Page 5 of 40 FirstFirst ... 3456715 ... LastLast
Results 161 to 200 of 1569
  1. #161
    Dec 03 2005
    audi, chevy, jeep, lots and lots of bicycles
    connecticut
    Intake looks good. How much flat do you have after the MAF before the bend going into the compressor housing? A minimum of around 4inches is ideal to allow for laminar MAF reading.
    If you need a PS pump I have a used one. In fact, I have a whole car I'm parting out. Just let me know.
    -Doug
    2002 A4 2008cc GT-3076R turbocharged Avant
    397awhp/371awtq on straight 93oct and 96*F ambient
    Tuned by Autospeed Performance
    I am selling an Authentic B6 Sportec Front Bumper. PM me for info.
  2. #162
    Jun 21 2005
    B6 Avant
    Milton, Ontario, Canada
    That intake looks awesome Chris.
  3. #163
    Veteran Member Four Rings MmmBoost's Avatar
    Nov 29 2005
    05 A4 USP Avant, 07 Suzuki GSX-R600, '69 VW Beetle w/ 1.9L aircooled turbo
    Edmonton, AB
    Quote Originally Posted by MikeWire View Post
    Wow very nice! Glad you gave that PS pump the business :)
    We'll see if it works. But yeah..... I gave it the biz. :) I don't like losing.
    I haven't measured how much there is, but I think it's around 5-6" ....but I plan on trimming about 1/2" off that so I can slide the filter back just a touch. I'll keep you posted on the P/S pump. I'm 90% that my "fix" is going to work just fine.
  4. #164
    Dec 03 2005
    connecticut
    Quote Originally Posted by MmmBoost View Post
    Before you go cutting anything leave it alone and check MAF readings at idle and part throttle. If they are jumping around then you are seeing effects from the bend and compressor inlet. I had those problems before I rebuilt my TIP. MAF sensors are sensitive.
    I have an entire B6 1.8T being sent to me this week so if you need anything email me and I'll take care of you.
    -Doug
  5. #165
    Nov 29 2005
    Edmonton, AB
    I'll wait until I have it running then. I'm sure I have at least 5" there. and the bend is nice and smooth. I believe the 90° is about a 5-6" CLR.
  6. #166
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    Orange County, CA
    coming together nicely!
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
  7. #167
    Nov 29 2005
    Edmonton, AB
    Day 15: Complete
    I can see light at the end of the tunnel!!!!
    Today I spent most of the night tidying up hoses/lines/wires and hooking up the rest of the wiring harness. I also cleaned up the intake pipe a bit to make sure there were no burrs or anything that could possibly come loose and go through the turbo. I picked up that last 2 fittings I needed to finish up the PCV system as well.
    I had to tighten up the coolant return line on the turbo.....which evidently is a complete bitch to get at. I ended up having to remove the compressor housing in order to tighten it. I would have had it in there and tight before, except I didn't know exactly where the turbo had to be clocked and if you turn the housing too much one way or another, it interferes with the coolant hose end.
    I installed my testpipe, but ran into a bit of a snag when I found out there wasn't enough clearance to get the bolt into the hole in the flange. I tried cutting some length off the treads but that didn't work. I tried grinding a little material off the diameter of the head.......that didn't work. Finally i got out a ball-peen hammer and have it a smack where the interference was. Problem solved! I am not much of a praying man.......but I'm praying that my downpipe fits onto the test pipe correctly.
    Tomorrow I should be able to have everything back together and running!!
  8. #168
    Senior Member Three Rings davkav's Avatar
    Dec 04 2008
    Dublin, Ireland
    You going to run a catch can chris? Lovely new turbo and your going to spit oil all over the inside of it
    You should try run the PCV line down under the passenger engine mount and up the TIP. Hide it away from view.
    -Dave
    B6 A4 USP Avant 1.8TQ 6M - 71r - 550s - Revo 550 File - Bosch 005 - ATP TIP - Custom Toyosport FMIC - Spec Stage 3+ - Apikol rear diff mount - 034 Street Trans Mount - APR Snub - RS4 Engine Mounts - ITG Panel Filter - VMR Boost Vent Gauge - THS Testpipe - Milltek CAT back
  9. #169
    Jun 21 2005
    B6 Avant
    Chris,...just noticed your braided coolant line is sitting right on top of your compressor housing. You should shield the braided line with heat proof cloth so the braided line doesn't eat through the compressor due to vibrations.
  10. #170
    Dec 03 2005
    connecticut
    probably need a stud on that part of the test pipe.
