclusion....ANY HID aftermarket system just produces too much heat for the stock fog light housings.
    There is only 2 solutions (one of which only exists).....
    1. hoen xenonmatch bulbs.
    why? even though they are not HIDs, the colors matches and generates the same heat as the factory h11 halogen bulbs.
    2. someone needs to produce a replacement projector fog light housing that can handle the HID heat.
    SO no offence HID concept but its just not going to work.
    I jus ordered some new OEM housings and hoen bulbs. PROBLEM SOLVED.
    b_boy
    '15 Q5 3.0T P+ Tech, Sport, S-line, B-O, HGB
    LED Color Match Fog/Int/Ext Lights, VAG-COM, underseat storage bins, Blacked-OUT Valance & W/S Trim, SQ Black Grille
    Tint: 15% F/R, 50% Windshield, Alum Pedals/Shifters, Remote Close hatch, KW HAS, 22x10.5 ET VFS1
    Coming soon: GIAC/APR?
    Veteran Member Four Rings ThePiombino's Avatar
    Dec 01 2008
    North JerZ
    I've been using Luminics for 1 1/2 years+ now and no problems. So I wouldn't say HOEN is the ONLY solution...
    09 A4 2.0T Quattro - Tip - Black/Black /// MODS: APR Stage II+ | AWE CB Exhaust | 034 HFC l EC HFIC Pipe | Forge DV Spacer | 3M Di-NOC Carbon Fiber Interior Trim | 3M Chrome Grille Trim | SG Supreme 28 | Debadged | Fly Eyes Kit (f&r) | Needle Sweep | Window/Moonroof control w/Keyfob | Seat Belt Chime Disabled | "Wink" Disabled | Double Unlock "Beep"
    Oct 27 2009
    '15 MBZ E400 Cab/'13 Subaru Outback 3.6R
    Miami, FL | Boone, NC
    I think I am going to go with the Luminics JDM yellow...
    Oct 27 2007
    NA
    Quote Originally Posted by B_Boy View Post
    so, you bought a blesk kit from us as well and had the melting issue?
    T: 1-888-579-5917
    F: 347-474-7348
    Dec 01 2008
    North JerZ
    Let's get some pics once you get those installed. I have the Luminics Titanium whites with Lamin-x overlays and I'm starting to get sick of the look during the daytime.
    Oct 28 2009
    Chicago, IL
    I had the same issue with DDM tuning 35W HID kit on my car before and I changed it to hidconcept's blesk kit.
    No more issue with Blesk kit though. DDM kit is much cheaper but you do get what you pay for IMO.
    I doubt that you have Blesk.
    Anyways, I went through hoen before but halogen is halogen. it can never be even close to true HID light.
    what you need to do is, find a good quality kit instead of cheap made in China kits for $30-50.
    Dec 01 2008
    North JerZ
    Quote Originally Posted by mctuners View Post
    +1
    Nov 24 2008
    Items for Sale
    Quote Originally Posted by mike@hidconcept View Post
    no i tried a few different HID systems and they all produce too much heat. nothing melted but it would fog up the housing and discolor the inside.
    anyone know how to take apart the fog light housing?
    b_boy
    Feb 15 2011
    houston tx
    Can u guys post pics of your HID lights because i want to put them in my A4 B8 and i want to see how they look.
    Mar 26 2012
    Montreal
    Where you guys just putting an HID bulb inside the Fog housing? No Projector??
    How did that look? Did it blind people?