    -Doug
  11. #171
    Senior Member Four Rings Turbavanttro's Avatar
    Jan 24 2008
    Lift, tools, B6 Sportec Avant, Saab 900 Carlsson
    Pennsylvania
    you're killing me man, i love your build. your car is so clean, and this build is right up there among my favorites.
    its refreshing to see a build that isnt all about achieving the most horsepower, or being the fastest 1.8T, etc.
    i cant wait to see photos of the "finished" product....(do we ever actually finish...)
  12. #172
    Senior Member Four Rings boy412's Avatar
    Jul 15 2007
    2003 A4 Avant 1.8TQM Sport
    Mount Rainier, MD
    What are you up to NOW Doug?
    RAI | MTM Stage II | DSMIC | Fluidampr | FX400 | Vogtlant GT coilovers | B6 S4 brakes | ER TIP | Forge 007 | STaSIS | Stërn | Apikol | JHM trio | Podi | OEM+
    2.0L stroker build in progress...
  13. #173
    Nov 29 2005
    Edmonton, AB
    Quote Originally Posted by davkav View Post
    I'll be running a catch can very soon. I'm just sick of my wallet bleeding. Right now I just want to get my car up and running....because I have a wedding to shoot next weekend. I also haven't decided on which can to run yet.
    Quote Originally Posted by SleeperAvant View Post
    I have a silicone/fibreglass sleeve that I'm going to put on there, I just haven't got around to it yet. The way the fitting is oriented, the line doesn't touch the manifold or the housing.
    A hammer solved the problem :)
    Quote Originally Posted by Turbavanttro View Post
    Thank you! I'm glad someone is on the same page as me. I don't care about having 600hp. I just wanted a clean setup with a nice amount of extra power.
  14. #174
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    Aprilia SXV 550 supermoto, BMW F800GS, MB ML500, bikes and firewood
    On A Dirt Road, Vermont
    I don't understand the reason for this AN setup... to me it looks like a silicone T-hose on the back of the VC, then a complex AN fitting... that ends in a barb to go to a rubber line? Why not just a double ended barbed fitting?
    Glad to see it's all coming together!
    Jon
    go > show
    Ich liebe mein Audi!
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
  15. #175
    Nov 29 2005
    Edmonton, AB
    Quote Originally Posted by lookaught View Post
    It looks clean, it's easy to take a apart, and it's easy to change.
    I hate hose barbs, I know this is overkill......but it's only money right?
  16. #176
    Apr 20 2007
    lol yeah I guess so. Reminds me of this:
    http://www.youtube.com/watch?v=CZmHDEa0Y20
    lol. It does look nice! Black AN fittings are bling bling!
    Jon
    go > show
  17. #177
    Jan 24 2008
    Pennsylvania
    i went into this kind of detail with my saab 900 and it became an absolute obsession. i wanted to with my b6 build but remembering what all of the awesome plumbing set me back on the saab i decided to avoid that route. but thanks to you, i am completely second guessing my decision realizing that it is alot of fun to put something together that is completely unique and also built to last. All that plumbing is rock solid, and looks as stout as the rest of the turbo hardware does.
    Well done. Doesnt it feel great to avoid all of the blue and red anodized plumbing fittings? No offense to those who use them, I just really dont like how they look. I could use a familiar four letter word starting with an R to describe what they remind me of, but I won't.....
  18. #178
    Senior Member Three Rings Casius's Avatar
    Aug 14 2007
    Ottawa, ON, CA
    Time for some Rice
    How much power do you expect from this setup?
    Man who goes to bed with itchy bum wakes up with stinky finger
    2003 B6 A4 1.8TQM APR Stage 1+
  19. #179
    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    Nice TIP reminds me of my setup
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
  20. #180
    Senior Member Four Rings Bische's Avatar
    Jun 03 2009
    '02 1.8TQM Wagon, '96 Ford Mondeo 2.0RS
    Sweden, north
    Quote Originally Posted by HIERLEVELZ View Post
    How does your car run with that intake?
    Looks like a HAI to me :)
    -Bische
    2011: 16.16sec@88mph
    163whp/208wtq
    <Bische's Wagon - The thread>
  21. #181
    Nov 29 2005
    Edmonton, AB
    I'm a very detail-oriented person. One of the biggest things that gets me is when people spend a PILE of money on a manifold.....turbo....wastegate......etc, but then when it comes to the plumbing and the electrical, just throw it together in a hot mess. It's such a shame.
    I don't mind the red and blue AN fittings on race cars and muscle cars. But when it comes to a classy build that isn't 100% business, I love black....or stainless. Fuck I've spent a LOT on fittings for this build, but I don't regret it a bit.
    Quote Originally Posted by Casius View Post
    Time for some Rice
    I'm hoping for 300 at the wheels.
    Quote Originally Posted by Bische View Post
    Having a cone filter right next to the turbo/manifold is NOT a good plan. .....what do your IAT's look like?
  22. #182
    Nov 29 2005
    Edmonton, AB
    Day 16: Complete
    Today did NOT go as well as I had hoped. I thought I'd be out breaking in the engine by 9pm. Sadly not the case.
    I got hung up on the downpipe to testpipe bolts. I got hung up trying to get the fucking downpipe reinstalled back into the rest of the exhaust. The 034 street density trans mount caused me a LOT of greif. Getting the old mount out was a pain, getting the new mount in was a PAIN. especially after I found out the bolt they supplied me with to bolt the mount to the bracket on the trans was about 3/8" too long and was hitting the tranmission. I FINALLY realized this was the issue after messing around for about 30 mins. I am not impressed. AND the studs they supplied to bolt the mount to the trans crossmember are also far too long. They stick out about 1" below the tranmission crossmember. I'll have to get under the car again tomorrow and cut them off with a dremel.
    I managed to get nearly everything else finished though. Engine is full of oil. I re-routed the PCV.
    All that's left for tomorrow is to finished putting in the intercooler piping, connect the TB to the cold side of the IC piping, add P/S fluid, install the bumper, headlights, and rig up a connection for my brake booster to the intake manifold. Then I should be good to flash the new software, prime the engine, and roll it over!
  23. #183
    Dec 04 2008
    Dublin, Ireland
    That looks way better. I might even do that myself.
    -Dave
  24. #184
    Dec 03 2005
    connecticut
    Very common. Wish you knew about this sooner: http://www.audigeeks.com/forums/index.php?topic=2785.0
    Have you had much luck with that DV/Splitter? Closed systems with a MAF generally do not like dumping to atmosphere. Something like a Forge 007 DV is ideal.
    -Doug
  25. #185
    Nov 29 2005
    Edmonton, AB
    I had no idea. But that's complete bullshit. Oh well. I finally got it in but it was pain in the ass.
    I had a 007 and bought a splitter. I was only running it for 2 weeks before I pulled the car off the road, but I had no issues with it so far. It sounds great!
    ....louder than I expected.
  26. #186
    Apr 16 2007
    Queens
    2003 A4 1.8TQM
  27. #187
    Senior Member Four Rings EErie B6's Avatar
    May 30 2008
    2005 allroad & 2004 B6 A4
    PA, but my true love is Jersey
    speaking of FMICs... who makes the one on MmmBoost's Avant? did i miss it somewhere? it was not listed in the OP.
    BTW: OP, you are a wizzard with both a camera, and the wrenches... when i dig in, by the end of the day im too mad (usually) & tired to bother/care about taking pics. Thus far, you appear to have done a fantastic job of both. ... and your custom CAI came out beautiful.
    EDIT: found it in his profile... RaceTec
    -John
    "get the biggest of everything you can. always. that's a winning combination. everytime. just ask the military." -Dan[FN]WTF
  28. #188
    Jun 21 2005
    B6 Avant
    Looking forward to tonight's report.
  29. #189
    Nov 29 2005
    Edmonton, AB
    Day 17: Complete
    SHE'S ALIVE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    All that was left to do today was finish connecting the IC/DV, topping up the coolant, priming the power steering pump, install the bumper and headlights, and sort out the brake booster. I had things all wrapped up by about 8pm tonight. I managed to get the ECU flashed with the new software after a bit of messing around. The instructions aren't all that clear, but I got it sorted out. After the car was flashed, I cleaned myself up and took it out to break in the engine.
    The car was running EXTREMELY lean. It was bucking like crazy. So I ended up adding a lot of extra fuel in the "quick settings" and that seems to have smoothed things out. After reviewing my flash and logs, and having a chat with Chris (bananas) it seems my MAF was set for the stock AMB MAF. So that has now been changed and I'm ready to flash the ECU with a few new changes tomorrow and see how it feels.
    I got about 60kms on the engine tonight. 3000-5500rpms for about 45 mins to an hour. Other than the minor fueling thing, the car feels great. The wastegate is set a little low @ 12-13psi.....but even at that the car pulls nice and strong. I can't wait until 23! Tomorrow I'll be hooking up the N75 and starting to tune.
    The oil is draining right now and i'll put some fresh stuff in it tomorrow along with a new filter. I think I'll change oil again at about 1500kms. .....or should I do it sooner? thoughts?
    I would like to thank EVERYONE who has helped me out throughout this build. It's been a long time planning and an even longer 17 days of hard work, but after tonight's first drive, I know it was completely worth it and it's only going to get better.
    And that's why you chain your oil RIGHT after the initial break-in
  30. #190
    Mar 27 2005
    Ducati S2R & Land Rover Discovery 2
    Tampa Bay Area
    2 things.
    1. Nice job with everything. You did an amazing job with the built and your pictures provided us a ton of information.
    2. I am also wondering about the old change thing too. SO that crap in your pic is from the first 50km of driving? I am honestly surprised to see that much material. My motor is being built next week so would like info on what oil you used for break-in and what oil was suggested for break-in and how long between the first couple change intervals.
    2004 A4 1.8TQ6MT - Dolphin Grey
    -Maestro Stage III with a built block
    -STaSIS/Ohlin/Swift Suspension w/ H-Sport Sways
    -STaSIS/Alcon 355mm Mono4 BBK & 305mm Rear
    -STaSIS 4:1 Center Diff & STaSIS LSD Rear Diff
    -19" RS10 Forged wheels w/ Nitto NT-05
    -Laser Intercepter Dual + Bel STI Magnum
    301hp & 331 ft/lb uncorrected
    on 93 oct
  31. #191
    Veteran Member Four Rings mrbacardi35's Avatar
    Sep 18 2006
    2002 a4 1.8t quattro
    Los Angeles, CA
    Chris, for the tranny mount I would recommend just using a bolt(1") instead of the stud. Much easier to r/r the mount.
    **MIKE**
  32. #192
    Senior Member Three Rings truls000's Avatar
    Feb 08 2010
    Norway
    Congratiulations on the completion of the engine! Ive been folowing your build from the start.
    BTW: are you running stock DV? Isnt the spring to week for your tune?
  33. #193
    Senior Member Three Rings kwik_shift's Avatar
    Aug 28 2008
    04 A4 USP & Jeep
    En el cuarto de tu mama, IL
    If you look at the pic with his maf and filter, you can see the forge splitter to the right.
    Just a B6
  34. #194
    Feb 08 2010
    Norway
    Quote Originally Posted by kwik_shift View Post
    Oh, deam! My bad, I thougt the 'one way' PCV valve was the Bosh DV.
  35. #195
    Veteran Member Four Rings bananas's Avatar
    Jun 13 2005
    1999 A4 Avant 1.8TQM
    Minnesota
    Day 17: Complete
    !!! Anytime you need Maestro advice, just IM me!
    '03 A4 1.8TQM 337WHP/355WTQ (93+meth) | My car's Mods | Fancy Pants™ Turbo Club Member #001
  36. #196
    Jul 15 2007
    Mount Rainier, MD
    Do mine next!
    I can't even fathom what this kind of work would cost to have done at a shop (for those of us who's Kung Fu is weak). I'll echo what others have said...its SOOOOO nice to see a build that focuses on attention to detail and elegance rather then extreme HP. That's what I want to do with MY Avant.
  37. #197
    Active Member Two Rings mmccollum's Avatar
    Jan 07 2009
    White B8 A4 \\ Black B6 A4 \\ White 04 R1
    Edmonton,AB
    Hey Chris, fantastic job with the build, im glad everything came out nicely, i didn't have any doubts! Can i get a high-res of this picture? lol, what an awesome plate.
    Thanks
  38. #198
    Aug 14 2007
    Ottawa, ON, CA
    Those first few kms would shave a large amount of crud off the engine, I imagine the amount would trail off very quickly after the first few kms, things would probably smooth pretty quick. If it was me I'd probably change it after another 1000 and then do another one after another 2000 or something like that. Not that I've ever done it but that just seems to make sense to me.
    Beautiful beast this thing is, nice work
  39. #199
    Nov 29 2005
    Edmonton, AB
    Quote Originally Posted by boy412 View Post
    Do mine next!
    Sent it up to Canadia and I'll sort you out. haha.
    I'm glad you enjoyed my build and appreciate what my goal was. I am extremely happy with the results. I can't wait to get this setup dialed in! It already feels great at 15 PSI.
  40. #200
    Nov 29 2005
    Edmonton, AB
    Finally had a chance to get out tonight and do some logging after getting my MAF scaled a little better. I ended up scaling my tt225 MAF by 5% tonight to help even out the fuel delivery. It may have been a tad much. I think i'll try 4.5% and log it again.
    For those interested here is a log from tonight. It's a mixture of highway cruising and WOT
    https://spreadsheets.google.com/ccc?...Kb3o4LUE&hl=en
